Home » Modeling » M2T (model-to-text transformation) » [Acceleo] NullPointerException in org.eclipse.acceleo.ide.ui
[Acceleo] NullPointerException in org.eclipse.acceleo.ide.ui [message #1272295] Mon, 17 March 2014 15:14 Go to next message
Ralph Gerbig is currently offline Ralph GerbigFriend
each time acceleo wants to build a file (e.g. new acceleo project wizard, clean of workspace) I get the following exception:
	at org.eclipse.acceleo.common.utils.ModelUtils.load(ModelUtils.java:386)
	at org.eclipse.acceleo.internal.ide.ui.resource.AcceleoUIResourceSet.getResource(AcceleoUIResourceSet.java:76)
	at org.eclipse.acceleo.internal.ide.ui.generators.AcceleoUIGenerator.generate(AcceleoUIGenerator.java:459)
	at org.eclipse.acceleo.internal.ide.ui.generators.AcceleoUIGenerator.generateJavaClass(AcceleoUIGenerator.java:184)
	at org.eclipse.acceleo.internal.ide.ui.builders.runner.CreateRunnableAcceleoOperation.run(CreateRunnableAcceleoOperation.java:172)
	at org.eclipse.acceleo.internal.ide.ui.builders.AcceleoBuilder.build(AcceleoBuilder.java:226)
	at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:734)
	at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:206)
	at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:246)
	at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:299)
	at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:302)
	at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:358)
	at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:381)
	at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:143)
	at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:241)
	at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
What can I do to resolve this? My script builds perfectly with maven.
Ralph
Re: [Acceleo] NullPointerException in org.eclipse.acceleo.ide.ui [message #1272608 is a reply to message #1272295] Tue, 18 March 2014 10:22 Go to previous messageGo to next message
I get the same error at the of the new acceleo project in Luna M6. The workspace is empty and newly created. I attached some screenshots.
Ralph
index.php/fa/17764/0/
index.php/fa/17765/0/
  • Attachment: error.png
    (Size: 75.05KB, Downloaded 244 times)
  • Attachment: error2.png
    (Size: 107.15KB, Downloaded 238 times)
Re: [Acceleo] NullPointerException in org.eclipse.acceleo.ide.ui [message #1279115 is a reply to message #1272295] Fri, 28 March 2014 08:49 Go to previous messageGo to next message
Onder Gurcan is currently offline Onder GurcanFriend
I am having the same problem. I am using Eclipse Luna M6 and Acceleo 3.5 that comes with it. It is a very annoying problem.
Somebody please help,
Thanks in advance,
Onder.
Re: [Acceleo] NullPointerException in org.eclipse.acceleo.ide.ui [message #1280637 is a reply to message #1279115] Sun, 30 March 2014 17:46 Go to previous messageGo to next message
Ed Willink is currently offline Ed WillinkFriend
I've seen this too, but dismissed it as irritating but benign.
Uninstalling Acceleo of course solved the problem. I've re-installed
Acceleo and don't see the problem... yet. I'll keep my eye out.
You should find a stack trace in the error log, which should help the
developers to fix the problem.
Ed Willink
On 28/03/2014 12:22, Onder Gurcan wrote:
> Hello,
> Thanks in advance,
> Onder.
Re: [Acceleo] NullPointerException in org.eclipse.acceleo.ide.ui [message #1290633 is a reply to message #1280637] Thu, 10 April 2014 09:38 Go to previous messageGo to next message
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=431835.
Ed Willink
On 30/03/2014 18:46, Ed Willink wrote:
> Hi
> Regards
> Ed Willink
>> Hello,
>> Thanks in advance,
>> Onder.
Re: [Acceleo] NullPointerException in org.eclipse.acceleo.ide.ui [message #1291741 is a reply to message #1290633] Fri, 11 April 2014 07:15 Go to previous messageGo to next message
Hi Ed,
the link is broken.
Ralph
Re: [Acceleo] NullPointerException in org.eclipse.acceleo.ide.ui [message #1291777 is a reply to message #1291741] Fri, 11 April 2014 07:51 Go to previous message
HI
If you mean the
in my previous posting, it works for me. Refresh your browser/get a
better browser/network connection.
Ed Willink
On 11/04/2014 08:15, Ralph Gerbig wrote:
> Hi Ed,
> the link is broken.
> Ralph
Previous Topic:[Acceleo] How to get attributes from this meta-model
Next Topic:Acceleo how to change the value of a variable of type String
Current Time: Sat May 26 17:56:30 GMT 2018
Powered by FUDForum. Page generated in 0.01506 seconds
