Home » Eclipse Projects » BIRT » fonts in charts look very bad
fonts in charts look very bad [message #211296] Fri, 12 January 2007 19:27 Go to next message
Jan Schroeder is currently offline Jan SchroederFriend
any text in my charts is almost illegible due to very poor font rendering
quality.
Even when using report designs form the BIRT project example pages, charts
rendered on my machine look nowhere near as good as in the screen shots
that go with those designs.
I looked through FAQs, WIKIs and googled the problem, but I can not figure
out what is wrong with my installation.
The problem exists in the 2.1.1 standalone report designer _and_ in
eclipse 3.2.1 with BIRT plugins (before I broke it by updating using the
update manager). So I guess it is a problem with my Java + AWT???
WinXP
Sun JRE 1.5.0_06-b05
awt.toolkit=sun.awt.windows.WToolkit
Any help would be very much appreciated.
Config details of the stand alone designer:
*** Platform Details:
*** System properties:
RUN_UNDER_ECLIPSE=false
catalina.base=/C:/birt-rcp-report-designer-2_1_1/plugins/org .eclipse.tomcat_4.1.130.v20060601/
catalina.home=/C:/birt-rcp-report-designer-2_1_1/plugins/org .eclipse.tomcat_4.1.130.v20060601/
catalina.useNaming=true
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-launcher
C:\birt-rcp-report-designer-2_1_1\BIRT.exe
-name
BIRT
-showsplash
600
-exitdata
1570_80
-vm
C:\WINDOWS\system32\javaw.exe
eclipse.ee.install.verify=false
eclipse.product=org.eclipse.birt.report.designer.ui.rcp.BIRT
eclipse.startTime=1168626407259
eclipse.vm=C:\WINDOWS\system32\javaw.exe
eclipse.vmargs=-jar
C:\birt-rcp-report-designer-2_1_1\startup.jar
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.path=C:\birt-rcp-report-designer-2_1_1\startup.ja r
java.class.version=49.0
java.endorsed.dirs=C:\Program Files\Java\jre1.5.0_06\lib\endorsed
java.ext.dirs=C:\Program Files\Java\jre1.5.0_06\lib\ext
java.home=C:\Program Files\Java\jre1.5.0_06
java.io.tmpdir=C:\DOCUME~1\jan\LOCALS~1\Temp\
java.library.path=C:\WINDOWS\system32;.;C:\WINDOWS\system32; C:\WINDOWS;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System3 2\Wbem;C:\Program
Files\ATI Technologies\ATI Control Panel;C:\Program Files\Common
Files\Adaptec Shared\System;C:\oracle-instantclient_10_2;C:\Program
Files\QuickTime\QTSystem\
java.naming.factory.initial=org.apache.naming.java.javaURLCo ntextFactory
java.naming.factory.url.pkgs=org.apache.naming
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=1.5.0_06-b05
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.5
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.5.0_06
java.vm.info=mixed mode, sharing
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.5.0_06-b05
line.separator=
org.osgi.framework.bootdelegation=*
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSG i/Minimum-1.1,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5
org.osgi.framework.language=en
org.osgi.framework.os.name=WindowsXP
org.osgi.framework.os.version=5.1
org.osgi.framework.processor=x86
org.osgi.framework.system.packages=javax.accessibility,javax .activity,javax.crypto,javax.crypto.interfaces,javax.crypto. spec,javax.imageio,javax.imageio.event,javax.imageio.metadat a,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,javax .imageio.spi,javax.imageio.stream,javax.management,javax.man agement.loading,javax.management.modelmbean,javax.management .monitor,javax.management.openmbean,javax.management.relatio n,javax.management.remote,javax.management.remote.rmi,javax. management.timer,javax.naming,javax.naming.directory,javax.n aming.event,javax.naming.ldap,javax.naming.spi,javax.net,jav ax.net.ssl,javax.print,javax.print.attribute,javax.print.att ribute.standard,javax.print.event,javax.rmi,javax.rmi.CORBA, javax.rmi.ssl,javax.security.auth,javax.security.auth.callba ck,javax.security.auth.kerberos,javax.security.auth.login,ja vax.security.auth.spi,javax.security.auth.x500,javax.securit y.cert,javax.security.sasl,javax.sound.midi,javax.sound.midi .spi,javax.sound.sampled,javax.sound.sampled.spi,javax.sql,j avax.sql.rowset,javax.sql.rowset.serial,javax.sql.rowset.spi ,javax.swing,javax.swing.border,javax.swing.colorchooser,jav ax.swing.event,javax.swing.filechooser,javax.swing.plaf,java x.swing.plaf.basic,javax.swing.plaf.metal,javax.swing.plaf.m ulti,javax.swing.plaf.synth,javax.swing.table,javax.swing.te xt,javax.swing.text.html,javax.swing.text.html.parser,javax. swing.text.rtf,javax.swing.tree,javax.swing.undo,javax.trans action,javax.transaction.xa,javax.xml,javax.xml.datatype,jav ax.xml.namespace,javax.xml.parsers,javax.xml.transform,javax .xml.transform.dom,javax.xml.transform.sax,javax.xml.transfo rm.stream,javax.xml.validation,javax.xml.xpath,org.ietf.jgss ,org.omg.CORBA,org.omg.CORBA_2_3,org.omg.CORBA_2_3.portable, org.omg.CORBA.DynAnyPackage,org.omg.CORBA.ORBPackage,org.omg .CORBA.portable,org.omg.CORBA.TypeCodePackage,org.omg.CosNam ing,org.omg.CosNaming.NamingContextExtPackage,org.omg.CosNam ing.NamingContextPackage,org.omg.Dynamic,org.omg.DynamicAny, org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.DynamicAny.D ynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPackage,org .omg.IOP.CodecPackage,org.omg.Messaging,org.omg.PortableInte rceptor,org.omg.PortableInterceptor.ORBInitInfoPackage,org.o mg.PortableServer,org.omg.PortableServer.CurrentPackage,org. omg.PortableServer.POAManagerPackage,org.omg.PortableServer. POAPackage,org.omg.PortableServer.portable,org.omg.PortableS erver.ServantLocatorPackage,org.omg.SendingContext,org.omg.s tub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w3c.dom.e vents,org.w3c.dom.ls,org.xml.sax,org.xml.sax.ext,org.xml.sax .helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.3.0
org.osgi.supports.framework.extension=true
os.arch=x86
os.name=Windows XP
os.version=5.1
osgi.arch=x86
osgi.bundles=org.eclipse.equinox.common@2:start,org.eclipse.update.configurator@3:start,org.eclipse.core.runtime@start
osgi.bundles.defaultStartLevel=4
osgi.bundlestore=C:\birt-rcp-report-designer-2_1_1\configura tion\org.eclipse.osgi\bundles
osgi.configuration.area=file:/C:/birt-rcp-report-designer-2_ 1_1/configuration/
osgi.framework=file:/c:/birt-rcp-report-designer-2_1_1/plugi ns/org.eclipse.osgi_3.2.0.v20060601.jar
osgi.framework.beginningstartlevel=1
osgi.framework.shape=jar
osgi.framework.version=3.2.0.v20060601
osgi.install.area=file:/C:/birt-rcp-report-designer-2_1_1/
osgi.instance.area=file:/C:/birt-rcp-report-designer-2_1_1/w orkspace/
osgi.logfile=C:\birt-rcp-report-designer-2_1_1\workspace\.me tadata\.log
osgi.manifest.cache=C:\birt-rcp-report-designer-2_1_1\config uration\org.eclipse.osgi\manifests
osgi.nl=en_US
osgi.os=win32
osgi.splashPath=platform:/base/plugins/org.eclipse.birt.repo rt.designer.ui.rcp
osgi.syspath=c:\birt-rcp-report-designer-2_1_1\plugins
osgi.ws=win32
path.separator=;
sun.arch.data.model=32
sun.boot.class.path=C:\Program
Files\Java\jre1.5.0_06\lib\rt.jar;C:\Program
Files\Java\jre1.5.0_06\lib\i18n.jar;C:\Program
Files\Java\jre1.5.0_06\lib\sunrsasign.jar;C:\Program
Files\Java\jre1.5.0_06\lib\jsse.jar;C:\Program
Files\Java\jre1.5.0_06\lib\jce.jar;C:\Program
Files\Java\jre1.5.0_06\lib\charsets.jar;C:\Program
Files\Java\jre1.5.0_06\classes
sun.boot.library.path=C:\Program Files\Java\jre1.5.0_06\bin
sun.cpu.endian=little
sun.cpu.isalist=pentium_pro+mmx pentium_pro pentium+mmx pentium i486 i386
i86
sun.desktop=windows
sun.io.unicode.encoding=UnicodeLittle
sun.jnu.encoding=Cp1252
sun.management.compiler=HotSpot Client Compiler
sun.os.patch.level=Service Pack 2
user.country=US
user.dir=C:\birt-rcp-report-designer-2_1_1
user.home=C:\Documents and Settings\jan
user.language=en
user.name=jan
user.timezone=America/New_York
user.variant=
webapplication.projectclasspath=
workspace.projectclasspath=
*** Features:
com.lowagie.itext (1.3.0.v20060926-0959) "Lowagie Itext"
org.apache.batik (1.6.0.v20060926-0959) "Apache Batik"
org.apache.batik.pdf (1.6.0.v20060926-0959) "Apache Batik Pdf"
org.apache.commons.codec (1.3.0.v20060926-0959) "Apache Commons Codec"
org.apache.derby.core (10.1.2.1) "Apache Derby Core Plug-in for Eclipse"
org.eclipse.birt (2.1.1.v20060926-0959) "Business Intelligence and
Reporting Tools"
org.eclipse.birt.chart (2.1.1.v20060926-0959) "BIRT Chart Framework"
org.eclipse.birt.chart.cshelp (2.1.1.v20060926-0959) "BIRT Chart
Context-sensitive Help"
org.eclipse.birt.chart.doc.isv (2.1.1.v20060926-0959) "BIRT Chart ISV
Documentation"
org.eclipse.birt.chart.runtime (2.1.1.v20060926-0959) "BIRT Chart Runtime"
org.eclipse.birt.cshelp (2.1.1.v20060926-0959) "BIRT Context-sensitive
Help"
org.eclipse.birt.doc (2.1.1.v20060926-0959) "BIRT Documentation"
org.eclipse.birt.doc.isv (2.1.1.v20060926-0959) "BIRT ISV Documentation"
org.eclipse.birt.example (2.1.1.v20060926-0959) "BIRT Example"
org.eclipse.birt.report.designer (2.1.1.v20060926-0959) "BIRT Report
Designer"
org.eclipse.birt.report.runtime (2.1.1.v20060926-0959) "BIRT Report
Runtime"
org.mozilla.rhino (1.6.0.v20060926-0959) "Mozilla Rhino"
org.w3c.sac (1.3.0.v20060926-0959) "W3C Sac"
*** Plug-in Registry:
com.ibm.icu (3.4.4.1) "International Components for Unicode for Java
(ICU4J)" [Active]
com.lowagie.itext (1.3.0.v20060909-0630) "Lowagie Itext" [Resolved]
org.apache.ant (1.6.5) "Apache Ant" [Resolved]
org.apache.batik (1.6.0.v20060623-1511) "Apache Batik" [Active]
org.apache.batik.pdf (1.6.0.v20060623-1511) "Apache Batik Pdf" [Resolved]
org.apache.commons.codec (1.3.0.v20060629-0630) "Apache Commons Codec"
[Resolved]
[Resolved]
org.apache.lucene (1.4.103.v20060601) "Apache Lucene" [Resolved]
org.apache.xerces (2.8.0.v200606131651) "Xerces 2.8.0" [Resolved]
org.eclipse.ant.core (3.1.100.v20060531) "Ant Build Tool Core" [Resolved]
org.eclipse.ant.ui (3.2.0.v20060531) "Ant UI" [Resolved]
org.eclipse.birt (2.1.1.v20060921-1226) "Business Intelligence and
Reporting Tools" [Resolved]
org.eclipse.birt.chart (2.1.1.v20060921-1226) "BIRT Chart Framework"
[Resolved]
org.eclipse.birt.chart.cshelp (2.1.1.v20060925-0939) "BIRT Chart
Context-sensitive Help" [Resolved]
org.eclipse.birt.chart.device.extension (2.1.1.v20060921-1226) "BIRT Chart
Device Extension(s)" [Active]
org.eclipse.birt.chart.device.pdf (2.1.1.v20060921-1226) "BIRT Chart
Device PDF Extension" [Resolved]
org.eclipse.birt.chart.device.svg (2.1.1.v20060926-0959) "BIRT Chart
Device SVG Extension" [Resolved]
org.eclipse.birt.chart.device.swt (2.1.1.v20060921-1226) "BIRT Chart
Device SWT Extension" [Active]
org.eclipse.birt.chart.doc.isv (2.1.1.v20060921-1226) "BIRT Chart ISV
Documentation" [Resolved]
org.eclipse.birt.chart.engine (2.1.1.v20060922-1058) "BIRT Chart Engine"
[Active]
org.eclipse.birt.chart.engine.extension (2.1.1.v20060926-0959) "BIRT Chart
Engine Extension" [Active]
org.eclipse.birt.chart.examples (2.1.1.v20060926-0959) "BIRT Chart
Examples Plug-in" [Resolved]
org.eclipse.birt.chart.reportitem (2.1.1.v20060921-1226) "BIRT
Chart-Report Integration" [Active]
org.eclipse.birt.chart.reportitem.ui (2.1.1.v20060921-1226) "BIRT
Chart-Report UI Integration Plug-in" [Active]
org.eclipse.birt.chart.runtime (2.1.1.v20060921-1226) "BIRT Chart Runtime"
[Resolved]
org.eclipse.birt.chart.ui (2.1.1.v20060926-0959) "BIRT Chart Library UI
Plug-in" [Active]
org.eclipse.birt.chart.ui.extension (2.1.1.v20060926-0959) "BIRT Chart UI
Extension" [Active]
org.eclipse.birt.core (2.1.1.v20060926-0959) "BIRT Core Package" [Active]
org.eclipse.birt.core.ui (2.1.1.v20060831-1059) "BIRT Core UI" [Active]
org.eclipse.birt.cshelp (2.1.1.v20060921-1226) "BIRT Context-sensitive
Help" [Resolved]
org.eclipse.birt.data (2.1.1.v20060922-1058) "BIRT Data Engine" [Active]
org.eclipse.birt.data.oda (2.1.1.v20060922-1058) "BIRT Open Data Access"
[Active]
org.eclipse.birt.data.oda.adapter.dtp (2.1.1.v20060922-1058) "BIRT-DTP ODA
Adapter Plug-in" [Resolved]
org.eclipse.birt.doc (2.1.1.v20060921-1226) "BIRT Documentation" [Resolved]
org.eclipse.birt.doc.isv (2.1.1.v20060921-1226) "BIRT ISV Documentation"
[Resolved]
org.eclipse.birt.example (2.1.1.v20060921-1226) "BIRT Example" [Resolved]
org.eclipse.birt.report.data.adapter (2.1.1.v20060922-1058) "BIRT Data
Adapter" [Active]
org.eclipse.birt.report.data.oda.jdbc (2.1.1.v20060922-1058) "BIRT
ODA-JDBC Bridge Driver" [Active]
org.eclipse.birt.report.data.oda.jdbc.ui (2.1.1.v20060922-1058) "BIRT JDBC
UI Plug-in" [Resolved]
org.eclipse.birt.report.data.oda.sampledb (2.1.1.v20060922-1058) "BIRT
Sample Database" [Active]
org.eclipse.birt.report.data.oda.sampledb.ui (2.1.1.v20060922-1058) "BIRT
Sample Database UI Plug-in" [Resolved]
org.eclipse.birt.report.data.oda.xml (2.1.1.v20060926-0959) "BIRT ODA-XML
Driver" [Resolved]
org.eclipse.birt.report.data.oda.xml.ui (2.1.1.v20060922-1058) "BIRT XML
org.eclipse.birt.report.designer (2.1.1.v20060921-1226) "BIRT Report
Designer" [Resolved]
org.eclipse.birt.report.designer.core (2.1.1.v20060922-1058) "BIRT
Designer Core" [Active]
org.eclipse.birt.report.designer.example.samplereport
(2.1.1.v20060925-0939) "BIRT Samplereport Plug-in" [Resolved]
org.eclipse.birt.report.designer.ui (2.1.1.v20060922-1058) "BIRT Designer
UI" [Active]
org.eclipse.birt.report.designer.ui.editors (2.1.1.v20060922-1058) "Rdt
Plug-in" [Active]
org.eclipse.birt.report.designer.ui.editors.schematic
(2.1.1.v20060925-0939) "BIRT Editors Plug-in" [Active]
org.eclipse.birt.report.designer.ui.lib (2.1.1.v20060926-0959) "BIRT
Designer UI for Library" [Active]
org.eclipse.birt.report.designer.ui.lib.explorer (2.1.1.v20060925-0939)
"BIRT Library Explorer Plug-in" [Active]
org.eclipse.birt.report.designer.ui.preview (2.1.1.v20060926-0959) "BIRT
Preview Plug-in" [Active]
org.eclipse.birt.report.designer.ui.rcp (2.1.1.v20060925-0939) "BIRT RCP
Designer" [Active]
org.eclipse.birt.report.engine (2.1.1.v20060926-0959) "BIRT Engine"
[Active]
org.eclipse.birt.report.engine.emitter.html (2.1.1.v20060926-0959) "BIRT
HTML Emitter" [Active]
org.eclipse.birt.report.engine.emitter.pdf (2.1.1.v20060926-0959) "BIRT
PDF emitter" [Resolved]
org.eclipse.birt.report.engine.fonts (2.1.1.v20060926-0959) "BIRT Engine
fonts" [Resolved]
org.eclipse.birt.report.model (2.1.1.v20060926-0959) "BIRT Model" [Active]
org.eclipse.birt.report.model.adapter.oda (2.1.1.v20060922-1058) "BIRT
Model ODA Adapter" [Resolved]
org.eclipse.birt.report.runtime (2.1.1.v20060921-1226) "BIRT Report
Runtime" [Resolved]
org.eclipse.birt.report.viewer (2.1.1.v20060926-0959) "BIRT Web Viewer"
[Active]
org.eclipse.birt.resources (2.1.1.v20060825-0630) "BIRT Resources Plug-in"
[Resolved]
org.eclipse.compare (3.2.0.v20060525) "Compare Support" [Resolved]
org.eclipse.core.commands (3.2.0.I20060511-0800a) "Commands" [Resolved]
org.eclipse.core.contenttype (3.2.0.v20060601a) "Eclipse Content
Mechanism" [Active]
org.eclipse.core.expressions (3.2.0.v20060602-0010) "Expression Language"
[Active]
org.eclipse.core.filebuffers (3.2.0.v20060602-0010) "File Buffers" [Active]
org.eclipse.core.filesystem (1.0.0.v20060601a) "Core File Systems"
[Resolved]
org.eclipse.core.filesystem.win32.x86 (1.0.0.v20060601a) "Core File System
for Windows" [Resolved]
org.eclipse.core.jobs (3.2.0.v20060601a) "Eclipse Jobs Mechanism" [Active]
org.eclipse.core.resources (3.2.0.v20060601a) "Core Resource Management"
[Active]
org.eclipse.core.resources.compatibility (3.2.0.v20060601a) "Core Resource
Management Compatibility Fragment" [Resolved]
org.eclipse.core.resources.win32 (3.2.0.v20060601a) "Core Resource
Management Win32 Fragment" [Resolved]
org.eclipse.core.runtime (3.2.0.v20060601b) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.1.100.v20060601a) "Core Runtime
Plug-in Compatibility" [Active]
org.eclipse.core.runtime.compatibility.auth (3.2.0.v20060601)
"Authorization Compatibility Plug-in" [Active]
org.eclipse.core.runtime.compatibility.registry (3.2.0.v20060602) "Eclipse
Registry Compatibility Fragment" [Resolved]
org.eclipse.core.variables (3.1.100.v20060517) "Core Variables" [Resolved]
org.eclipse.datatools.connectivity (0.9.1.20060831) "Data Tools Platform
Connectivity Plug-in" [Resolved]
org.eclipse.datatools.connectivity.oda (3.0.2.200608301) "DTP Open Data
Access" [Active]
org.eclipse.datatools.connectivity.oda.consumer (3.0.2.200608301) "DTP ODA
Consumer Helper Component Plug-in" [Active]
org.eclipse.datatools.connectivity.oda.design (3.0.2.200608301) "DTP ODA
Design Session Model" [Resolved]
org.eclipse.datatools.connectivity.oda.design.ui (3.0.2.200609201) "DTP
ODA Designer UI Framework Plug-in" [Resolved]
org.eclipse.datatools.connectivity.oda.designer.finfo (0.9.1.200609191)
"Eclipse Data Tools Platform Connectivity Open Data Access (ODA) Designer"
[Resolved]
org.eclipse.datatools.connectivity.oda.finfo (0.9.1.200609191) "Eclipse
Data Tools Platform Connectivity Open Data Access (ODA)" [Resolved]
org.eclipse.datatools.connectivity.oda.flatfile (3.0.2.200608311) "DTP ODA
Flat File Run-time Driver" [Resolved]
org.eclipse.datatools.connectivity.oda.flatfile.ui (3.0.2.200608301) "DTP
ODA Flat File Designer" [Resolved]
org.eclipse.datatools.connectivity.oda.profile (3.0.2.200608301) "DTP ODA
Connection Profile Framework Plug-in" [Resolved]
org.eclipse.datatools.connectivity.ui (0.9.1.200608251) "Data Tools
Platform Connectivity UI Plug-in" [Resolved]
org.eclipse.datatools.connectivity.ui.dse (0.9.1.200608251) "Eclipse Data
Tools Platform Data Source Explorer Plug-in" [Resolved]
org.eclipse.debug.core (3.2.0.v20060601) "Debug Core" [Active]
org.eclipse.debug.ui (3.2.0.v20060601) "Debug UI" [Active]
org.eclipse.draw2d (3.2.0.v20060616) "Draw2d" [Active]
org.eclipse.emf.common (2.2.0.v200606221156) "EMF Common" [Active]
org.eclipse.emf.ecore (2.2.0.v200606221156) "EMF Ecore" [Active]
org.eclipse.emf.ecore.xmi (2.2.0.v200606221156) "EMF XMI" [Active]
org.eclipse.equinox.common (3.2.0.v20060601a) "Common Eclipse Runtime"
[Active]
org.eclipse.equinox.preferences (3.2.0.v20060601) "Eclipse Preferences
Mechanism" [Active]
org.eclipse.equinox.registry (3.2.0.v20060601) "Extension Registry
Support" [Active]
org.eclipse.gef (3.2.0.v20060616) "Graphical Editing Framework" [Active]
org.eclipse.help (3.2.0.v20060518) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.100.v20060510b) "Help Application Server"
[Active]
org.eclipse.help.base (3.2.0.v20060601) "Help System Base" [Active]
org.eclipse.help.ui (3.2.0.v20060510b) "Help System UI" [Resolved]
org.eclipse.help.webapp (3.2.0.v20060510b) "Help System Webapp" [Resolved]
org.eclipse.jdt.core (3.2.0.v_670) "Java Development Tools Core" [Resolved]
org.eclipse.jdt.core.manipulation (1.0.0.v20060602-0010) "Java Code
Manipulation Functionality" [Resolved]
org.eclipse.jdt.debug (3.2.0.v20060601) "JDI Debug Model" [Resolved]
org.eclipse.jdt.debug.ui (3.2.0.v20060517) "JDI Debug UI" [Resolved]
org.eclipse.jdt.junit (3.2.0.v20060602-0010) "Java Development Tools JUnit
support" [Resolved]
org.eclipse.jdt.junit.runtime (3.2.0.v20060602-0010) "Java Development
Tools JUnit runtime support" [Resolved]
org.eclipse.jdt.launching (3.2.0.v20060525) "Java Development Tools
Launching Support" [Resolved]
org.eclipse.jdt.ui (3.2.0.v20060602-0010) "Java Development Tools UI"
[Resolved]
org.eclipse.jface (3.2.0.I20060602-0010) "JFace" [Resolved]
org.eclipse.jface.text (3.2.0.v20060602-0010) "JFace Text" [Resolved]
org.eclipse.ltk.core.refactoring (3.2.0.v20060602-0010) "Refactoring Core"
[Resolved]
org.eclipse.ltk.ui.refactoring (3.2.0.v20060602-0010) "Refactoring UI"
[Resolved]
org.eclipse.pde (3.2.0.v20060511-1200) "Eclipse Plug-in Development
Environment" [Resolved]
org.eclipse.pde.build (3.2.0.v20060601) "Plug-in Development Environment
Build Support" [Resolved]
org.eclipse.pde.core (3.2.0.v20060601b) "Plug-in Development Core"
[Resolved]
org.eclipse.pde.runtime (3.2.0.v20060511-0800) "Plug-in Development
Environment Runtime" [Resolved]
org.eclipse.pde.ui (3.2.0.v20060526-0010) "Plug-in Development UI"
[Resolved]
org.eclipse.search (3.2.0.v20060602-0010) "Search Support" [Resolved]
org.eclipse.swt (3.2.0.v3232l) "Standard Widget Toolkit" [Resolved]
org.eclipse.swt.win32.win32.x86 (3.2.0.v3232l) "Standard Widget Toolkit
org.eclipse.team.core (3.2.0.I200605181830) "Team Support Core" [Active]
org.eclipse.team.ui (3.2.0.I200606011710) "Team Support UI" [Resolved]
org.eclipse.text (3.2.0.v20060602-0010) "Text" [Resolved]
org.eclipse.tomcat (4.1.130.v20060601) "Tomcat Wrapper" [Active]
org.eclipse.ui (3.2.0.I20060602-0010) "Eclipse UI" [Active]
org.eclipse.ui.cheatsheets (3.2.0.v20060516) "Cheat Sheets" [Active]
org.eclipse.ui.console (3.1.100.v20060518) "Console" [Resolved]
org.eclipse.ui.editors (3.2.0.v20060602-0010) "Default Text Editor"
[Active]
org.eclipse.ui.externaltools (3.1.100.v20060511) "External Tools" [Active]
org.eclipse.ui.forms (3.2.0.v20060530) "Eclipse Forms" [Active]
org.eclipse.ui.ide (3.2.0.I20060602-0010) "Eclipse IDE UI" [Resolved]
org.eclipse.ui.intro (3.2.0.v20060601) "Welcome Framework" [Resolved]
org.eclipse.ui.navigator (3.2.0.I20060526-0010) "Common Navigator View"
[Resolved]
org.eclipse.ui.navigator.resources (3.2.0.I20060511-2000) "Navigator
Workbench Components" [Resolved]
org.eclipse.ui.views (3.2.0.I20060511-2000) "Views" [Active]
org.eclipse.ui.views.properties.tabbed (3.2.0.I20060511-0800a) "Tabbed
Properties View" [Resolved]
org.eclipse.ui.win32 (3.2.0.I20060511-2000) "Eclipse UI Win32
Enhancements" [Resolved]
org.eclipse.ui.workbench (3.2.0.I20060602-0010) "Workbench" [Active]
org.eclipse.ui.workbench.texteditor (3.2.0.v20060602-0010) "Text Editor
Framework" [Active]
org.eclipse.update.configurator (3.2.0.v20060511) "Install/Update
Configurator" [Active]
org.eclipse.update.core (3.2.0.v20060602) "Install/Update Core" [Resolved]
org.eclipse.update.core.win32 (3.2.0.v20060511) "Install/Update Core for
Windows" [Resolved]
org.eclipse.update.ui (3.2.0.v20060601) "Install/Update UI" [Resolved]
org.junit (3.8.1) "JUnit Testing Framework" [Resolved]
org.mozilla.rhino (1.6.0.v20060629-0630) "Mozilla Rhino" [Resolved]
org.w3c.sac (1.3.0.v20060629-0630) "W3C Sac" [Resolved]
system.bundle (3.2.0.v20060601) "OSGi System Bundle" [Active]
*** User Preferences:
#Fri Jan 12 14:21:03 EST 2007
/instance/org.eclipse.jdt.ui/tabWidthPropagated=true
/instance/org.eclipse.help.ui/browser.maximized=false
/instance/org.eclipse.birt.report.designer.ui/designer.previ ew.preference.elementname.description.preferencestore=;;Inse rt
flexible-format presentation of Data Set rows in Header/Detail/Footer
bands;Insert a row/column layout to visually arrange other items.;Insert
column presentation of Data Set rows in Header/Detail/Footer bands;Insert
a text block (plain text/HTML) with optional in-line expression(s).;Insert
a piece of static text.;;;Insert a Data Set column or expression
result.;;Insert an image from a file or URL.;;;;
/instance/org.eclipse.birt.report.viewer/browser.maximized=f alse
/instance/org.eclipse.jdt.ui/useQuickDiffPrefPage=true
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.editor.tab.w idth=
/instance/org.eclipse.birt.chart.reportitem.ui/enable_live=t rue
/instance/org.eclipse.birt.chart.reportitem.ui/max_row=6
@org.eclipse.help.ui=3.2.0.v20060510b
file_export_version=3.0
/instance/org.eclipse.birt.report.designer.ui/org.eclipse.bi rt.report.designer.ui.preferences.resourcestore=C\:\\Documen ts
and Settings\\jan\\Desktop\\workspace\\Second
Story\\webapp\\WEB-INF\\birt-reports\\resources
/instance/org.eclipse.birt.report.viewer/browser.y=210
/instance/org.eclipse.birt.report.viewer/browser.x=162
/instance/org.eclipse.birt.report.viewer/browser.w=1024
/instance/org.eclipse.update.ui/ConfigurationView.showUnconf =true
@org.eclipse.pde.core=3.2.0.v20060601b
@org.eclipse.jdt.ui=3.2.0.v20060602-0010
/instance/org.eclipse.core.resources/version=1
/instance/org.eclipse.pde.core/platform_path=C\:\\birt-rcp-r eport-designer-2_1_1
/instance/org.eclipse.birt.report.viewer/svg_flag=true
@org.eclipse.birt.report.data.oda.xml.ui=2.1.1.v20060922-105 8
/instance/org.eclipse.birt.report.designer.ui/Palette\ Size=125
/instance/org.eclipse.birt.report.viewer/browser.h=768
@org.eclipse.jdt.launching=3.2.0.v20060525
@org.eclipse.birt.report.data.oda.jdbc.ui=2.1.1.v20060922-10 58
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .source=1.5
@org.eclipse.birt.report.designer.ui=2.1.1.v20060922-1058
/instance/org.eclipse.ant.ui/useQuickDiffPrefPage=true
/instance/org.eclipse.ui.workbench/overridepresentation=true
/instance/org.eclipse.ui.editors/overviewRuler_migration=mig rated_3.1
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .compliance=1.5
/instance/org.eclipse.birt.report.data.oda.jdbc.ui/Deleted\ Jar\
List=rO0ABXNyABFqYXZhLnV0aWwuSGFzaE1hcAUH2sHDFmDRAwACRgAKbG9 hZEZhY3RvckkACXRocmVzaG9sZHhwP0AAAAAAAAx3CAAAABAAAAAAeA\=\=
/instance/org.eclipse.birt.report.designer.ui/user_maxrow=50 0
@org.eclipse.jdt.core=3.2.0.v_670
/instance/org.eclipse.birt.report.data.oda.jdbc.ui/user_max_ num_of_schema=20
@org.eclipse.birt.report.viewer=2.1.1.v20060926-0959
/instance/org.eclipse.help.ui/browser.y=143
/instance/org.eclipse.help.ui/browser.x=238
/instance/org.eclipse.help.ui/browser.w=1024
/instance/org.eclipse.jdt.ui/proposalOrderMigrated=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .problem.assertIdentifier=error
@org.eclipse.birt.chart.reportitem.ui=2.1.1.v20060921-1226
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.builder. resourceCopyExclusionFilter=*.launch
/instance/org.eclipse.jdt.ui/fontPropagated=true
@org.eclipse.core.resources=3.2.0.v20060601a
/instance/org.eclipse.birt.report.data.oda.jdbc.ui/JDBC\ Jar\
List=rO0ABXNyABFqYXZhLnV0aWwuSGFzaE1hcAUH2sHDFmDRAwACRgAKbG9 hZEZhY3RvckkACXRocmVzaG9sZHhwP0AAAAAAAAx3CAAAABAAAAABdAAacG9 zdGdyZXMtamRiYzItNy40LjIxNC5qYXJzcgA1b3JnLmVjbGlwc2UuYmlydC5 yZXBvcnQuZGF0YS5vZGEuamRiYy51aS51dGlsLkphckZpbGX1YJoUc1N5HAI AAkwACGZpbGVOYW1ldAASTGphdmEvbGFuZy9TdHJpbmc7TAAIZmlsZVBhdGh xAH4ABHhwcQB+AAJ0AHJDOlxEb2N1bWVudHMgYW5kIFNldHRpbmdzXGphblx EZXNrdG9wXHdvcmtzcGFjZVxTZWNvbmQgU3RvcnlcdGhpcmRQYXJ0eUxpYnN camRiY0RyaXZlcnNccG9zdGdyZXMtamRiYzItNy40LjIxNC5qYXJ4
/instance/org.eclipse.birt.report.data.oda.jdbc.ui/user_max_ num_of_table_each_schema=100
/instance/org.eclipse.jdt.launching/org.eclipse.jdt.launchin g.PREF_VM_XML= <?xml
version\="1.0" encoding\="UTF-8"?>\r\n<vmSettings
defaultVM\=" 57,org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType 13,1168035698194 ">\r\n<vmType
id\="org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType ">\r\n<vm
id\="1168035698194"
javadocURL\="http\://java.sun.com/j2se/1.5.0/docs/api/"
name\="jre1.5.0_06" path\="C\:\\Program
Files\\Java\\jre1.5.0_06"/>\r\n</vmType>\r\n</vmSettings >\r\n
/instance/org.eclipse.birt.report.viewer/user_locale=English (United
States)
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .problem.enumIdentifier=error
@org.eclipse.update.ui=3.2.0.v20060601
@org.eclipse.ui.workbench=3.2.0.I20060602-0010
/instance/org.eclipse.help.ui/browser.h=768
/instance/org.eclipse.birt.report.data.oda.jdbc.ui/JDBC\ Driver\
Map=rO0ABXNyABFqYXZhLnV0aWwuSGFzaE1hcAUH2sHDFmDRAwACRgAKbG9h ZEZhY3RvckkACXRocmVzaG9sZHhwP0AAAAAAAAx3CAAAABAAAAACdAAwb3Jn LmVjbGlwc2UuYmlydC5yZXBvcnQuZGF0YS5vZGEuc2FtcGxlZGIuRHJpdmVy c3IAOG9yZy5lY2xpcHNlLmJpcnQucmVwb3J0LmRhdGEub2RhLmpkYmMudWku dXRpbC5Ecml2ZXJJbmZvpAGLHD+7w98CAANMAAtkaXNwbGF5TmFtZXQAEkxq YXZhL2xhbmcvU3RyaW5nO0wACmRyaXZlck5hbWVxAH4ABEwAC3VybFRlbXBs YXRlcQB+AAR4cHQAI0NsYXNzaWMgTW9kZWxzIEluYy4gU2FtcGxlREIgRHJp dmVydAAwb3JnLmVjbGlwc2UuYmlydC5yZXBvcnQuZGF0YS5vZGEuc2FtcGxl ZGIuRHJpdmVydAAbamRiYzpjbGFzc2ljbW9kZWxzOnNhbXBsZWRidAAkb3Jn LmFwYWNoZS5kZXJieS5qZGJjLkVtYmVkZGVkRHJpdmVyc3EAfgADdAAcQXBh Y2hlIERlcmJ5IEVtYmVkZGVkIERyaXZlcnQAJG9yZy5hcGFjaGUuZGVyYnku amRiYy5FbWJlZGRlZERyaXZlcnQAN2pkYmM6ZGVyYnk6W3N1YnN1YnByb3Rv Y29sOl1EQVRBQkFTRVs7QVRUUklCVVRFPVZBTFVFXSp4
@org.eclipse.ui.editors=3.2.0.v20060602-0010
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.javadoclocat ions.migrated=true
/instance/org.eclipse.birt.report.viewer/default_browser=org .eclipse.birt.report.viewer.systembrowser
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.formatterpro files.version=10
/instance/org.eclipse.birt.report.viewer/always_external_bro wser=true
/instance/org.eclipse.birt.report.data.oda.xml.ui/user_max_n um_of_element_passed=100000
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .codegen.targetPlatform=1.5
@org.eclipse.ant.ui=3.2.0.v20060531
/instance/org.eclipse.jdt.ui/org.eclipse.jface.textfont=1|Co urier
New|10|0|WINDOWS|1|0|0|0|0|0|0|0|0|1|0|0|0|0|Courier New;
/instance/org.eclipse.birt.report.designer.ui/platformState= 1166380640064
/instance/org.eclipse.jdt.ui/useAnnotationsPrefPage=true
/instance/org.eclipse.ant.ui/useAnnotationsPrefPage=true
*** Current Install Configuration:
Install configuration:
Last changed on Dec 17, 2006
file:/C:/birt-rcp-report-designer-2_1_1/configuration/org.ec lipse.update/platform.xml
Configured sites:
platform:/base/
Configured features:
ID: org.apache.batik, Version: 1.6.0.v20060926-0959
ID: org.eclipse.birt.doc.isv, Version: 2.1.1.v20060926-0959
2.8.0.v200605151647--08422828353873
ID: org.mozilla.rhino, Version: 1.6.0.v20060926-0959
ID: org.eclipse.birt.example, Version: 2.1.1.v20060926-0959
ID: org.eclipse.birt.chart.cshelp, Version: 2.1.1.v20060926-0959
ID: org.eclipse.birt.chart.runtime, Version: 2.1.1.v20060926-0959
ID: org.eclipse.birt, Version: 2.1.1.v20060926-0959
ID: org.eclipse.birt.doc, Version: 2.1.1.v20060926-0959
ID: org.eclipse.birt.report.runtime, Version: 2.1.1.v20060926-0959
ID: org.apache.batik.pdf, Version: 1.6.0.v20060926-0959
ID: org.eclipse.birt.chart, Version: 2.1.1.v20060926-0959
ID: com.lowagie.itext, Version: 1.3.0.v20060926-0959
ID: org.apache.commons.codec, Version: 1.3.0.v20060926-0959
ID: org.w3c.sac, Version: 1.3.0.v20060926-0959
ID: org.eclipse.birt.cshelp, Version: 2.1.1.v20060926-0959
ID: org.apache.derby.core, Version: 10.1.2.1
ID: org.eclipse.birt.report.designer, Version: 2.1.1.v20060926-0959
ID: org.eclipse.birt.chart.doc.isv, Version: 2.1.1.v20060926-0959
Configured plug-ins:
file:/C:/birt-rcp-report-designer-2_1_1/plugins/com.ibm.icu_ 3.4.4.1.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/com.lowagie. itext_1.3.0.v20060909-0630/
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.apache.a nt_1.6.5/
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.apache.b atik.pdf_1.6.0.v20060623-1511/
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.apache.b atik_1.6.0.v20060623-1511/
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.apache.c ommons.codec_1.3.0.v20060629-0630/
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.apache.d erby.core_10.1.2.1/
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.apache.l ucene_1.4.103.v20060601/
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.apache.x erces_2.8.0.v200606131651/
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. ant.core_3.1.100.v20060531.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. ant.ui_3.2.0.v20060531.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. birt.chart.cshelp_2.1.1.v20060925-0939/
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. birt.chart.device.extension_2.1.1.v20060921-1226.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. birt.chart.device.pdf_2.1.1.v20060921-1226.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. birt.chart.device.svg_2.1.1.v20060926-0959.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. birt.chart.device.swt_2.1.1.v20060921-1226.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. birt.chart.doc.isv_2.1.1.v20060921-1226/
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. birt.chart.engine.extension_2.1.1.v20060926-0959.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. birt.chart.engine_2.1.1.v20060922-1058.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. birt.chart.examples_2.1.1.v20060926-0959/
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. birt.chart.reportitem.ui_2.1.1.v20060921-1226.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. birt.chart.reportitem_2.1.1.v20060921-1226.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. birt.chart.runtime_2.1.1.v20060921-1226.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. birt.chart.ui.extension_2.1.1.v20060926-0959.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. birt.chart.ui_2.1.1.v20060926-0959.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. birt.chart_2.1.1.v20060921-1226.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. birt.core.ui_2.1.1.v20060831-1059.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. birt.core_2.1.1.v20060926-0959.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. birt.cshelp_2.1.1.v20060921-1226/
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. birt.data.oda.adapter.dtp_2.1.1.v20060922-1058.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. birt.data.oda_2.1.1.v20060922-1058/
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. birt.data_2.1.1.v20060922-1058.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. birt.doc.isv_2.1.1.v20060921-1226/
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. birt.doc_2.1.1.v20060921-1226/
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. birt.example_2.1.1.v20060921-1226.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. birt.report.data.adapter_2.1.1.v20060922-1058.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. birt.report.data.oda.jdbc.ui_2.1.1.v20060922-1058.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. birt.report.data.oda.jdbc_2.1.1.v20060922-1058/
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. birt.report.data.oda.sampledb.ui_2.1.1.v20060922-1058.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. birt.report.data.oda.sampledb_2.1.1.v20060922-1058/
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. birt.report.data.oda.xml.ui_2.1.1.v20060922-1058.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. birt.report.data.oda.xml_2.1.1.v20060926-0959.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. birt.report.designer.core_2.1.1.v20060922-1058.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. birt.report.designer.example.samplereport_2.1.1.v20060925-09 39/
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. birt.report.designer.ui.editors.schematic_2.1.1.v20060925-09 39.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. birt.report.designer.ui.editors_2.1.1.v20060922-1058.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. birt.report.designer.ui.lib.explorer_2.1.1.v20060925-0939.ja r
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. birt.report.designer.ui.lib_2.1.1.v20060926-0959.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. birt.report.designer.ui.preview_2.1.1.v20060926-0959.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. birt.report.designer.ui.rcp_2.1.1.v20060925-0939.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. birt.report.designer.ui_2.1.1.v20060922-1058/
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. birt.report.designer_2.1.1.v20060921-1226.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. birt.report.engine.emitter.html_2.1.1.v20060926-0959.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. birt.report.engine.emitter.pdf_2.1.1.v20060926-0959.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. birt.report.engine.fonts_2.1.1.v20060926-0959/
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. birt.report.engine_2.1.1.v20060926-0959.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. birt.report.model.adapter.oda_2.1.1.v20060922-1058.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. birt.report.model_2.1.1.v20060926-0959.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. birt.report.runtime_2.1.1.v20060921-1226.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. birt.report.viewer_2.1.1.v20060926-0959/
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. birt.resources_2.1.1.v20060825-0630.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. birt_2.1.1.v20060921-1226.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. compare_3.2.0.v20060525.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. core.commands_3.2.0.I20060511-0800a.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. core.contenttype_3.2.0.v20060601a.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. core.expressions_3.2.0.v20060602-0010.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. core.filebuffers_3.2.0.v20060602-0010.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. core.filesystem.win32.x86_1.0.0.v20060601a.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. core.filesystem_1.0.0.v20060601a.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. core.jobs_3.2.0.v20060601a.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. core.resources.compatibility_3.2.0.v20060601a.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. core.resources.win32_3.2.0.v20060601a.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. core.resources_3.2.0.v20060601a.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. core.runtime.compatibility.auth_3.2.0.v20060601.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. core.runtime.compatibility.registry_3.2.0.v20060602/
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. core.runtime.compatibility_3.1.100.v20060601a.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. core.runtime_3.2.0.v20060601b.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. core.variables_3.1.100.v20060517.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. datatools.connectivity.oda.consumer_3.0.2.200608301.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. datatools.connectivity.oda.design.ui_3.0.2.200609201.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. datatools.connectivity.oda.designer.finfo_0.9.1.200609191.ja r
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. datatools.connectivity.oda.design_3.0.2.200608301.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. datatools.connectivity.oda.finfo_0.9.1.200609191.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. datatools.connectivity.oda.flatfile.ui_3.0.2.200608301.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. datatools.connectivity.oda.flatfile_3.0.2.200608311.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. datatools.connectivity.oda.profile_3.0.2.200608301.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. datatools.connectivity.oda_3.0.2.200608301.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. datatools.connectivity.ui.dse_0.9.1.200608251/
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. datatools.connectivity.ui_0.9.1.200608251/
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. datatools.connectivity_0.9.1.20060831/
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. debug.core_3.2.0.v20060601.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. debug.ui_3.2.0.v20060601.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. draw2d_3.2.0.v20060616.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. emf.common_2.2.0.v200606221156.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. emf.ecore.xmi_2.2.0.v200606221156.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. emf.ecore_2.2.0.v200606221156.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. equinox.common_3.2.0.v20060601a.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. equinox.preferences_3.2.0.v20060601.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. equinox.registry_3.2.0.v20060601.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. gef_3.2.0.v20060616.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. help.appserver_3.1.100.v20060510b.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. help.base_3.2.0.v20060601.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. help.ui_3.2.0.v20060510b.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. help.webapp_3.2.0.v20060510b/
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. help_3.2.0.v20060518.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. jdt.core.manipulation_1.0.0.v20060602-0010.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. jdt.core_3.2.0.v_670.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. jdt.debug.ui_3.2.0.v20060517.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. jdt.debug_3.2.0.v20060601/
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. jdt.junit.runtime_3.2.0.v20060602-0010/
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. jdt.junit_3.2.0.v20060602-0010/
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. jdt.launching_3.2.0.v20060525.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. jdt.ui_3.2.0.v20060602-0010.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. jface.text_3.2.0.v20060602-0010.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. jface_3.2.0.I20060602-0010.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. ltk.core.refactoring_3.2.0.v20060602-0010.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. ltk.ui.refactoring_3.2.0.v20060602-0010.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. osgi_3.2.0.v20060601.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. pde.build_3.2.0.v20060601/
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. pde.core_3.2.0.v20060601b.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. pde.runtime_3.2.0.v20060511-0800.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. pde.ui_3.2.0.v20060526-0010.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. pde_3.2.0.v20060511-1200.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. search_3.2.0.v20060602-0010.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. swt.win32.win32.x86_3.2.0.v3232l.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. swt_3.2.0.v3232l.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. team.core_3.2.0.I200605181830.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. team.ui_3.2.0.I200606011710.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. text_3.2.0.v20060602-0010.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. tomcat_4.1.130.v20060601/
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. ui.cheatsheets_3.2.0.v20060516.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. ui.console_3.1.100.v20060518.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. ui.editors_3.2.0.v20060602-0010.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. ui.externaltools_3.1.100.v20060511.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. ui.forms_3.2.0.v20060530.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. ui.ide_3.2.0.I20060602-0010.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. ui.intro_3.2.0.v20060601.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. ui.navigator.resources_3.2.0.I20060511-2000.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. ui.navigator_3.2.0.I20060526-0010.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. ui.views.properties.tabbed_3.2.0.I20060511-0800a.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. ui.views_3.2.0.I20060511-2000.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. ui.win32_3.2.0.I20060511-2000.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. ui.workbench.texteditor_3.2.0.v20060602-0010.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. ui.workbench_3.2.0.I20060602-0010.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. ui_3.2.0.I20060602-0010.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. update.configurator_3.2.0.v20060511.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. update.core.win32_3.2.0.v20060511.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. update.core_3.2.0.v20060602.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.eclipse. update.ui_3.2.0.v20060601.jar
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.junit_3. 8.1/
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.mozilla. rhino_1.6.0.v20060629-0630/
file:/C:/birt-rcp-report-designer-2_1_1/plugins/org.w3c.sac_ 1.3.0.v20060629-0630/
Re: fonts in charts look very bad [message #211401 is a reply to message #211296] Sat, 13 January 2007 11:02 Go to previous messageGo to next message
David Michonneau is currently offline David MichonneauFriend
Can you post a screenshot of the problem?
Are you rendering your charts in SVG, or which other format?
David
> rendering
> quality.
> charts
> shots
> figure
> the update manager). So I guess it is a problem with my Java + AWT???
> WinXP
> win32
> -ws
> win32
> -arch
> x86
> -launcher
> -name
> BIRT
> -showsplash
> 600
> -exitdata
> 1570_80
> -vm
> eclipse.vmargs=-jar
> file.separator=\
> ;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\ Program
> ry
> line.separator=
> javax.crypto,javax.crypto.interfaces,javax.crypto.spec,javax .imageio,j
> avax.imageio.event,javax.imageio.metadata,javax.imageio.plug ins.bmp,ja
> vax.imageio.plugins.jpeg,javax.imageio.spi,javax.imageio.str eam,javax.
> management,javax.management.loading,javax.management.modelmb ean,javax.
> management.monitor,javax.management.openmbean,javax.manageme nt.relatio
> .timer,javax.naming,javax.naming.directory,javax.naming.even t,javax.na
> ming.ldap,javax.naming.spi,javax.net,javax.net.ssl,javax.pri nt,javax.p
> rint.attribute,javax.print.attribute.standard,javax.print.ev ent,javax.
> rmi,javax.rmi.CORBA,javax.rmi.ssl,javax.security.auth,javax. security.a
> uth.callback,javax.security.auth.kerberos,javax.security.aut h.login,ja
> ax.security.sasl,javax.sound.midi,javax.sound.midi.spi,javax .sound.sam
> pled,javax.sound.sampled.spi,javax.sql,javax.sql.rowset,java x.sql.rows
> et.serial,javax.sql.rowset.spi,javax.swing,javax.swing.borde r,javax.sw
> ing.colorchooser,javax.swing.event,javax.swing.filechooser,j avax.swing
> .plaf,javax.swing.plaf.basic,javax.swing.plaf.metal,javax.sw ing.plaf.m
> wing.text.html,javax.swing.text.html.parser,javax.swing.text .rtf,javax
> .swing.tree,javax.swing.undo,javax.transaction,javax.transac tion.xa,ja
> vax.xml,javax.xml.datatype,javax.xml.namespace,javax.xml.par sers,javax
> .xml.transform,javax.xml.transform.dom,javax.xml.transform.s ax,javax.x
> ml.transform.stream,javax.xml.validation,javax.xml.xpath,org .ietf.jgss
> RBA.DynAnyPackage,org.omg.CORBA.ORBPackage,org.omg.CORBA.por table,org.
> omg.CORBA.TypeCodePackage,org.omg.CosNaming,org.omg.CosNamin g.NamingCo
> ntextExtPackage,org.omg.CosNaming.NamingContextPackage,org.o mg.Dynamic
> ,org.omg.DynamicAny,org.omg.DynamicAny.DynAnyFactoryPackage, org.omg.Dy
> namicAny.DynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryP ackage,org
> g.omg.PortableInterceptor.ORBInitInfoPackage,org.omg.Portabl eServer,or
> g.omg.PortableServer.CurrentPackage,org.omg.PortableServer.P OAManagerP
> ackage,org.omg.PortableServer.POAPackage,org.omg.PortableSer ver.portab
> le,org.omg.PortableServer.ServantLocatorPackage,org.omg.Send ingContext
> ,org.omg.stub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org .w3c.dom.e
> os.arch=x86
> os.name=Windows XP
> os.version=5.1
> osgi.arch=x86
> clipse.osgi\bundles
> uration/
> g
> osgi.nl=en_US
> osgi.os=win32
> r.ui.rcp
> osgi.ws=win32
> path.separator=;
> i386
> i86
> sun.desktop=windows
> user.country=US
> user.language=en
> user.name=jan
> user.variant=
> *** Features:
> Eclipse"
> Reporting Tools"
> Documentation"
> Runtime"
> Help"
> Documentation"
> Designer"
> Runtime"
> (ICU4J)" [Active]
> [Resolved]
> [Resolved]
> Eclipse"
> [Resolved]
> [Resolved]
> [Resolved]
> Chart
> Engine"
> [Active]
> Chart
> Runtime"
> [Resolved]
> UI
> Plug-in" [Active]
> UI
> Extension" [Active]
> [Active]
> [Active]
> Help" [Resolved]
> [Active]
> Access"
> [Active]
> ODA
> [Resolved]
> Documentation"
> [Resolved]
> [Resolved]
> Adapter" [Active]
> JDBC
> "BIRT
> ODA-XML
> Driver" [Resolved]
> XML
> Designer
> UI" [Active]
> "Rdt
> Plug-in" [Active]
> "BIRT
> RCP
> Designer" [Active]
> [Active]
> "BIRT
> "BIRT
> Engine
> fonts" [Resolved]
> [Active]
> Runtime" [Resolved]
> Viewer"
> [Active]
> Plug-in"
> [Resolved]
> [Resolved]
> Mechanism" [Active]
> Language"
> [Active]
> [Active]
> [Resolved]
> System
> [Active]
> Management"
> [Active]
> Resource
> Runtime
> "Eclipse
> [Resolved]
> Platform
> Data
> Access" [Active]
> ODA
> ODA
> "DTP
> (0.9.1.200609191)
> Designer"
> [Resolved]
> "Eclipse
> ODA
> "DTP
> ODA
> Data
> [Active]
> Mechanism" [Active]
> Support" [Active]
> [Active]
> Server"
> [Active]
> [Resolved]
> [Resolved]
> JUnit
> support" [Resolved]
> [Resolved]
> Core"
> [Resolved]
> [Resolved]
> Environment
> [Resolved]
> [Resolved]
> Toolkit
> [Active]
> [Active]
> [Active]
> View"
> [Resolved]
> Editor
> Framework" [Active]
> [Resolved]
> for
> Windows" [Resolved]
> nce.elementname.description.preferencestore=;;Insert
> items.;Insert
> bands;Insert
> designer.ui.preferences.resourcestore=C\:\\Documents
> gner-2_1_1
> 5
> e=1.5
> ema=20
> kkACXRocmVzaG9sZHhwP0AAAAAAAAx3CAAAABAAAAABdAAacG9zdGdyZXMta mRiYzItNy4
> 0LjIxNC5qYXJzcgA1b3JnLmVjbGlwc2UuYmlydC5yZXBvcnQuZGF0YS5vZGE uamRiYy51a
> S51dGlsLkphckZpbGX1YJoUc1N5HAIAAkwACGZpbGVOYW1ldAASTGphdmEvb GFuZy9TdHJ
> pbmc7TAAIZmlsZVBhdGhxAH4ABHhwcQB+AAJ0AHJDOlxEb2N1bWVudHMgYW5 kIFNldHRpb
> mdzXGphblxEZXNrdG9wXHdvcmtzcGFjZVxTZWNvbmQgU3RvcnlcdGhpcmRQY XJ0eUxpYnN
> le_each_schema=100
> XML=<?xml
> defaultVM\="57,org.eclipse.jdt.internal.debug.ui.launcher.StandardVMTy
> pe13,1168035698194">\r\n<vmType
> m
> id\="1168035698194"
> States)
> numIdentifier=error
> kACXRocmVzaG9sZHhwP0AAAAAAAAx3CAAAABAAAAACdAAwb3JnLmVjbGlwc2 UuYmlydC5y
> ZXBvcnQuZGF0YS5vZGEuc2FtcGxlZGIuRHJpdmVyc3IAOG9yZy5lY2xpcHNl LmJpcnQucm
> Vwb3J0LmRhdGEub2RhLmpkYmMudWkudXRpbC5Ecml2ZXJJbmZvpAGLHD+7w9 8CAANMAAtk
> aXNwbGF5TmFtZXQAEkxqYXZhL2xhbmcvU3RyaW5nO0wACmRyaXZlck5hbWVx AH4ABEwAC3
> VybFRlbXBsYXRlcQB+AAR4cHQAI0NsYXNzaWMgTW9kZWxzIEluYy4gU2FtcG xlREIgRHJp
> VydAAbamRiYzpjbGFzc2ljbW9kZWxzOnNhbXBsZWRidAAkb3JnLmFwYWNoZS 5kZXJieS5q
> ZGJjLkVtYmVkZGVkRHJpdmVyc3EAfgADdAAcQXBhY2hlIERlcmJ5IEVtYmVk ZGVkIERyaX
> ZlcnQAJG9yZy5hcGFjaGUuZGVyYnkuamRiYy5FbWJlZGRlZERyaXZlcnQAN2 pkYmM6ZGVy
> Ynk6W3N1YnN1YnByb3RvY29sOl1EQVRBQkFTRVs7QVRUUklCVVRFPVZBTFVF XSp4
> ted=true
> ion=10
> ent_passed=100000
> argetPlatform=1.5
> 064
> Location:
> te/platform.xml
> Configured sites:
> platform:/base/
> r
> 0.v20060909-0630/
> .v20060623-1511/
> 10.1.2.1/
> 103.v20060601/
> 0.v200606131651/
> .0.v20060531.jar
> t.designer.example.samplereport_2.1.1.v20060925-0939/
> t.designer.ui.editors.schematic_2.1.1.v20060925-0939.jar
> t.designer.ui.lib.explorer_2.1.1.v20060925-0939.jar
> .v20060921-1226.jar
> 2.0.v20060525.jar
> connectivity.oda.designer.finfo_0.9.1.200609191.jar
> .2.0.v20060601.jar
> .0.v20060616.jar
> v20060616.jar
> 3.2.0.v20060601.jar
> 2.0.v20060510b.jar
> p_3.2.0.v20060510b/
> .v20060518.jar
> .2.0.v_670.jar
> 3.2.0.v20060601/
> .v20060601.jar
> 3.2.0.v20060601/
> .2.0.v20060601b.jar
> v20060511-1200.jar
> v3232l.jar
> .v20060602-0010.jar
> .130.v20060601/
> .2.0.v20060530.jar
> .2.0.v20060601.jar
> 20060602-0010.jar
> 3.2.0.v20060601.jar
> 0.v20060629-0630/
> 60629-0630/
Re: fonts in charts look very bad [message #211598 is a reply to message #211296] Mon, 15 January 2007 19:42 Go to previous messageGo to next message
Jonathan Brown is currently offline Jonathan BrownFriend
I have this problem as well (and have had it since v2.1). I was never able
to figure out the source of the problem but I did find a workaround.
1. Try selecting the chart that looks bad and inspecting the properties for
it.
2. Clear the values for the height and width.
a. the chart should remain whatever size you last resized it to.
3. Preview/display the report
On my system, the above three steps fixes the fonts so that they are
actually legible. The problem is that anytime you edit the chart you have
to repeat the process. Tedious yes, but it's the best solution I've found.
For what it's worth, I believe I tried every chart type, format, and unit
combination available in an attempt to fix the fonts.
jb
"Jan Schroeder" <jan-schroeder@gmx.net> wrote in message
news:741721b6721b226420af0f0beee2a800$1@www.eclipse.org...
> quality.
> WinXP
> win32
> -ws
> win32
> -arch
> x86
> -launcher
> -name
> BIRT
> -showsplash
> 600
> -exitdata
> 1570_80
> -vm
> eclipse.vmargs=-jar
> file.separator=\
> line.separator=
> os.arch=x86
> os.name=Windows XP
> os.version=5.1
> osgi.arch=x86
> osgi.nl=en_US
> osgi.os=win32
> osgi.ws=win32
> path.separator=;
> i86
> sun.desktop=windows
> user.country=US
> user.language=en
> user.name=jan
> user.variant=
> *** Features:
> Reporting Tools"
> Documentation"
> Help"
> Designer"
> Runtime"
> (ICU4J)" [Active]
> [Resolved]
> [Resolved]
> [Resolved]
> [Active]
> [Resolved]
> Plug-in" [Active]
> Extension" [Active]
> Help" [Resolved]
> [Active]
> [Resolved]
> [Resolved]
> Adapter" [Active]
> Driver" [Resolved]
> UI" [Active]
> Plug-in" [Active]
> Designer" [Active]
> [Active]
> fonts" [Resolved]
> Runtime" [Resolved]
> [Active]
> [Resolved]
> Mechanism" [Active]
> [Active]
> [Active]
> [Resolved]
> [Active]
> Access" [Active]
> [Resolved]
> [Active]
> Mechanism" [Active]
> Support" [Active]
> [Active]
> [Resolved]
> support" [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> [Active]
> [Resolved]
> Framework" [Active]
> Windows" [Resolved]
> id\="1168035698194"
> States)
> Location:
> Configured sites:
> platform:/base/
Re: fonts in charts look very bad [message #211638 is a reply to message #211598] Tue, 16 January 2007 07:51 Go to previous messageGo to next message
Leos Literak is currently offline Leos LiterakFriend
Jonathan Brown napsal(a):
> it.
I've got the same issue and I use this workaround too
Leos
Re: fonts in charts look very bad [message #211726 is a reply to message #211401] Tue, 16 January 2007 15:56 Go to previous messageGo to next message
here is a screenshot of how it looks on my machine:
http://home.nc.rr.com/potato/birt/chart.jpg
it should look like this:
http://download.eclipse.org/birt/downloads/examples/reports/ 2.1/combochart/final.JPG
Jan
PS: a workaround was posted later in this threat, but a developer might
still be interested in this problem. BTW, I switched JDKs and still have
the same problem.
Re: fonts in charts look very bad [message #211734 is a reply to message #211598] Tue, 16 January 2007 15:58 Go to previous messageGo to next message
yep, this workaround works. Thank you!
> it.
> jb
>> quality.
>> WinXP
Re: fonts in charts look very bad [message #211780 is a reply to message #211726] Tue, 16 January 2007 17:03 Go to previous messageGo to next message
What size did you set for the chart? Is it in %?
Can you attach a sample report with the problem?
David
> hart/final.JPG
> Jan
> might still be interested in this problem. BTW, I switched JDKs and
> still have the same problem.
Re: fonts in charts look very bad [message #211914 is a reply to message #211780] Tue, 16 January 2007 21:18 Go to previous messageGo to next message
For the screenshots I used the example report at
http://www.eclipse.org/birt/phoenix/examples/reports/birt2.1 /combochart/index.php
to make sure there isn't anything wrong with my report design itself.
In this report the chart size is given in inches.
> David
>> hart/final.JPG
>> Jan
Re: fonts in charts look very bad [message #212031 is a reply to message #211914] Wed, 17 January 2007 11:33 Go to previous messageGo to next message
I tried this report, and the chart fonts look fine both in SVG and PNG. I
use the 2.1.1 IDE build. Did you try to get the all-in-one build for 2.1.1?
Are you running in US locale by the way?
David
> t/index.php
>> Thanks,
>> David
>>> oc
>>> hart/final.JPG
>>> Jan
Re: fonts in charts look very bad [message #212062 is a reply to message #212031] Wed, 17 January 2007 14:10 Go to previous messageGo to next message
I tried the all-in-one. I first encountered the problem in 2.1.1 (when I
first installed BIRT) but I'm using 2.2 at present.
My systems are configured for US locale.
"David Michonneau" <dmichonneau@actuate.com> wrote in message
news:9c678db74f88c9084ae4ffe7e6@news.eclipse.org...
> David
>> t/index.php
>>> Thanks,
>>> David
>>>> oc
>>>> hart/final.JPG
>>>> Jan
Re: fonts in charts look very bad [message #212089 is a reply to message #212062] Wed, 17 January 2007 14:50 Go to previous messageGo to next message
Ok, can you try something: When you see the invalid image, right click and
save it to disk. Then open it with an image viewer (IE will do). Is it still
distorted or not? That will tell us if the problem happens in Swing or if
the size set by the viewer is somehow wrong.
- If it's not distorted, can you check the image size with an image editor,
and compare it to the size set in the report design. Can you also try to
insert a regular image in the report, set its real size in the properties,
and see if it appears distorted when previewed?
- If the image is distorted, it's probably something wrong in your Swing
lib. I would advise to uninstall/reinstall java, using the latest version.
Thanks.
David
> (when I first installed BIRT) but I'm using 2.2 at present.
>> PNG. I use the 2.1.1 IDE build. Did you try to get the all-in-one
>> build for 2.1.1? Are you running in US locale by the way?
>> Thanks,
>> David
>>> ar
>>> t/index.php
>>> itself.
>>>> Thanks,
>>>> David
>>>>> mb
>>>>> oc
>>>>> hart/final.JPG
>>>>> Jan
>>>>> and
Re: fonts in charts look very bad [message #212128 is a reply to message #212089] Wed, 17 January 2007 16:17 Go to previous messageGo to next message
Now _that_ is shocking. I have been struggling with this problems for many
days (weeks?). I _know_ I tried various versions of Birt (stand alone
2.1.1 (with different JREs/JDKs); Eclipse 3.2.1 all in one; 3.2.1 all in
one + updated plugins) and always had the font problem. Yesterday I
deleted the height and width values for the chart in the report design (as
recommended in this thread) and the font looked good. Now I can not
recreate the font problem anymore. Even when specifying values for height
and width the chart font looks great.
I downloaded the example report again to make sure I didn't make any other
changes -> still works fine. I can not make the fonts look bad anymore.
I don't think it was a problem with the viewer (I tried the built in
viewer and configured Firefox as an external viewer -> both had the
problem).
> Thanks.
> David
>>> Thanks,
>>> David
>>>> ar
>>>> t/index.php
>>>> itself.
>>>>> Thanks,
>>>>> David
>>>>>> mb
>>>>>> oc
>>>>>> hart/final.JPG
>>>>>> Jan
>>>>>> and
Re: fonts in charts look very bad [message #212224 is a reply to message #212089] Wed, 17 January 2007 21:49 Go to previous messageGo to next message
I installed the absolute latest drop for this test: the "Report Designer
Full Eclipse Install" from
http://download.eclipse.org/birt/downloads/build.php?build=N -R1-2.2M4-200701100630
After installing the main component, I ran the update wizard (because I
needed the Subversion plugin to get to my work) and discovered that there
was a critical missing dependency on Apache Xerces 2.8. I installed the
missing Apache component followed by Subclipse 1.1.9.
I sync'd my project and set the width of the chart to 100%. The height
value is left unspecified (per my workaround of not specifying values to
keep the fonts from becoming blurry). FYI: The last time I did the
set/clear workaround for height, I had used a value of 200 points.
Using the interval viewer to preview the report, the image was blurry and I
saved it to disk.
I switched over to the properties for the chart and cleared the width value.
In the designer, the size of the chart was unchanged by this action.
I then switched over to the Preview tab and the fonts were clear. I saved
this image to disk as well.
In looking at the two images outside of eclipse, they are identical.
Neither is distorted and the file size is the same.
I'll try to do the other actions you requested later tonight when I get a
chance. Let me know if there is something else you're curious about based
on the above info.
Lastly, I'm using JDK 1.5.0_10.
jb
news:9c678db75398c9086666ffec80@news.eclipse.org...
> still distorted or not? That will tell us if the problem happens in Swing
> or if the size set by the viewer is somehow wrong.
> editor, and compare it to the size set in the report design. Can you also
> try to insert a regular image in the report, set its real size in the
> properties, and see if it appears distorted when previewed?
> Thanks.
> David
>>> Thanks,
>>> David
>>>> ar
>>>> t/index.php
>>>> itself.
>>>>> Thanks,
>>>>> David
>>>>>> mb
>>>>>> oc
>>>>>> hart/final.JPG
>>>>>> Jan
>>>>>> and
Re: fonts in charts look very bad [message #212355 is a reply to message #212224] Thu, 18 January 2007 15:47 Go to previous messageGo to next message
That's the problem. % size will distort images and charts in a web viewer,
you should use an absolute size in inches or points instead.
Let me explain why:
This % size in HTML is interpreted by the browser to resize your image dynamically
depending on the space available (on your browser window). Needless to say,
BIRT does not know about the browser window size you use, nor will regenerate
an updated image if you change it. So it will generate the chart image based
on a given default size, and the browser will use that image and extend/shrink
it to use 100% of the space. As a result the image is distorted.
If you do not set any size, the browser will use the image real size, and
so it will be fine.
Let me know if you also have issues when settings the width in points.
David
> Designer Full Eclipse Install" from
> 200701100630
> I needed the Subversion plugin to get to my work) and discovered that
> there was a critical missing dependency on Apache Xerces 2.8. I
> installed the missing Apache component followed by Subclipse 1.1.9.
> height value is left unspecified (per my workaround of not specifying
> values to keep the fonts from becoming blurry). FYI: The last time I
> did the set/clear workaround for height, I had used a value of 200
> points.
> and I saved it to disk.
> value. In the designer, the size of the chart was unchanged by this
> action.
> saved this image to disk as well.
> get a chance. Let me know if there is something else you're curious
> about based on the above info.
> jb
>> click and save it to disk. Then open it with an image viewer (IE will
>> do). Is it still distorted or not? That will tell us if the problem
>> happens in Swing or if the size set by the viewer is somehow wrong.
>> also try to insert a regular image in the report, set its real size
>> in the properties, and see if it appears distorted when previewed?
>> Swing lib. I would advise to uninstall/reinstall java, using the
>> latest version.
>> Thanks.
>> David
>>>> Thanks,
>>>> David
>>>>> ch
>>>>> ar
>>>>> t/index.php
>>>>> itself.
>>>>>> Thanks,
>>>>>> David
>>>>>>> co
>>>>>>> mb
>>>>>>> oc
>>>>>>> hart/final.JPG
>>>>>>> Jan
>>>>>>> developer
>>>>>>> and
Re: fonts in charts look very bad [message #212359 is a reply to message #212128] Thu, 18 January 2007 15:49 Go to previous message
At least the problem is fixed, it might have been an old cached image in
your browser (unlikely if you also had the same problem in Firefox). Let
me know if the problem re-appears or if you can find the reason.
David
> many
> in
> (as
> height
> other
> anymore.
> problem).
>> latest version.
>> Thanks.
>> David
>>>> Thanks,
>>>> David
>>>>> ch
>>>>> ar
>>>>> t/index.php
>>>>> itself.
>>>>>> Thanks,
>>>>>> David
>>>>>>> co
>>>>>>> mb
>>>>>>> oc
>>>>>>> hart/final.JPG
>>>>>>> Jan
>>>>>>> developer
>>>>>>> and
Previous Topic:It is possible to have Report Viewer in Java Application (SWT) ?
Next Topic:Problem with Pie Chart and Labels
Current Time: Mon May 28 04:56:06 GMT 2018
Powered by FUDForum. Page generated in 0.03152 seconds
