Home » Modeling » Papyrus » Display default value of value properties fails
Display default value of value properties fails [message #1271107] Fri, 14 March 2014 09:26 Go to next message
Tomas Sandkvist is currently offline Tomas SandkvistFriend
Don't know if this is a bug or that I can't see how to make it work, I have added a value property to a block, and set the default value (a real number).
Next I select Default value from the Appearance tab, but all I get is the '=' sign, not the value I set in the UML tab?
Tomas Sandkvist
[Updated on: Fri, 14 March 2014 09:37]
Report message to a moderator
Re: Display default value of value properties fails [message #1271124 is a reply to message #1271107] Fri, 14 March 2014 10:23 Go to previous messageGo to next message
Philippe Roland is currently offline Philippe RolandFriend
Hi Tomas,
I just tried performing the exact steps you described (using yesterday's nightly), and it seems to work [EDIT - Oops, no it doesn't. See below]. Which version of Papyrus are you using?
Philippe
[Updated on: Mon, 17 March 2014 09:13]
Re: Display default value of value properties fails [message #1271175 is a reply to message #1271107] Fri, 14 March 2014 12:38 Go to previous messageGo to next message
Klaas Gadeyne is currently offline Klaas GadeyneFriend
It seems you are using SysML?
Bitten by this one? https://bugs.eclipse.org/bugs/show_bug.cgi?id=413634
Re: Display default value of value properties fails [message #1271194 is a reply to message #1271175] Fri, 14 March 2014 13:23 Go to previous messageGo to next message
It seems my initial response hasn't gone through moderation so I can't edit it just yet; I wanted to point out, though, that I did manage to reproduce the problem on yesterday's nightly after I'd set the value to a real number as mentioned.
After testing it a bit, it seems that LiteralNull also shows an empty "=" sign, but I don't know if that's intended?
Philippe
Re: Display default value of value properties fails [message #1272129 is a reply to message #1271175] Mon, 17 March 2014 06:14 Go to previous messageGo to next message
Hi Philippe!
Yes, that's the same issue as I have, and yes I'm a SysML guy. I use 0.10.2.v201403040623 due to some other issues I had that were mitigated in that build. I can update to the latest 0.10.2 nightly, unless you have tested with a Luna nightly? Then perhaps this issue remains in the 0.10.2 builds?
Tomas
[Updated on: Mon, 17 March 2014 06:14]
Re: Display default value of value properties fails [message #1272179 is a reply to message #1272129] Mon, 17 March 2014 09:20 Go to previous message
Hi Tomas,
Sorry, I didn't edit my original reply in time - turns out it doesn't work on the Luna nightly, either. I'll have a quick look at the code and report on Klaas's bug if I see anything
EDIT : Found the issue: a switch case statement that didn't include a case for LiteralReals. I added a proposed patch (for the luna branch) to Klaas's bug report.
Philippe
[Updated on: Mon, 17 March 2014 13:28]
Previous Topic:How to use allocation table (old and new) ?
Next Topic:Statemachine to Java code generator
Current Time: Sun Jun 24 07:36:55 GMT 2018
Powered by FUDForum. Page generated in 0.01614 seconds
