Home » Newcomers » Newcomers » I can't restart Eclipse
I can't restart Eclipse [message #210764] Tue, 15 May 2007 11:02 Go to next message
Eclipse User
Originally posted by: kzoli78.gmail.com
Initially when starting Eclipse, it asks for workspace and runs normally.
Unfortunatelly the program leave some (maybe configuration or lock) file
on HDD during close. Because of this the next time it won't start with an
error:
"JVM terminated. Exit code=1
/usr/bin/java
-Xms40m
-Xmx256m
-jar /opt/eclipse/startup.jar
-os linux
-ws gtk
-arch x86_64
-launcher /opt/eclipse/eclipse
-name Eclipse
-showsplash 600
-exitdata e0013
-vm /usr/bin/java
-vmargs
-Xms40m
-Xmx256m
-jar /opt/eclipse/startup.jar"
I'm using openSuse 10.2(X86_64) Kernel 2.6.18.8-0-3 (default)
Re: I can't restart Eclipse [message #210780 is a reply to message #210764] Tue, 15 May 2007 11:17 Go to previous messageGo to next message
Eclipse User
Originally posted by: krzysztofHMMMMdaniel.gmail.com
Go to workspace/.metadata and check the .log file.
There should be a clue.
Chris
Re: I can't restart Eclipse [message #210803 is a reply to message #210780] Tue, 15 May 2007 12:57 Go to previous messageGo to next message
Eclipse User
There is no .log file, just these files:
lock
version.ini
Re: I can't restart Eclipse [message #210857 is a reply to message #210780] Wed, 16 May 2007 02:51 Go to previous messageGo to next message
Eclipse User
Error: Workspace in use or cannot be created, choose a different on.
Eclipse did shutdown correctly, but left some garbage on HDD.
Re: I can't restart Eclipse [message #210905 is a reply to message #210857] Wed, 16 May 2007 05:12 Go to previous message
Eclipse User
delete .lock file, this should help.
but before that do a backup copy of workspace.
Chris
Previous Topic:Filtered Resources
Next Topic:Extension Point for Preference Initializer is not called
Current Time: Sat May 25 17:46:13 EDT 2013
Powered by FUDForum. Page generated in 0.01513 seconds
