Home » Newcomers » Newcomers » How to add Custom ConnectionRouter to GMF Appearance Properties View
How to add Custom ConnectionRouter to GMF Appearance Properties View [message #206801] Mon, 23 April 2007 09:58 Go to next message
Originally posted by: umamahesh.pramati.com
I am trying to add ManhattanConnectionRouter to the existing
ConnectionRouters like Oblique ,Rectilinear and Tree in the GMF Appearance
Properties View. This seems to be difficult as the Properties View is
working based on Routing class which is a final class and has private
constructor.
Is there a way to add this to Properties? If not, Could anyone help me
to set ManhattanConnectionRouter as ConnectionRouter.
Thanking you in anticipation!
Uma Mahesh
Re: How to add Custom ConnectionRouter to GMF Appearance Properties View [message #206856 is a reply to message #206801] Mon, 23 April 2007 11:57 Go to previous message
Uma,
The GMF newsgroup is very active so your question is likely to get
attention there while it is likely to be overlooked here.
news://news.eclipse.org/eclipse.modeling.gmf
Uma Mahesh wrote:
> Appearance Properties View. This seems to be difficult as the
> Properties View is working based on Routing class which is a final
> class and has private constructor.
> me to set ManhattanConnectionRouter as ConnectionRouter.
> Uma Mahesh
Previous Topic:excluding src packages from a build
Next Topic:java.lang.IllegalStateException
Current Time: Tue Jan 16 16:00:48 GMT 2018
Powered by FUDForum. Page generated in 0.03291 seconds
