Home » Eclipse Projects » e(fx)clipse » efxeclipse Tutorial 3 doesn't show up
efxeclipse Tutorial 3 doesn't show up [message #1253841] Sat, 22 February 2014 19:19 Go to next message
Steven Parry is currently offline Steven ParryFriend
I'm trying to install/run efxeclipse tutorial 3 (which is here: https://wiki.eclipse.org/Efxclipse/Tutorials/Tutorial3).
i followed the instructions precisely, but i do not see the media project. What i see under Java FX is JavaFX Library Project and JavaFX project...no media app.
I'm using eclipse 4.4M5 (actually the latest bundle provided by efxeclipse. with JDK 8. Does anyone know what could be the issue or what i could check?
Thanks!
Re: efxeclipse Tutorial 3 doesn't show up [message #1254138 is a reply to message #1253841] Sun, 23 February 2014 03:29 Go to previous messageGo to next message
Hello
I reinstalled from fresh and did a fresh workspace- i was then able to see the project and create it. However...it doesn't compile. All of the org.eclipse.fx dependencies doen't seem to be found
eg
Description Resource Path Location Type
Bundle 'org.eclipse.fx.core.databinding' cannot be resolved MANIFEST.MF /Media1/META-INF line 16 Plug-in Problem
Bundle 'org.eclipse.fx.ui.databinding' cannot be resolved MANIFEST.MF /Media1/META-INF line 17 Plug-in Problem
Bundle 'org.eclipse.fx.ui.di' cannot be resolved MANIFEST.MF /Media1/META-INF line 14 Plug-in Problem
Bundle 'org.eclipse.fx.ui.theme' cannot be resolved MANIFEST.MF /Media1/META-INF line 13 Plug-in Problem
Bundle 'org.eclipse.fx.ui.workbench.fx' cannot be resolved MANIFEST.MF /Media1/META-INF line 7 Plug-in Problem
This is straight out of the box using an eclipse bundle at the efxclipe site - it is installed. any idea what i need to do ?
S.
Re: efxeclipse Tutorial 3 doesn't show up [message #1254280 is a reply to message #1254138] Sun, 23 February 2014 07:11 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
So did you setup a target platform and enabled it?
Tom
On 23.02.14 04:29, Steven Parry wrote:
> Hello
> eg
> Thanks
> S.
Re: efxeclipse Tutorial 3 doesn't show up [message #1254474 is a reply to message #1254280] Sun, 23 February 2014 12:23 Go to previous message
Tom
Thanks for responding! Ok - i got it to work now. Thanks for your help.
Snazzy demo by the way!
Previous Topic:Application building error
Next Topic:Problem running E4/e(fx)clipse on iMac
Current Time: Wed May 23 17:09:37 GMT 2018
Powered by FUDForum. Page generated in 0.02556 seconds
