Home » Newcomers » Newcomers » bootclasspath
bootclasspath [message #206138] Thu, 19 April 2007 15:31 Go to next message
Originally posted by: pinosol.gmail.com
How can I set up bootclasspath in the project settings? I know only one
way to do it. It can be done through setting of JVM.
Re: bootclasspath [message #206625 is a reply to message #206138] Sun, 22 April 2007 06:56 Go to previous messageGo to next message
Asaf Yaffe is currently offline Asaf YaffeFriend
Why would you need that in the Project Settings? What are you trying to
accomplish?
If you want to define the bootclasspath when you launch a class from
your project, create a launch configuration for the class, and add the
-Xbootclasspath argument to the "VM Arguments" section of the
"Arguments" tab.
HTH,
Asaf
Asaf Yaffe
Eclipse TPTP Committer, JVMTI Profiler
Re: bootclasspath [message #206727 is a reply to message #206625] Sun, 22 April 2007 21:17 Go to previous message
Originally posted by: eclipse5.rizzoweb.com
Asaf Yaffe wrote:
>> one way to do it. It can be done through setting of JVM.
> accomplish?
> "Arguments" tab.
An alternative to using -Xbootclasspath as an argument is to edit the
Classpath tab of the launch configuration - it has places to add both
bootstrap and application libraries to the runtime environment.
Hope this helps,
Eric
Previous Topic:Why don't drop???
Next Topic:All import files being flagged unresolvable
Current Time: Wed May 23 22:57:52 GMT 2018
Powered by FUDForum. Page generated in 0.02856 seconds
