Home » Eclipse Projects » Eclipse Platform » Problem using eclipse.refreshLocal with ant
Problem using eclipse.refreshLocal with ant [message #205918] Thu, 04 March 2004 14:41 Go to next message
Jacques Bonet is currently offline Jacques BonetFriend
I converted my Eclipse ide from release 2.1.2 to 3.0 M7.
After installed it, I try to run my build.xml projets file.
Now I get an error when I execute the target :
<target name="build" depends="date">
<eclipse.refreshLocal resource="${project}" depth="infinite"/>
<eclipse.incrementalBuild project="${project}"/>
</target>
Here the error message :
BUILD FAILED:
X:\FC_HMI_Framework\FactoryCast_HMI_Java_components\FCHMI\bu ild.xml:50:
Could not create task or type of type: eclipse.refreshLocal.
Ant could not find the task or a class this task relies upon.
This is common and has a number of causes; the usual
solutions are to read the manual pages then download and
install needed JAR files, or fix the build file:
- You have misspelt 'eclipse.refreshLocal'.
Fix: check your spelling.
- The task needs an external JAR file to execute
and this is not found at the right place in the classpath.
Fix: check the documentation for dependencies.
Fix: declare the task.
- The task is an Ant optional task and optional.jar is absent
Fix: look for optional.jar in ANT_HOME/lib, download if needed
- The task was not built into optional.jar as dependent
libraries were not found at build time.
Fix: look in the JAR to verify, then rebuild with the needed
libraries, or download a release version from apache.org
- The build file was written for a later version of Ant
Fix: upgrade to at least the latest release version of Ant
- The task is not an Ant core or optional task
and needs to be declared using <taskdef>.
Remember that for JAR files to be visible to Ant tasks implemented
in ANT_HOME/lib, the files must be in the same directory or on the
classpath
Please neither file bug reports on this problem, nor email the
Ant mailing lists, until all of these causes have been explored,
as this is not an Ant bug.
Total time: 1 second
After that, I try to build the sample project org.eclipse.help.examples.ex1
provided by the eclipse.org.
<target name="refresh" depends="init" if="eclipse.running">
<eclipse.refreshLocal resource="${plugin}" depth="infinite"/>
</target>
I get no problem but I found the instruction if="eclipse.running" return
false, so I removed it.
Now when I execute the target :
<target name="refresh" depends="init">
</target>
I have the same error than in my project :
BUILD FAILED:
V:\FC_HMI_ConfTools\eclipse\workspace\org.eclipse.help.examp les.ex1\build.xm
l:73: Could not create task or type of type: eclipse.refreshLocal.
classpath
Total time: 721 milliseconds
I think there is a classpath problem.
What jar is missing?
Re: Problem using eclipse.refreshLocal with ant [message #205930 is a reply to message #205918] Thu, 04 March 2004 15:02 Go to previous messageGo to next message
Originally posted by: richkulp.NO.SPAM.us.ibm.com
By default in 3.0, ant runs in a separate vm. Since it is a separate vm,
it doesn't know anything about eclipse. If you want it to run in the
Eclipse VM, open the configuration and go to the JRE page and select run
in same JRE as workspace.
Thanks, Rich Kulp
Re: Problem using eclipse.refreshLocal with ant [message #216348 is a reply to message #205930] Fri, 26 March 2004 16:36 Go to previous messageGo to next message
Originally posted by: alan.hebert.lucernex.com
Can you please direct me to the section where this configuration is changed?
"Rich Kulp" <richkulp@NO.SPAM.us.ibm.com> wrote in message
news:c27g81$ooq$1@eclipse.org...
> Thanks, Rich Kulp
Re: Problem using eclipse.refreshLocal with ant [message #216357 is a reply to message #216348] Fri, 26 March 2004 16:55 Go to previous message
Darin Swanson is currently offline Darin SwansonFriend
As Rich indicated you use the JRE page for the Ant Launch configuration when
displayed in the Launch configuration Dialog.
Run>External Tools>External Tools...
OR
Context Menu for your Ant build file>Run Ant...
HTH
Darins
"Alan Hebert" <alan.hebert@lucernex.com> wrote in message
news:c41maq$73g$1@eclipse.org...
changed?
> > Thanks, Rich Kulp
Previous Topic:Eclipse under linux looks bad...
Next Topic:Documentation for Branding with Eclipse 2.1
Current Time: Sat Feb 24 14:44:55 GMT 2018
Powered by FUDForum. Page generated in 0.01647 seconds
