Home » Language IDEs » ServerTools (WTP) » webservice
webservice [message #203143] Fri, 26 October 2007 14:44 Go to next message
Originally posted by: xdzgor.hotmail.com
Hi - in general is it possible to return a "custom type" from a java
webservice? I mean for example a simple class such as
public class MyClass {
private String name;
public String getName() {
return name;
public void setName(String name) {
this.name = name;
I have not been able to get this to work using Axis2 - my client which is
a c# application always recieves a MyClass object with a null name. If I
simply return a String from my web-service method then that works fine.
Are there any general pitfalls with writing webservices in java? (I have
written several with Visual Studio c#, and this is easy - you click on the
"make webservice project" button...)
Peter
Re: webservice [message #203304 is a reply to message #203143] Mon, 29 October 2007 16:11 Go to previous message
Lawrence Mandel is currently offline Lawrence MandelFriend
Hi Peter,
> return name;
> this.name = name;
Yes it is.
is
I'm not sure how Axis2 generates Web services. As an alternative method,
you can develop your service top down, describing your service first by
creating a WSDL document and then generating stub code that you can hook
up to your objects.
the
There are definitely places where people go wrong (I see a lot of invalid
XML schemas) because of complexity but no limitations of Java Web
services.
Lawrence
Previous Topic:JSP Web Service Client test facility option missing?
Next Topic:Method DependencyManager.getModStamp missing
Current Time: Sat May 26 06:24:44 GMT 2018
Powered by FUDForum. Page generated in 0.01859 seconds
