Home » Eclipse Projects » BIRT » Converting counters to rates
Converting counters to rates [message #200848] Tue, 14 November 2006 23:46 Go to next message
Originally posted by: owen.discobabe.net
I have a data source containing a timestamp and the number of bytes
transmitted in the lifetime of a network interface at the given
timestamp. I would like to generate a chart showing time on the X-axis
(so far, so good) but bandwidth on the y-axis. Basically, I'd like to
plot not the raw bytes-out counter but number of bytes per 1-second
interval.
What would be the easiest way to do that with BIRT? I got excited when I
saw the "grouping" but it doesn't appear to do what I want. Any help
greatly appreciated.
Owen
Re: Converting counters to rates [message #200978 is a reply to message #200848] Wed, 15 November 2006 14:54 Go to previous message
As a follow up, I had a look at how rrdtool solves this problem and it
has a concept of COUNTER and DERIVE, the latter being useful for just
the problem I describe. I tried googling for BIRT and DERIVE to see if
had anything similar but no luck. Any ideas?
Owen
Owen Fraser-Green wrote:
> interval.
> Cheers,
> Owen
Previous Topic:Change the date format at runtime
Next Topic:How can i change dynamically a dataset ?
Current Time: Sun Apr 22 11:58:53 GMT 2018
Powered by FUDForum. Page generated in 0.01925 seconds
