Home » Eclipse Projects » BIRT » How can i change dynamically a dataset ?
How can i change dynamically a dataset ? [message #200510] Mon, 13 November 2006 13:36 Go to next message
Originally posted by: esteban27.free.fr
I need to change dynamically (by script) the dataset binding parameter of
a table ?
Someone can help me pls ?
Stephane
Re: How can i change dynamically a dataset ? [message #200576 is a reply to message #200510] Mon, 13 November 2006 16:40 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
Can you give more information on what you are wanting to do?
You should be able to use the expression builder on the binding tab for the
parmater to enter an expression that dynamically changes the value.
Jason
"Stephane" <esteban27@free.fr> wrote in message
news:5b786df9cde58dd085519a46b2db5c6f$1@www.eclipse.org...
> a table ?
> Stephane
Re: How can i change dynamically a dataset ? [message #200603 is a reply to message #200576] Mon, 13 November 2006 17:27 Go to previous messageGo to next message
Hi Jason,
I have a table and i want to change the dataset binding to mytable,
compare to a report parameter !
So if my report parameter is true i want to bind my table to mydataset
else i want to bind my table to 'none' (i dont want to see mytable AND i
dont want to execute the dataset)!
This by script like :
if (my report parameter) {
this.setDataset("MyDataSet");
}else{
this.setDataset("NONE");
} in the oncreate event of my table
I know i can use the Visibility properties of my table with 'For specifics
outputs' but i dont want to execute the query of my dataset !
Stephane
Re: How can i change dynamically a dataset ? [message #200611 is a reply to message #200603] Mon, 13 November 2006 20:08 Go to previous messageGo to next message
Ok you can do this one of two ways. The first is the easiest.
1 - Simply put a piece of code in the beforeFactory like this:
reportContext.getReportRunnable().designHandle.getDesignHand le().findElement( "table1").drop();
Make sure you name the table.
2 - Create a duplicate dataset that returns no rows and put code in the
reportContext.getReportRunnable().designHandle.getDesignHand le().findElement( "table2").setProperty("dataSet",
"Data Set1");
Jason
news:befda40f86a33b983ddce7e3bdaeed58$1@www.eclipse.org...
> Hi Jason,
> }else{
> Thanks
> Stephane
Re: How can i change dynamically a dataset ? [message #200793 is a reply to message #200611] Tue, 14 November 2006 16:59 Go to previous messageGo to next message
Thanks Jason
Ok i see, i do it :
" reportContext.getReportRunnable().designHandle.getDesignHand le().findElement( "TableSco").drop();
in the beforeFactory"
but i have this error : "getReportRunnable is not a function"
"Caused by: org.mozilla.javascript.EcmaError: TypeError: getReportRunnable
n'est pas une fonction (<inline>#2)"
I forgot something ?
Stephane
Re: How can i change dynamically a dataset ? [message #200833 is a reply to message #200793] Tue, 14 November 2006 22:15 Go to previous messageGo to next message
What version of BIRT are you running?
Jason
news:23818e0a062f5e5867edcdc8c04dad0d$1@www.eclipse.org...
> Thanks Jason
> Ok i see, i do it :
> Stephane
Re: How can i change dynamically a dataset ? [message #200924 is a reply to message #200833] Wed, 15 November 2006 08:38 Go to previous messageGo to next message
Hi Jason
I have Birt 2.0.0
Stephane
Re: How can i change dynamically a dataset ? [message #200993 is a reply to message #200924] Wed, 15 November 2006 17:42 Go to previous message
I dont think those functions where added until Birt 2.1.1
Jason
news:9b11c4372b99a051e1019e18d5727f09$1@www.eclipse.org...
> Hi Jason
> I have Birt 2.0.0
> Thanks
> Stephane
Previous Topic:Converting counters to rates
Next Topic:configurable url
Current Time: Sun Feb 18 11:02:55 GMT 2018
Powered by FUDForum. Page generated in 0.02294 seconds
