Home » Language IDEs » ServerTools (WTP) » working with XML and XML schemas
working with XML and XML schemas [message #198668] Wed, 22 August 2007 06:33 Go to next message
Zohar Amir is currently offline Zohar AmirFriend
I need to work with XML and XML schemas. I'm looking for something which is
schema-aware, so that it can auto-complete as I type and suggest possible
values.
Is there anything I can use with eclipse for this?
Zohar.
Re: working with XML and XML schemas [message #198715 is a reply to message #198668] Wed, 22 August 2007 09:38 Go to previous messageGo to next message
Zohar,
Have you tried the XML and XML Schema editors provided by WTP?
zohar wrote:
> which is schema-aware, so that it can auto-complete as I type and
> suggest possible values.
> Zohar.
Re: working with XML and XML schemas [message #198722 is a reply to message #198715] Wed, 22 August 2007 12:15 Go to previous messageGo to next message
Any tutorial or something to learn how to use them?
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:fah080$gn4$1@build.eclipse.org...
> Zohar,
> zohar wrote:
>> is schema-aware, so that it can auto-complete as I type and suggest
>> possible values.
>> Thanks,
>> Zohar.
Re: working with XML and XML schemas [message #198843 is a reply to message #198722] Thu, 23 August 2007 02:41 Go to previous messageGo to next message
David Williams is currently offline David WilliamsFriend
Do you have them installed yet? I'll start there.
If you use/install Eclipse 3.3 base platform (or SDK) you can go to the Europa
update site, find the XML Feature (under WST, I believe) select it, and then click
the 'required featues' button to automatically select the other things that are needed.
Once installed, under the New .... Samples menu is an option to create an example project with some sample xml and schema files.
That should get you started, at least to the point where perhaps you could ask a more specific question? Others might know of some more specific tutorials, but I'm not sure there is one for simple editing ... which is what I think you are asking for. Let us know if not and/or if this helps.
Re: working with XML and XML schemas [message #198867 is a reply to message #198843] Thu, 23 August 2007 06:17 Go to previous messageGo to next message
Is there a way to assign a schema to an XML file? I have both and I want to
"link them", so that the XML is validated according to the schema I have.
Zohar.
"David Williams" <david_williams@us.ibm.com> wrote in message
news:op.txhq2rofac05ss@dmw2t23.ibm.com...
> Europa
> then click
> that are needed.
Re: working with XML and XML schemas [message #198880 is a reply to message #198867] Thu, 23 August 2007 11:11 Go to previous message
Zohar,
You could use an xsi:schemaLocation for this purpose. WTP also has
support for an XML catalog where you can specify that a particular
target namespace is associated with a particular schema location, which
is basically the same as an xsi:schemaLocation but is outside the XML
document rather than repeated in each one.
> want to "link them", so that the XML is validated according to the
> schema I have.
> Zohar.
>> the Europa
>> and then click
Previous Topic:Launch NewXMLWizard programmatically
Next Topic:Tomcal server.xml out of sync - any way to refresh ?
Current Time: Thu Feb 22 21:03:07 GMT 2018
Powered by FUDForum. Page generated in 0.01381 seconds
