Home » Eclipse Projects » Buckminster dev » Re: [buckminster-dev] Strange resolver behaviour when resolving PDE plugins - using "native&quo
Re: [buckminster-dev] Strange resolver behaviour when resolving PDE plugins - using "native&quo [message #18796] Mon, 26 May 2008 15:19 Go to next message
Thomas Hallgren is currently offline Thomas HallgrenFriend
Hi Mikhail,
Mikhail Kadan wrote:
> So I can made a conclusion, that Buckminster also searches his
> "native" target platform (target platform which was used to start
> Eclipse), and if it finds a match here, which has bigger version than
> others, it will try to materialize this plugin from "native" platform.
Yes, your conclusion is correct.
> How can I set Buckminster not to look in his "native" target platform
> for plugins?
You declare an advisory node in the component query where you omit the
target platform from the resolution scope (see the "Resolution Scope"
pane under the "Advisor node" tab in the CQUERY editor.
> ps By the way, can anyone provide example how "eclipse.platform"
> reader works? I've tried such RMAP but couldn't get it to work:
The "eclipse.platform" reader type is for internal use only. You should
not use it in an RMAP.
Thomas Hallgren
Re: [buckminster-dev] Strange resolver behaviour when resolving PDE plugins - using "native& [message #1219271] Tue, 03 December 2013 05:03 Go to previous message
Previous Topic:[buckminster-dev] emma.headless.feature dropped?
Next Topic:Website is down
Current Time: Wed Apr 25 20:40:56 GMT 2018
Powered by FUDForum. Page generated in 0.01794 seconds
