Home » Newcomers » Newcomers » Debugger stops with FileNotFoundException
Debugger stops with FileNotFoundException [message #197060] Wed, 28 February 2007 23:02 Go to next message
Originally posted by: keith.1.walker.lmco.com
This is a follow-up to the posting "Unexpected breakpoint in debugger". I
didn't find a bug report as was suggested in that posting.
When I run my program normally, everything is fine. But when I run in the
debugger, I get the error below. I've tried changing this option with no
effect: Window>Preferences>Java>Debug>Suspend execution on uncaught
exceptions
The problem seems to happen in cases where a class is instantiated from
another branch in the source tree or in a different project or from an
external jar. (I've double checked that referenced project is in the
Build Path and in the Referenced Projects.) It works in the very simple
case where the classes are in the same project and source tree.
Setup:
Eclipse 3.2.0 using JRE 1.4.2
Windows XP Pro
Has anyone else run into this?
Keith
Thread [main] (Suspended (exception FileNotFoundException))
URLClassPath$JarLoader.getJarFile(URL) line: 576
URLClassPath$JarLoader.<init>(URL, URLStreamHandler, HashMap) line: 545
URLClassPath$3.run() line: 323
AccessController.doPrivileged(PrivilegedExceptionAction) line: not
available [native method]
URLClassPath.getLoader(URL) line: 312
URLClassPath.getLoader(int) line: 289
URLClassPath.getResource(String, boolean) line: 159
URLClassLoader$1.run() line: 191
AccessController.doPrivileged(PrivilegedExceptionAction,
AccessControlContext) line: not available [native method]
Launcher$AppClassLoader(URLClassLoader).findClass(String) line: 187
Launcher$AppClassLoader(ClassLoader).loadClass(String, boolean) line: 289
Launcher$AppClassLoader.loadClass(String, boolean) line: 274
Launcher$AppClassLoader(ClassLoader).loadClass(String) line: 235
Launcher$AppClassLoader(ClassLoader).loadClassInternal(Strin g) line: 302
DebugClass.foo() line: 13
DebugTest2.doSomething() line: 17
DebugTest2.main(String[]) line: 10
Re: Debugger stops with FileNotFoundException [message #197078 is a reply to message #197060] Thu, 01 March 2007 01:18 Go to previous messageGo to next message
Darin Swanson is currently offline Darin SwansonFriend
Do you have an exception breakpoint set for FileNotFoundException...check
the breakpoints view
HTH
Darins
"Keith" <keith.1.walker@lmco.com> wrote in message
news:5c5861815783b53570b8ebd5b5792b00$1@www.eclipse.org...
> exceptions
> Setup:
> Eclipse 3.2.0 using JRE 1.4.2 Windows XP Pro
> Keith
> available [native method] URLClassPath.getLoader(URL) line: 312
> URLClassPath.getLoader(int) line: 289 URLClassPath.getResource(String,
> boolean) line: 159 URLClassLoader$1.run() line: 191
> DebugClass.foo() line: 13 DebugTest2.doSomething() line: 17
Re: Debugger stops with FileNotFoundException [message #197349 is a reply to message #197060] Thu, 01 March 2007 23:51 Go to previous message
Originally posted by: eclipse5.rizzoweb.com
Please don't cross-post to multiple groups. Choose what seems to be the
most appropriate one and the community will re-direct you if it is the
wrong place.
Eric
Previous Topic:Displaying the full path in the title bar
Next Topic:NoSuchFieldError
Current Time: Sun May 27 23:48:17 GMT 2018
Powered by FUDForum. Page generated in 0.02547 seconds
