Home » Eclipse Projects » BIRT » Report Viewer PDF Problem
Report Viewer PDF Problem [message #196406] Thu, 19 October 2006 08:10 Go to next message
Originally posted by: p.corbett.ecu.edu.au
I have deployed BIRT 2.1.1 on Tomcat 5.5.17 and I am having problems
producing a PDF from a report.
I have copied the itext-1.3.jar to
/WebViewerExample/WEB-INF/platform/plugins/com.lowagie.itext /lib.
and iTextAsian.jar to
but the problem persists. The downloaded example file did not have a lib
directory as described above so I have added it.
In IE I this error occurs:
org.eclipse.birt.report.service.api.ReportServiceException: Report engine
fails to create extension to handle this request.
In Firefox
File does not begin with '%PDF-'
Any help would be appreciated
Re: Report Viewer PDF Problem [message #196568 is a reply to message #196406] Thu, 19 October 2006 16:21 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
Does this fail on the test report?
When you click view example it should load a similar URL to this
http://localhost:8080/birt2.1.1/frameset?__report=test.rptde sign&sample=my+parameter
Select the print icon in the toolbar.
Jason
"Peter Corbett" <p.corbett@ecu.edu.au> wrote in message
news:d50be27d5bae93a6deb4ba64e756c346$1@www.eclipse.org...
> /WebViewerExample/WEB-INF/platform/plugins/com.lowagie.itext /lib. but the
> In Firefox
Re: Report Viewer PDF Problem [message #196675 is a reply to message #196568] Thu, 19 October 2006 23:37 Go to previous messageGo to next message
Yes that fails too.
Error message is:
My URL is
http://localhost:7070/birt-viewer/frameset?__report=test.rpt design&sample
> Jason
>> In Firefox
Re: Report Viewer PDF Problem [message #196809 is a reply to message #196675] Fri, 20 October 2006 14:19 Go to previous messageGo to next message
What OS are you running?
I will download the same Tomcat version and give it a try.
Jason
news:c713cabd5c85a2097b9d9fab5e0ed01f$1@www.eclipse.org...
> Yes that fails too.
> Error message is:
> My URL is
>> Jason
>>> engine fails to create extension to handle this request.
>>> In Firefox
Re: Report Viewer PDF Problem [message #197775 is a reply to message #196809] Thu, 26 October 2006 03:34 Go to previous messageGo to next message
Ken Carroll is currently offline Ken CarrollFriend
Was there any conclusion to this ? I am experiencing the same problem and am
unable to resolve it.
Ken
"Jason Weathersby" <jweathersby@actuate.com> wrote in message
news:ehalto$udt$1@utils.eclipse.org...
> Jason
> > Yes that fails too.
> > Error message is:
engine
> > My URL is
> >> Jason
> >>> In Firefox
Re: Report Viewer PDF Problem [message #198186 is a reply to message #197775] Sun, 29 October 2006 23:01 Go to previous messageGo to next message
Ken,
Verify that you do have both iText files added the lowagie plugin.
Jason
"Ken Carroll" <ken.carroll@fmr.com> wrote in message
news:ehpabd$4jo$1@utils.eclipse.org...
> am
> Ken
>> Jason
>> > Yes that fails too.
>> > Error message is:
> engine
>> > My URL is
>> >> Jason
>> >>> In Firefox
Re: Report Viewer PDF Problem [message #198318 is a reply to message #198186] Mon, 30 October 2006 12:09 Go to previous messageGo to next message
I definitely have added the itext files into the itext plugin folder exactly
as directed in the installation instructions.
I just now got a response from bugzilla (bug # 162313) saying that v2.1.1
has problems with pdf's suggesting I should move to a later release.
Ken
news:ei3brn$7p2$1@utils.eclipse.org...
> Ken,
> Jason
and
> > am
> > Ken
> >> Jason
> >> > Yes that fails too.
> >> > Error message is:
> > engine
> >> > My URL is
> >> >> Jason
but
lib
> >> >>> In Firefox
Re: Report Viewer PDF Problem [message #198704 is a reply to message #198318] Thu, 02 November 2006 10:53 Go to previous messageGo to next message
Originally posted by: timgaulza.gmail.com
Will this work, I am experiencing similar problems with 2.2M1
news:ei4q2a$v9v$1@utils.eclipse.org...
>exactly
> Ken
>> Ken,
>> Jason
> and
>> > am
>> > Ken
>> >> Jason
>> >> > Yes that fails too.
>> >> > Error message is:
>> > engine
>> >> > My URL is
>> >> >> Jason
>> >> >>>problems
> but
> lib
>> >> >>> In Firefox
Re: Report Viewer PDF Problem [message #198854 is a reply to message #198704] Thu, 02 November 2006 20:22 Go to previous messageGo to next message
Are you using the Allinone or RCP download?
Jason
"Tim Gaul" <timgaulza@gmail.com> wrote in message
news:eicin0$6eh$1@utils.eclipse.org...
>>exactly
>> Ken
>>> Ken,
>>> Jason
>> and
>>> > am
>>> > Ken
>>> >> Jason
>>> >> > Yes that fails too.
>>> >> > Error message is:
>>> > engine
>>> >> > My URL is
>>> >> >> Jason
>>> >> >>>problems
>> but
>> lib
>>> >> >>> Report
>>> >> >>> In Firefox
Re: Report Viewer PDF Problem [message #198956 is a reply to message #198318] Fri, 03 November 2006 09:13 Go to previous messageGo to next message
Originally posted by: reg.hill-labs.co.nz
I had this problem, and I had installed the itext jars, then I had another
look, and somewhere down the upgrade path, I picked up two other
com.lowagie.itext... versions that I had not yet added the itext jars to...
You may already have checked for muliple itext locatioins... just thought
I would mention it, as it solved my problem.
Colin
Re: Report Viewer PDF Problem [message #199166 is a reply to message #198956] Sun, 05 November 2006 10:20 Go to previous messageGo to next message
Mira is currently offline MiraFriend
I was wondering if there was a solution to this problem, since I have
not been able to create pdf files with the 2.1.1 or 2.1.0 version of birt.
I am using Red Hat.
I added itext-1.3.jar to
/plugins/com.lowagie.itext_1.3.0.N20060628-1351/lib
Is there something else that I should have done? I have downloaded the
lates
birt (full all-in-one installation with eclipse). I can create report, but
I cannot create pdf files - eclipse crashes.
Someone please help and let me know what should be done.
Thanks a lot,
Mira
Re: Report Viewer PDF Problem [message #199317 is a reply to message #199166] Mon, 06 November 2006 17:18 Go to previous messageGo to next message
Copy iText-1.3.jar and iTextAsian.jar to the lib directory.
Jason
"Mira" <mkaloper@ucdavis.edu> wrote in message
news:a96fca910eb59c079a742861c6e2d75b$1@www.eclipse.org...
> I was wondering if there was a solution to this problem, since I have not
> I am using Red Hat. I added itext-1.3.jar to
> lates birt (full all-in-one installation with eclipse). I can create
> report, but I cannot create pdf files - eclipse crashes.
> Thanks a lot,
> Mira
Re: Report Viewer PDF Problem [message #200016 is a reply to message #199317] Thu, 09 November 2006 17:58 Go to previous messageGo to next message
Justin Knash is currently offline Justin KnashFriend
I'm having the same problem. I'm running Birt on Suse Linux Enterprise
Desktop 10. When I try to do anything with a PDF file, eclipse crashes
and I get a window with a java error and an ok button. Any help is much
appreciated.
Re: Report Viewer PDF Problem [message #200063 is a reply to message #200016] Thu, 09 November 2006 19:58 Go to previous messageGo to next message
Can you post the error?
Jason
"Justin Knash" <jknash@gmail.com> wrote in message
news:83450d09a097b5a4554f492760b6b792$1@www.eclipse.org...
> appreciated.
Re: Report Viewer PDF Problem [message #200760 is a reply to message #200063] Tue, 14 November 2006 15:51 Go to previous messageGo to next message
Here is the text I get in my terminal -
# An unexpected error has been detected by HotSpot Virtual Machine:
# SIGSEGV (0xb) at pc=0x99ea320b, pid=28966, tid=3084696416
# Java VM: Java HotSpot(TM) Client VM (1.4.2_11-b06 mixed mode)
# Problematic frame:
# C [libxul.so+0x4e020b] _ZN18nsAString_internal6AssignERKS_+0x15
# An error report file with more information is saved as
hs_err_pid28966.log
# If you would like to submit a bug report, please visit:
# http://java.sun.com/webapps/bugreport/crash.jsp
Here is the text on the window with the OK button -
JVM terminated. Exit code=1
/usr/bin/java
-Xms40m
-Xmx256m
-jar /usr/local/eclipse-birt/./startup.jar
-os linux
-ws gtk
-arch x86
-launcher /usr/local/eclipse-birt/./eclipse
-name Eclipse
-showsplash 600
-exitdata 900024
-vm /usr/bin/java
-vmargs
-Xms40m
-Xmx256m
thanks,
Justin
Re: Report Viewer PDF Problem [message #201092 is a reply to message #200760] Wed, 15 November 2006 20:00 Go to previous message
Justin,
Can you log a bug with the error and the version of BIRT you are using?
Jason
news:cdd8a3f2bf00bd90d997f666b8b2dcd0$1@www.eclipse.org...
> hs_err_pid28966.log
> /usr/bin/java
> -Xms40m
> -Xmx256m
> -os linux
> -ws gtk
> -arch x86
> -name Eclipse
> -showsplash 600
> -exitdata 900024
> -vm /usr/bin/java
> -vmargs
> -Xms40m
> -Xmx256m
> thanks,
> Justin
Previous Topic:Viewer running out of memory with large data sets
Next Topic:is it possible to scale(set the min and max) the X axis?
Current Time: Sat May 26 06:24:54 GMT 2018
Powered by FUDForum. Page generated in 0.03317 seconds
