Home » Eclipse Projects » BIRT » transform SQLs built in JSPs to BIRT data sets
transform SQLs built in JSPs to BIRT data sets [message #194134] Wed, 04 October 2006 15:39 Go to next message
Originally posted by: mhanganu.tremend.ro
I am trying to migrate some pages of an existing reporting application
built with JSPs and SQL queries executed in the page (using <sql:query>
tag).
I just convinced our client BIRT is a good solution but I found myself
faced with a major problem that I do not know how to solve:
1. I need the report to receive several parameters (no problem here)
2. Based on those parameters, the old rep. app. build a query. For example:
if(someVar == "userX") {
sql += " and table1.col1 > 3";
} else {
sql += " and table1.col1 in (select col1 from table1 where id between 2
and 4)";
As you can see, the SQL queries are built on the fly.
How can I transform this kind of constructions to BIRT?
Marius Hanganu
Re: transform SQLs built in JSPs to BIRT data sets [message #194175 is a reply to message #194134] Wed, 04 October 2006 16:58 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
As long as you do not modify the returned list of columns this can be done
in scripting or property binding.
If you need to modify the returned list of columns you will need to use the
Design Engine API.
Take a look at:
http://www.eclipse.org/birt/phoenix/deploy/reportScripting.p hp
Data Set Events for an example of how to modify the query based on
parameters.
Jason
"Marius Hanganu" <mhanganu@tremend.ro> wrote in message
news:b2b765a41eb2e3200efbae434393efef$1@www.eclipse.org...
> Hello,
> tag).
> example:
> } else {
> and 4)";
> Marius Hanganu
Re: transform SQLs built in JSPs to BIRT data sets [message #194182 is a reply to message #194175] Wed, 04 October 2006 17:11 Go to previous messageGo to next message
Thanks Jason for the response. I will analyze the resources and
hopefully it will work out for me.
I have another question though: the result sets retrieved in the JSP
pages are iterated and transform. For example, a result set looking like:
name value date
'Dan' 1 10 sep 2006
'Mark' 2 10 sep 2006
'Dan' 1 11 sep 2006
'Mark' 3 11 sep 2006
'Dan' 5 12 sep 2006
'Mark' 1 12 sep 2006
is transformed to
Name 10sep2006 11sep2006 12sep2006
Dan 1 1 5
Mark 2 3 1
Is this kind of manipulation possible with BIRT? I guess the problem is
to generate a table with a variable no of columns.
If so, perhaps you can help me with some indications.
Marius Hanganu
> Design Engine API.
> Take a look at:
> parameters.
> Jason
>> Hello,
>> tag).
>> example:
>> } else {
>> and 4)";
>> Thanks,
>> Marius Hanganu
> Design Engine API.
> Take a look at:
> parameters.
> Jason
>> Hello,
>> tag).
>> example:
>> } else {
>> and 4)";
>> Thanks,
>> Marius Hanganu
Re: transform SQLs built in JSPs to BIRT data sets [message #194191 is a reply to message #194182] Wed, 04 October 2006 17:34 Go to previous messageGo to next message
Does this have to scroll to the right?
You can do the aggregate piece of this easy just by grouping on name with a
sub group of date.
Jason
news:eg0pvk$u38$1@utils.eclipse.org...
> Thanks Jason for the response. I will analyze the resources and hopefully
> I have another question though: the result sets retrieved in the JSP pages
> name value date
> 'Dan' 1 10 sep 2006
> 'Dan' 1 11 sep 2006
> 'Dan' 5 12 sep 2006
> is transformed to
> Dan 1 1 5
> Mark 2 3 1
> Is this kind of manipulation possible with BIRT? I guess the problem is to
> Marius Hanganu
>> done in scripting or property binding.
>> the Design Engine API.
>> Take a look at:
>> parameters.
>> Jason
>>> Hello,
>>> tag).
>>> example:
>>> } else {
>>> 2 and 4)";
>>> Thanks,
>>> Marius Hanganu
>> Take a look at:
>> parameters.
>> Jason
>>> Hello,
>>> tag).
>>> example:
>>> } else {
>>> 2 and 4)";
>>> Thanks,
>>> Marius Hanganu
Re: transform SQLs built in JSPs to BIRT data sets [message #194199 is a reply to message #194191] Wed, 04 October 2006 17:48 Go to previous messageGo to next message
Yes, it should scroll to the right. Is this a problem?
Marius Hanganu
> sub group of date.
> Jason
>> name value date
>> 'Dan' 1 10 sep 2006
>> 'Dan' 1 11 sep 2006
>> 'Dan' 5 12 sep 2006
>> is transformed to
>> Dan 1 1 5
>> Mark 2 3 1
>> Thanks,
>> Marius Hanganu
>>> Take a look at:
>>> parameters.
>>> Jason
>>>> Hello,
>>>> tag).
>>>> example:
>>>> } else {
>>>> 2 and 4)";
>>>> Thanks,
>>>> Marius Hanganu
>>> Take a look at:
>>> parameters.
>>> Jason
>>>> Hello,
>>>> tag).
>>>> example:
>>>> } else {
>>>> 2 and 4)";
>>>> Thanks,
>>>> Marius Hanganu
Re: transform SQLs built in JSPs to BIRT data sets [message #194205 is a reply to message #194199] Wed, 04 October 2006 18:05 Go to previous messageGo to next message
Cristian Popescu is currently offline Cristian PopescuFriend
Hi Marius,
from what I know a table in birt is defined with a maximum number of
columns (which is a fix number). My previous solution to this problem is
to define a maximum number of columns and then display the ones I need,
the rest will be hidden.
Cristian
Re: transform SQLs built in JSPs to BIRT data sets [message #194222 is a reply to message #194205] Wed, 04 October 2006 18:17 Go to previous messageGo to next message
Hi Cristian,
The JSP report I'm trying to convert to BIRT uses actually dates as
column headers. Those dates are retrieved from a filter page and date
range could vary from 1 day to 3 years ( 1000+ days).
If that's the case, I'll have to display 10-1000 columns. Is this
something that can be done with BIRT?
Do you know what is the maximum number of columns?
Marius
Cristian wrote:
> Hi Marius,
> Cristian
Re: transform SQLs built in JSPs to BIRT data sets [message #194237 is a reply to message #194222] Wed, 04 October 2006 18:44 Go to previous messageGo to next message
Hi Marius,
1000+ columns is a big number. BIRT is a powerfull tool to generate PDFS.
Try to determine if you ever want to generate PDFS that have a table with
1000+ columns (I don't think that will fit on any page). To answer you to
the second question: I don't know of any limitation on the number of
columns in Birt. I mostly use the Birt Design Tool.
I pretty much had the same problem, but to display some statistics
according to some companies. Because the companies were retrieved from a
DB, their number was variable. The problem was that the table might not be
accessible to be printed in a fancy format because it won't fit on any
page. I've requested the client to determine the maximum number of
companies that would be printed at a time. The solution also implements a
jsp box where you could select the companies to be printed (a maximum
number was defined).
Cristian
Re: transform SQLs built in JSPs to BIRT data sets [message #194260 is a reply to message #194237] Wed, 04 October 2006 19:15 Go to previous messageGo to next message
Thank you Cristian,
I will try to identify a max interval and set a maximum number of columns.
Marius
Cristian wrote:
> Hi Marius,
> PDFS. Try to determine if you ever want to generate PDFS that have a
> table with 1000+ columns (I don't think that will fit on any page). To
> answer you to the second question: I don't know of any limitation on the
> number of columns in Birt. I mostly use the Birt Design Tool.
> be accessible to be printed in a fancy format because it won't fit on
> any page. I've requested the client to determine the maximum number of
> a jsp box where you could select the companies to be printed (a maximum
> Cristian
Re: transform SQLs built in JSPs to BIRT data sets [message #194268 is a reply to message #194191] Wed, 04 October 2006 19:20 Go to previous messageGo to next message
Hi Jason,
I'm trying to understand how can you make that result set perpendicular.
What do you mean by grouping by name and subgrouping by date?
Marius
> sub group of date.
> Jason
>> name value date
>> 'Dan' 1 10 sep 2006
>> 'Dan' 1 11 sep 2006
>> 'Dan' 5 12 sep 2006
>> is transformed to
>> Dan 1 1 5
>> Mark 2 3 1
>> Thanks,
>> Marius Hanganu
>>> Take a look at:
>>> parameters.
>>> Jason
>>>> Hello,
>>>> tag).
>>>> example:
>>>> } else {
>>>> 2 and 4)";
>>>> Thanks,
>>>> Marius Hanganu
>>> Take a look at:
>>> parameters.
>>> Jason
>>>> Hello,
>>>> tag).
>>>> example:
>>>> } else {
>>>> 2 and 4)";
>>>> Thanks,
>>>> Marius Hanganu
Re: transform SQLs built in JSPs to BIRT data sets [message #194276 is a reply to message #194268] Wed, 04 October 2006 19:43 Go to previous messageGo to next message
Hi Marius,
what are you trying, from what I see, is to move the date elements as
column headers. I have no idea how you could do that.
Grouping on name with a sub group of date on your querry that returns:
'Dan' 1 10 sep 2006
'Dan' 1 11 sep 2006
'Dan' 5 12 sep 2006
will have as result:
'Dan' 1 10 sep 2006
'Dan' 1 11 sep 2006
'Dan' 5 12 sep 2006
To transform this result set into
Dan 1 1 5
Mark 2 3 1
you will have to use some java logic or Rhino (BIRT scripting) logic.
Store them into an object and redisplay that object into a table. The
fetch is done on a row and not on a column, that's why you can't do that
with a single table.
Hope that helps you,
Cristian
Re: transform SQLs built in JSPs to BIRT data sets [message #194284 is a reply to message #194276] Wed, 04 October 2006 20:08 Go to previous messageGo to next message
Hi Cristian,
I had no clue either how you can turn row headers into column headers.
Jason said something that confused me and I wanted more clarifications
from him.
But you are saying I can do some js logic that would turn my row headers
into column headers. If I do that, then how can I fill a table in the
report, with column headers and so?
Marius Hanganu
Cristian wrote:
> Hi Marius,
> 'Dan' 1 10 sep 2006
> 'Dan' 1 11 sep 2006
> 'Dan' 5 12 sep 2006
> 'Dan' 1 10 sep 2006
> 'Dan' 1 11 sep 2006
> 'Dan' 5 12 sep 2006
> Dan 1 1 5
> Mark 2 3 1
> Cristian
Re: transform SQLs built in JSPs to BIRT data sets [message #194300 is a reply to message #194284] Wed, 04 October 2006 20:26 Go to previous message
Hi Marius,
I gave you the answer to that question with the subgrouppin and groupping
data (see the example from my previous message).
about the table:
see Birt documentation how you can use Java objects inside Birt reports
(for me I just use assign scripted objects to my report design file- there
is a method that do this). inside the report design file i use these
object.
Lets say we have a java object X inside the report design. This X object
is defined to store that structure you want to display. There is no
problem to populate this object the first time you call your querry
(inside the onFetch method assigned to your DataSet).
Now, how to populate a table with your object:
1.you define the column names
2.add scripting to your dataset
for "open" method (click your dataset in the data explorer, then click
script):
totalrows=X.getObjectList().size()
currentrow=0;
for "onFetch" method:
if(currentrow>=totalrows) return(false);
column "myColumn" value for row i= X.getObjectList().get(i).getElement();
currentrow++;
return(true);
Hope this helps you,
Cristian
Previous Topic:Getting empty reports
Next Topic:Need help with report structure
Current Time: Tue Jun 19 04:21:44 GMT 2018
Powered by FUDForum. Page generated in 0.02848 seconds
