Home » Language IDEs » PHP Development Tools (PDT) » Problem when debugging with "Web Script using XDebug"
Problem when debugging with "Web Script using XDebug" [message #18459] Tue, 08 May 2007 19:21 Go to next message
Ali B. is currently offline Ali B.Friend
Member
Hello everyone,
I have installed clean PDT-all-in-one 0.7 RC3 along with the XDebug
plugin 0.2.0. I have followed every inch of the XDebug plugin included
PDF instructions (V 1.04) to configure it.
Now my debugging with "PHP EXE script Xdebug" works like a *charm*. But
when I try to debug with "PHP Web Script using Xdebug", my browser
(tried internal, IE, FF) pop ups with an opened url and displays the
whole page. while eclipse gives me the "Xdebug waiting for session".
I made sure to run my apache run in the workspace folder using
Apache.exe -c "DocumentRoot "D:\eclipse\workspace"" and made sure my
correct php.ini file (the one that displays when running a phpinfo()
correctly.
below is my xdebug portion of my php.ini (Note: I am running a non-debug
build of PHP, and thread safety is enabled in my php.ini
[xdebug]
zend_extension_ts=D:\wamp\php\ext\php_xdebug.dll
xdebug.remote_enable=1
xdebug.remote_host=localhost
xdebug.remote_port=9000
xdebug.remote_handler=dbgp
I have tried with and without double quotes for the path, host and the
handler but with the same outcome.
I have also attached a screenshot of the PHP->Debug portion of eclipse
preferences, and also of the web xdebug config window.
The project name is test and I am debugging its index.php. When I debug
with web script using xdebug, I get something like the following url in
my broswer:
http://localhost/test/index.php?XDEBUG_SESSION_START=ECLIPSE _XDEBUG&KEY=11786513979533
Am I missing something here? Appreciate all the help, please let me know
if any more info is needed.
Ali
Re: (attachments added) Problem when debugging with "Web Script using XDebug" [message #18484 is a reply to message #18459] Tue, 08 May 2007 19:25 Go to previous messageGo to next message
Member
--------------090909070700050409090700
Sorry about forgetting to attach the screen shots, here they are.
Ali B. wrote:
> Hello everyone,
> correctly.
> [xdebug]
> my broswer:
> Cheers,
> Ali
Content-Type: image/jpeg;
name="debug_prefs.jpg"
Content-Disposition: inline;
filename="debug_prefs.jpg"
/9j/4AAQSkZJRgABAAEAYABgAAD//gAfTEVBRCBUZWNobm9sb2dpZXMgSW5j LiBWMS4wMQD/
2wCEAAgFBgcGBQgHBgcJCAgJDBQNDAsLDBgREg4UHRkeHhwZHBsgJC4nICIr IhscKDYoKy8x
MzQzHyY4PDgyPC4yMzEBCAkJDAoMFw0NFzEhHCExMTExMTExMTExMTExMTEx MTExMTExMTEx
MTExMTExMTExMTExMTExMTExMTExMTExMf/EAaIAAAEFAQEBAQEBAAAAAAAA AAABAgMEBQYH
CAkKCwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoLEAACAQMDAgQDBQUE BAAAAX0BAgMA
BBEFEiExQQYTUWEHInEUMoGRoQgjQrHBFVLR8CQzYnKCCQoWFxgZGiUmJygp KjQ1Njc4OTpD
REVGR0hJSlNUVVZXWFlaY2RlZmdoaWpzdHV2d3h5eoOEhYaHiImKkpOUlZaX mJmaoqOkpaan
qKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4eLj5OXm5+jp6vHy8/T1 9vf4+foRAAIB
AgQEAwQHBQQEAAECdwABAgMRBAUhMQYSQVEHYXETIjKBCBRCkaGxwQkjM1Lw FWJy0QoWJDTh
JfEXGBkaJicoKSo1Njc4OTpDREVGR0hJSlNUVVZXWFlaY2RlZmdoaWpzdHV2 d3h5eoKDhIWG
h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW 19jZ2uLj5OXm
5+jp6vLz9PX29/j5+v/AABEIAykCcQMBEQACEQEDEQH/2gAMAwEAAhEDEQA/ AOh1XXZtcvZJ
52drbfmCBuFRRnaSuSN2Ccnnqe2BX0lKgqEUlv1f9dDgqtyY2E24H/HtF/3y Kp83cx2JTJAP
+XaL/vkUrPuF/IYZrf8A59ov++adpdx/IPOt/wDn2i/75os+4B51v/z7Rf8A fNFn3APOt/8A
n2i/75os+4B51v8A8+0X/fNFn3APOt/+faL/AL5os+4B51v/AM+0X/fNFn3A POt/+faL/vmi
z7gHnW//AD7Rf980WfcA863/AOfaL/vmiz7gHnW//PtF/wB80WfcA863/wCf aL/vmiz7gHnW
/wDz7Rf980WfcA863/59ov8Avmiz7gHnW/8Az7Rf980WfcA863/59ov++aLP uAedb/8APtF/
3zRZ9wDzrf8A59ov++aLPuAedb/8+0X/AHzRZ9wDzrf/AJ9ov++aLPuAedb/ APPtF/3zRZ9w
Dzrf/n2i/wC+aLPuAedb/wDPtF/3zRZ9wE863/59ov8Avmi0u4fIPOt/+faL /vmi0u4fIPOt
/wDn2i/75otLuHyDzrf/AJ9ov++aLS7h8g863/59ov8Avmi0u4fIPOt/+faL /vmi0u4fIPOt
/wDn2i/75otLuHyDzrf/AJ9ov++aLS7h8g8+3/59ov8Avmi0u4fIPPt/+faL /vkUWl3D5B59
v/z7Rf8AfIotLuHyDz7f/n2i/wC+RRaXcPkHn2//AD7Rf98ii0u4fIPPt/8A n2i/75FFpdw+
Qefb/wDPtF/3yKLS7h8g8+3/AOfaL/vkUWl3D5B59v8A8+0X/fIotLuHyDz7 f/n2i/75FFpd
w+Qefb/8+0X/AHyKLS7h8g8+3/59ov8AvkUWl3D5B59v/wA+0X/fIotLuHyD z7f/AJ9ov++R
RaXcPkHn2/8Az7Rf98ii0u4fIPPt/wDn2i/75FFpdw+Qefb/APPtF/3yKLS7 h8g8+3/59ov+
+RRaXcPkHn2//PtF/wB8ii0u4fIdvgA5t4F+u0UWl3YxPNtx/wAsbb/vpf8A Gi0u7Cwgmtz9
23hb/dAP8qLSXVha3QlIiXhoLRD6NIgI/DNJc3S/4hb0GlrcdUsh/wBtY/8A Gnyz8/uYfcJv
h3KqW0L7vulMMD9COKWq3bCz7AyKDzBaD/trGP61l7emvtmyw9T+UjYRj/lj ZD6zR/40fWKf
84/q1X+V/cQxatdaNcifTyLaVSGKqcxyjnAYA4YYJ/PIIPNbOnCvH3tV/Wwo xlCXY6//AIWp
of8Az66j/wB+0/8Ai683+zK3dfj/AJHVzo4TSoi6RqOrYAr16r5bs5bczUUa 2vwGztYv7Ogu
JZP4yI2JrzqdWcm3J2N5UqUdEY2mXl5PJJFe2c8BUZV3iKhvbnvXZGSZy1IK Oxt21jFJaC4n
uGiBm8oBY93OM5PI4qZTalypdLkpKzbGS6bdRzyRCGSQxsVJRSRmmqsWk7jc WnYiFrcGISiC
Xy2OA+w4J+tVzRva+oraXLF5pkttJFCFlknddxQRHHTPB7+/FRCqpXfRDcbJ FdbO5Z2RbeUu
hAZQhyPrV88bXuKzAWlxsdxBLsjJDNsOFI659KOeO1wswNnciLzTbyiMDO/Y cY+tHPG9r6hZ
ifZp/J87yZPK/v7Tt/OnzK9r6hZitaXCKjNBKqycIShAb6etLmje1wtpcbNb zW7BZ4niYjID
qVOPxpqSlswaaGYpiDFABigAxQAYoAMUAGKADFABigAxQAYoAMUAGKADFACY oAMUAGKADFAB
igAxQAYoAMUAGKADFABigAxQAYoAMUAGKADFABigAxQAYoAMUAGKADFABigA xQAYoAMUAGKA
DFABigAxQAYoAMUAGKADFABigAxQAYoAMUAGKADFABigAxQBHcufMkHo5/nW kI6IbKcjmtlE
Rc0Af6aD/wBNY/5mufEbfJlxNbQodJurOefW7qa2ihMaI0QzksGPPyn+7Wdd 1oSUaKu3f9PN
dxQUWryZNdaf4SmtbldO1W8mu0gkkjjZSAxVC3OUHHHrUwqYyMlzwSV0vvdu 43GlZ8r1MPQP
lsmI7PP/AOilqsdtL0X6mmG1lH1NnTbCLWLaeK3n2amvzRQvgJKoHIB/vf59 SPnZM9r+G9di
pqmkppmjLLqczRajcENBaKBlU7tJ6Z7D/wCvths3hLmlaOy6mNcL/wAS61P/ AEzb/wBGPXvY
H+CeTiv4zMGvUOc6vSFKwwuOoANctVXujBy5JJroUfFFnrEjGXSYrSdXPMb2 8O5fxZcH865I
QcdGdE61N6p/mR+FdH1C08251YWizyDaqQW8abR7sqjPb2rdJLY5ZzT0R1lv PHBpojMccson
8wK4bAGOvBFZyi3O+ysJSSi0JLcGXTWR5CZ3uPMbtkbev50KFpqy0sPnun3L N1dwtAzQiINJ
AIipV9w9uu3HGQaiNN3s+9+n/DjU0kvSw43Vsby5JKlJoVQMwbGQBwcc447U uSXKvJgppNel
iOe7R7a6j3qGZIkTYrAMFPPXJ/OmoNSi/NsOdWt5DoryKO1t2XyhNAjJh1ck 5z0wcc55zSlT
bk10foEZpJeQi3MIniYyfKtn5LcH72DxTcJWenW4KaTj5f8ABIrl4ZTFOs23 ZEqGHac8dvTH
fr+FVFOLat13JbTitdkWbi+jE7PbSRJ50qOW2OWXHc5OOOnHWs403a0ltfsX Ka3XkUdUFvI8
bQbd5BMnl7gmcnoDyK2pc0bp7Ezkn6lPyq1uRcPKouFw8qi4XDyqLhcPKouF w8qi4XDyqLhc
PKouFw8qi4XDyqLhcPKouFw8qi4XDyqLhcPKouFxPJouFw8mi4XDyaLhcPJo uFw8mi4XDyaL
hcPJouFw8mi4XDyaLhcPJouFw8mi4XDyaLhcPJouFw8mi4XDyaLhcPJouFw8 mi4XDyaLhcPJ
ouFw8mi4XDyaLhcPJouFw8mi4XDyaLhcPJouFw8mi4XDyaLhcPJouFw8mi4X DyaLhcPJouFw
8mi4XDyaLhcPJouFw8mi4XDyaLhcPJouFw8mi4XDyaLhcPJouFw8mi4XDyaL hcqukZuphKSo
Dt0+tbK/KrFJq7uQ3MUIA8lifXNaQcupMmlsWfD0ebv6SR/zNY4nRfJlQf5j dLe2m0e4tZru
K2dpopFMquQQqyA/dU/3hW1WMo1VKMb6Pa3l3a7GcWnFpuw62hsrGSadtVtJ P9HmQJGk25ma
JlAGUA6sOpok6lRKKg1qu3Rp9yfdi783fv29CPQBnSpm9GuP/RS1yZjopei/ U68G/fh6mloN
7p2m28l/Mv2jUI2AtoGX5FOP9YT3x6f/AKx81c+gnCUnyrYZrmo2Os6Z9qus w6xDtQsifLcr
0ycdGA/z/dzbNaUJQlZfD+RlMmdKtW/6Zt/6MevocA/3KPGxjtXZzdeqYHa+ GtOv9Stsafb+
d5Srv+dVxnOOpHoa4a9WFJ++7GPs3N6G0PDmuj/lwH/f5P8AGub61Q/m/Bi9 hPsKfDmu/wDP
gP8Av6n+NH1qh/N+DD2E+ww+Gtd7WA/7/J/jT+t0P5vwYewl2D/hGte/58B/ 3+T/ABo+t0P5
vwYewkH/AAjWvf8APgP+/wAn+NH1uh/N+DD2Eg/4RrXv+fAf9/k/xo+t0P5v wYewkH/CNa9/
z4D/AL/J/jR9bofzfgw9hIP+Ea17/nwH/f5P8aPrdD+b8GHsJB/wjWvf8+A/ 7/J/jR9bofzf
gw9hIP8AhGte/wCfAf8Af5P8aPrdD+b8GHsJB/wjWvf8+A/7/J/jR9bofzfg w9hIP+Ea17/n
wH/f5P8AGj63Q/m/Bh7CQf8ACNa9/wA+A/7/ACf40fW6H834MPYSD/hGte/5 8B/3+T/Gj63Q
/m/Bh7CQf8I1r3/PgP8Av8n+NH1uh/N+DD2Eg/4RrXv+fAf9/k/xo+t0P5vw YewkH/CNa9/z
4D/v8n+NH1uh/N+DD2Eg/wCEa17/AJ8B/wB/k/xo+t0P5vwYewkRy6BrUJQS WIXeSq/vU5OC
fX0Bo+t0F9r8GP2Euw3+xNY/58x/39X/ABqfruH/AJvwf+QfV59g/sTWP+fM f9/V/wAaPruH
/m/B/wCQfV59g/sTWP8AnzH/AH9X/Gj67h/5vwf+QfV59g/sTWP+fMf9/V/x o+u4f+b8H/kH
1efYP7E1j/nzH/f1f8aPruH/AJvwf+QfV59g/sTWP+fMf9/V/wAaPruH/m/B /wCQfV59g/sT
WP8AnzH/AH9X/Gj67h/5vwf+QfV59g/sTWP+fP8A8ip/jR9dw/8AN+D/AMg+ rz7B/Ymsf8+f
/kVP8aPruH/m/B/5B9Xn2D+xNY/58/8AyKn+NH13D/zfg/8AIPq8+wf2JrH/ AD5/+RU/xo+u
4f8Am/B/5B9Xn2D+xNY/58//ACKn+NH13D/zfg/8g+rz7B/Ymsf8+f8A5FT/ ABo+u4f+b8H/
AJB9Xn2D+xNY/wCfP/yKn+NH13D/AM34P/IPq8+wf2JrH/Pn/wCRU/xo+u4f +b8H/kH1efYP
7E1j/nz/APIqf40fXcP/ADfg/wDIPq8+wf2JrH/Pn/5FT/Gj67h/5vwf+QfV 59g/sTWP+fP/
AMip/jR9dw/834P/ACD6vPsH9iax/wA+f/kVP8aPruH/AJvwf+QfV59g/sTW P+fP/wAip/jR
9dw/834P/IPq8+wf2JrH/Pn/AORU/wAaPruH/m/B/wCQfV59g/sTWP8Anz/8 ip/jR9dw/wDN
+D/yD6vPsH9iax/z5/8AkVP8aPruH/m/B/5B9Xn2D+xNY/58/wDyKn+NH13D /wA34P8AyD6v
PsH9iax/z5/+RU/xo+u4f+b8H/kH1efYP7E1j/nz/wDIqf40fXcP/N+D/wAg +rz7B/Ymsf8A
Pn/5FT/Gj67h/wCb8H/kH1efYP7E1j/nz/8AIqf40fXcP/N+D/yD6vPsH9ia x/z5/wDkVP8A
Gj67h/5vwf8AkH1efYP7E1j/AJ8//Iqf40fXcP8Azfg/8g+rz7B/Ymsf8+f/ AJFT/Gj67h/5
vwf+QfV59g/sTWP+fP8A8ip/jR9dw/8AN+D/AMg+rz7B/Ymsf8+f/kVP8aPr uH/m/B/5B9Xn
2D+xNY/58/8AyKn+NH13D/zfg/8AIPq8+wf2JrH/AD5/+RU/xo+u4f8Am/B/ 5B9Xn2D+xNY/
58//ACKn+NH13D/zfg/8g+rz7B/Ymsf8+f8A5FT/ABo+u4f+b8H/AJB9Xn2D +xNY/wCfP/yK
n+NH13D/AM34P/IPq8+wf2JrH/Pn/wCRU/xo+u4f+b8H/kH1efYP7E1j/nz/ APIqf40fXcP/
ADfg/wDIPq8+wf2JrH/Pn/5FT/Gj67h/5vwf+QfV59g/sTWP+fP/AMip/jR9 dw/834P/ACD6
vPsH9iax/wA+f/kVP8aPruH/AJvwf+QfV59g/sTWP+fP/wAip/jR9dw/834P /IPq8+wf2JrH
/Pn/AORU/wAaPruH/m/B/wCQfV59g/sTWP8Anz/8ip/jR9dw/wDN+D/yD6vP sH9iax/z5/8A
kVP8aPruH/m/B/5B9Xn2D+xNY/58/wDyKn+NH13D/wA34P8AyD6vPsH9iax/ z5/+RU/xo+u4
f+b8H/kH1efYY3h7UnYs+mqWPU+cBn8mprH0FtP8H/kP2E+w0+Gr/wD6Bi/9 /wAf/FU/7Qo/
z/h/wA9hLsPh0HVYDmCxEfOeJV6/iaTx2HlvL8H/AJB7CfREbeF7pmLHRYsn k4nI/QPgU/7Q
pL/l4/u/4AfV5fyiHwrcd9Fj/wDAlv8A4un/AGlTX/Lx/d/wBfVn/L/X3ksO g6pboI7fTkjj
GfkEikHPXOWJOfes5Y3DzvzSvfyf+RcaM4tNK1iP/hGr3tosQ/7eD/8AF1y3 wP8AN+f+R1+2
xPf8hp8MXv8A0BYv/Ag//F0f7D/N+f8AkNV8Suv5FTWNMv7CyD3VqsEI/doF dSB1OOCT616G
GrUJfu6T29TlmpuXNM4fzl9DXpgeu/CP/j2vv92L/wBnrw803j8/0Ko7s7Ke +aO6a3itJ7h1
RXYxlAACWA+8w/umvJUdL3Nm7O1hv264/wCgVef99Q//ABdHKu/5hd9g+3XH /QKvP++of/i6
OVd/zC77B9uuP+gVef8AfUP/AMXRyrv+YXfYPt1x/wBAq8/76h/+Lo5V3/ML vsH264/6BV5/
31D/APF0cq7/AJhd9g+3XH/QKvP++of/AIujlXf8wu+wfbrj/oFXn/fUP/xd HKu/5hd9g+3X
H/QKvP8AvqH/AOLo5V3/ADC77B9uuP8AoFXn/fUP/wAXRyrv+YXfYPt1x/0C rz/vqH/4ujlX
f8wu+wfbrj/oFXn/AH1D/wDF0cq7/mF32D7dcf8AQKvP++of/i6OVd/zC77B 9uuP+gVef99Q
/wDxdHKu/wCYXfYE1B/tEMU1jcwecxRWcxkZ2lv4WJ6Ke1HLpow5uli7UlBQ AUAUdU+/Z/8A
XVv/AEVJUy2GitWBQUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAU AFABQAUAFABQ
AUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAF ABQAUAFABQAU
AFAHNfEL/kBx/wDXYf8AoLV6uV/xn6fqjGtsjxqvqTA9k+Ef/Htff7sX/s9e Fmm8fn+hVHdn
YQ/8hu6/69of/Qpa8l/Cv67Gy+JmPa+KZRqeo29/plxBbW1/HZxXQ8vYd6pt 3fOW5ZxztHDL
3ziYe8o93f8ADm/RfeVL3W7dEn+X+d/JJkVx47tIluZY9K1Se3tIzNPPGkWy OHe6+Zy4LL+7
ZsKC2MHHNEPeUWtnbX1Sa/NenUpxd+VavXT03/HTz6XF07x/oeo+JTodrMGn LvEjieEh3QEs
vlhzKMbW5ZApxwTkZcIuSbXTX5f18yZe7b5fjsZ/iHxBq1t4x+yxR39vp1qt sDJDHbPFK0zs
v7zc3mBeABsAIO4kEYzCb5ZS9UvlG/39e3TuVJJKNvV/el/nf1G2PjuWxtBN rlrL9kh0y0uX
vQYUVpZcjBy4xubABwFHzFiBg1rUSUpJaWk0vuT/AFe/5kxTdvRt+Vr/ANaX NHRPHuna5Jbx
aXaXV1LMzq6wvBIsOwpuLSJIUwBKp+VmOMjGRilyv5b/AJ/qrfjtdpN2/r+v 6+RY1/xM+ia3
DBcWUr6d9imuri6TZiERlckguCQATkBSeVx3qE/iv0t+N/8ALTp3L5W+VR3b sUtM+I2i6haT
3UayLFaSRrcss9vMtuj5Cyu0UjKEyCDzkdSAOapqyTezuvmle3z6W66E90u1 /wCvTctw+Jrm
417TbS20m7NlfW8s3nN5alQroFcgyZ2kNnG0t8y8DkAineSelrfjfR+egSaS TWuv+Wq/r06X
6SkAUAFABQBS1D/j703/AK+T/wCipKqOz/rqS90XakoKACgCjqn37P8A66t/ 6KkqZbDRWrAo
5jxV4putG1/RdGsNNhvLjVzKEaa6MCR7FDckI5OQfSnBObkl0VxyXLDm87GR oXxNTVr7Q7Ma
S8Eup3FzbTBp8i3eEAnB2/ODkc8VcIKesXpyqS/ImT5FK+6lykVz8TpY4ZjB oqSSprv9jIr3
ZRWPaQkIcD2wfrSpwc+S32k39xU1yc/91J/edD4Q8UPr9zq1ldWP2G+0m58i dEl82NsjIZX2
rnODwQCKSSdNTjs7r5rchu03B9k/kzAPxJuY7fWNRl0JP7J0a/ayupo7wtMA CB5gj8sAjkcb
89etKNuWEpO3N+HqXOLUpQjq0rnQ3vjbw9YymOe/PyRxyyPHBJJHCkn3DI6q VjB6/MRxz0pu
LTs9NbfPsSneKktmrr072MVPiJbWXijxDY65JHb6dpv2byLiK3lk4kXJMjLu AGcAEgDnvTjG
8Ff4rtfdt/Xl5Mc9GuXVWubd3418PWa6q0+ohV0jyzeERSMIvM+50X5s5/hz UtNJSfVtfNbg
ld8q7X+W5Fqnj3w3pck6Xd+/+iojztFazSrAH+5vZFIQnsCQaahK9vO3z7CW trdVf5HRowdF
dTlWGQfak1Z2YJpq6FpDCgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoA KACgAoAKACgA
oAKACgAoAKACgAoAKACgAoAKACgAoAKAI55lhUEgszHaiL9529B/nAAJOACa ic1BXY4xcnYr
kahb3TF4JLqN41IEJjCxtltyjcVJGNvJ6nPToOZVZwk7q68rab97Pt/wNjXl i1pp95NbXAnD
gxvFJG2x43xlTgHsSOhB4PeuinUU1poZyjymRd+MNEs/EsPh24uZl1Wfb5Vu LSZt4IzuDBdp
Xg5bOBhskYONbO1yDdpDGqZHGY4XdckbgVHTg9TVqDFcAksMUZnOdyjJ4+Vu 4OOOvQ/h9SUb
aoEwdhGhZuAOvGagYkUiypuQ5X1xii1gOd+IX/IDj/67D/0Fq9XK/wCM/T9U Y1tkeNV9SYHs
nwj/AOPa+/3Yv/Z68LNN4/P9CqO7OqkvLW01u4+1XMMG+2h2+Y4XOGlzjNeX ytxVv62NbpS1
MTV7LTri11pbLXIFfVVGYpblPKik2qvmqQN4YBVON2MqMYOTWbpScVFrS6fo r3dvxavfXyL9
pFPm02a8n2v+T8irPomlz38sa+IY7TSHsYLNrO2nhAnRC+VcshYKVYD5GU8n 2rW0m3KSvrfy
2X6r028yedJK0tUt76+v/B3uaemwaZpl+8tn4mdLNpHk/s8zW5gDOSWIJTzB 8xJxvwCemOKl
RklZq/8AX9LXoJyj0dh+oW+g39zNcTarErzfZ9wW4jAHkuXXH1LHPt6VPs5W tbv+MeX8vxK5
49/6vcoS6H4faOOOPxBJAkdrDbYjuoufJO6KTJU4dSSeMA9GBHFXJTcnLzv6 Pr960ad1boJT
iklp1+5/1ddU+pf05NOtbuK7uvEp1G5ijkiWS5lt1O1yhIxGijgoMcdz14wK Mkmkt7fhf/MX
Mu43XLbQtZniluNYSILDLbyJFcxhZopMbkbOSPug5Uhhjg1Hs5a7/wDDbP1X T8blqolbVaO/
9eT6kAsdNmsWsdU8Vzapau6l4rmW1AkQZ/dtsjUlDxkHk4wTgkGnBy3j3/r5 brz+RKnGN+V9
Len9LT/g6klrZ6PaS6bJD4hcNpyPEha5ibzImIPlvkHIG1QCMN8vLHJy7Tcr tbrXz8/XfbTX
YHKNrJpa39PJeX9I2v7Y0z/oI2f/AH/X/Gp5Jdg549w/tjTP+gjZ/wDf9f8A Gjkl2Dnj3D+2
NM/6CNn/AN/1/wAaOSXYOePcP7Y0z/oI2f8A3/X/ABo5Jdg549yvcX9ndX+n Ja3cEzi4YlY5
AxA8qTniqUWk7oTkm1ZmrWZYUAFAFHVPv2f/AF1b/wBFSVMthorVgUch4x8I 3HiHxT4e1ATC
Kz00zfaAlxJDM29QBsZMEcjn5hx606doyk31Vhyd6fKu6ZT1f4c2VxrHhgWN jp66JpBn8+0n
Uv5m9Rg4IIY5GSWOe/NVCVpScu1l5ClrCy3buYjfC3URZSWcMthBbnxENTRI ZJItlvjGxSqg
q4HTGAPWqpz5fZ832U0/mE7Pn5eqVvkejaJoenaFBLDpdv5ImkaaV2kaR5XP VmdiWY+5JrO7
sl0Qra36nAnwF4ifT/EOi+dpsNhrupPdSXSzSNNFEzAlRHsALELjO/HJ60JJ wpwn9n8evy19
S5yfPKcN2ra/cSXHw2mtdR1T7HFFqWm6kkYNtcardWXl7U2bWEQYSqQB94Aj pTcnKLT7t/Nu
+3k/MzjGMGnHokvktNyG++H+vs3iK2s/7Kjs9dgtLfe1xLutliQK2E2Hf3xl x2yaqbVRcstu
Zy890/0HH3FGy2jb8CHXPhnrLQ+I7LR57CS01qC0jWS6mdJITAAPuqhDAgdc j6UpT51Z/wAz
l946aVNxt0jy/hYwvHVm2kWHijRbK8029udYmtf9EWdhepL8nyrFt+dTwQ2R jJ6kVdN884pb
c8n97u79rCgvZe/L+RL7k1p3Pb7VSltErDDKgBH4VnN3k2iaaagk+xJUlhQA UAFABQAUAFAB
QAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUA FABQAUAFAEVz
brcRhWLIyncjrwyN6j/OCCQcgkVE6amrMqMnF3RQji1S4u5VuLmW1ijRAjQC MrK2W3NhgxHG
3g9Dnr1PDDDTcmpvTpaxvKpBJcqLtpbC1V/3jyySNvkkfG5zgDsAOgA4A6V2 U6apqyMJzcmP
aCJrhLhokM0asiyFRuVWILAHqASq5HfaPStSSSgCLySCdk0iAknaMY569RVc whlukpRTcsSV
A+U45Pqcf5/oN9gLFSMQAAAAYA6AUAc38Qv+QHH/ANdh/wCgtXq5X/Gfp+qM a2yPGq+pMD2T
4R/8e19/uxf+z14Wabx+f6FUd2d7XjnQFABQAUAFABQAUAFABQAUAFABQAUA FABQAUAFABQB
R1T79n/11b/0VJUy2GitWBQUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUA FABQAUAFABQA
UAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFA BQAUAFABQAUA
FABQAUAFAHNfEL/kBx/9dh/6C1erlf8AGfp+qMa2yPGq+pMD2T4R/wDHtff7 sX/s9eFmm8fn
+hVHdne1450GVrOs/wBlx3kzpCLextvtVxLLIy7U+ckgKjE4CE/41SStdktu 9kWbG8lmuZre
4ijjkiVH/dylwQxYdSo5+U/pQ0rXQJu9mUdU1a/TU/7N0TT4Ly5jiWeZrm5a 3ijRiQo3Kjks
SrcYxgHJHGYV3drZfn/W/qt9bW9Lef8AX/DfPsKfEthDdRWd4ZYLtggkVYZJ IoZGAIjaZV2K
3IwCQTlcDkZbtq1sr/h+fyv1FZpK/wDXT7vMhtfGmg3UTyw3cvlrEsys1rMg mQkAGLKjzcll
GEycsB1IFFnr5f8AB/DRu+1tdgtry+v4b/d17EkHizR55reCOa4+0XLMqQNZ zLKCpUHchTcg
G9SSwAwwPTmmld2X9b/5Neum7QPRXIL7xXbB/IsVmW6S5hiaO7s5oAyPMsbM hdV3gbuqkjke
oyQXO12/+1bX5fmKT5brr/lb/M6KkMKACgAoAKACgAoAKACgAoAo6sAzWgYB gZWBBGQf3Una
pkNFH7La/wDPna/9+E/wrG4w+y2v/Pna/wDfhP8ACi4B9ltf+fO1/wC/Cf4U XAPstr/z52v/
AH4T/Ci4B9ltf+fO1/78J/hRcA+y2v8Az52v/fhP8KLgH2W1/wCfO1/78J/h RcA+y2v/AD52
v/fhP8KLgH2W1/587X/vwn+FFwD7La/8+dr/AN+E/wAKLgH2W1/587X/AL8J /hRcA+y2v/Pn
a/8AfhP8KLgH2W1/587X/vwn+FFwD7La/wDPna/9+E/wouAfZbX/AJ87X/vw n+FFwD7La/8A
Pna/9+E/wouAfZbX/nztf+/Cf4UXAPstr/z52v8A34T/AAouAfZbX/nztf8A vwn+FFwD7La/
8+dr/wB+E/wouAfZbX/nztf+/Cf4UXAPstr/AM+dr/34T/Ci4B9ltf8Anztf +/Cf4UXAPstr
/wA+dr/34T/Ci4B9ltf+fO1/78J/hRcA+y2v/Pna/wDfhP8ACi4B9ltf+fO1 /wC/Cf4UXAPs
tr/z52v/AH4T/Ci4B9ltf+fO1/78J/hRcA+y2v8Az52v/fhP8KLgH2W1/wCf O1/78J/hRcA+
y2v/AD52v/fhP8KLgH2W1/587X/vwn+FFwD7La/8+dr/AN+E/wAKLgH2W1/5 87X/AL8J/hRc
A+y2v/Pna/8AfhP8KLgH2W1/587X/vwn+FFwD7La/wDPna/9+E/wouAfZbX/ AJ87X/vwn+FF
wD7La/8APna/9+E/wouAfZbX/nztf+/Cf4UXAPstr/z52v8A34T/AAouAfZb X/nztf8Avwn+
FFwD7La/8+dr/wB+E/wouAfZbX/nztf+/Cf4UXAPstr/AM+dr/34T/Ci4B9l tf8Anztf+/Cf
4UXAPstr/wA+dr/34T/Ci4B9ltf+fO1/78J/hRcA+y2v/Pna/wDfhP8ACi4B 9ltf+fO1/wC/
Cf4UXAPstr/z52v/AH4T/Ci4B9ltf+fO1/78J/hRcA+y2v8Az52v/fhP8KLg H2W1/wCfO1/7
8J/hRcA+y2v/AD52v/fhP8KLgH2W1/587X/vwn+FFwOc8fwQx6IhighjPnAZ SNVP3W9BXqZW
/wB8/T9UZVtkeO19SYHsnwj/AOPa+/3Yv/Z68LNN4/P9CqO7O9rxzoOU8deF h4jtLq3ngtJ7
ae3EZ85dzwsBIA8fyNhwJDggZFVpaxOqd0XPDXh5dKimiktLCGAqqxW9rGBG gy5OBtAGfMPQ
dz60tLWGr3uN8SeG5dUmlms7izjNzALe6gv7P7XBMiksuU3phgWPOcc8g4BG co3Tj0evo+6/
rotutqVrPtf8e/8AXfuZFp8Obey1KC5gGj3CosIZ73SVmuFaNFQGKUOuzhAQ CGwckelaTfNz
dL39dfz/AMtCVoort933dP68729U8DRajpFjYTXUbCysltV8y2EiSMrxOGZC cFcxAFe4Y8jr
TnLmm592n91/8/kOPuq3r+JY8OeExo9xHOP7Ltykc0Zj0vTvscbbzGd23e3z Dy8ZzzkdMcpu
8XHXW3ytfb7ybap9jJ0z4c/Yr6K6a8sRLEU3SQaf5Utxtljk3TSGRjI58sgs cfeJx6uEuX/g
aLaS0X/b34BNc7fz9df+G8ju6kYUAFABQAUAFABQAUAFABQBR1T79n/11b/0 VJUy2GitWBQU
AFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFAB QAUAFABQAUAF
ABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFAHNf EL/kBx/9dh/6
C1erlf8AGfp+qMa2yPGq+pMD2T4R/wDHtff7sX/s9eFmm8fn+hVHdne1450G Pr+qixtr8ypC
LW0tDcXMsrkbI8PkhQjbsBCcY/A1Vla7Ju72RcsbyWa5mt7iKOOSJUf93KXB DFh1Kjn5T+lD
StdAm72ZQ8U+IV8Ppasbc3Alk/e4fb5MI+/KeDkLkce/UVMdZqHf9WkvvbXy u+hUtIOXb/Jv
8k/yHy+KNIi1Q6c1xL9oWZYGItpTGkjAFVaQLsUkMuMkZzgc0R97bz/C9/mr bb/egl7qu/6v
sO8M69Dr9pNPDb3EHkzyQss0MkedrsuQXVd2cZ4zg8HkULWMZd0n96v/AF3B 6ScexrUAFABQ
AUAFABQAUAFABQAUAFABQBR1T79n/wBdW/8ARUlTLYaK1YFBQAUAFABQAUAF ABQAUAFABQAU
AFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAUNZ1FtOghE Fv8Aabm5lEME
W8IGcgnlj0ACsSQCcA4BPFa0qfO97Jav0/rRefYT0TZUk186ZbqfEMC2lw7M I4rIyXm9QASw
CxhsDOCSoA455FWqKm7Unddb2jb73b8QXN1X9f5/oPHifSDeLapdM7s6x70h kaMMwVlBkC7R
uDLjJ5zxS+rVbXt37X0vfTfSzuTzxsn00/HYxtG8aLc3d7LfutrZR+aYo5LG 4ilASQRg7mG2
QsSPlUBgSFwT06KmE5YR5dZO3VNaq+26t32er0RTdpuK2X6LXXbv+Zu6br+n ajK0VtJMsq7y
0c1tJC67ducq6gj76/XPFc1ShOmuZ7eTT79vRiTTdiKLxTo8ySPDcu6RIruy 28hA3BSq52/e
YOuF+8c8A81Tw1WOjXluul7/AHWd3suo076Dp9ft/wCwb3VLNHm+yRuzQzI8 D7lXO1lddy54
6joQeaSoSVSNN9Wuz3dugJp/IpxeKVtLmWz16COzu12FEtHkuxIHDkAYjVt3 7t/l29MYJzWn
1bnSlSd1rvZbW82rarW/cnm7/wBf1+Oy1LbeJtLF1PbLLM8sAfOy2lZWKDLK rBSHYd1UluDx
waz9hU5VPp6r7/JeexV0mk/60v8AfbWw208TabObVDK3mXCRndHDK0KM6gqr SbAqk5GA20nc
vHIqpYacXLyv1V9N9L6/K637C5vdT7kF/wCLrC2tWuIIry5RJ44SyWc+xt7h dyMEIkA5Py5z
wO4pwws5SSdldN7rtfVX0+Y5O1/Im1vXZLCfT7azgt3uL/d5X2y4NsnG35c7 GO87hhdueG6Y
qaVHn5m3pHsrv81p3d+3cG0o83ovv/r7xV8TaclylpdPJBdb0ilXyZGjilYK QjShdgJ3ADJ5
yMUfV5tc0dVrbbVK+tt+gm+Ve9/X9dx0XifSZEmdbiRUhTzN728irKucboyV xKMkAbN2dy+o
ynh6itpvpuvxXT526lbS5f60318jN1rxgltp80tjBO0u6CONZbK43qZJCm5o tgbaNpIwctjH
GRnalhXKaUmuvVdFfe+/5b9xXVm+y/4b8S1pfia2ks7MXUjz3U5YYtbG442u U3Mm0tEMj+Pg
EEZOM1E8O+Z8uiVt2uqvvs/l9xKlZXf9fLf+vMfquu3FtrUWlWFpbT3DQ+ft uLvyGkXJGIht
bew2kkHaBleeeFSoxlBzk2knbRXt5vVWX56lTfKl3d7fL+vzLB8Q6d9rltUk maWPeMi3k8t2
UEsivt2swwcqpJ4PHBrN0ZqHP09Vf1tvbz2Ha0lFmPH46tWtrKY2d1ELqye6 zJbThIyu3gkR
n5fmPz4xwOuRXU8FJTlG60aW663899NiFPRP1NSPxTo7ztD9rKbPMBkeGRIg Y87x5hULkbWJ
Gc4BPSud4eoo81u3a+trab9V89Ck9Uur0+ZGni7R2RmEl4GBUCJrC4WR9wYr sQpucYVjlQeF
JqnhaqdtOvVdO+um637i5ka9rcR3VtFcQMWilQOhKlSQRkcHkfQ1hKLg3F9B p3JakYUAc18Q
v+QHH/12H/oLV6uV/wAZ+n6oxrbI8ar6kwPZPhH/AMe19/uxf+z14Wabx+f6 FUd2d7XjnQcp
468LDxHaXVvPBaT209uIz5y7nhYCQB4/kbDgSHBAyKrS1idU7oueGvDy6VFN FJaWEMBVVit7
WMCNBlycDaAM+Yeg7n1paWsNXvcTX/CNl4gv3n1We7aH7KbZIILmW3ADEl9x RhvDfKMHj5e+
ajl0lZ6u3yttp6v8vnak04tdCKw8LTW+mG1udS+0TNd29083k7dxiEQxjcfv eV1zxu74rZzv
JSttzfjzf5maiknFbWt9xpaDpk+lRXMEl0lxA9xJNCBDseMO5cqx3ENyxwQF 4x161mvhSfTT
5LRfPv37Ip/E2uv9M06ACgAoAKACgAoAKACgAoAKACgAoAo6p9+z/wCurf8A oqSplsNFasCg
oAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKA CgAoAKACgAoA
KAMXxZDdSWNvJp0F1LeW9wJYTbiI7G2sCWWR0DIQSpAYH5uMdR04eSUmpNJN a3v+ievVenyE
9mjnbh/FczR3X9m3q38ayRBxa2nk+U4XI2fa924FAc7+549OpRwyvHmXK7dZ Xur9eTz7CTkt
Wttv6v8A5dPO5Y2V5YaZ9gt/DutCFbm3mQs1mSBEIgFP+kc58rr79OKc5xnN Tc4397+b7XN/
d8yEnZp9SO60/U5UjMeh6xHLC00kTf6GQHe4WZSR9p5AKAEZGQeopwnCP249 F9rpFxf2eqfy
8ymr3uu/4/5fiQ20HiqO+nv30m7S8llkDMkFsY2idIgcIbvKuDEOdzDk8HPD l9XcPZqStbvK
97ye/Jtr2/4KTlzXt6fd117j49KvR4buNHm8PatMJWhcPItky7o0jUbkNxhl JiBI44JHvRKp
B1VVU0rX/m6tv+Xz/UILlun1Vixa21/D4avtIPhKa2F4rqx0+1s7eMbl25Mf 2psn3zzxUzlC
VWNT2t7W3cns778qHG8W3b+vvLUUb2jWI0zwZqFhDaTtOYrdbJFcmNk6CcYP zZz7Vm3zcznV
Tura83dP+XyElZWSKkUGsR6hHI+harJZW0811bW+20WRJZAwO6T7ThlHmPgb QeRknHNP2fs3
FTXM0o3961lbpy76Lr8irvm8rpv+vXX/AIGhm6ZoN/aXNpdS+ETNKiQecbi0 s55VeNFU+VN9
pUqPlBGVODk+1dFStCSlFVbJ3tZyWjbeq5Xff7tCLSstNfvNFU8RLpP9mnSN Q8m3aJrJhBa7
o/LcMok/0vDj5QDgJ36Vi3R5/ac6vrf4tbqzt7mm/mV3SWj/AK/Au61e+Ib6 1WC38P3aI8bR
3EV1bWk8UwOP4ftSkd+CSMHmsqdOhFtua8rOSa+fI/yGm0vP+v63Maz03XIV ksJND1E6R58E
gixamd/KSMLmT7SAMtEMjaeO4zx0zqUZe/zrm97+a2rfTl10fda/jKvHSOml unzt27eQzTdB
vdOgkhtvCrxFFUW9zDYWUdwGR1dDK4usSDKjcAFz7VU68ZtN1PVXlbZp2XLp vpq7A1dvTR39
fv8AL/hzS267cSyT6joeoyTyNbEmCK1jTEMpkHBumPOcdff2rBexhZQmre9v zdY2/kQO73/r
W/cS0TXtOvDcabouop5zN9oWeK1kDqZXkAXF0u0jzGGTkHg4ofsZR5ZzWlrW 5lskv5HvZDd7
3S11JPEja5rUb2n9gXy6fMgWWGaCzlcEEndG/wBqG1umCQ2CARSoKlRanzq6 d1ZyXyfuvT7t
2gbbVrffZr7ippumXen65JfReEJHR5ZJRI9nZfa1L5JHni56ZY9VzjjPernO M6Ps3V6Jbytp
5cv676g78ykl9+v6jJdP16TTLazGk6kDBaS2Jcw2nzwuFA4+1cONg+boeflH alUpKo5uS1af
2t03/d21238xa2sl1dvR9CxeWN7d6XHYS+H9bVFmuJWZGswxEolGB/pHBHm9 ec46c1nGUYT5
1ON7Jfa6cv8Ad8hrs11KVzZ+KL6eeTUNDeaRhCIpDaW2F2eZyF+2blcGQEOr gjHQVrGWHgko
Ttv1l1t15NtNU0yY8y06W/Xquq2+f47MNz4it7CS2h0zXM/Y0ghll+xSNHKA wMpJuMuTleD/
AHevJrCUaEpczlHe/wBpaaafDp11XfyLi7Wuv6+/oaum6hqs+rsLrSNStrSS NVXzvsuyJhuL
MSkrMd2VGMcY9zWE6dOMNJJu/wDe2001SWmrBX0RuVylHNfEL/kBx/8AXYf+ gtXq5X/Gfp+q
Ma2yPGq+pMD2T4R/8e19/uxf+z14Wabx+f6FUd2d7XjnQY+v6qLG2vzKkItb S0NxcyyuRsjw
+SFCNuwEJxj8DVWVrsm7vZFyxvJZrma3uIo45IlR/wB3KXBDFh1Kjn5T+lDS tdAm72Zl6prW
rw6xcWelaPb30drbxzyl70wyNvLjai+WVJ+Q/edRkjkdazvaLk9k7fgn+pdt kt3939fInh8U
6XK9iitdKL+NJIJTZzeSd4yoMu3YCemC2ckDuK0cWpOHVfprp307Et2V3p+m ttfnoVLDxpYX
GmyXs1pqcSR3EkBCabdSn5GYbvlj6ELknoDwTkVF1yxl3V/wT/XfqVZ8ziun 9f1/wToYJo7i
COeB1kilUOjqchlIyCKqUXFtPdExkpJSWzH0hhQAUAFABQAUAFABQAUAFABQ BR1T79n/ANdW
/wDRUlTLYaK1YFBQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAU AFABQAUAFABQ
Ac18Qv8AkBx/9dh/6C1erlf8Z+n6oxrbI8ar6kwPZPhH/wAe19/uxf8As9eF mm8fn+hVHdne
1450HKeOvCw8R2l1bzwWk9tPbiM+cu54WAkAeP5Gw4EhwQMiq0tYnVO6Lnhr w8ulRTRSWlhD
AVVYre1jAjQZcnA2gDPmHoO59aWlrDV73DUdF1aTWp73S9Wt7KK6gjgmV7Iy yqFLndG/mBVP
zn7yMMgcHpU2vFwls3f8Ev0LvZppar7v6+ZkP8PIRq1tcwzWYgtJLd4DNZeb cwrFsxGkxf5E
O08BerMc81pGbU3N+e2m6a172vp5JL1ia5o8rf8AV739X1/4ay6j4EnvQIZr 7T7q0jnnljt7
7TTOiiV95JXzApkUlgr44DEYOSTjytxs+1r9bLa3Z2376bWs9ObVtd7/AOd/ Lrb/AIFup0Sw
/srRrLTxJ5v2SBId+3bu2qBnHbp0rapPnm5dzKEeSKiXKgoKACgAoAKACgAo AKACgAoAKAKO
qffs/wDrq3/oqSplsNFasCgoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoA KACgAoAKACgA
KACgAoAKAOa+IX/IDj/67D/0Fq9XK/4z9P1RjW2R41X1JgeyfCP/AI9r7/di /wDZ68LNN4/P
9CqO7O9rxzoMfX9VFjbX5lSEWtpaG4uZZXI2R4fJChG3YCE4x+BqrK12Td3s i5Y3ks1zNb3E
UcckSo/7uUuCGLDqVHPyn9KGla6BN3szM1Pxho+kaxcadq+oWOnNFbxzxtdX aRGbcXBADY6b
Bzz1rNytFtbrp8k/1NOXVdmMsvGOm3NtZljJHPdQxyYWGSSKJ3QMsbzBdisd wwGIJ3LxyM3W
i6fMl0v87fn8vMmGqTez/wA7XItG8baXdW1gl5O0d5cLCsuy1l8mOaRFYIZN pRSd64BbJyBy
auUP3jjHz/C9/wAmK9o3Z09ZjCgAoAKACgAoAKACgAoAKACgAoAo6p9+z/66 t/6KkqZbDRWr
AoKACgAoAzb/AFc2d21umn3l15cSyyPAEIRSWA4LBiflPCgmuqlhvaQ5nNK7 sr38vK3Xq0ZS
qcr5Um/u/wAyYatp5khiW9t/OuEEkMRlAeRSMghepHFR9XqpN8rstG7aIpVI O2u+xDpOuWGo
2kcqXVsspSMyQiZWaJnxhT75OOnNXXwlWjNxcXbWztvbqTCrGS31LF3qdhZI z3l7bW6I/ls0
sqoA2M7Tk9cc4rOFCrUdoRb66IuU4xV27DbvUre2tIrhc3AnKrAsGGMxPIC8 45HOc4xyTinT
oSnNwelt79PX+ric4qPMtUQRa7aBZf7QzpkkJG9Lx0TAIJBDBipBwehPQ+la SwlTT2fvp/y3
f4WT/AlVF9rT1G3XiPS7aSFGu4GNxC00RE0YWQLjgEsBk547cHninDBVpptR ejSej0v8gdaE
ba73/AtHU7BbiW3a+tlnhTzJIjKu6NePmIzkDkc+9Y+wq8qkouz0Ts9WVzxT tfUZ/bOl/Z5b
j+0rPyYW2SSeeu1G9Cc4B9qr6tX5lHkd3srPUXtIau6038i5FJHNEksLrJG4 DK6nIYHoQfSs
JRcW01ZotNSV1sOpDCgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKAC gAoAKACgAoAK
ACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKAOa+IX/IDj/wCuw/8A QWr1cr/jP0/V
GNbZHjVfUmB7J8I/+Pa+/wB2L/2evCzTePz/AEKo7s72vHOg5Tx14WHiO0ur eeC0ntp7cRnz
l3PCwEgDx/I2HAkOCBkVWlrE6p3Rc8NeHl0qKaKS0sIYCqrFb2sYEaDLk4G0 AZ8w9B3PrS0t
Yave5oJpu3Vr2+87/j6t44dm37uwuc5zznf+lRKN6cod7/ikv0KTtJPt/mcr ZfDqGy1CC5T+
x7kosO+S80lZbhWjRUzFLvBThAQCGwcnPark+bm6Xv66/n/loLovL7t/6/q9 zR/B2qQ+bp93
fW40iO5t5Qgtj50/kxw7WEnmEIpeMZUoTgHnkGr57tTe6cmvK7e/fR36dPO6 atdR6q3+f4aH
c1mMKACgAoAKACgAoAKACgAoAKACgCjqn37P/rq3/oqSplsNFasCgoAKAIgi ySOXG7acAHoO
AaBGdd2+pxarJcadFZtHNbxxFppWUxlWc5ChTuHzjjcvTqOtdlOdF0lCo3dN vRLW6XW+m3Zm
TUlPmik/w/RmVD4WktLtFjQXVrmFtz380JQoqrny1BR/uA849O1dcsepwd9J a/Zi923u9Vvb
S/czdF8ye+19WvwX3iReHtTNvZiVLKGXToEihWOVmWYq8bncdg2j93jgN94n ty5YyipStdqb
bei0umtNXffy2J9jNpJ20vb8Pu213/DVt5DqWmXp1aW2hnnleQC3hE0qoGSM Z3JExyDHjlQC
G6iqpyo1oewi2kravlWzfRyS69+hUlOMvaNddte1uib6durNODTbsaFpKxiO O9sEjcRyH5Cw
QqyEjOOGPIBwcHB6VySrU/b1G/hlfbfe6f8AwBwjJ0YrZ6P5/wBafiUr6x1V tTs9Ra1tZLoz
KogWV/LjRY5eWk2ZyS5/hHYe9b06tBU5UlJqNt7K7bcdlfy792E4zdm1rfb/ AINvToJP4ev/
ALFsgNqZZ4rpJkZ2VYzMwf5SFOQCMcgZ68dKI4ylz3leycbbXfKra66X+dtt dwdOVr6Xd/x/
X89dhL7w5f3MMtoDaLAHuJo5t7b3aVXG1l24AG885Odo49HTxtKDU9b+6mui 5WtU7+W1lvuK
VKWyt3v12a/p9tLFnVtEuZb03VnFAWVYRFmd4GjZBKNwZVb++OCCCMgisqGK hGHJNvrfRO9+
Xu123TTWlmVKk9LLol22Zr2Fs8Nhbw3RjmljjCswQAE45IAAA/AD6VxVZRlU coqybNYJqPvb
k/kxf880/wC+RWRYeTF/zzT/AL5FAB5MX/PNP++RQAeTF/zzT/vkUAHkxf8A PNP++RQAeTF/
zzT/AL5FAB5MX/PNP++RQAeTF/zzT/vkUAHkxf8APNP++RQAeTF/zzT/AL5F AB5MX/PNP++R
QAeTF/zzT/vkUAHkxf8APNP++RQAeTF/zzT/AL5FAB5MX/PNP++RQAeTF/zz T/vkUAHkxf8A
PNP++RQAeTF/zzT/AL5FAB5MX/PNP++RQAeTF/zzT/vkUAHkxf8APNP++RQA eTF/zzT/AL5F
AB5MX/PNP++RQAeTF/zzT/vkUAHkxf8APNP++RQAeTF/zzT/AL5FAB5MX/PN P++RQAeTF/zz
T/vkUAHkxf8APNP++RQAeTF/zzT/AL5FAB5MX/PNP++RQAeTF/zzT/vkUAHk xf8APNP++RQA
eTF/zzT/AL5FAB5MX/PNP++RQAeTF/zzT/vkUAHkxf8APNP++RQAeTF/zzT/ AL5FAB5MX/PN
P++RQAeTF/zzT/vkUAIYIyMBFU+qjBFADoiWiRj1KgmgB1AHNfEL/kBx/wDX Yf8AoLV6uV/x
n6fqjGtsjxqvqTA9k+Ef/Htff7sX/s9eFmm8fn+hVHdne1450GPr+qixtr8y pCLW0tDcXMsr
kbI8PkhQjbsBCcY/A1Vla7Ju72RcsbyWa5mt7iKOOSJUf93KXBDFh1Kjn5T+ lDStdAm72Zna
x4gl0nWo4Lm3tk0wWct3PePcMHiWPAbEYjO77y/xDv6DMxt719LW/H8tn/W1 tPTl3Yn/AAmW
iCN28663pIsfk/YZ/OcsCQUj2b3BCsdygjCk54NCva9v6037brfuL/h/vdvz GQeMLGXU7i0S
3vnjis4rtZo7Kdw6vuOMBOuFHHUkkYypo6N9nb8vv36dNdg7ef6X/wAv0Kd9 4x3XtgmlKHhn
cJKLm3kiljbz4YyCjbWU7ZSeR/dPTrUI3lZ7f8Cf6xt94pNKLa3X/Af6l+z1 +S48X3WkCFDb
wxEiUEhvMURlgexGJk6dCD17KCvFyfR6ea1X5pocvdaS/r+lZ/Mrp450iJJP t7y20kTuJAkE
syxIsrxiR3VCqKfLY5YgDue9EVzctutvvaTt+K9RtON/K/4D7jxbaHXbPTbA yT77iSK4kFrK
Y12RuxVZQuxnDKAVBJ6jGRwo6pvok39zS+fXYUtEvO34/l8xt94106305ruG C/l8u5hgkhew
uI5k8xgA3lmPeRjOMLgkYBzR1j53/BX/AK9bh38lf8bF+08SaZd6gLGCWfzi Sqs9rKkbMv3k
EjKELDByoORtbI4OGovXy/q/mvNaA9LX/q/5fM1qQBQAUAFABQAUAUdU+/Z/ 9dW/9FSVMtho
rVgUFABQAyP78n+9/QUAPoAKACgAoAKACgAoAKACgAoAKACgAoAKACgCK6la GIGNA7s6Iqs2
0ZZgvJwfX0q4R5nYmTsh/wBm1P8A597P/wACW/8AiK09nHv+H/BJ5pdv6+4P s2p/8+9n/wCB
Lf8AxFHs49/w/wCCHNLt/X3B9m1P/n3s/wDwJb/4ij2ce/4f8EOaXb+vuD7N qf8Az72f/gS3
/wARR7OPf8P+CHNLt/X3B9m1P/n3s/8AwJb/AOIo9nHv+H/BDml2/r7g+zan /wA+9n/4Et/8
RR7OPf8AD/ghzS7f19wfZtT/AOfez/8AAlv/AIij2ce/4f8ABDml2/r7g+za n/z72f8A4Et/
8RR7OPf8P+CHNLt/X3B9m1P/AJ97P/wJb/4ij2ce/wCH/BDml2/r7g+zan/z 72f/AIEt/wDE
Uezj3/D/AIIc0u39fcH2bU/+fez/APAlv/iKPZx7/h/wQ5pdv6+4Ps2p/wDP vZ/+BLf/ABFH
s49/w/4Ic0u39fcH2bU/+fez/wDAlv8A4ij2ce/4f8EOaXb+vuD7Nqf/AD72 f/gS3/xFHs49
/wAP+CHNLt/X3B9m1P8A597P/wACW/8AiKPZx7/h/wAEOaXb+vuD7Nqf/PvZ /wDgS3/xFHs4
9/w/4Ic0u39fcH2bU/8An3s//Alv/iKPZx7/AIf8EOaXb+vuD7Nqf/PvZ/8A gS3/AMRR7OPf
8P8AghzS7f19xBJJeRMVeK0BHpNIf/adaLDX2f5f5kuo1/X/AACP7XODgraD 6yyD/wBp1X1R
/wBW/wAw9r/X9IsWsrSxEyIEdXdGVW3DKsV4OB6elcs48rsaRd0S1BQUAFAB QBRbWtKXU/7M
bU7MX/8Az6mdfN6bvuZz056dOa19jU5Pacr5e9tPvFe2hLLqFlDbJczXlvHb uu5JWlUIw2ls
g5wRtBP0GalQlfltr/S/Ma12E03U9P1WBptLvra9iVtjPbyrIobGcEqTzyPz p1KU6TtOLXro
JNPYbZ6tpt7dT2tlqFpcXFucTRRTK7xnOPmAORz60SpTjFScWk+tgbSdupcr MYUAFABQAUAF
ADIP9RH/ALo/lQA+gDmviF/yA4/+uw/9BavVyv8AjP0/VGNbZHjVfUmB7J8I /wDj2vv92L/2
evCzTePz/Qqjuzva8c6DlPHXhYeI7S6t54LSe2ntxGfOXc8LASAPH8jYcCQ4 IGRVaWsTqndF
zw14eXSopopLSwhgKqsVvaxgRoMuTgbQBnzD0Hc+tLS1hq97kfiTw5e6zfmS PUbe3tXsZrN4
mtGeT95jLB/MAGCq8bT355GCD5W2+8X/AOAu/wDn/W9N6K3n+JH4j8KS6rdS 3EF1Zo7iEAXV
mZhGY/Nw6lZEZHzJkMrArt9+J1W3d/ikv0+dwi7JLyt+N9V1XkQX3g27ngaC LWd0ctnBbT/a
4GmMxiYsCxEillbcwdTncD1HOak7t6K177ddE79NlporPXVaAnZLvr+PbtZ/ hpvqVtM+Hq2E
qSJd2kIWcT+TZ2AghB3wMQqBztH7j1P3++OajPkt1t/9v/8AJfgQ43v5/wDA /wAi5ZaBqq21
nf2t1Bp+rfv2nW5g+0x4mcOykK68qVUAhscHrwREU4RUV2V/XVtr1bb+fQuV m5X76emy/BIo
/wDCHar9pv7JNQgj02+tFhvJXtd0k5aSZpfLxIBH/rDjcr4yOuDmo2Ss9k1Z eiild/LXRddr
qwnKLUk/e11879vL5+Zam8GXrj7LHrfkafFLPLbpFblZ4mlSQHMu/nBkJGFB wMEnrUttrXe1
vLdPVddrPVX1BWi1bbR/crf8H18tCDTvAL2Frei1udMs7i4a2kT7DpnkQI8M hcFo/MJbOQD8
wPHBHauZpK3Rt+Wqs1bTp+P3E21bfa3n63LOh+CY9J8QNqSposu+WSYynSQt 4HkyWxOH6ZY4
ypO3gk9aUHyR5Vta3/D9/wAL7jneTu/K/wDwO34nW0gCgAoAKACgAoAo6p9+ z/66t/6KkqZb
DRWrAoKACgBkf35P97+goA5rU9W1m0n1e9iksG03SnHmWzQOJnQRJI5EofAI 3HA2c4AyM5Gv
Ik4X+1+F3YEnN8sd/wCvuGxePtIuNZm0q0DT3UfmqipNBmWSMEsgTzN6n5W5 ZVXjrggnJp+z
c10V/l/Xz8hq10n1t+P9dDM0vxs2k6Lp954oF6smpgSjz5rKNYgQpPlqJA7J 83Aw7+vOK2dN
e09lHf8AHtrb/htd+2cpWUqnTX7t/wAvyNnX/EqQeHZrqy82OaT7RDAxVTtk iWQkkEkY/dnH
XtxWcI3lFd+V/JuP+Ze1/It6Jq91f6lqtrPYSwxWU4jjnJTbINiNjhyc/Nno Bgjvmlb3FLrr
p82v0JvZ28kYtl4wktbS5vvEF3ZW6xRB30/yHt7m3ZnCqCZXw6knb5mETIzn GcOytprt5d90
9n1SevlsW1+8cVsr/cuq8vS/bcuaP44sNZeCLTLW6uZZWdWWF4ZBFsKbizrI UxiRT8rE9R1G
Kbg1r5X/AD/VW/Ha7U3/AK/r+vwJrvxjplnpqX1ws0cRgMrbti+Ud6xiNyW2 qxckcnaNrEkA
ZqbdvL53Ta38l/TKSu7ev/ku/wDW/bqRaN430/WZLeLTbW5uZZWdWWJ4ZFh2 lNxZ1kKYxIp+
VicZHXiq5H8v+H/VW/Ha7UXsbun3f22F5Ps9xb7JXj2zpsY7WK7gP7pxkHuC Km2ifcp6Nos0
gCgAoAKACgCC9+5D/wBfMH/o1a1pfF9/5ET2M/UNa122m1q/ik05tM0eXEls 1vIJpI1iSR2E
okwGAY4GznAGRnI1gr8t/tO3pq4/P8CuVylyR30+/wDQIfiJo1xrc+kWYa4u 4/NSNUngzNJG
CWQJ5nmKflbl1VTjrggmG37OU49Ff5f18/IEleKfW3yv/XQytJ8dvo2hade+ KxfLLqoEo8+a
xjWIEKT5aLIrunzcDDv684B2cEqiorf8e2tv+G137ZydlKpbRX+5a/fb8jc8 ReKUt/DU93Y+
dFPJ9phgcop2SRLISSCSMfuzjr24qIq8oLvyv5Nx/wAy1bXyLWja3eX1/rVt Pp8sEenzeXFO
SmyQeWjYwHLZ+bPQDBHfNRJ2pc/XX8G1+go/Eo+n4nJ6Z8Qb1rK3unvNL1eO VIJJzpdrIxsi
8saGJ1WSQs5DttAwcxn5TnjblSlbpffvpJ6ellffR9N2n1tvrp1/r7tdr62t ax49ddSFvZ3l
po9oXiRrvWrCaEIWSZj8sjRE58pQDnHJ69s4q+77/hy/5v7inpsv6ubltr17 J4Ri1doofMWQ
eYwRhHJCJdrSoM5AZAXUEngjk9atpKUVa17adU30+Teu3XREJq0nfa9vO2v/ AAPyuiBfEt49
7c2ypbBjexRWvDHdDvZZC3P3h5MxHQD5c575xaUU5ed/Tl5k/novUuSs3bay ++6T+5tXMqT4
m6bqcZi0J5HuFmgZFjkgla4iaZEbCq7FCQ4GJAhG7tg4uMW2nb5f9uya123X f8AmuW8W/wCl
/Xz6HSW/iB73RtSurPTblb6w8xH0+cqJPNVAyplCy/MCpBBP3h9KmfuxUls/ XvZ6b6dlv0HB
JzUJabfc+piR+OYdJ0uW717U7C7fzUiSG3h+wSxOys2yVLiXCHau4F2TI6Dp luysl59raW/F
X1WrX3kwvK72stuu/wCvR2t12LuneOrHVITLpVhf30aWxuZGg8plQZkG3d5m GbdEy/KWGSDn
HNEvcTlLRLrr2T9dnfbp3au4rmait3/X9f8ADj9b8daPo9uZ5y7xkReW4kij SVpFZgoeR1UE
Ku47iBgrgkkCiS5W4vdNr7rX/NChaceZbWv8novv/TWyJPD/AIxsfEE8MelW t1OkkQlknUxm
KEFpFwWDkMd0bD5N3YjjmnytX/romvwfytrbS6vb+v6/r5nRVIwoAKAOM8S6 yukOJZ4JXtmu
GSWVORCMnBI69cf/AK8A+lBe6jmk9Shp+sx6ne3UVpG728GF+0gjy2buo9cc c/8A1s7LYi50
ll9yb/r5n/8ARrV4dX4vu/I7IbE9ZFhQAUAFAHLS6Nf3+raoJrhIdO+2w3Cx C2PmyskURBWQ
tjbuUA4XPBGfTtlVhClGyvLla30V3JbW7Pv2ISvK3TT+v6/MwNR0HVk8J6UB eaneOLR1NnJB
FtgY2sgAwkavwSFwWPX1rrjXp/WJaJarW719+Pnbz2El7v6fedlo+mXVrdXN 9qN1FdXdxGkR
8iAwxhE3FQFLMc5dskt6cDFedVqRlHkgrLV73etvJdhxT0b/AK/r+lvfkmOp RaS9j4fXUPst
tbqoe602SK5tV8yPdGjDZ5o8sP8Ac+bKA7yStd/uOanVtdvo1Z6PVrW2tt9N fh3Ku+Ztbu/3
+u3y1u+ti54bsb2a9tEuNS1S4s4xNJ80N3ZgMGhKq3muZGH3yMsQQSOgxUV5 wUZNRSenWL/m
u9EkunTs97MzXZfr2/r+ri6hDrw0u8it5b1W09RbJIA7tOhlVncAMGkYRBRl WDZLhTuqISpc
0XK3vb+Vk18k5a2tayV1Y11Uml5tfPZfLVdno35J4csr6W8tFn1LVLiziWaQ bobq0AYNCVVv
Ocu/O8jcxBBI6DFVXnGMZNRSen8r/mu9El26dnvZma7f59v62/zH+D7q8s0u WuodXvQWgQzy
pcK0ju5DHyJv9WF3AsY2KYGQBjbRiYwlZRst9NOi7rV36XV799yn8Ta8/wDh uz+X+R0smp+X
5/8AoN63k3EcHyxZ379nzrzyg38nttb0riVO9tVqm/S19/N209UU9L+l/wCv Mv1kAyD/AFEf
+6P5UAPoA5r4hf8AIDj/AOuw/wDQWr1cr/jP0/VGNbZHjVfUmB7J8I/+Pa+/ 3Yv/AGevCzTe
Pz/Qqjuzva8c6DH1/VRY21+ZUhFraWhuLmWVyNkeHyQoRt2AhOMfgaqytdk3 d7IuWN5LNczW
9xFHHJEqP+7lLghiw6lRz8p/ShpWugTd7MztY8QS6TrUcFzb2yaYLOW7nvHu GDxLHgNiMRnd
95f4h39BmY296+lrfj+Wz/ra2npy7sr3/jfTLeye5t47ycxXEMEkX2KdZAJG 2hwmzcy9SCAQ
xGAc0Lded16NK+q6dN+4rrW3RX/GxYk8YaHC0wmuZokgR3eWS0mWL5AS6iQr tZlAOVBLDa2R
wcO39fO1/TXfYdnorb/8P8hs3jTQoCBLPcodokbNjP8Au0LMod/k+RCUb5mw uBnOCDSSbaj1
0XzdrJ9nrs9d+zJbSXN0/wAt7d/kTnxPpf2ua0jkneWIPytrKY5GQEsiSbdj uMHKqS3B44NT
KXLBztsr/wBeXmWo+8ovrb8SbwzrMev6HaanDDNAtxGrmOaJ4ypIBIG9VJHP DAYPUVrOPJK3
9f8AAM4u5pVBQUAFABQAUAFABQAUAFAFHVPv2f8A11b/ANFSVMthorVgUFAB QAyP78n+9/QU
AY914aS5v7qaXUr77LeOsk9ipjEMhCKvJCeZghFyN+DyDwSKtTenlt+f9XFb sSWehGyvJZLb
U75LSV3kNifKMIZ8liCU3j5iTjfjJ6Y4qGrw5H2t/X5ajv7ya0KVz4MtJoFg i1C+tojZpZTL
EYszxoCF3FkJBG4/dK9eavnfPz+d7ef9W/q4raW9fxEufBlrcb45dR1D7KXl dLYNHsiaVXDk
HZuOfMY/MTg9MDilGTi0+1vuTTX5LzsDX9fKxrWelpZ6heXUVzcbbwhngJXY rhQu5eNwJCgY
zjjoDmp+zy/0v6eodU+ysZreEoplb7dq2pXkioEt5ZWiD22GV8oVQZO5EOX3 Z285yc0pNbb9
/v8Al1fTqPy6dv619NS9YaO1tdxXVzqV5f3EUbxrJcCJflcoSMRoo4KDHHc/ gXsmkt7fhf8A
zFYhm8NWUkd+vmXEbXsqy+YjgNCytuUpxxh8vg5yWOcg4pJuKSXR3+//AIGn oVe7bfa39f10
RNYaO1tdxXVzqV5f3EUbxrJcCJflcoSMRoo4KDHHc/g72TSW9vwv/mTYtafa fYoXj+0XFxul
eTdO+5huYttB/ujOAOwApX0S7DerbLNIAoAKACgAoAgvfuQ/9fMH/o1a1pfF 9/5ET2EuPCsd
xf3c0uqah9jvZRLcaepiEMhCquCQnmYIRcjfg8g8Eg6R923lqvLW/wCfcbd9 tNLE1l4fNjey
y22q36WcrySGwPlNCGfJYglPMHzEtjfgE9McVPLeHI9rW9P621voDfvKS0/r +tijdeCLOaBY
ItR1C1iNklhMsJizPEgIXczISCNx+6VznmtOZ87n5p26XX49uv63X2bev47/ ANbiXPge0ufM
jl1PUjaM80kdqHj8uJpVcOVOzcc+Yx+Zjg9MDilF8rT7W+5NNL8Eu9gev9eV jXtNHjtL+/uo
rq42XxDSW7FTGrhQu9fl3AlVUYzjjpnNQ1eDg9vyvv8Ai763+7QFo010GjQ7 YaPZaZvm8iyM
BjbI3HymUrnjHO0Z4/KtZTbnz9dfxTX6iStFxEm0G1m12LV2kmFxFtwoI2fK sijjGekrd+w/
GYvlvbrf8bf/ACKG9bF2/tIr6xuLO5XdDcRtE49VYYP6GpaurbFRk4SUl0M2 28M2dvcaZMJr
mQ6dC0KCRwRLkY3vxy3LcjH3245puzctNGrW8l2/IhK0Uuzv9/8AV/VFIeDt un/YI9f1ZbSM
xm2i/wBHb7LscMmxjEWbG0D5y3HXnmnd6NvVdfk1+N/Up2u9NH0/r/hjRsdC js9Ou7Zby7ee
9ZnnvGZVndyoXflVCggKoGFA4HFKWqSWlv8AO/W/X5dNtBLR3ev9bf1676lB vCCSE3E+tanL
qQdGj1A+Qs0QUOAoVYxGVxJJwyH7x9Bh3ta2m/zvb/Jfdcd+j1X9f1+Gxp6X pAsLiS5lvbm9
uZYkikluBGCwQuQcIqjPzkcDsPxL6Wt5/gl+hNij/wAIlZx6eltaXd5aSxXJ uYbqJ08yJsFQ
BuUqVCHYAVI2gdxmlquW3RW9e9/V6+pTd3Jvr/Wn9dX3L2l6SLC4kuZb25vb mWJIpJZxGCwQ
uQcIqjPzkcDsPxd9LLvf8Ev0JsaNIYUAFAHM3tpNJNcxyWskkcjuCDGWVlJP 5jBr0oThyrU5
nF3ehTt9Le1t47azsZYooxtVQhwP8+taKpBLdGfJK+xqWX3Jv+vmf/0a1eLV +L7vyO2GxPWR
YUAFABQBl33hnQdQunur/RNNuriTG+Wa0jd2wMDJIyeAB+FbwxFaC5YzaXqx cqIP+EN8Lf8A
QtaP/wCAMX/xNV9bxH/Px/excq7B/wAIb4W/6FrR/wDwBi/+Jo+t4j/n4/vY cq7B/wAIb4W/
6FrR/wDwBi/+Jo+t4j/n4/vYcq7B/wAIb4W/6FrR/wDwBi/+Jo+t4j/n4/vY cq7B/wAIb4W/
6FrR/wDwBi/+Jo+t4j/n4/vYcq7B/wAIb4W/6FrR/wDwBi/+Jo+t4j/n4/vY cq7GxbwxW0Ec
FvEkMMShEjRQqooGAAB0AHaudtyd3uUEH+oj/wB0fypAPoA5r4hf8gOP/rsP /QWr1cr/AIz9
P1RjW2R41X1JgeyfCP8A49r7/di/9nrws03j8/0Ko7s72vHOg5Tx14WHiO0u reeC0ntp7cRn
zl3PCwEgDx/I2HAkOCBkVWlrE6p3Rc8NeHl0qKaKS0sIYCqrFb2sYEaDLk4G 0AZ8w9B3PrS0
tYave5H4k8OXus35kj1G3t7V7GazeJrRnk/eYywfzABgqvG09+eRgg+VtvvF /wDgLv8A5/1v
Teit5/iSax4clvprq4t75beeVbUxFod6o0EjSAsNw3AlsEAg470k3Hbu396S f4fiJJWs+1jE
/wCFdRie/dTov+mCcm5Ojj7YjyhtxEwk6AscArnbwSetOD9nZLZW/Bp699rd O45Nyd38/utp
279Tf1Pw/wDbv7W/0ry/7SsktP8AV58vb5nzdef9Z046UJ2t/iUvy0/AS0t5 KxmaT4Hg0zX5
dQij0d45JZZRI2lqL1TJkkC4D9MsQMpnbxk9alL926flbTT7+/8ATG3qn6fh +Ru+HNOuNJ0a
20+5uo7o2qCKORITFlFGFyNxy2ByRgE9h0q5ScnzPfr6+X/Dsm1m7bGjUjCg AoAKACgAoAKA
CgAoAo6p9+z/AOurf+ipKmWw0VqwKCgAoAZH9+T/AHv6CgB9ABQAUAFABQAU AFABQAUAFABQ
AUAFABQAUAQ3hgFuftSB4iQCpTfkkgAYwc84qoKV/d3Jla2pU+z6d/0Cn/8A Be//AMRW1qvf
8f8Agke52/APs+nf9Ap//Be//wARRar3/H/gh7nb8A+z6d/0Cn/8F7//ABFF qvf8f+CHudvw
D7Pp3/QKf/wXv/8AEUWq9/x/4Ie52/APs+nf9Ap//Be//wARRar3/H/gh7nb 8A+z6d/0Cn/8
F7//ABFFqvf8f+CHudvwD7Pp3/QKf/wXv/8AEUWq9/x/4Ie52/APs+nf9Ap/ /Be//wARRar3
/H/gh7nb8A+z6d/0Cn/8F7//ABFFqvf8f+CHudvwD7Pp3/QKf/wXv/8AEUWq 9/x/4Ie52/AP
s+nf9Ap//Be//wARRar3/H/gh7nb8A+z6d/0Cn/8F7//ABFFqvf8f+CHudvw D7Pp3/QKf/wX
v/8AEUWq9/x/4Ie52/APs+nf9Ap//Be//wARRar3/H/gh7nb8A+z6d/0Cn/8 F7//ABFFqvf8
f+CHudvwD7Pp3/QKf/wXv/8AEUWq9/x/4Ie52/APs+nf9Ap//Be//wARRar3 /H/gh7nb8A+z
6d/0Cn/8F7//ABFFqvf8f+CHudvwD7Pp3/QKf/wXv/8AEUWq9/x/4Ie52/AP s+nf9Ap//Be/
/wARRar3/H/gh7nb8C3ZmA26/ZUEcQJAUJswQSCMYGOc1jNST97cuNraE1SU FABQAUAFABQA
UAFABQAUAFABQAUAFADIP9RH/uj+VAD6AOa+IX/IDj/67D/0Fq9XK/4z9P1R jW2R41X1Jgey
fCP/AI9r7/di/wDZ68LNN4/P9CqO7O9rxzoMfX9VFjbX5lSEWtpaG4uZZXI2 R4fJChG3YCE4
x+BqrK12Td3si5Y3ks1zNb3EUcckSo/7uUuCGLDqVHPyn9KGla6BN3syvr2p XWlizkgtIbiC
a5jgmZ5zG0Yd1QMoCENy3IJX61MdZqPe/wCCb/Qp6RbXQiXxTpXnTQyPdQPC yqwnsp4c5cIC
pZBuXcQCy5AyCSAc0R95Jry/Hb7+nd6bg/ddn5v7t/uJL7xFp1iszSfa5Rbz eTL9msp7jY+w
Pz5aNxtYc9O2c8UrpJPo7/g7P8R21sv6v/X5d0aUE0dxBHPA6yRSqHR1OQyk ZBFVKLi2nuiY
yUkpLZj6QwoAKACgAoAKACgAoAKACgAoAo6p9+z/AOurf+ipKmWw0VqwKCgA oAZH9+T/AHv6
CgDGvPEyWd/cwy6Zfm1tJFjnvkEbQxllVskb/MwA4ydmByTwCatQei77f166 Cb7FyTXNIjur
i1fVLJbm1jMs0JnTfEgGSzLnIGCDk+tZt2i5dEUk20u+xkeHfG+l6rZwXN1q Gk2f2x8WkQ1F
HkkBxhWUhdr8gFBuwT1rV02ny9fL9O/X7iW0m+y/r/gmrq+s22naTcXySRTe UkhRBKB5jICW
QHnkbTn0wfSoiryS72+5tK/4j7iafr+m6heX9na3Mb3OnvsniEilh8oOcA5x zjJxyCKlu0Of
pr+F/wDIS+JR6szrLxjbzrbG403ULH7Ysb23niI+cjuibhsdsAGRMhsHDcA8 1r7N35eq38tG
/wBHsDdlfp/X9feWtW8Rx6fqC6fFp95fXTbNsdv5QzuEh6u6jgRNnn061EU3 t5/hb/NDem46
TxFAmhrqcVpdTbpRB9mQIJRKZPLKHcwXIfIJ3Y44JpuNpKK1v+Vr/l8wXW+l v6/4YnsNWE5W
O9tJdLuJC3lW93LCZJFUAsyiN2BAyM88UnZLf/gC17CprukPdW9rHqti1xdI JIIhcIXmQ5+Z
RnLDg8j0o5Xdq2w3pqxbfW9Jub2SyttUspruJyjwR3CNIjDOVKg5B+U8ex9K Em1dbA/ddmQT
+JdIt9Vt9Olv7dJ7lJHjzMgB2MFZeuc5zxj+FvSktb+Vn8nfX00B6W83b5le fxfoqR2txb6n
p9xZSztDLdJdoY4CI2f5mBx/CBgkdarlaeuml/xS/UXTQmHiTTlluHmu7WGw gt4ZxevcKInE
hcD5umPlGDnnNHK0tdHe34J/qPd6F+DULK48j7Pd28v2mMyw7JFbzUGMsuDy ORyPUUnFptNb
Cvpcde/ch/6+YP8A0ataUvi+/wDImexvVoAUAFABQAUAFABQAUAFABQAUAFA BQAUAFABQAUA
FAHL6rqFrb3iRXU0Uck8zRxK+MsQTwP89wO4r0aatFHPJ6lD7davfSWkcsf2 mJQ7IPvKD0P+
fUeore2hmbNl9yb/AK+Z/wD0a1eHV+L7vyOyGxPWRZz3jQyGLTIo4b+4WW92 vDYXP2eWQeTK
cb96cZAONw6d67MKl77dlZdVdbrpZ/kTJ2Rl6VL4ms724tUggujHaRvsvNQd WhUyTbBkRvvY
IFDNnkr1brWlVUJU+Zu2r1SWvuxv1Vle7S89kEb8yt9z9f69O7M7wv8A2rqM sM8Q1R7iOS1L
Xkl+TbLH5MTSIYjJ8zEF+fL6sDkYyOmv7OndO1ve0tr8UkrO2ltOuy2753bV uuny/r/gabrW
1uz1DUPFdxFbRvNDDaQkr/bNzYhCzSZIWIEMTgdcdBXLQnCFG8tNX9lS6Lua Tvol2Fv/ABRe
6ff6nZNFbSHTYJLvcMgTRKgIiBLcSAsCxOQFKnHz8KGHjOEZ92l829/8P63V 9CkrSUe9v+Cv
Nuzt/wADVLLWvErxRw3tnBZzXcyR211NCgjwVdjmOOdy3CAA71yXHHHNTo0E /dd7Xutb6W6u
K79nZIzUnbmtp/n/AF+nUujW723guUuXtJLi31G3syyRsisHEWTtLEg/vDjk 9B1rL2MJOPLd
JqT+7m8l2G24p36W/Ex4dZ1620spbXMN/eyXV0yItkX2xRysrbme4RQASoHz ZAIAU4Jrd06L
aclZKMb69WlbaLffp56FWfM156f1/wAN+JHput6j5Vxq0ItRZ3t7bLJbGNml JlhgGVcMANu7
ONpyAeRTrUIJKk73SnZ+jk9V527oiE21z9bL9NF+nd6C+Gdd1x0sLPTtNE1h ZxW0M7Yjzhok
YvvMylcB+nltnb154vEUaSc5zlZtytv0b02d727q1/vFdJKP9a/18zZ8Na9e XDTrr72tpKFi
ZYPKMfl+YxCgSb2SUE4AZCOTgqDxXNXoRil7K73/AAWulk187+Te5TupeWv3 Lrf/AIb8Tea9
tE8zddQL5cixPmQDa7Y2qfQncuB1OR61yKEtLLf9N/yZWxPUgMg/1Ef+6P5U APoA5r4hf8gO
P/rsP/QWr1cr/jP0/VGNbZHjVfUmB7J8I/8Aj2vv92L/ANnrws03j8/0Ko7s 72vHOg5Tx14W
HiO0ureeC0ntp7cRnzl3PCwEgDx/I2HAkOCBkVWlrE6p3Rc8NeHl0qKaKS0s IYCqrFb2sYEa
DLk4G0AZ8w9B3PrS0tYave5PrelX2qXVsgv4YNOikjmkiFsTM7o24Yk34UZC 5Gwng8jPEpa3
fnb5pr9Sn8Nl/WxhaJ8PorC4nkuprGbz7SS0ke3sfJlnDlT5k0hdjJJ8p+Y4 ySTgU7tQaWjd
ttk1ezS9X36Ces1J6779U+j8vIl1XwQ2oWNhBPd2d20HmNcC/sftEU0khBaQ R7wFcHO0ndtD
Ec0ppSbtorW816Pu+umrt83FuKt5/wDDJ97aHSaJYf2Vo1lp4k837JAkO/bt 3bVAzjt06VpU
nzzcu5EI8kVEuVBQUAFABQAUAFABQAUAFABQAUAUdU+/Z/8AXVv/AEVJUy2G itWBQUAFADI/
vyf739BQBzeo6TrF1PrFlHHYppuquN9y07mZEMSRuBFswSdpwd/GQcHGDrzp 8t/s/jrf5fiE
W4S5o7lXSvClxY6280kKTwLcTzw3B1W5BQybj/x7EGLPzlcg89cZ4rJtum49 bW/rt/XQHZST
W2n4L8f8itq/hPWrvSrXTo54nhi09LbH9oTW6RSqCGfZGv74H5eHIAx05Nbc 69tz/wB5P5Xv
a23z8/Ilr93y+v4/1t/SfqPhjW7u0bTh/Z620c11LHOZn3v5qy4BTZhcGQc7 mzjPHSphJRlF
vokvucX+Udu73G+tuv8Al/mdBp1he2uoar5gt2tbyQTROrtvDeWqFWXbjHyZ yG74xxk5TXNT
cPX8W38t/Pv5Dj7sk/JX+RjReBbRPD9rZSxJdXCi2W4N3PJcIyI6M6KJCdqn b90AA8ZHHG0p
p1L9Lv12aX3X+WpKTs+4k/gOzGtpLp9tb6bp26N3isHe0csqTKSDFtOf3id+ QDn3mMrJp+f4
8v8Ak/wG12NLX/D8dx4aXStNsrOWOOWJxbXTERShZA7B22sTuwckg5J5qb+8 pPp/k0renQcU
oppdTKu/Cl1f6NHpsWmaP4fjSZp86dIXw23AwBFHw2Sr+qZH8WVrms1K97dO m+z8uvrbsEbJ
NbXttv6+vb/gWZ/wit8+uG9uraCWK5lhuJVj1e5hW3kRUXCxKuyUAoCCwXPQ jii6SaT72fXW
/wBz1ewney9LW6b/ANad+pNBpPiC1tNNgitdKf8AsiQeQTdyL9pXY8ZL/uj5 Zwwbjfk5HvQp
a81t1a3RbbfdZLt101bS1S73/Hr+OvfoImga9bwwPaT2Ud35d5G7h2xEZpfM V0yh3FSACCB1
znjBTdlyra0fL4V+t9912YLe773+T/y/HyKNp4W1yz1KPUoreylmjljcQXOr XE/3Y5kJ82SN
iD+8BACgcH8aU1FWXn+PL9/wk2vq/L52bfy3GyeBtQVEljlheVJVuPJS7mtg WLXBdBLGNyAe
fwQDnbggZpKSiklstPlyxV/vjt26lXbu3pf/ADv/AMO++vkdDoekT6ebBRY2 MEUMU/mk3Et1
Mju4b5JnAYqfmLZxzt9KHJa+iXbb/LoLp8/6+Zr3v3If+vmD/wBGrVUvi+/8 iZ7G9WgBQAUA
FABQAUAFABQAUAFABQAUAFABQAUAFABQAUAcZr1ha6ql1aXqbozK+COChycM D2NerBe6vQ5Z
bsz9J0qDSLZkjcyzyHdNO/35W9T+vH9ck6JaGV9TpbL7k3/XzP8A+jWrwqvx fd+R3w2J6yLK
Wq2DahFEsV7PYyRSeYssCRM4O0jH7xGA4Y8gZ98ZzpTqezbur39f0aE1czh4 cvBK8o8T6qJH
UKz+RZ5YDOAT5HIGT+Zrb28LW9mresv/AJIVnvcZbeGLm0Qpa+JNTgQ4ysdv ZKOAAOkHoAPo
BTliYy+Kmn85f/JBy26lTUvAdtqs4n1PVLm9mVdokuLGwkYD0y1ueOTWlPGu krQil6OS/wDb
gcb6Nk6eEXj2bNe1BfLkaVMWtkNrsCGYf6PwSGOT1OT61DxSe8FtbeW3b4tg 5fP+lsVYvh9Z
w2s9rFqM8dvcEGaJbCwCSYORuH2fBwfWtHjpNpuOq21np/5MLls2+4+PwHbR zQzR6pcpLAqp
E62NgGjVTlQp+z8AHkAUvrsrNcq185f/ACQciC48B21zI0lxqlzM7SeczSWN gxL4xuJNv97H
frSjjXFWjFL5y/8Akgcb7iw+BYIL1b2HVrqO7VdizpZWAkC424DfZ84xx9OK HjW4uDirPpeV
v/Sg5dvIJPAsElzb3MmrXTz2qqsErWVgWiC/dCn7PlQO2KFjWk0oqz31lr6+ 8DhdWYtp4Hhs
oXhs9Xu7eJ5FlZIrKxRWdTlWIFv1BAIPbFEsa5NOUU7ecv8A5IfLq3ffcnbw rM3mbvEOpHzJ
FlfNtZfM642sf3HJG1cHqMD0qViUrWgtPOXXf7Xmws+50FvG0UEcbyvOyKFM jgBnIH3jtAGT
14AHsK5G7u6Vigg/1Ef+6P5UgH0Ac18Qv+QHH/12H/oLV6uV/wAZ+n6oxrbI 8ar6kwPZPhH/
AMe19/uxf+z14Wabx+f6FUd2d7XjnQZ99cTyTzWVvBC/7kM7Sy7OGLAYGxgf unr+tVZWuybu
9kSWN5LNczW9xFHHJEqP+7lLghiw6lRz8p/ShpWugTd7MxfEHia90m+vBDpt tPY6dbR3V1M9
4Y5ArF8iNPLIY4Q4BZckgUoLmeu1+X5u3+aLa003s3228/6RX/4WFo3lCNby wbUTe/ZP7P8A
tqecP33l7tv3unzYx0/OpvomtdL/APkrf/AFte+hZ8NeJb3U7i0h1LTraza+ s/ttt9nuzP8A
uwVBD5jTafnXGNwPzc8c6uHLzLrG1/nf/J/1sm9mtnf8PL+rdd0dLWYwoAKA CgAoAKACgAoA
KACgAoAKAKOqffs/+urf+ipKmWw0VqwKCgAoAZH9+T/e/oKAH0AFABQAUAFA BQAUAFABQAUA
FABQAUAFABQBHcQ+dHs3tGQyuGXGQVII6gjqKqMuV3JaurBi8/6Cdz/3xF/8 RWntfJfj/mLk
8wxef9BO5/74i/8AiKPa+S/H/MOTzDF5/wBBO5/74i/+Io9r5L8f8w5PMMXn /QTuf++Iv/iK
Pa+S/H/MOTzDF5/0E7n/AL4i/wDiKPa+S/H/ADDk8wxef9BO5/74i/8AiKPa +S/H/MOTzDF5
/wBBO5/74i/+Io9r5L8f8w5PMMXn/QTuf++Iv/iKPa+S/H/MOTzDF5/0E7n/ AL4i/wDiKPa+
S/H/ADDk8wxef9BO5/74i/8AiKPa+S/H/MOTzDF5/wBBO5/74i/+Io9r5L8f 8w5PMMXn/QTu
f++Iv/iKPa+S/H/MOTzDF5/0E7n/AL4i/wDiKPa+S/H/ADDk8wxef9BO5/74 i/8AiKPa+S/H
/MOTzDF5/wBBO5/74i/+Io9r5L8f8w5PMMXn/QTuf++Iv/iKPa+S/H/MOTzD F5/0E7n/AL4i
/wDiKPa+S/H/ADDk8wxef9BO5/74i/8AiKPa+S/H/MOTzIXtJHYs93IzHqTD CSf/AByqWIkt
F+v+YvZrv+QgsmBBF04I/wCmMP8A8RT+sz/q/wDmL2a/qxPbw+RHs3s5LM5Z sZJYknoAOprC
UuZ3LS5VYkqSgoAKACgAoAKACgAoAKACgAoAKACgAoAZB/qI/wDdH8qAH0Ac 18Qv+QHH/wBd
h/6C1erlf8Z+n6oxrbI8ar6kwPZPhH/x7X3+7F/7PXhZpvH5/oVR3Z3teOdB zfirQP7XkZ57
HTr+2CITFexeYFZN+GVdrZOHI9fzp6NWuTqndEvhrw8ulRTRSWlhDAVVYre1 jAjQZcnA2gDP
mHoO59aNLWGr3uTS+GdNufEja3e2lpdXKxRRwNNbqz25RnO5XPIzvHTHSiPu J23b/RK39dxy
96yeyI38ObtFGnfasYvftfmeX/0383bjP4Z/HHapaukuyt/5K4/8Ed9W+5N4 W8N6b4a02K10
6ztIJBGiTzQW6xGdlGNzY6nqeSetaTlzPTRdiUtbvc16gYUAFABQAUAFABQA UAFABQAUAFAF
HVPv2f8A11b/ANFSVMthorVgUFABQAyP78n+9/QUAct488fWPgf7O+raZqc1 tccJc2scbRh+
fkJLghsDPI5GcZwcUo3Ea3hXXU8SaLDqsFhe2ME/MK3iKjyJ2cBWPyntnGev QglNWA5PVPGH
iC3vfFU1qmmvZeG2jZreSGQS3EZjDtiQPhSBnHyHtRGypxnLq2tPW1/x8get R010Sf3pv9C5
dfFPw7a38dq7Snd5Idw8Q8sygFQULh2wGBJVWAz14ONFSbnyLu181/wdNepH tEqaqPayfyf9
X9Cn4Y8eTJfXtpr8d06SazcWVpdKkQiGwZWI4IbOAeSvOetZq3soy68rl623 /rQ0muWq10ul
6XS/X1NGH4l6G9la3ckd5BBc2EuoK0ka/LHG20g4Y/MT0Az9aJrkcovdJP8A 8C2XqTB86TXV
tfduaPhzxbBrupXOnrp1/YXNvBFcMl2I+UkztI2O3PHQ4IpuLXNrrF2fruJS T5fNXXoZdhrH
iNvG93od1eaU1vZWsd08kdhIryKzEFBmYhTx15+lKLjyTm/su34XLn8cYx66 /jYWz+JGm3mi
tq9vpuorZLsBmn8m3jyxYYDyyKjEFOcMcbgOucVKDha/X/JP9fwYdWu3+dv6 8hE+JekzWunT
2VjqN5/aMM80aRLECoh/1gYs4XjnoSDjg9KmS5FJvZJSfo/xEndqPVtr57ks HxG0e6v9OsrG
G5ubjULeO5jQNDEVR+gxJIu48HITceKrkfNKK6f5X9dtdiedKKl3/wA7em+m 5haN8Q3tRq+o
+I2vI4hqb2FpasbWONSv8IcsPmABLM77eflJ6UopckO8lf8AP8Nl3uXNWqSS 2jb8Uv8Agv03
NZPihokttYy2tpqV096Z0ihtoVmffDjcuEYhicjBUkY5yBzVRpuUrLsn8m7f K3W4k9G+zt+F
/wAenqP8a+KdS0jxJo2l2Bhij1CKaSSR9PmvHUoFwBHEwPc59KmnHmlJdkvx dhSdoxfdv8rk
lx8QdPstTm0+4s79jaXMFpcXSRIsSySgFOC+/Bz2BI704x5mraXbS9V0/wCD sJy5U79Em/Rk
3/Cead5F7eCyvzpVk8kcupBE8jdGCWAG7eRkFQduCeM1ndKCn0e3nrZff52L t77gum/l/XkQ
P8RtLt4Lg31jqNldQpDIlnLHGZp1lO2MoFcqcnjBII74q3B83Kt78vz39Ntf kRzq3M9rc3y/
P/hzF0rx3qCateR6r50Mba4LCG2kt43eJDFu2lkkAHIJ3Zf0x6TTs4Xevxv/ AMB/y9Ne/Uqe
k7LT4F/4F/Xy7GpYfFDRbm1F1Pa6hZW72Ml/FJcJHiSNG2tgK7HOeMEDPanN cl091Z2/xbeW
4QfNa2zuvu3/AK/U1vDni2DXNSudPGnX9hc28EVwyXYjGUkztI2O3PHQ4Iqn G3N/ddn67kqS
fL5q69DoKgsKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoA KACgAoAKACgA
oAKACgAoAZB/qI/90fyoAfQBzXxC/wCQHH/12H/oLV6uV/xn6fqjGtsjxqvq TA9k+Ef/AB7X
3+7F/wCz14Wabx+f6FUd2d7XjnQRXg3WkwxuzGwxjOePTBz+R+hpMCWmAUAR QDEtwcYzID0x
n5V9hn9fr2CAW6njtbaW4nYJFChd2PYAZJpTlyRcuxUYuTUUc9p3jO0k0iK7 1SCaxuHna3Np
HG9xIJApcKAi5JKYbgd6tq1l6/g7P5J9e2pEXzXtsrfirr77/foObx14dWMS fbZimwSOy2kz
CFSzLmUhP3QDIwO/GCpzjFCTbSXW342tr53Vh7L7/wAN9C9F4k0uXUWsYpZm lUsoYW0vlOy5
3Kkm3Y7DByqkn5TxwcLo321+Xpu/kNq1l3/X8iqPGWiCMM8t5E5kESwS2Fwk zMVZgBEyBzkK
2CBg7SByKaV7Jdf+B+V032Wu2ou/l+u35W9dCa88U6TY3NxBey3NsbeNpHkm s5kiKqu5tshT
a5AycKSeD6Gktf687fddrXbUOqXf/K/5DF8X6MYJ5RNcjyHVDEbKcSuWzt2R lN7g4JBUEEKT
2NLovPTzuld6bqy11Bauy7X+X/D6eo+PxTpL3cNsJLpZJioy9lOixswBVJGK BY3ORhXIb5l4
5GaSbdl/Xp3+Xn2B6K7/AK1t93mbNIAoAKACgAoAo6p9+z/66t/6KkqZbDRW rAoKACgBkf35
P97+goAjv7K01G0e01C1hu7aTG+GeMOjYORlTweQD+FGwE9AHKXvgKxvNQ1O 4k1HUlg1eSN7
2zR4xFNsAAUnZvCkDkBhnJpxfKlG10m3r3YpK8nJaNpL5ItR+EoLTV7nUdI1 G/0s3ZjNxBb+
U0UpQYB2yI23jAO0jgD601JpWequ39+/nqJxXTTS3+X3FO1+HumQap9se8v7 iMXst+tpK0fk
rPICC3CBuAeMscVK0io9k4/J7lS96XN5p/NbFBfhbpVvZPAt3f3scdjNZW9t czRpHGjndjcs
e4fNjk7seh6UTbknfdpK/wDhd15fgEUotdEm39+/9XLfgXwrqej6vqOqa1eC ea6hht4kEolK
Rxg4y4ijBPP93t1OeNHJWl3k7v7rf1+XeOWzjbZK34m5FoFrH4iu9bWSb7Td 2yWzoSNgVSSC
BjOeT3rK3uSh0lr+Fi/tRl20/G5kp4B06HRdI021vb+3/saYz2twjxmRWO7O QyFD94/w1o5t
zU+qVvlZL9BWVpJ9Xf53uNsvh5pNn9iKXV85s47qNC7oSwuDly3y9Rnjp75q HrB0+jio/Jfq
P7an1T5vnaxHcfDbSbmz0uyurq7ns9LjSOGF0gJwpB/1nl+YM4GdrLnFaKo1 P2nXT8FZf569
SHBODh0d/wAdyd/AOlm3dI7m+hm/tJtTiuY5FEkEzHnb8u0rjIwwbgmojJx5 bfZTXye5crSc
m+tvwVkXV8MRvqul6ne6lfXt3pnmiKSXyl3CQAEMERRwBxjHvmnGXLdpbq34 3E1dWfe/4WDX
fDEWraxYaqmo32n3lgkkcUlt5R4fG7IkRgelKL5W2uqS+53CSUkk+jv+Fild eAtMup72ae6v
Wkvbu3vJTvQfvIQAuPl4Bxz+mKafLy2+y3Jer/QTjfmv9pJP5fqL/wAIHpwg vbIXt+NKvXkk
l00OnkbpAQxB27wMksBuwDziosuRQ6Lby1uvu87lXtNzXXfz/wCH8iu/w40u eGb7bf6jd3ci
wol5K8fmwLEdyBNqBeDycqc981bk+bmWjvzfO1vyIUEly9Lcvy/P/hhY/h3p omE9xqGo3M/9
oDUWlkaIF5QmzBCoBtx2AH1qVaMeVLpJf+Bb/wDAKeru/wC6/wDwHYhf4aaP HpUNpG11cC10
6awijmmVA6u27LMqZB3Y5A49DRUbm5S6tRX/AIC7oKaUOVdE2/v3/r8SXwL4 V1PR9X1HVNav
BPNdQw28SCUSlI4wcZcRRgnn+726nPGjkrS7yd391v6/LvPLZxtslb8TsazL CgAoAKACgAoA
KACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKAGQ f6iP/dH8qAH0
1450EV4N1pMMbsxsMYznj0wc/kfoaTAlpgFAFeOGNppmeJSRICCU9kPXA7qO 56DnjAQFTW9G
i1TR59MR/ssNztSUxDaWjyAyggjGVG3Pb8KLaryaf3f8Eadr2ObuvBt9p2sW 114ZvfLSS5Wa
b+0DLeeWwhlQuS8odtwaNcBuNoPSqi2rrpr+Ljp+F7+omlb7vwb/AM3/AFvF F4L1VbnUrNNQ
t49P1K2CX0rWpaSd3kmabysSDyv9Ycbg+Mjrg5cWkknsnouuiju/NrXRdbW0 s3KSkpp+937d
tPJW/Ulh+HkNre3slo2lwLc+eUuV0wC/haQNkrchweCxx8udvGe9Rrycv/DP W+q6rvtcLpST
XS3nsunbv1JfDvgNdH1SK/WbToSjo7Q6fpwtYmKpKmcb2OT5uSST93340jKy a9fx5f8A5H8S
HG/4f0/vK198Oftmo3N097ZK8rTlbj+z83REqOu15jJllXeNoAUAKBU0n7O3 lby2knr3em/m
3boXN87v/W1tOy/rvfa1Xw5Pc6qdUsb+O2vIxF5JltzKilBKDuUMpYFZSOCM EA5PSkm47d39
zS0+9JisrJPt+pnp4IP/AAkQ1m5/sK7uJJI5p5J9HDyiRFVcwyeZmMfKCAd+ Dk57U4Pk28/X
X/g/hpcJ3ktf+B939eh2NIAoAKACgAoAo6p9+z/66t/6KkqZbDRWrAoKACgB kf35P97+goAf
QAUAFABQAUAFABQAUAFABQAUAFABQAUAR3E3kR79jOSyoFXGSWIA6kDqaqMe Z2Jbsrhm8/6B
lz/33F/8XWnsvNfj/kLm8gzef9Ay5/77i/8Ai6PZea/H/IObyDN5/wBAy5/7 7i/+Lo9l5r8f
8g5vIM3n/QMuf++4v/i6PZea/H/IObyDN5/0DLn/AL7i/wDi6PZea/H/ACDm 8gzef9Ay5/77
i/8Ai6PZea/H/IObyDN5/wBAy5/77i/+Lo9l5r8f8g5vIM3n/QMuf++4v/i6 PZea/H/IObyD
N5/0DLn/AL7i/wDi6PZea/H/ACDm8gzef9Ay5/77i/8Ai6PZea/H/IObyDN5 /wBAy5/77i/+
Lo9l5r8f8g5vIM3n/QMuf++4v/i6PZea/H/IObyDN5/0DLn/AL7i/wDi6PZe a/H/ACDm8gze
f9Ay5/77i/8Ai6PZea/H/IObyDN5/wBAy5/77i/+Lo9l5r8f8g5vIM3n/QMu f++4v/i6PZea
/H/IObyDN5/0DLn/AL7i/wDi6PZea/H/ACDm8gzef9Ay5/77i/8Ai6PZea/H /IObyDN5/wBA
y5/77i/+Lo9l5r8f8g5vIM3n/QMuf++4v/i6PZea/H/IObyDN5/0DLn/AL7i /wDi6PZea/H/
ACDm8gzef9Ay5/77i/8Ai6PZea/H/IObyDN5/wBAy5/77i/+Lo9l5r8f8g5v IM3n/QMuf++4
v/i6PZea/H/IObyDN5/0DLn/AL7i/wDi6PZea/H/ACDm8gzef9Ay5/77i/8A i6PZea/H/IOb
yDN5/wBAy5/77i/+Lo9l5r8f8g5vIM3n/QMuf++4v/i6PZea/H/IObyDN5/0 DLn/AL7i/wDi
6PZea/H/ACDm8gzef9Ay5/77i/8Ai6PZea/H/IObyDN5/wBAy5/77i/+Lo9l 5r8f8g5vIRmu
1GW024AHcvF/8XR7HzX4/wCQufyIjeOOtpIP+20P/wAXV/Vp/wBX/wAhe0X9 WE+2kAFrWQJu
VSwkibbuYKMgOT1IqXQlFXf6/wCQ1URbrA0CgBkH+oj/AN0fyoAfQBzXxC/5 Acf/AF2H/oLV
6uV/xn6fqjGtsjxqvqTA9k+Ef/Htff7sX/s9eFmm8fn+hVHdne1450EV4N1p MMbsxsMYznj0
wc/kfoaTAlpgV9QuTaWxlVA7F0RVLbRlmCjJwcDJ9KcVdibsikbu7tH33Ftb Kk0yKTHcFmBY
qgwPLGe3U/0FNKPRiu1uiDxhqE2mafHPa28dzO00cKRySmJSXdVGWCsQBuz0 NYyTclFdb/gr
/oaKyTb6GND4lFt58Gu2v2K8gKfubUvd+cr7tpjCoHb7j5GwEbGPQZqLXV15 /wBemq1HZ/L+
vx/zRXHjTTo9SlSeV1s/IikSVbWUlCzSK3m4X92AUA+cLg5z04ag3p1vby2T Wu2t9O/QTdlf
pr+G5rPrmmx26XEl2kcLvJGJHBVQ0YYvkkcABG5PHFQ9Ffyv8tP80NK7su9v mN0fXbDWHlSx
NwHhVWZZ7WWA7WztIEirkHB5HpVOLSu/QV1ex0dn/wAeyfj/ADrWGwmTVQgo AKACgAoAKACg
Cjqn37P/AK6t/wCipKmWw0VqwKCgAoAZH9+T/e/oKAH0AFAGf4h1RdF0ee/d FcRbRh3EaAsw
UFm/hUE5LYOACcGj529RxV/x/BXKaeIha2MU2swrDLMSYo9P8y+EseAfMXZG G2/MASVABI55
GacbO3330t6/1+RMbyXMtiKHxXZo92bl2kjWfZbC0t5J3kj8qNy+2MMcAyfe wAMr68ji0lff
W/lZtfLb8xrXbbT8S3J4k01ZhDC89y5iEuba1lmQKV3Dc6KVUkcgEgnI9RUT vBSfa/4Dir28
/wCv6+fYpWHjTS7jTbO6mF1btcxLKyGznPkg/wATnZ8qZzh2wp2kg4BrWVNq fKv6/wCD5b7d
yE/d5iSXxPbPrtnplgXmaS4eGeT7PJ5S7Y3YhZcbCwZQCASRyMccTBc130tf 8Uvu3HL3V934
lOfxiY/Es+kKdEi8mdIdtzq3lXEmVVsrD5Zz97AG7kjtSik48z89tdr/AOV/ Qcvd0/4G5ftv
F+iXMTyxXcgjSEThntpUEiHAzGSo8zkgYXJyQOpFDTX3pfft9/TuHW3r+G/3 dewr+LdHiMIm
luoWlGdsljOhjXdtDSApmNSc4Z8A4PPBpqLk7L+vL1fRbibtHme3+W/3dSnr HjK0s72O3syZ
fLklW4keCYQrsidiBKFK7gVAIG4jnjI4Kced+X/2yX6/8Ecvd9f+Bcux+LNF e4aH7WybPMDS
yQyJDmPO8eYVCZXaxIznAJ6VPTm6Wv8ALT/O3rpuHVLq9PmFv4s0eeKSQTXE SxtEjefZzQnM
rbYyA6AkE8ZHFXySul3dvmlf8hXWvkr/ACNO9+5D/wBfMH/o1aql8X3/AJEz 2KuteKrvSL3V
Fn0+1+x2MEMi3BvSpYyvsXeDHiNAQxZtzYUZwegtP3bvTW3ltff5q3d6Fcuq S7N/dfb+kSDX
9VaK1t49KspdSuw8kSR35a1MKhSZPO8vODvUAbMk+3zVTi727b36atJer39L 9dHCacebo9vu
vf0+/p3NLQdUk1KG4W6tRZ3lpMYLiFZBIqtgMCrYGVKspBIB55APFFvdUl1/ zs/xHqnZ/wBf
1t6pma/ii4dZ4bfSil8NQ+wQQXU6osjCLzS7OgfauzcRwTwMgE4CSbUWut2/ Kza/Oy079tR2
s5X6W/HRfn/wCi/j6AT6fZbdNttQuSwmhvdSWBYyshiZUO0tIxdW2gKAQOSp wDUUpSsttH56
6rTv317WuKV4Ru11fpp1v5ppryZpav4qg0zUYoGgL2oMgubveFSApE8hX/aO EOemMjntWfNp
J9Em/WzSsvv376K7valFtqK3bS+/+tu2va8GjeMItR8O6hrROnGC0RpAtnfr dsAF3bZNq4V+
nyqWHoTVTjKMbR1ey7N9NfV+RMGpSs9F59u77aE1n4jm/wCEbttRvbVFna6W 0mSNyFDed5TM
MjOM5OPwz3qp8qkrPRq//krkTG7T01QQeM9HvBGLC4ZzKYjGZoJoUlR3VdyM Uw/LD7uQCQCV
zmkk27f1s39zs9dmtVfS7b5d/wCrWv8Adce3jHRVjkk827MayCNGWwnYTsc4 EJCfvvuk/u93
AJ6c1KaaTXX/ACvf0t1LcWm12/4b776W3voVNe8b6bY6M91YSyXNy9q1xBGl pNLtAyAZQq5j
G4EHft5Vh2OKSvNQ84+mr77arVdyV8PN6/et9N9OppR+JdKe+ezE8okTeC5t 5BCzICXVZSux
mGDlQxI2txwcTJ8sXPolf5d/+CNJ6Lq7fj+RU8Ma9eams/262SA/Z47yJVyC schfYjA5+YBM
kjjLYxxkuonSg2943T9Uk/1t52v1spi1KSts9vS9r/PfyvbzKNp4o8QXc9gI dC0wQ31obxGb
VJAyxjZkFfs/3vnHGccHkU5r2fPf7P8Awf8AIa1tbqP8FeM/+EmmVd+grut/ O8my1j7VcR9O
Hj8pduM4JycHA71ThZPy7bff+Qm7OxLqni1rLxNFo629qTI8cYEl3tuX3/xx wbf3ka/xNuGN
r8fLzEE53S8/PZX17J7IqfuRUv63tZPv1t6dzV8O39xfWcq36xreWkz28/lA hGZejKCSQGUq
2CTjOMnrT0cVJdf0bT/FP5E7Sce36pNfgzTpDCgAoAKACgAoAKACgAoAKACg AoAKACgCrqjb
LJyOMFf/AEIVrSV5omexx03iLT1lvopJzC9icyiRSpxx8wB6jJxx3x6jPoRS Odsl0+8S/sEu
og6pL5LKHXaQDNH2/wAj0rPEfBp5/kxw3/rub9eKdgUAMg/1Ef8Auj+VAD6A Oa+IX/IDj/67
D/0Fq9XK/wCM/T9UY1tkeNV9SYHsnwj/AOPa+/3Yv/Z68LNN4/P9CqO7O9rx zoIrwbrSYY3Z
jYYxnPHpg5/I/Q0mBLTAqatbS3Vi0VuUWUOjrvOBlXDYP5U4uzE1dHK6T4Mj sNQSez0nRNOK
SJ5klnbiN2UMr7QQgyDgd8ZHtQkou9/w/wCCJ3eljW8V6U17psdtYSw2UqzR zI7Qb0BjZGGV
DLkYUDqOKyl7sk10v+Kt+porWaZzeq+DH1eLz9UurK81HzEcNNYB7XagcBDC XJIxI5+/ncc5
wNtZp8tref42+7ZW/G5V3az/AK1v/wAB+XnqR/8ACGXQgltIrzTLSxu7Zba7 t7TTTECoZyfK
/ekRkiQ9Q3PNWp2ab6NP5pL8NPu0v1J1WsdHr/Xr/Vh194PubiCS1l1Lfp6P cSxQRW+2fMqy
AgyF9pwZDj5R0AOetRzuK5lukkvk01+S6peg0le3T/gW/rqWPB0GuNeX9/4g iWGSWOKGNPJS
JiE3kkqsso6v/e7Hgd7fKo2XVt/gl+nn6kJNNdkv8zt7P/j2T8f51cNhsmqh BQAUAFABQAUA
FAFHVPv2f/XVv/RUlTLYaK1YFBQAUAMj+/J/vf0FAD6ACgCvqEd1LaOlhcpa 3GQUlki81Rgg
kFcjIIyOCDz1o2A5G5+H6XG2eVtHmvDNLLIlxpQktCZAgYrCZMq37tTu38ks TnPFJ2slslb8
W/1enYN739f+H7+u+3Qde+AIbho5R/ZLyRsdsN1pYmtlUxxIQsW8FcGIEENw CRz1puWv3+u7
e/z17iW1n5Gtp2h3mm3RFnd2UNhMFM9qlkVwwjCfuiJMRrhV+UhsY61MvfTj LbX118+uuoLS
zW/4GM/gBnNo9xLo1/Jb26WudQ0gTjy0J2Ff3gKvgncc4PGFGKtVGpcz3bu7 aa+XZffbuD2s
vO3z/ryNa08OXdvqVvIdSiawtbqW5htxbYkBkD7g0m/BAMhIwo44OetTGVlr 2t8tP8gkr7ab
P8P6Y8aRrEGp3k1lqdilneTCWSGWxd5B8ioQHEqjkLx8vGe9S0nDkfn+Lb/U q/vcyIZ/Chks
9Ohjvtkun2iwRSGHILq0TK5GemYhlc8g9RWkptzlNdWn+d1807EpK3K/P8SL UPDOqags4utX
tR9ugFrfLFYsokiDMR5eZSUbDsCSWHQ4GOVCSi12TT+a/TRXX3NXHd7rR62f r/l0/G5HfeDr
u6je0/taNLASTywxfZMyIZVkDBn34YAyEjCjgYJPWiEuVpvdWX3NP9LCa6LR f8C3/BLGoeFF
udGWxe5kZY5bmY+UgV280SjaMnAI8zqeDjtmp53G0o7pJL1Vn/7bt+I4pbPZ sq+HrLxLcy3t
5qcy6dcS/Z44z9ljDMkbMzgoJpV+YMVzuyOTgYGdLxSXq2/uS/S/X/KEne3l Zeuv/AOovfuQ
/wDXzB/6NWil8X3/AJBPYbcaNrP9tahqFjq9pbi5hijijawZzGY2J+Y+aNwO 5wQAp5GCMc6K
6jbzv+Fv0Xz7rQbs2vT+v6/4cp2fhC7sCb2w1GzttWaeWV3jsStqwkCB18gS Z58tWzvzuyeh
Ip35Uox2tb8W/la7t5N+onre/e//AA/e/X0XY2tC0uTTYrhrm5+13l3MZ7iY RiNWfaFAVcna
oVVABJOBySeaL2iorp/nd/iw1bu/6/rf1bMb/hGNW+1XV02r2Pntei9tSNPc LC/l+UQ4875w
Y+OCvJz7Uo3jFLtf5ptt/jZr066lN6vs/wBGmvy17+RFL4Jn+xSQW+qRI19A 1vqTyWm/z1Z5
HYxjeBG26WTGd4wRkHGS07NL7Ktp10st/Oyvp00sCnJPm6pt/fb8rJLXbe5N rvw98O6xPHNL
pdjFLuczzLap50waNk5fGcgsGyc8qKSvFtx09Ojunf8AruKL5Uutrb+QyXw5 qbTrJe3cV/Ld
S28U8kNuLdUt4WaQbgXYsxY7SQcfMMKoyaaequut3620svJ2evbV7Im1ocq6 Ky9G0n+HoTHw
xfGQ2p1SH+yBdm7WD7IfPDmQy7fN37du8/3M44z3qLXjZ9FZfc46/J+Wv3FN 63Wl7X/rzt59
bdLE3g8SwaPE17gaZBHCf3X+t2yRPn73GfKx3+97c6ykpTlJrf8Aykv/AG78 CUrRsMj8M6xD
a2kEOtWgGluraezaexKKFZNsv73958jYyuw5APtU80r8zeuz8+/zuk+3lYr3 dUlp+Wv9L063
1Kr+BryOyuLay1mKEX9u8V+0lnv8xmeSQvH848v5pX4O/jA6jJadml0Ti130 st/Oyvp3sJtv
V76/j/l0/G5Jp3gO2sdauLxYtHeKd5pDI2lgXqmTduAuA/TLED5M7eMnrWfL +6dPuraaff3/
AA7ju1JSXS2/l+QaZoWvx28bQ3tvYXaWyWNwbi1+0JOsRbZLHskXYSHOQ2e3 HGTdR+1vzaKW
rXVN6Oz26aaevVExSgko/Z29Ol9tuu2t+lmbFroEdpNYGCdvKsbBrJFZclgf LwxPHP7v079q
KjdTnv8Aa/Df/MILlUV2J7HR7eHw9b6NeJFe28VslvIssYKSgKBypyMHHTmn UaqScmt3cI3j
sYsvg3yr3FhPbWulefDdfY47JRJG8QAUQyBgI1O0ZG0n5nwRniYvk1etrtd9 VbXvpp00snor
FNJqy0urfje/rd39dbX31PDNrdQWtzc38P2e6vrh7h4dwYxAgKqkgkEhFXOC RnOCetO3LGMb
3t+rb/C9vkTvJy/rRJfja/zNekMKACgAoAKACgAoAKACgAoAKACgAoAKAKWt ZGmykDoVP/jw
rah/ERE/hON1TSNN1O4guLyBXkgOVP8AeH91vUZ5x/QkH0bHMy9GcrJjoGh/ 9HR1lifg+/8A
Jjp3v/Xc2q8Q7goAZB/qI/8AdH8qAH0Ac18Qv+QHH/12H/oLV6uV/wAZ+n6o xrbI8ar6kwPZ
PhH/AMe19/uxf+z14Wabx+f6FUd2d7XjnQRXg3WkwxuzGwxjOePTBz+R+hpM CWmAUARQDEtw
cYzID0xn5V9hn9fr2CAlpgRTjMtucZxIT0zj5W9jj9Pr2KAlpgZljrCXGkza hLBKiQyzIUiR
pnIjkZMhVG4k7c4AJ570PSKfdJ/eh295rsJpviHTdRZUtZpRIVdjFNbyROoQ qG3K6gqfnXgg
Eggjih+7Fyey/wCD/k/uEtXb5fhf8mVbfxloVxcxQQXcrtKyIHFrL5as6qyK z7dqFg64DEZz
jrTs+bl9fwvf7rPTtr1Qm+VXf9dPzKl943sIrqyW1+0yW8lw0Mkn2C4IkAjk YeSQuJTlB9zd
x+dTFp6+V1966drNv012KknG/l/X39Ld9Nyf/hNdGDKxuGMcqr5KxwTPM7nz Mp5QTcGHlNxy
2QQQOMvZf1tZP9U/TXvZf1+NvzHT+NtAt7eKZrqd0kjMpEVlPI0SBipaRVQm Mbgw+cDlWHY4
aV2ory/HbXbUOl/X8N9N9DoByMikCdwoAKACgCjqn37P/rq3/oqSplsNFasC goAKAGR/fk/3
v6CgB9ABQAUAFABQAUAFABQAUAFABQAUAFABQAyeFJ4/LkztyD8rFSCDkEEc jkU4ycXdCaTV
mR/ZF/573n/gXL/8VWntZf0kTyIPsi/897z/AMC5f/iqPay/pIORB9kX/nve f+Bcv/xVHtZf
0kHIg+yL/wA97z/wLl/+Ko9rL+kg5EH2Rf8Anvef+Bcv/wAVR7WX9JByIPsi /wDPe8/8C5f/
AIqj2sv6SDkQfZF/573n/gXL/wDFUe1l/SQciD7Iv/Pe8/8AAuX/AOKo9rL+ kg5EH2Rf+e95
/wCBcv8A8VR7WX9JByIPsi/897z/AMC5f/iqPay/pIORB9kX/nvef+Bcv/xV HtZf0kHIg+yL
/wA97z/wLl/+Ko9rL+kg5EH2Rf8Anvef+Bcv/wAVR7WX9JByIPsi/wDPe8/8 C5f/AIqj2sv6
SDkQfZF/573n/gXL/wDFUe1l/SQciD7Iv/Pe8/8AAuX/AOKo9rL+kg5EH2Rf +e95/wCBcv8A
8VR7WX9JByIPsi/897z/AMC5f/iqPay/pIORB9kX/nvef+Bcv/xVHtZf0kHI g+yL/wA97z/w
Ll/+Ko9rL+kg5EH2Rf8Anvef+Bcv/wAVR7WX9JByIPsi/wDPe8/8C5f/AIqj 2sv6SDkQfZF/
573n/gXL/wDFUe1l/SQciD7Iv/Pe8/8AAuX/AOKo9rL+kg5EH2Rf+e95/wCB cv8A8VR7WX9J
ByIPsi/897z/AMC5f/iqPay/pIORB9kX/nvef+Bcv/xVHtZf0kHIg+yL/wA9 7z/wLl/+Ko9r
L+kg5EH2Rf8Anvef+Bcv/wAVR7WX9JByIPsi/wDPe8/8C5f/AIqj2sv6SDkQ fZF/573n/gXL
/wDFUe1l/SQciD7Iv/Pe8/8AAuX/AOKo9rL+kg5EH2Rf+e95/wCBcv8A8VR7 WX9JByIQ2cZ2
75LlwrBgr3MjDIORwWx1FL2sv6SDkRYrMsKAGQf6iP8A3R/KgB9AHNfEL/kB x/8AXYf+gtXq
5X/Gfp+qMa2yPGq+pMD2T4R/8e19/uxf+z14Wabx+f6FUd2d7XjnQRXg3Wkw xuzGwxjOePTB
z+R+hpMCWmAUARQDEtwcYzID0xn5V9hn9fr2CAlpgMlijlXbLGrjnhhnqCD+ hI/GgBFt4Vfe
sMYYHO4KM555/wDHm/M+tFgOXl8K6rLpt7pkmr2TWE8rzRx/YH3AtN5hSQ+d iRDllZQF3A9R
3Vvdinuremitt+Wuj1s9ir2k2tL/AH/L+v8AMraX4Gu9HbztJ1HTrOZ2k3xw 6XstwkixBgka
yDacxAgliPmOQetOXvQ5OjVvPdvT/wACffp85Wj5ut7/AIWL2neDxZaKNOa+ 8wfaLacv5WM+
UsQxjPfyuvbd3xzdSSm7tfzf+Tc35c34CinFP5D9M8OahaS6bHc6pbz2WlPm 1jSzMcuzy3jC
u/mEMQGHIVenTnhKTu5S1bVvyd/wHJLaOivcj07wf9i1qPUPt+/y5ml8vycZ ybg4zu/6eP8A
x334IPkjbyt+EV/7b+IS953MPxB4a1y0Nza+Hw9wurRyRXckkEbRRq0sjg5M 6MhAlYEhJM4B
254KpO0oxey5X91k/wAIrS3z3sT2co76/jt+PX/JHoYGAB6UhJWVhaBhQAUA UdU+/Z/9dW/9
FSVMthorVgUFABQAyP78n+9/QUAPoAKAMnxdNc23hnUZ7G5ktLiGBpI5Y1Vi pUZ6MCOcY5HQ
/jTj8UV3aX3uw1/mYGv+KV0TX9M0+TWYAsKxC6ineJZrrzW8tWAwPukbjtAH PpxVQXPUaS8v
R2b/AMkvV9jOV400/n8tP0v56LuFvr+qQxlLqfcbjUtltL5aj92LryniPGMh cYPUgnuuaKaT
cU97XfneLf4Pfpt3ZU9HJrb9f+Cv18h+geLU1Dxfe6eupWtzHIsv2e2jkQvA YWCMGxyN5O4Z
7Dipim6Tkld6P776fLT5tjl7s0um3zsn/mu2i7nVadLcT2EEt7a/Y7h0DSQe YJPKbHK7hwce
opySTsncRYqRhQAUAFABQAUAFABQBzEmpX0nhxZlumink1L7N5qomVQ3Rj4B BGdvHIqlG7gu
6v8A+SN/mDdubyMi/fXbO21OSLxDq909tfw2kcaw2QZlfys4zEq7vnYDJA6Z pxs+TTe/4c3+
WoPRvyRu6TqM+naeG1lNcaSWfYn2u2imkAwOT9kUqqdeWx3zxilK2iVvx/G+ n/A+ZOur/r/M
z/COrapdaz5V/NdtBc2zTxm4iiWKQ7wAbdkAbZg8iX58FD604pcjvureut73 6dvTZ9Bz0n7u
2vp5fP8AB620R2NQMKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAK ACgAoAKACgAo
AKACgAoAKACgAoAKAGQf6iP/AHR/KgB9AHNfEL/kBx/9dh/6C1erlf8AGfp+ qMa2yPGq+pMD
2T4R/wDHtff7sX/s9eFmm8fn+hVHdne1450EV4N1pMMbsxsMYznj0wc/kfoa TAlpgV9QuTaW
xlVA7F0RVLbRlmCjJwcDJ9KcVdibsjKttYcXV2nlWxMN3Hb3AjmYtHI6xkAZ jXd8siHOT1xn
jAaUejFdrdE3i3W/+Ee0STUNls22SOP/AEm48iJd7hdzSbW2gbsk4PSovql3 /wAm/wBDRK6f
kZdl42s20wXV5NYTSSu6QJos8uqb9oBY/u4gwxkZ4wMrk8iio+WOm9m/L/hr +goq78tCPT/H
Eb2ekPd2zvLfyJC/2SGaTymNuJSSoQ4+8BjJABznggazio1HD1/CVt/10/Uh P3eb0/Evp418
PvHLIL1xHEVw7W0qrKGfYrRkriRSxA3JkcjnkVn0T/4fa6031S079C2rS5X5 /hv919e3U3La
ZLi3jnjEipIodRJG0bAEZ5VgCp9iARTa5XYlMkpDCgAoAKACgAoAKACgCjqn 37P/AK6t/wCi
pKmWw0VqwKCgAoAZH9+T/e/oKAH0AFAFXVdPttV0+axvVka3nXbIscrRkjPT cpBH4HkcUbO4
J2IF0LThY3Vm0DPDeJsn8yV3eQbAnLkls7QOc579ead3e/nf573/AK9AWn9d O3oEmg6ZJaw2
0lqGit7j7VEGZiUl3Ft4Oc5yT37kdKLu6flb5Wt+QraNd/8Ah/0Hro2npBZQ pbhY7A5twGYb
PlKdc88MeueuetJ6381b5dvwQ/8AO/z7k2nWVvpthBY2UflW9ugjjTcTtUDA GTyfxqpScndi
LFSMKACgAoAKACgAoAKAMpfDelrqP25YZhJ5nneX9pl8kSdd/k7vL3Z5ztzn nrzTi3FWX9en
b/LQUve3/q239eSLL6VZP5u6HPnTpcv8zcyLt2t17bF46cUJtWt0v+N7/mxv qXKTVwMvSvD2
maTcNPYwPG5UooaaR1iUnJWNWYiNSQOFAHA9BT5mo8v9abA/ed3/AF/wTUpA FABQAUAFABQA
UAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFA DIP9RH/uj+VA
D6AOa+IX/IDj/wCuw/8AQWr1cr/jP0/VGNbZHjVfUmB7J8I/+Pa+/wB2L/2e vCzTePz/AEKo
7s72vHOgivButJhjdmNhjGc8emDn8j9DSYEtMCpq1tLdWLRW5RZQ6Ou84GVc Ng/lTi7MTV0c
doHgOPSdWnu7LT9KszLcxySNbxBCiqIzsTEa/IfLBxnG4sevFCsne/4f8ETu 9LHT69pD3+l/
ZtOlgspkmhmSRoPMQNG6sAUDLkYUDqOKlXUlJdP1TX6l6WafUz5tD1+eaC7k 1rT1vYlkhLx6
a4jaF9pI2GYkOCgIbdjkgqaJJOLj3Wv42t977gna3k7r+vu+4r2PgyfT7O0i tdTTzrW4SYPJ
bblcC3EDKVDg8gEgg8Ejg45upLnfk+ZP0k76dntrr6dpSsmuun3oZbeCblZL I3urJcJpixxW
W212MsSyxyESHeQ7ERINwCgYJxzTU2nzPd7/AHNfL4m3+Fhy1XKtFrp6/wCW tvXW52FQAUAF
ABQAUAFABQAUAFAFHVPv2f8A11b/ANFSVMthorVgUFABQAyP78n+9/QUAPoA KACgAoAKACgA
KACgAo
Re: (attachments added) Problem when debugging with "Web Script using XDebug" [message #18551 is a reply to message #18484] Wed, 09 May 2007 10:31 Go to previous messageGo to next message
D Kelsey is currently offline D KelseyFriend
Hi Ali. It sounds like XDebug is not initiating the session from the web server.
Can you post the output from a web script which does phpinfo() to see if XDebug is
seen and what the configuration is when running within the web browser.
> Ali B. wrote:
>> Hello everyone,
>> correctly.
>> [xdebug]
>> my broswer:
>> Cheers,
>> Ali
Re: (attachments added) Problem when debugging with "Web Script using XDebug" [message #18572 is a reply to message #18551] Wed, 09 May 2007 17:06 Go to previous messageGo to next message
Member
--------------050907080901010400070401
Thanks for the reply Dave, here is a saved page of what I get when I
web-xdebug a file with <?php phpinfo(); ?> while starting the apache
with Apache.exe -c "DocumentRoot "D:\eclipse\workspace""
Thanks again, appreciate your help.
Ali
> server.
> XDebug is
>> Ali B. wrote:
>>> Hello everyone,
>>> correctly.
>>> [xdebug]
>>> my broswer:
>>> Cheers,
>>> Ali
Content-Type: text/html;
name="index.html"
filename="index.html"
PCFET0NUWVBFIGh0bWwgUFVCTElDICItLy9XM0MvL0RURCBYSFRNTCAxLjAg VHJhbnNpdGlv
bmFsLy9FTiIgIkRURC94aHRtbDEtdHJhbnNpdGlvbmFsLmR0ZCI+CjxodG1s PjxoZWFkPg0K
DQo8c3R5bGUgdHlwZT0idGV4dC9jc3MiPg0KYm9keSB7YmFja2dyb3VuZC1j b2xvcjogI2Zm
ZmZmZjsgY29sb3I6ICMwMDAwMDA7fQ0KYm9keSwgdGQsIHRoLCBoMSwgaDIg e2ZvbnQtZmFt
aWx5OiBzYW5zLXNlcmlmO30NCnByZSB7bWFyZ2luOiAwcHg7IGZvbnQtZmFt aWx5OiBtb25v
c3BhY2U7fQ0KYTpsaW5rIHtjb2xvcjogIzAwMDA5OTsgdGV4dC1kZWNvcmF0 aW9uOiBub25l
OyBiYWNrZ3JvdW5kLWNvbG9yOiAjZmZmZmZmO30NCmE6aG92ZXIge3RleHQt ZGVjb3JhdGlv
bjogdW5kZXJsaW5lO30NCnRhYmxlIHtib3JkZXItY29sbGFwc2U6IGNvbGxh cHNlO30NCi5j
ZW50ZXIge3RleHQtYWxpZ246IGNlbnRlcjt9DQouY2VudGVyIHRhYmxlIHsg bWFyZ2luLWxl
ZnQ6IGF1dG87IG1hcmdpbi1yaWdodDogYXV0bzsgdGV4dC1hbGlnbjogbGVm dDt9DQouY2Vu
dGVyIHRoIHsgdGV4dC1hbGlnbjogY2VudGVyICFpbXBvcnRhbnQ7IH0NCnRk LCB0aCB7IGJv
cmRlcjogMXB4IHNvbGlkICMwMDAwMDA7IGZvbnQtc2l6ZTogNzUlOyB2ZXJ0 aWNhbC1hbGln
bjogYmFzZWxpbmU7fQ0KaDEge2ZvbnQtc2l6ZTogMTUwJTt9DQpoMiB7Zm9u dC1zaXplOiAx
MjUlO30NCi5wIHt0ZXh0LWFsaWduOiBsZWZ0O30NCi5lIHtiYWNrZ3JvdW5k LWNvbG9yOiAj
Y2NjY2ZmOyBmb250LXdlaWdodDogYm9sZDsgY29sb3I6ICMwMDAwMDA7fQ0K Lmgge2JhY2tn
cm91bmQtY29sb3I6ICM5OTk5Y2M7IGZvbnQtd2VpZ2h0OiBib2xkOyBjb2xv cjogIzAwMDAw
MDt9DQoudiB7YmFja2dyb3VuZC1jb2xvcjogI2NjY2NjYzsgY29sb3I6ICMw MDAwMDA7fQ0K
LnZyIHtiYWNrZ3JvdW5kLWNvbG9yOiAjY2NjY2NjOyB0ZXh0LWFsaWduOiBy aWdodDsgY29s
b3I6ICMwMDAwMDA7fQ0KaW1nIHtmbG9hdDogcmlnaHQ7IGJvcmRlcjogMHB4 O30NCmhyIHt3
aWR0aDogNjAwcHg7IGJhY2tncm91bmQtY29sb3I6ICNjY2NjY2M7IGJvcmRl cjogMHB4OyBo
ZWlnaHQ6IDFweDsgY29sb3I6ICMwMDAwMDA7fQ0KPC9zdHlsZT48dGl0bGU+ cGhwaW5mbygp
PC90aXRsZT48L2hlYWQ+PGJvZHk+PGRpdiBjbGFzcz0iY2VudGVyIj4NCjx0 YWJsZSBib3Jk
ZXI9IjAiIGNlbGxwYWRkaW5nPSIzIiB3aWR0aD0iNjAwIj4NCjx0Ym9keT48 dHIgY2xhc3M9
ImgiPjx0ZD4NCjxhIGhyZWY9Imh0dHA6Ly93d3cucGhwLm5ldC8iPjxpbWcg c3JjPSJpbmRl
eF9maWxlcy9pbmRleF8wMDIuZ2lmIiBhbHQ9IlBIUCBMb2dvIiBib3JkZXI9 IjAiPjwvYT48
aDEgY2xhc3M9InAiPlBIUCBWZXJzaW9uIDUuMi4wPC9oMT4NCjwvdGQ+PC90 cj4NCjwvdGJv
ZHk+PC90YWJsZT48YnI+DQo8dGFibGUgYm9yZGVyPSIwIiBjZWxscGFkZGlu Zz0iMyIgd2lk
dGg9IjYwMCI+DQo8dGJvZHk+PHRyPjx0ZCBjbGFzcz0iZSI+U3lzdGVtIDwv dGQ+PHRkIGNs
YXNzPSJ2Ij5XaW5kb3dzIE5UIFRIRU1BQ0hJTkUgNS4xIGJ1aWxkIDI2MDAg PC90ZD48L3Ry
Pg0KPHRyPjx0ZCBjbGFzcz0iZSI+QnVpbGQgRGF0ZSA8L3RkPjx0ZCBjbGFz cz0idiI+Tm92
ICAyIDIwMDYgMTE6NTA6NTUgPC90ZD48L3RyPg0KPHRyPjx0ZCBjbGFzcz0i ZSI+Q29uZmln
dXJlIENvbW1hbmQgPC90ZD48dGQgY2xhc3M9InYiPmNzY3JpcHQgL25vbG9n byBjb25maWd1
cmUuanMgICItLWVuYWJsZS1zbmFwc2hvdC1idWlsZCIgIi0td2l0aC1nZD1z aGFyZWQiIDwv
dGQ+PC90cj4NCjx0cj48dGQgY2xhc3M9ImUiPlNlcnZlciBBUEkgPC90ZD48 dGQgY2xhc3M9
InYiPkFwYWNoZSAyLjAgSGFuZGxlciA8L3RkPjwvdHI+DQo8dHI+PHRkIGNs YXNzPSJlIj5W
aXJ0dWFsIERpcmVjdG9yeSBTdXBwb3J0IDwvdGQ+PHRkIGNsYXNzPSJ2Ij5l bmFibGVkIDwv
dGQ+PC90cj4NCjx0cj48dGQgY2xhc3M9ImUiPkNvbmZpZ3VyYXRpb24gRmls ZSAocGhwLmlu
aSkgUGF0aCA8L3RkPjx0ZCBjbGFzcz0idiI+RDpcd2FtcFxBcGFjaGUyXGJp blxwaHAuaW5p
IDwvdGQ+PC90cj4NCjx0cj48dGQgY2xhc3M9ImUiPlBIUCBBUEkgPC90ZD48 dGQgY2xhc3M9
InYiPjIwMDQxMjI1IDwvdGQ+PC90cj4NCjx0cj48dGQgY2xhc3M9ImUiPlBI UCBFeHRlbnNp
b24gPC90ZD48dGQgY2xhc3M9InYiPjIwMDYwNjEzIDwvdGQ+PC90cj4NCjx0 cj48dGQgY2xh
c3M9ImUiPlplbmQgRXh0ZW5zaW9uIDwvdGQ+PHRkIGNsYXNzPSJ2Ij4yMjAw NjA1MTkgPC90
ZD48L3RyPg0KPHRyPjx0ZCBjbGFzcz0iZSI+RGVidWcgQnVpbGQgPC90ZD48 dGQgY2xhc3M9
InYiPm5vIDwvdGQ+PC90cj4NCjx0cj48dGQgY2xhc3M9ImUiPlRocmVhZCBT YWZldHkgPC90
ZD48dGQgY2xhc3M9InYiPmVuYWJsZWQgPC90ZD48L3RyPg0KPHRyPjx0ZCBj bGFzcz0iZSI+
WmVuZCBNZW1vcnkgTWFuYWdlciA8L3RkPjx0ZCBjbGFzcz0idiI+ZW5hYmxl ZCA8L3RkPjwv
dHI+DQo8dHI+PHRkIGNsYXNzPSJlIj5JUHY2IFN1cHBvcnQgPC90ZD48dGQg Y2xhc3M9InYi
PmVuYWJsZWQgPC90ZD48L3RyPg0KPHRyPjx0ZCBjbGFzcz0iZSI+UmVnaXN0 ZXJlZCBQSFAg
U3RyZWFtcyA8L3RkPjx0ZCBjbGFzcz0idiI+cGhwLCBmaWxlLCBkYXRhLCBo dHRwLCBmdHAs
IGNvbXByZXNzLnpsaWIgICA8L3RkPjwvdHI+DQo8dHI+PHRkIGNsYXNzPSJl Ij5SZWdpc3Rl
cmVkIFN0cmVhbSBTb2NrZXQgVHJhbnNwb3J0cyA8L3RkPjx0ZCBjbGFzcz0i diI+dGNwLCB1
ZHAgPC90ZD48L3RyPg0KPHRyPjx0ZCBjbGFzcz0iZSI+UmVnaXN0ZXJlZCBT dHJlYW0gRmls
dGVycyA8L3RkPjx0ZCBjbGFzcz0idiI+Y29udmVydC5pY29udi4qLCBzdHJp bmcucm90MTMs
IHN0cmluZy50b3VwcGVyLCBzdHJpbmcudG9sb3dlciwgc3RyaW5nLnN0cmlw X3RhZ3MsIGNv
bnZlcnQuKiwgY29uc3VtZWQsIHpsaWIuKiA8L3RkPjwvdHI+DQo8L3Rib2R5 PjwvdGFibGU+
PGJyPg0KPHRhYmxlIGJvcmRlcj0iMCIgY2VsbHBhZGRpbmc9IjMiIHdpZHRo PSI2MDAiPg0K
PHRib2R5Pjx0ciBjbGFzcz0idiI+PHRkPg0KPGEgaHJlZj0iaHR0cDovL3d3 dy56ZW5kLmNv
bS8iPjxpbWcgc3JjPSJpbmRleF9maWxlcy9pbmRleC5naWYiIGFsdD0iWmVu ZCBsb2dvIiBi
b3JkZXI9IjAiPjwvYT4NClRoaXMgcHJvZ3JhbSBtYWtlcyB1c2Ugb2YgdGhl IFplbmQgU2Ny
aXB0aW5nIExhbmd1YWdlIEVuZ2luZTo8YnI+WmVuZCZuYnNwO0VuZ2luZSZu YnNwO3YyLjIu
MCwmbmJzcDtDb3B5cmlnaHQmbmJzcDsoYykmbmJzcDsxOTk4LTIwMDYmbmJz cDtaZW5kJm5i
c3A7VGVjaG5vbG9naWVzPGJyPiZuYnNwOyZuYnNwOyZuYnNwOyZuYnNwO3dp dGgmbmJzcDtY
ZGVidWcmbmJzcDt2Mi4wLjBSQzQtZGV2LCZuYnNwO0NvcHlyaWdodCZuYnNw OyhjKSZuYnNw
OzIwMDIsJm5ic3A7MjAwMywmbmJzcDsyMDA0LCZuYnNwOzIwMDUsJm5ic3A7 MjAwNiwmbmJz
cDsyMDA3LCZuYnNwO2J5Jm5ic3A7RGVyaWNrJm5ic3A7UmV0aGFuczxicj48 L3RkPjwvdHI+
DQo8L3Rib2R5PjwvdGFibGU+PGJyPg0KPGhyPg0KPGgxPjxhIGhyZWY9Imh0 dHA6Ly9sb2Nh
bGhvc3QvdGVzdC9pbmRleC5waHA/PVBIUEI4QjVGMkEwLTNDOTItMTFkMy1B M0E5LTRDN0Iw
OEMxMDAwMCI+UEhQIENyZWRpdHM8L2E+PC9oMT4NCjxocj4NCjxoMT5Db25m aWd1cmF0aW9u
PC9oMT4NCjxoMj5QSFAgQ29yZTwvaDI+DQo8dGFibGUgYm9yZGVyPSIwIiBj ZWxscGFkZGlu
Zz0iMyIgd2lkdGg9IjYwMCI+DQo8dGJvZHk+PHRyIGNsYXNzPSJoIj48dGg+ RGlyZWN0aXZl
PC90aD48dGg+TG9jYWwgVmFsdWU8L3RoPjx0aD5NYXN0ZXIgVmFsdWU8L3Ro PjwvdHI+DQo8
dHI+PHRkIGNsYXNzPSJlIj5hbGxvd19jYWxsX3RpbWVfcGFzc19yZWZlcmVu Y2U8L3RkPjx0
ZCBjbGFzcz0idiI+T248L3RkPjx0ZCBjbGFzcz0idiI+T248L3RkPjwvdHI+ DQo8dHI+PHRk
IGNsYXNzPSJlIj5hbGxvd191cmxfZm9wZW48L3RkPjx0ZCBjbGFzcz0idiI+ T248L3RkPjx0
ZCBjbGFzcz0idiI+T248L3RkPjwvdHI+DQo8dHI+PHRkIGNsYXNzPSJlIj5h bGxvd191cmxf
aW5jbHVkZTwvdGQ+PHRkIGNsYXNzPSJ2Ij5PZmY8L3RkPjx0ZCBjbGFzcz0i diI+T2ZmPC90
ZD48L3RyPg0KPHRyPjx0ZCBjbGFzcz0iZSI+YWx3YXlzX3BvcHVsYXRlX3Jh d19wb3N0X2Rh
dGE8L3RkPjx0ZCBjbGFzcz0idiI+T2ZmPC90ZD48dGQgY2xhc3M9InYiPk9m ZjwvdGQ+PC90
cj4NCjx0cj48dGQgY2xhc3M9ImUiPmFyZ19zZXBhcmF0b3IuaW5wdXQ8L3Rk Pjx0ZCBjbGFz
cz0idiI+JmFtcDs8L3RkPjx0ZCBjbGFzcz0idiI+JmFtcDs8L3RkPjwvdHI+ DQo8dHI+PHRk
IGNsYXNzPSJlIj5hcmdfc2VwYXJhdG9yLm91dHB1dDwvdGQ+PHRkIGNsYXNz PSJ2Ij4mYW1w
OzwvdGQ+PHRkIGNsYXNzPSJ2Ij4mYW1wOzwvdGQ+PC90cj4NCjx0cj48dGQg Y2xhc3M9ImUi
PmFzcF90YWdzPC90ZD48dGQgY2xhc3M9InYiPk9mZjwvdGQ+PHRkIGNsYXNz PSJ2Ij5PZmY8
L3RkPjwvdHI+DQo8dHI+PHRkIGNsYXNzPSJlIj5hdXRvX2FwcGVuZF9maWxl PC90ZD48dGQg
Y2xhc3M9InYiPjxpPm5vIHZhbHVlPC9pPjwvdGQ+PHRkIGNsYXNzPSJ2Ij48 aT5ubyB2YWx1
ZTwvaT48L3RkPjwvdHI+DQo8dHI+PHRkIGNsYXNzPSJlIj5hdXRvX2dsb2Jh bHNfaml0PC90
ZD48dGQgY2xhc3M9InYiPk9uPC90ZD48dGQgY2xhc3M9InYiPk9uPC90ZD48 L3RyPg0KPHRy
Pjx0ZCBjbGFzcz0iZSI+YXV0b19wcmVwZW5kX2ZpbGU8L3RkPjx0ZCBjbGFz cz0idiI+PGk+
bm8gdmFsdWU8L2k+PC90ZD48dGQgY2xhc3M9InYiPjxpPm5vIHZhbHVlPC9p PjwvdGQ+PC90
cj4NCjx0cj48dGQgY2xhc3M9ImUiPmJyb3dzY2FwPC90ZD48dGQgY2xhc3M9 InYiPjxpPm5v
IHZhbHVlPC9pPjwvdGQ+PHRkIGNsYXNzPSJ2Ij48aT5ubyB2YWx1ZTwvaT48 L3RkPjwvdHI+
DQo8dHI+PHRkIGNsYXNzPSJlIj5kZWZhdWx0X2NoYXJzZXQ8L3RkPjx0ZCBj bGFzcz0idiI+
PGk+bm8gdmFsdWU8L2k+PC90ZD48dGQgY2xhc3M9InYiPjxpPm5vIHZhbHVl PC9pPjwvdGQ+
PC90cj4NCjx0cj48dGQgY2xhc3M9ImUiPmRlZmF1bHRfbWltZXR5cGU8L3Rk Pjx0ZCBjbGFz
cz0idiI+dGV4dC9odG1sPC90ZD48dGQgY2xhc3M9InYiPnRleHQvaHRtbDwv dGQ+PC90cj4N
Cjx0cj48dGQgY2xhc3M9ImUiPmRlZmluZV9zeXNsb2dfdmFyaWFibGVzPC90 ZD48dGQgY2xh
c3M9InYiPk9mZjwvdGQ+PHRkIGNsYXNzPSJ2Ij5PZmY8L3RkPjwvdHI+DQo8 dHI+PHRkIGNs
YXNzPSJlIj5kaXNhYmxlX2NsYXNzZXM8L3RkPjx0ZCBjbGFzcz0idiI+PGk+ bm8gdmFsdWU8
L2k+PC90ZD48dGQgY2xhc3M9InYiPjxpPm5vIHZhbHVlPC9pPjwvdGQ+PC90 cj4NCjx0cj48
dGQgY2xhc3M9ImUiPmRpc2FibGVfZnVuY3Rpb25zPC90ZD48dGQgY2xhc3M9 InYiPjxpPm5v
DQo8dHI+PHRkIGNsYXNzPSJlIj5kaXNwbGF5X2Vycm9yczwvdGQ+PHRkIGNs YXNzPSJ2Ij5P
bjwvdGQ+PHRkIGNsYXNzPSJ2Ij5PbjwvdGQ+PC90cj4NCjx0cj48dGQgY2xh c3M9ImUiPmRp
c3BsYXlfc3RhcnR1cF9lcnJvcnM8L3RkPjx0ZCBjbGFzcz0idiI+T2ZmPC90 ZD48dGQgY2xh
c3M9InYiPk9mZjwvdGQ+PC90cj4NCjx0cj48dGQgY2xhc3M9ImUiPmRvY19y b290PC90ZD48
dGQgY2xhc3M9InYiPjxpPm5vIHZhbHVlPC9pPjwvdGQ+PHRkIGNsYXNzPSJ2 Ij48aT5ubyB2
YWx1ZTwvaT48L3RkPjwvdHI+DQo8dHI+PHRkIGNsYXNzPSJlIj5kb2NyZWZf ZXh0PC90ZD48
YWx1ZTwvaT48L3RkPjwvdHI+DQo8dHI+PHRkIGNsYXNzPSJlIj5kb2NyZWZf cm9vdDwvdGQ+
PHRkIGNsYXNzPSJ2Ij48aT5ubyB2YWx1ZTwvaT48L3RkPjx0ZCBjbGFzcz0i diI+PGk+bm8g
dmFsdWU8L2k+PC90ZD48L3RyPg0KPHRyPjx0ZCBjbGFzcz0iZSI+ZW5hYmxl X2RsPC90ZD48
dGQgY2xhc3M9InYiPk9uPC90ZD48dGQgY2xhc3M9InYiPk9uPC90ZD48L3Ry Pg0KPHRyPjx0
ZCBjbGFzcz0iZSI+ZXJyb3JfYXBwZW5kX3N0cmluZzwvdGQ+PHRkIGNsYXNz PSJ2Ij48aT5u
byB2YWx1ZTwvaT48L3RkPjx0ZCBjbGFzcz0idiI+PGk+bm8gdmFsdWU8L2k+ PC90ZD48L3Ry
Pg0KPHRyPjx0ZCBjbGFzcz0iZSI+ZXJyb3JfbG9nPC90ZD48dGQgY2xhc3M9 InYiPkQ6L3dh
bXAvbG9ncy9waHBfZXJyb3IubG9nPC90ZD48dGQgY2xhc3M9InYiPkQ6L3dh bXAvbG9ncy9w
aHBfZXJyb3IubG9nPC90ZD48L3RyPg0KPHRyPjx0ZCBjbGFzcz0iZSI+ZXJy b3JfcHJlcGVu
ZF9zdHJpbmc8L3RkPjx0ZCBjbGFzcz0idiI+PGk+bm8gdmFsdWU8L2k+PC90 ZD48dGQgY2xh
c3M9InYiPjxpPm5vIHZhbHVlPC9pPjwvdGQ+PC90cj4NCjx0cj48dGQgY2xh c3M9ImUiPmVy
cm9yX3JlcG9ydGluZzwvdGQ+PHRkIGNsYXNzPSJ2Ij42MTM1PC90ZD48dGQg Y2xhc3M9InYi
PjYxMzU8L3RkPjwvdHI+DQo8dHI+PHRkIGNsYXNzPSJlIj5leHBvc2VfcGhw PC90ZD48dGQg
Y2xhc3M9InYiPk9uPC90ZD48dGQgY2xhc3M9InYiPk9uPC90ZD48L3RyPg0K PHRyPjx0ZCBj
bGFzcz0iZSI+ZXh0ZW5zaW9uX2RpcjwvdGQ+PHRkIGNsYXNzPSJ2Ij5EOi93 YW1wL3BocC9l
eHQvPC90ZD48dGQgY2xhc3M9InYiPkQ6L3dhbXAvcGhwL2V4dC88L3RkPjwv dHI+DQo8dHI+
PHRkIGNsYXNzPSJlIj5maWxlX3VwbG9hZHM8L3RkPjx0ZCBjbGFzcz0idiI+ T248L3RkPjx0
ZCBjbGFzcz0idiI+T248L3RkPjwvdHI+DQo8dHI+PHRkIGNsYXNzPSJlIj5o aWdobGlnaHQu
Ymc8L3RkPjx0ZCBjbGFzcz0idiI+PGZvbnQgc3R5bGU9ImNvbG9yOiByZ2Io MjU1LCAyNTUs
IDI1NSk7Ij4jRkZGRkZGPC9mb250PjwvdGQ+PHRkIGNsYXNzPSJ2Ij48Zm9u dCBzdHlsZT0i
Y29sb3I6IHJnYigyNTUsIDI1NSwgMjU1KTsiPiNGRkZGRkY8L2ZvbnQ+PC90 ZD48L3RyPg0K
PHRyPjx0ZCBjbGFzcz0iZSI+aGlnaGxpZ2h0LmNvbW1lbnQ8L3RkPjx0ZCBj bGFzcz0idiI+
PGZvbnQgc3R5bGU9ImNvbG9yOiByZ2IoMjU1LCAxMjgsIDApOyI+I0ZGODAw MDwvZm9udD48
L3RkPjx0ZCBjbGFzcz0idiI+PGZvbnQgc3R5bGU9ImNvbG9yOiByZ2IoMjU1 LCAxMjgsIDAp
OyI+I0ZGODAwMDwvZm9udD48L3RkPjwvdHI+DQo8dHI+PHRkIGNsYXNzPSJl Ij5oaWdobGln
aHQuZGVmYXVsdDwvdGQ+PHRkIGNsYXNzPSJ2Ij48Zm9udCBzdHlsZT0iY29s b3I6IHJnYigw
LCAwLCAxODcpOyI+IzAwMDBCQjwvZm9udD48L3RkPjx0ZCBjbGFzcz0idiI+ PGZvbnQgc3R5
bGU9ImNvbG9yOiByZ2IoMCwgMCwgMTg3KTsiPiMwMDAwQkI8L2ZvbnQ+PC90 ZD48L3RyPg0K
PHRyPjx0ZCBjbGFzcz0iZSI+aGlnaGxpZ2h0Lmh0bWw8L3RkPjx0ZCBjbGFz cz0idiI+PGZv
bnQgc3R5bGU9ImNvbG9yOiByZ2IoMCwgMCwgMCk7Ij4jMDAwMDAwPC9mb250 PjwvdGQ+PHRk
IGNsYXNzPSJ2Ij48Zm9udCBzdHlsZT0iY29sb3I6IHJnYigwLCAwLCAwKTsi PiMwMDAwMDA8
L2ZvbnQ+PC90ZD48L3RyPg0KPHRyPjx0ZCBjbGFzcz0iZSI+aGlnaGxpZ2h0 LmtleXdvcmQ8
L3RkPjx0ZCBjbGFzcz0idiI+PGZvbnQgc3R5bGU9ImNvbG9yOiByZ2IoMCwg MTE5LCAwKTsi
PiMwMDc3MDA8L2ZvbnQ+PC90ZD48dGQgY2xhc3M9InYiPjxmb250IHN0eWxl PSJjb2xvcjog
cmdiKDAsIDExOSwgMCk7Ij4jMDA3NzAwPC9mb250PjwvdGQ+PC90cj4NCjx0 cj48dGQgY2xh
c3M9ImUiPmhpZ2hsaWdodC5zdHJpbmc8L3RkPjx0ZCBjbGFzcz0idiI+PGZv bnQgc3R5bGU9
ImNvbG9yOiByZ2IoMjIxLCAwLCAwKTsiPiNERDAwMDA8L2ZvbnQ+PC90ZD48 dGQgY2xhc3M9
InYiPjxmb250IHN0eWxlPSJjb2xvcjogcmdiKDIyMSwgMCwgMCk7Ij4jREQw MDAwPC9mb250
PjwvdGQ+PC90cj4NCjx0cj48dGQgY2xhc3M9ImUiPmh0bWxfZXJyb3JzPC90 ZD48dGQgY2xh
c3M9InYiPk9uPC90ZD48dGQgY2xhc3M9InYiPk9uPC90ZD48L3RyPg0KPHRy Pjx0ZCBjbGFz
cz0iZSI+aWdub3JlX3JlcGVhdGVkX2Vycm9yczwvdGQ+PHRkIGNsYXNzPSJ2 Ij5PZmY8L3Rk
Pjx0ZCBjbGFzcz0idiI+T2ZmPC90ZD48L3RyPg0KPHRyPjx0ZCBjbGFzcz0i ZSI+aWdub3Jl
X3JlcGVhdGVkX3NvdXJjZTwvdGQ+PHRkIGNsYXNzPSJ2Ij5PZmY8L3RkPjx0 ZCBjbGFzcz0i
diI+T2ZmPC90ZD48L3RyPg0KPHRyPjx0ZCBjbGFzcz0iZSI+aWdub3JlX3Vz ZXJfYWJvcnQ8
L3RkPjx0ZCBjbGFzcz0idiI+T2ZmPC90ZD48dGQgY2xhc3M9InYiPk9mZjwv dGQ+PC90cj4N
Cjx0cj48dGQgY2xhc3M9ImUiPmltcGxpY2l0X2ZsdXNoPC90ZD48dGQgY2xh c3M9InYiPk9m
ZjwvdGQ+PHRkIGNsYXNzPSJ2Ij5PZmY8L3RkPjwvdHI+DQo8dHI+PHRkIGNs YXNzPSJlIj5p
bmNsdWRlX3BhdGg8L3RkPjx0ZCBjbGFzcz0idiI+LjtDOlxwaHA1XHBlYXI8 L3RkPjx0ZCBj
bGFzcz0idiI+LjtDOlxwaHA1XHBlYXI8L3RkPjwvdHI+DQo8dHI+PHRkIGNs YXNzPSJlIj5s
b2dfZXJyb3JzPC90ZD48dGQgY2xhc3M9InYiPk9uPC90ZD48dGQgY2xhc3M9 InYiPk9uPC90
ZD48L3RyPg0KPHRyPjx0ZCBjbGFzcz0iZSI+bG9nX2Vycm9yc19tYXhfbGVu PC90ZD48dGQg
Y2xhc3M9InYiPjEwMjQ8L3RkPjx0ZCBjbGFzcz0idiI+MTAyNDwvdGQ+PC90 cj4NCjx0cj48
dGQgY2xhc3M9ImUiPm1hZ2ljX3F1b3Rlc19ncGM8L3RkPjx0ZCBjbGFzcz0i diI+T248L3Rk
Pjx0ZCBjbGFzcz0idiI+T248L3RkPjwvdHI+DQo8dHI+PHRkIGNsYXNzPSJl Ij5tYWdpY19x
dW90ZXNfcnVudGltZTwvdGQ+PHRkIGNsYXNzPSJ2Ij5PZmY8L3RkPjx0ZCBj bGFzcz0idiI+
T2ZmPC90ZD48L3RyPg0KPHRyPjx0ZCBjbGFzcz0iZSI+bWFnaWNfcXVvdGVz X3N5YmFzZTwv
dGQ+PHRkIGNsYXNzPSJ2Ij5PZmY8L3RkPjx0ZCBjbGFzcz0idiI+T2ZmPC90 ZD48L3RyPg0K
PHRyPjx0ZCBjbGFzcz0iZSI+bWFpbC5mb3JjZV9leHRyYV9wYXJhbWV0ZXJz PC90ZD48dGQg
ZTwvaT48L3RkPjwvdHI+DQo8dHI+PHRkIGNsYXNzPSJlIj5tYXhfZXhlY3V0 aW9uX3RpbWU8
L3RkPjx0ZCBjbGFzcz0idiI+MzA8L3RkPjx0ZCBjbGFzcz0idiI+MzA8L3Rk PjwvdHI+DQo8
dHI+PHRkIGNsYXNzPSJlIj5tYXhfaW5wdXRfdGltZTwvdGQ+PHRkIGNsYXNz PSJ2Ij42MDwv
dGQ+PHRkIGNsYXNzPSJ2Ij42MDwvdGQ+PC90cj4NCjx0cj48dGQgY2xhc3M9 ImUiPm9wZW5f
YmFzZWRpcjwvdGQ+PHRkIGNsYXNzPSJ2Ij48aT5ubyB2YWx1ZTwvaT48L3Rk Pjx0ZCBjbGFz
cz0idiI+PGk+bm8gdmFsdWU8L2k+PC90ZD48L3RyPg0KPHRyPjx0ZCBjbGFz cz0iZSI+b3V0
cHV0X2J1ZmZlcmluZzwvdGQ+PHRkIGNsYXNzPSJ2Ij48aT5ubyB2YWx1ZTwv aT48L3RkPjx0
ZCBjbGFzcz0idiI+PGk+bm8gdmFsdWU8L2k+PC90ZD48L3RyPg0KPHRyPjx0 ZCBjbGFzcz0i
ZSI+b3V0cHV0X2hhbmRsZXI8L3RkPjx0ZCBjbGFzcz0idiI+PGk+bm8gdmFs dWU8L2k+PC90
ZD48dGQgY2xhc3M9InYiPjxpPm5vIHZhbHVlPC9pPjwvdGQ+PC90cj4NCjx0 cj48dGQgY2xh
c3M9ImUiPnBvc3RfbWF4X3NpemU8L3RkPjx0ZCBjbGFzcz0idiI+OE08L3Rk Pjx0ZCBjbGFz
cz0idiI+OE08L3RkPjwvdHI+DQo8dHI+PHRkIGNsYXNzPSJlIj5wcmVjaXNp b248L3RkPjx0
ZCBjbGFzcz0idiI+MTI8L3RkPjx0ZCBjbGFzcz0idiI+MTI8L3RkPjwvdHI+ DQo8dHI+PHRk
IGNsYXNzPSJlIj5yZWFscGF0aF9jYWNoZV9zaXplPC90ZD48dGQgY2xhc3M9 InYiPjE2Szwv
dGQ+PHRkIGNsYXNzPSJ2Ij4xNks8L3RkPjwvdHI+DQo8dHI+PHRkIGNsYXNz PSJlIj5yZWFs
cGF0aF9jYWNoZV90dGw8L3RkPjx0ZCBjbGFzcz0idiI+MTIwPC90ZD48dGQg Y2xhc3M9InYi
PjEyMDwvdGQ+PC90cj4NCjx0cj48dGQgY2xhc3M9ImUiPnJlZ2lzdGVyX2Fy Z2NfYXJndjwv
dGQ+PHRkIGNsYXNzPSJ2Ij5PbjwvdGQ+PHRkIGNsYXNzPSJ2Ij5PbjwvdGQ+ PC90cj4NCjx0
cj48dGQgY2xhc3M9ImUiPnJlZ2lzdGVyX2dsb2JhbHM8L3RkPjx0ZCBjbGFz cz0idiI+T2Zm
PC90ZD48dGQgY2xhc3M9InYiPk9mZjwvdGQ+PC90cj4NCjx0cj48dGQgY2xh c3M9ImUiPnJl
Z2lzdGVyX2xvbmdfYXJyYXlzPC90ZD48dGQgY2xhc3M9InYiPk9uPC90ZD48 dGQgY2xhc3M9
InYiPk9uPC90ZD48L3RyPg0KPHRyPjx0ZCBjbGFzcz0iZSI+cmVwb3J0X21l bWxlYWtzPC90
Pjx0ZCBjbGFzcz0iZSI+cmVwb3J0X3plbmRfZGVidWc8L3RkPjx0ZCBjbGFz cz0idiI+T248
L3RkPjx0ZCBjbGFzcz0idiI+T248L3RkPjwvdHI+DQo8dHI+PHRkIGNsYXNz PSJlIj5zYWZl
X21vZGU8L3RkPjx0ZCBjbGFzcz0idiI+T2ZmPC90ZD48dGQgY2xhc3M9InYi Pk9mZjwvdGQ+
PC90cj4NCjx0cj48dGQgY2xhc3M9ImUiPnNhZmVfbW9kZV9leGVjX2Rpcjwv dGQ+PHRkIGNs
YXNzPSJ2Ij48aT5ubyB2YWx1ZTwvaT48L3RkPjx0ZCBjbGFzcz0idiI+PGk+ bm8gdmFsdWU8
L2k+PC90ZD48L3RyPg0KPHRyPjx0ZCBjbGFzcz0iZSI+c2FmZV9tb2RlX2dp ZDwvdGQ+PHRk
IGNsYXNzPSJ2Ij5PZmY8L3RkPjx0ZCBjbGFzcz0idiI+T2ZmPC90ZD48L3Ry Pg0KPHRyPjx0
ZCBjbGFzcz0iZSI+c2FmZV9tb2RlX2luY2x1ZGVfZGlyPC90ZD48dGQgY2xh c3M9InYiPjxp
Pm5vIHZhbHVlPC9pPjwvdGQ+PHRkIGNsYXNzPSJ2Ij48aT5ubyB2YWx1ZTwv aT48L3RkPjwv
dHI+DQo8dHI+PHRkIGNsYXNzPSJlIj5zZW5kbWFpbF9mcm9tPC90ZD48dGQg Y2xhc3M9InYi
PnlvdUB5b3VyZG9tYWluPC90ZD48dGQgY2xhc3M9InYiPnlvdUB5b3VyZG9t YWluPC90ZD48
L3RyPg0KPHRyPjx0ZCBjbGFzcz0iZSI+c2VuZG1haWxfcGF0aDwvdGQ+PHRk IGNsYXNzPSJ2
Ij48aT5ubyB2YWx1ZTwvaT48L3RkPjx0ZCBjbGFzcz0idiI+PGk+bm8gdmFs dWU8L2k+PC90
ZD48L3RyPg0KPHRyPjx0ZCBjbGFzcz0iZSI+c2VyaWFsaXplX3ByZWNpc2lv bjwvdGQ+PHRk
IGNsYXNzPSJ2Ij4xMDA8L3RkPjx0ZCBjbGFzcz0idiI+MTAwPC90ZD48L3Ry Pg0KPHRyPjx0
ZCBjbGFzcz0iZSI+c2hvcnRfb3Blbl90YWc8L3RkPjx0ZCBjbGFzcz0idiI+ T2ZmPC90ZD48
dGQgY2xhc3M9InYiPk9mZjwvdGQ+PC90cj4NCjx0cj48dGQgY2xhc3M9ImUi PlNNVFA8L3Rk
Pjx0ZCBjbGFzcz0idiI+bG9jYWxob3N0PC90ZD48dGQgY2xhc3M9InYiPmxv Y2FsaG9zdDwv
dGQ+PC90cj4NCjx0cj48dGQgY2xhc3M9ImUiPnNtdHBfcG9ydDwvdGQ+PHRk IGNsYXNzPSJ2
Ij4yNTwvdGQ+PHRkIGNsYXNzPSJ2Ij4yNTwvdGQ+PC90cj4NCjx0cj48dGQg Y2xhc3M9ImUi
PnNxbC5zYWZlX21vZGU8L3RkPjx0ZCBjbGFzcz0idiI+T2ZmPC90ZD48dGQg Y2xhc3M9InYi
Pk9mZjwvdGQ+PC90cj4NCjx0cj48dGQgY2xhc3M9ImUiPnRyYWNrX2Vycm9y czwvdGQ+PHRk
ZCBjbGFzcz0iZSI+dW5zZXJpYWxpemVfY2FsbGJhY2tfZnVuYzwvdGQ+PHRk IGNsYXNzPSJ2
ZD48L3RyPg0KPHRyPjx0ZCBjbGFzcz0iZSI+dXBsb2FkX21heF9maWxlc2l6 ZTwvdGQ+PHRk
IGNsYXNzPSJ2Ij4yTTwvdGQ+PHRkIGNsYXNzPSJ2Ij4yTTwvdGQ+PC90cj4N Cjx0cj48dGQg
Y2xhc3M9ImUiPnVwbG9hZF90bXBfZGlyPC90ZD48dGQgY2xhc3M9InYiPkQ6 L3dhbXAvdG1w
PC90ZD48dGQgY2xhc3M9InYiPkQ6L3dhbXAvdG1wPC90ZD48L3RyPg0KPHRy Pjx0ZCBjbGFz
cz0iZSI+dXNlcl9kaXI8L3RkPjx0ZCBjbGFzcz0idiI+PGk+bm8gdmFsdWU8 L2k+PC90ZD48
dGQgY2xhc3M9InYiPjxpPm5vIHZhbHVlPC9pPjwvdGQ+PC90cj4NCjx0cj48 dGQgY2xhc3M9
ImUiPnZhcmlhYmxlc19vcmRlcjwvdGQ+PHRkIGNsYXNzPSJ2Ij5FR1BDUzwv dGQ+PHRkIGNs
YXNzPSJ2Ij5FR1BDUzwvdGQ+PC90cj4NCjx0cj48dGQgY2xhc3M9ImUiPnht bHJwY19lcnJv
cl9udW1iZXI8L3RkPjx0ZCBjbGFzcz0idiI+MDwvdGQ+PHRkIGNsYXNzPSJ2 Ij4wPC90ZD48
L3RyPg0KPHRyPjx0ZCBjbGFzcz0iZSI+eG1scnBjX2Vycm9yczwvdGQ+PHRk IGNsYXNzPSJ2
Ij5PZmY8L3RkPjx0ZCBjbGFzcz0idiI+T2ZmPC90ZD48L3RyPg0KPHRyPjx0 ZCBjbGFzcz0i
ZSI+eTJrX2NvbXBsaWFuY2U8L3RkPjx0ZCBjbGFzcz0idiI+T248L3RkPjx0 ZCBjbGFzcz0i
diI+T248L3RkPjwvdHI+DQo8dHI+PHRkIGNsYXNzPSJlIj56ZW5kLnplMV9j b21wYXRpYmls
aXR5X21vZGU8L3RkPjx0ZCBjbGFzcz0idiI+T2ZmPC90ZD48dGQgY2xhc3M9 InYiPk9mZjwv
dGQ+PC90cj4NCjwvdGJvZHk+PC90YWJsZT48YnI+DQo8aDI+PGEgbmFtZT0i bW9kdWxlX2Fw
YWNoZTJoYW5kbGVyIj5hcGFjaGUyaGFuZGxlcjwvYT48L2gyPg0KPHRhYmxl IGJvcmRlcj0i
MCIgY2VsbHBhZGRpbmc9IjMiIHdpZHRoPSI2MDAiPg0KPHRib2R5Pjx0cj48 dGQgY2xhc3M9
ImUiPkFwYWNoZSBWZXJzaW9uIDwvdGQ+PHRkIGNsYXNzPSJ2Ij5BcGFjaGUv Mi4wLjU5IChX
aW4zMikgUEhQLzUuMi4wIDwvdGQ+PC90cj4NCjx0cj48dGQgY2xhc3M9ImUi PkFwYWNoZSBB
UEkgVmVyc2lvbiA8L3RkPjx0ZCBjbGFzcz0idiI+MjAwMjA5MDMgPC90ZD48 L3RyPg0KPHRy
Pjx0ZCBjbGFzcz0iZSI+U2VydmVyIEFkbWluaXN0cmF0b3IgPC90ZD48dGQg Y2xhc3M9InYi
PndlYm1hc3RlckBsb2NhbGhvc3QgPC90ZD48L3RyPg0KPHRyPjx0ZCBjbGFz cz0iZSI+SG9z
dG5hbWU6UG9ydCA8L3RkPjx0ZCBjbGFzcz0idiI+bG9jYWxob3N0OjgwIDwv dGQ+PC90cj4N
Cjx0cj48dGQgY2xhc3M9ImUiPk1heCBSZXF1ZXN0cyA8L3RkPjx0ZCBjbGFz cz0idiI+UGVy
IENoaWxkOiAwIC0gS2VlcCBBbGl2ZTogb24gLSBNYXggUGVyIENvbm5lY3Rp b246IDEwMCA8
L3RkPjwvdHI+DQo8dHI+PHRkIGNsYXNzPSJlIj5UaW1lb3V0cyA8L3RkPjx0 ZCBjbGFzcz0i
diI+Q29ubmVjdGlvbjogMzAwIC0gS2VlcC1BbGl2ZTogMTUgPC90ZD48L3Ry Pg0KPHRyPjx0
ZCBjbGFzcz0iZSI+VmlydHVhbCBTZXJ2ZXIgPC90ZD48dGQgY2xhc3M9InYi Pk5vIDwvdGQ+
PC90cj4NCjx0cj48dGQgY2xhc3M9ImUiPlNlcnZlciBSb290IDwvdGQ+PHRk IGNsYXNzPSJ2
Ij5EOi93YW1wL0FwYWNoZTIgPC90ZD48L3RyPg0KPHRyPjx0ZCBjbGFzcz0i ZSI+TG9hZGVk
IE1vZHVsZXMgPC90ZD48dGQgY2xhc3M9InYiPmNvcmUgbW9kX3dpbjMyDQpt cG1fd2lubnQg
aHR0cF9jb3JlIG1vZF9zbyBtb2RfYWNjZXNzIG1vZF9hY3Rpb25zIG1vZF9h bGlhcyBtb2Rf
YXNpcw0KbW9kX2F1dGggbW9kX2F1dG9pbmRleCBtb2RfY2dpIG1vZF9kaXIg bW9kX2VudiBt
b2RfaW1hcCBtb2RfaW5jbHVkZQ0KbW9kX2lzYXBpIG1vZF9sb2dfY29uZmln IG1vZF9taW1l
IG1vZF9uZWdvdGlhdGlvbiBtb2RfcmV3cml0ZQ0KbW9kX3NldGVudmlmIG1v ZF91c2VyZGly
IG1vZF9waHA1IDwvdGQ+PC90cj4NCjwvdGJvZHk+PC90YWJsZT48YnI+DQo8 dGFibGUgYm9y
ZGVyPSIwIiBjZWxscGFkZGluZz0iMyIgd2lkdGg9IjYwMCI+DQo8dGJvZHk+ PHRyIGNsYXNz
PSJoIj48dGg+RGlyZWN0aXZlPC90aD48dGg+TG9jYWwgVmFsdWU8L3RoPjx0 aD5NYXN0ZXIg
VmFsdWU8L3RoPjwvdHI+DQo8dHI+PHRkIGNsYXNzPSJlIj5lbmdpbmU8L3Rk Pjx0ZCBjbGFz
cz0idiI+MTwvdGQ+PHRkIGNsYXNzPSJ2Ij4xPC90ZD48L3RyPg0KPHRyPjx0 ZCBjbGFzcz0i
ZSI+bGFzdF9tb2RpZmllZDwvdGQ+PHRkIGNsYXNzPSJ2Ij4wPC90ZD48dGQg Y2xhc3M9InYi
PjA8L3RkPjwvdHI+DQo8dHI+PHRkIGNsYXNzPSJlIj54Yml0aGFjazwvdGQ+ PHRkIGNsYXNz
PSJ2Ij4wPC90ZD48dGQgY2xhc3M9InYiPjA8L3RkPjwvdHI+DQo8L3Rib2R5 PjwvdGFibGU+
PGJyPg0KPGgyPkFwYWNoZSBFbnZpcm9ubWVudDwvaDI+DQo8dGFibGUgYm9y ZGVyPSIwIiBj
ZWxscGFkZGluZz0iMyIgd2lkdGg9IjYwMCI+DQo8dGJvZHk+PHRyIGNsYXNz PSJoIj48dGg+
VmFyaWFibGU8L3RoPjx0aD5WYWx1ZTwvdGg+PC90cj4NCjx0cj48dGQgY2xh c3M9ImUiPkhU
VFBfSE9TVCA8L3RkPjx0ZCBjbGFzcz0idiI+bG9jYWxob3N0IDwvdGQ+PC90 cj4NCjx0cj48
dGQgY2xhc3M9ImUiPkhUVFBfVVNFUl9BR0VOVCA8L3RkPjx0ZCBjbGFzcz0i diI+TW96aWxs
YS81LjAgKFdpbmRvd3M7IFU7IFdpbmRvd3MgTlQgNS4xOyBlbi1VUzsgcnY6 MS44LjEuMykg
R2Vja28vMjAwNzAzMDkgRmlyZWZveC8yLjAuMC4zIDwvdGQ+PC90cj4NCjx0 cj48dGQgY2xh
c3M9ImUiPkhUVFBfQUNDRVBUIDwvdGQ+PHRkIGNsYXNzPSJ2Ij50ZXh0L3ht bCxhcHBsaWNh
dGlvbi94bWwsYXBwbGljYXRpb24veGh0bWwreG1sLHRleHQvaHRtbDtxPTAu OSx0ZXh0L3Bs
YWluO3E9MC44LGltYWdlL3BuZywqLyo7cT0wLjUgPC90ZD48L3RyPg0KPHRy Pjx0ZCBjbGFz
cz0iZSI+SFRUUF9BQ0NFUFRfTEFOR1VBR0UgPC90ZD48dGQgY2xhc3M9InYi PmVuLXVzLGVu
O3E9MC43LGFyO3E9MC4zIDwvdGQ+PC90cj4NCjx0cj48dGQgY2xhc3M9ImUi PkhUVFBfQUND
RVBUX0VOQ09ESU5HIDwvdGQ+PHRkIGNsYXNzPSJ2Ij5nemlwLGRlZmxhdGUg PC90ZD48L3Ry
Pg0KPHRyPjx0ZCBjbGFzcz0iZSI+SFRUUF9BQ0NFUFRfQ0hBUlNFVCA8L3Rk Pjx0ZCBjbGFz
cz0idiI+SVNPLTg4NTktMSx1dGYtODtxPTAuNywqO3E9MC43IDwvdGQ+PC90 cj4NCjx0cj48
dGQgY2xhc3M9ImUiPkhUVFBfS0VFUF9BTElWRSA8L3RkPjx0ZCBjbGFzcz0i diI+MzAwIDwv
dGQ+PC90cj4NCjx0cj48dGQgY2xhc3M9ImUiPkhUVFBfQ09OTkVDVElPTiA8 L3RkPjx0ZCBj
bGFzcz0idiI+a2VlcC1hbGl2ZSA8L3RkPjwvdHI+DQo8dHI+PHRkIGNsYXNz PSJlIj5QQVRI
IDwvdGQ+PHRkIGNsYXNzPSJ2Ij5EOlxBY3RpdmVTdGF0ZSBLb21vZG8gSURF DQo0LjBcO0M6
XFByb2dyYW0gRmlsZXNcUEMgQ29ubmVjdGl2aXR5DQpTb2x1dGlvblw7Qzpc cGhwNVw7Qzpc
V0lORE9XU1xzeXN0ZW0zMjtDOlxXSU5ET1dTO0M6XFdJTkRPV1NcU3lzdGVt MzJcV2JlbTtD
OlxQcm9ncmFtDQpGaWxlc1xDb21tb24gRmlsZXNcQWRvYmVcQUdMO0M6XFBy b2dyYW0NCkZp
bGVzXEphdmFcanJlMS41LjBfMDhcYmluXDtDOlxQcm9ncmFtIEZpbGVzXElE TSBDb21wdXRl
cg0KU29sdXRpb25zXFVsdHJhRWRpdC0zMjtDOlxQcm9ncmFtIEZpbGVzXFF1 aWNrVGltZVxR
VFN5c3RlbVwgPC90ZD48L3RyPg0KPHRyPjx0ZCBjbGFzcz0iZSI+U3lzdGVt Um9vdCA8L3Rk
Pjx0ZCBjbGFzcz0idiI+QzpcV0lORE9XUyA8L3RkPjwvdHI+DQo8dHI+PHRk IGNsYXNzPSJl
Ij5DT01TUEVDIDwvdGQ+PHRkIGNsYXNzPSJ2Ij5DOlxXSU5ET1dTXHN5c3Rl bTMyXGNtZC5l
eGUgPC90ZD48L3RyPg0KPHRyPjx0ZCBjbGFzcz0iZSI+UEFUSEVYVCA8L3Rk Pjx0ZCBjbGFz
cz0idiI+LkNPTTsuRVhFOy5CQVQ7LkNNRDsuVkJTOy5WQkU7LkpTOy5KU0U7 LldTRjsuV1NI
IDwvdGQ+PC90cj4NCjx0cj48dGQgY2xhc3M9ImUiPldJTkRJUiA8L3RkPjx0 ZCBjbGFzcz0i
diI+QzpcV0lORE9XUyA8L3RkPjwvdHI+DQo8dHI+PHRkIGNsYXNzPSJlIj5T RVJWRVJfU0lH
TkFUVVJFIDwvdGQ+PHRkIGNsYXNzPSJ2Ij4mbHQ7YWRkcmVzcyZndDtBcGFj aGUvMi4wLjU5
IChXaW4zMikgUEhQLzUuMi4wIFNlcnZlciBhdCBsb2NhbGhvc3QgUG9ydCA4 MCZsdDsvYWRk
cmVzcyZndDsNCiA8L3RkPjwvdHI+DQo8dHI+PHRkIGNsYXNzPSJlIj5TRVJW RVJfU09GVFdB
UkUgPC90ZD48dGQgY2xhc3M9InYiPkFwYWNoZS8yLjAuNTkgKFdpbjMyKSBQ SFAvNS4yLjAg
PC90ZD48L3RyPg0KPHRyPjx0ZCBjbGFzcz0iZSI+U0VSVkVSX05BTUUgPC90 ZD48dGQgY2xh
c3M9InYiPmxvY2FsaG9zdCA8L3RkPjwvdHI+DQo8dHI+PHRkIGNsYXNzPSJl Ij5TRVJWRVJf
QUREUiA8L3RkPjx0ZCBjbGFzcz0idiI+MTI3LjAuMC4xIDwvdGQ+PC90cj4N Cjx0cj48dGQg
Y2xhc3M9ImUiPlNFUlZFUl9QT1JUIDwvdGQ+PHRkIGNsYXNzPSJ2Ij44MCA8 L3RkPjwvdHI+
DQo8dHI+PHRkIGNsYXNzPSJlIj5SRU1PVEVfQUREUiA8L3RkPjx0ZCBjbGFz cz0idiI+MTI3
LjAuMC4xIDwvdGQ+PC90cj4NCjx0cj48dGQgY2xhc3M9ImUiPkRPQ1VNRU5U X1JPT1QgPC90
ZD48dGQgY2xhc3M9InYiPkQ6L2VjbGlwc2Uvd29ya3NwYWNlIDwvdGQ+PC90 cj4NCjx0cj48
dGQgY2xhc3M9ImUiPlNFUlZFUl9BRE1JTiA8L3RkPjx0ZCBjbGFzcz0idiI+ d2VibWFzdGVy
QGxvY2FsaG9zdCA8L3RkPjwvdHI+DQo8dHI+PHRkIGNsYXNzPSJlIj5TQ1JJ UFRfRklMRU5B
TUUgPC90ZD48dGQgY2xhc3M9InYiPkQ6L2VjbGlwc2Uvd29ya3NwYWNlL3Rl c3QvaW5kZXgu
cGhwIDwvdGQ+PC90cj4NCjx0cj48dGQgY2xhc3M9ImUiPlJFTU9URV9QT1JU IDwvdGQ+PHRk
IGNsYXNzPSJ2Ij4xMTQxIDwvdGQ+PC90cj4NCjx0cj48dGQgY2xhc3M9ImUi PkdBVEVXQVlf
SU5URVJGQUNFIDwvdGQ+PHRkIGNsYXNzPSJ2Ij5DR0kvMS4xIDwvdGQ+PC90 cj4NCjx0cj48
dGQgY2xhc3M9ImUiPlNFUlZFUl9QUk9UT0NPTCA8L3RkPjx0ZCBjbGFzcz0i diI+SFRUUC8x
LjEgPC90ZD48L3RyPg0KPHRyPjx0ZCBjbGFzcz0iZSI+UkVRVUVTVF9NRVRI T0QgPC90ZD48
dGQgY2xhc3M9InYiPkdFVCA8L3RkPjwvdHI+DQo8dHI+PHRkIGNsYXNzPSJl Ij5RVUVSWV9T
VFJJTkcgPC90ZD48dGQgY2xhc3M9InYiPlhERUJVR19TRVNTSU9OX1NUQVJU PUVDTElQU0Vf
WERFQlVHJmFtcDtLRVk9MTE3ODcyOTk2MzA2MjEgPC90ZD48L3RyPg0KPHRy Pjx0ZCBjbGFz
cz0iZSI+UkVRVUVTVF9VUkkgPC90ZD48dGQgY2xhc3M9InYiPi90ZXN0L2lu ZGV4LnBocD9Y
REVCVUdfU0VTU0lPTl9TVEFSVD1FQ0xJUFNFX1hERUJVRyZhbXA7S0VZPTEx Nzg3Mjk5NjMw
NjIxIDwvdGQ+PC90cj4NCjx0cj48dGQgY2xhc3M9ImUiPlNDUklQVF9OQU1F IDwvdGQ+PHRk
IGNsYXNzPSJ2Ij4vdGVzdC9pbmRleC5waHAgPC90ZD48L3RyPg0KPC90Ym9k eT48L3RhYmxl
Pjxicj4NCjxoMj5IVFRQIEhlYWRlcnMgSW5mb3JtYXRpb248L2gyPg0KPHRh YmxlIGJvcmRl
cj0iMCIgY2VsbHBhZGRpbmc9IjMiIHdpZHRoPSI2MDAiPg0KPHRib2R5Pjx0 ciBjbGFzcz0i
aCI+PHRoIGNvbHNwYW49IjIiPkhUVFAgUmVxdWVzdCBIZWFkZXJzPC90aD48 L3RyPg0KPHRy
Pjx0ZCBjbGFzcz0iZSI+SFRUUCBSZXF1ZXN0IDwvdGQ+PHRkIGNsYXNzPSJ2 Ij5HRVQgL3Rl
c3QvaW5kZXgucGhwP1hERUJVR19TRVNTSU9OX1NUQVJUPUVDTElQU0VfWERF QlVHJmFtcDtL
RVk9MTE3ODcyOTk2MzA2MjEgSFRUUC8xLjEgPC90ZD48L3RyPg0KPHRyPjx0 ZCBjbGFzcz0i
ZSI+SG9zdCA8L3RkPjx0ZCBjbGFzcz0idiI+bG9jYWxob3N0IDwvdGQ+PC90 cj4NCjx0cj48
dGQgY2xhc3M9ImUiPlVzZXItQWdlbnQgPC90ZD48dGQgY2xhc3M9InYiPk1v emlsbGEvNS4w
IChXaW5kb3dzOyBVOyBXaW5kb3dzIE5UIDUuMTsgZW4tVVM7IHJ2OjEuOC4x LjMpIEdlY2tv
LzIwMDcwMzA5IEZpcmVmb3gvMi4wLjAuMyA8L3RkPjwvdHI+DQo8dHI+PHRk IGNsYXNzPSJl
Ij5BY2NlcHQgPC90ZD48dGQgY2xhc3M9InYiPnRleHQveG1sLGFwcGxpY2F0 aW9uL3htbCxh
cHBsaWNhdGlvbi94aHRtbCt4bWwsdGV4dC9odG1sO3E9MC45LHRleHQvcGxh aW47cT0wLjgs
aW1hZ2UvcG5nLCovKjtxPTAuNSA8L3RkPjwvdHI+DQo8dHI+PHRkIGNsYXNz PSJlIj5BY2Nl
cHQtTGFuZ3VhZ2UgPC90ZD48dGQgY2xhc3M9InYiPmVuLXVzLGVuO3E9MC43 LGFyO3E9MC4z
IDwvdGQ+PC90cj4NCjx0cj48dGQgY2xhc3M9ImUiPkFjY2VwdC1FbmNvZGlu ZyA8L3RkPjx0
ZCBjbGFzcz0idiI+Z3ppcCxkZWZsYXRlIDwvdGQ+PC90cj4NCjx0cj48dGQg Y2xhc3M9ImUi
PkFjY2VwdC1DaGFyc2V0IDwvdGQ+PHRkIGNsYXNzPSJ2Ij5JU08tODg1OS0x LHV0Zi04O3E9
MC43LCo7cT0wLjcgPC90ZD48L3RyPg0KPHRyPjx0ZCBjbGFzcz0iZSI+S2Vl cC1BbGl2ZSA8
L3RkPjx0ZCBjbGFzcz0idiI+MzAwIDwvdGQ+PC90cj4NCjx0cj48dGQgY2xh c3M9ImUiPkNv
bm5lY3Rpb24gPC90ZD48dGQgY2xhc3M9InYiPmtlZXAtYWxpdmUgPC90ZD48 L3RyPg0KPHRy
IGNsYXNzPSJoIj48dGggY29sc3Bhbj0iMiI+SFRUUCBSZXNwb25zZSBIZWFk ZXJzPC90aD48
L3RyPg0KPHRyPjx0ZCBjbGFzcz0iZSI+WC1Qb3dlcmVkLUJ5IDwvdGQ+PHRk IGNsYXNzPSJ2
Ij5QSFAvNS4yLjAgPC90ZD48L3RyPg0KPHRyPjx0ZCBjbGFzcz0iZSI+U2V0 LUNvb2tpZSA8
L3RkPjx0ZCBjbGFzcz0idiI+WERFQlVHX1NFU1NJT049RUNMSVBTRV9YREVC VUc7IGV4cGly
ZXM9V2VkLCAwOS1NYXktMjAwNyAxNzo1OTo0OSBHTVQ7IHBhdGg9LyA8L3Rk PjwvdHI+DQo8
dHI+PHRkIGNsYXNzPSJlIj5LZWVwLUFsaXZlIDwvdGQ+PHRkIGNsYXNzPSJ2 Ij50aW1lb3V0
PTE1LCBtYXg9MTAwIDwvdGQ+PC90cj4NCjx0cj48dGQgY2xhc3M9ImUiPkNv bm5lY3Rpb24g
PC90ZD48dGQgY2xhc3M9InYiPktlZXAtQWxpdmUgPC90ZD48L3RyPg0KPHRy Pjx0ZCBjbGFz
cz0iZSI+VHJhbnNmZXItRW5jb2RpbmcgPC90ZD48dGQgY2xhc3M9InYiPmNo dW5rZWQgPC90
ZD48L3RyPg0KPHRyPjx0ZCBjbGFzcz0iZSI+Q29udGVudC1UeXBlIDwvdGQ+ PHRkIGNsYXNz
PSJ2Ij50ZXh0L2h0bWwgPC90ZD48L3RyPg0KPC90Ym9keT48L3RhYmxlPjxi cj4NCjxoMj48
YSBuYW1lPSJtb2R1bGVfYmNtYXRoIj5iY21hdGg8L2E+PC9oMj4NCjx0YWJs ZSBib3JkZXI9
IjAiIGNlbGxwYWRkaW5nPSIzIiB3aWR0aD0iNjAwIj4NCjx0Ym9keT48dHI+ PHRkIGNsYXNz
PSJlIj5CQ01hdGggc3VwcG9ydCA8L3RkPjx0ZCBjbGFzcz0idiI+ZW5hYmxl ZCA8L3RkPjwv
dHI+DQo8L3Rib2R5PjwvdGFibGU+PGJyPg0KPGgyPjxhIG5hbWU9Im1vZHVs ZV9jYWxlbmRh
ciI+Y2FsZW5kYXI8L2E+PC9oMj4NCjx0YWJsZSBib3JkZXI9IjAiIGNlbGxw YWRkaW5nPSIz
IiB3aWR0aD0iNjAwIj4NCjx0Ym9keT48dHI+PHRkIGNsYXNzPSJlIj5DYWxl bmRhciBzdXBw
b3J0IDwvdGQ+PHRkIGNsYXNzPSJ2Ij5lbmFibGVkIDwvdGQ+PC90cj4NCjwv dGJvZHk+PC90
YWJsZT48YnI+DQo8aDI+PGEgbmFtZT0ibW9kdWxlX2NvbV9kb3RuZXQiPmNv bV9kb3RuZXQ8
L2E+PC9oMj4NCjx0YWJsZSBib3JkZXI9IjAiIGNlbGxwYWRkaW5nPSIzIiB3 aWR0aD0iNjAw
Ij4NCjx0Ym9keT48dHIgY2xhc3M9ImgiPjx0aD5DT00gc3VwcG9ydDwvdGg+ PHRoPmVuYWJs
ZWQ8L3RoPjwvdHI+DQo8dHIgY2xhc3M9ImgiPjx0aD5EQ09NIHN1cHBvcnQ8 L3RoPjx0aD5k
aXNhYmxlZDwvdGg+PC90cj4NCjx0ciBjbGFzcz0iaCI+PHRoPi5OZXQgc3Vw cG9ydDwvdGg+
PHRoPmVuYWJsZWQ8L3RoPjwvdHI+DQo8L3Rib2R5PjwvdGFibGU+PGJyPg0K PHRhYmxlIGJv
cmRlcj0iMCIgY2VsbHBhZGRpbmc9IjMiIHdpZHRoPSI2MDAiPg0KPHRib2R5 Pjx0ciBjbGFz
cz0iaCI+PHRoPkRpcmVjdGl2ZTwvdGg+PHRoPkxvY2FsIFZhbHVlPC90aD48 dGg+TWFzdGVy
IFZhbHVlPC90aD48L3RyPg0KPHRyPjx0ZCBjbGFzcz0iZSI+Y29tLmFsbG93 X2Rjb208L3Rk
Pjx0ZCBjbGFzcz0idiI+MDwvdGQ+PHRkIGNsYXNzPSJ2Ij4wPC90ZD48L3Ry Pg0KPHRyPjx0
ZCBjbGFzcz0iZSI+Y29tLmF1dG9yZWdpc3Rlcl9jYXNlc2Vuc2l0aXZlPC90 ZD48dGQgY2xh
c3M9InYiPjE8L3RkPjx0ZCBjbGFzcz0idiI+MTwvdGQ+PC90cj4NCjx0cj48 dGQgY2xhc3M9
ImUiPmNvbS5hdXRvcmVnaXN0ZXJfdHlwZWxpYjwvdGQ+PHRkIGNsYXNzPSJ2 Ij4wPC90ZD48
dGQgY2xhc3M9InYiPjA8L3RkPjwvdHI+DQo8dHI+PHRkIGNsYXNzPSJlIj5j b20uYXV0b3Jl
Z2lzdGVyX3ZlcmJvc2U8L3RkPjx0ZCBjbGFzcz0idiI+MDwvdGQ+PHRkIGNs YXNzPSJ2Ij4w
PC90ZD48L3RyPg0KPHRyPjx0ZCBjbGFzcz0iZSI+Y29tLmNvZGVfcGFnZTwv dGQ+PHRkIGNs
L2k+PC90ZD48L3RyPg0KPHRyPjx0ZCBjbGFzcz0iZSI+Y29tLnR5cGVsaWJf ZmlsZTwvdGQ+
dmFsdWU8L2k+PC90ZD48L3RyPg0KPC90Ym9keT48L3RhYmxlPjxicj4NCjxo Mj48YSBuYW1l
PSJtb2R1bGVfY3R5cGUiPmN0eXBlPC9hPjwvaDI+DQo8dGFibGUgYm9yZGVy PSIwIiBjZWxs
cGFkZGluZz0iMyIgd2lkdGg9IjYwMCI+DQo8dGJvZHk+PHRyPjx0ZCBjbGFz cz0iZSI+Y3R5
cGUgZnVuY3Rpb25zIDwvdGQ+PHRkIGNsYXNzPSJ2Ij5lbmFibGVkIDwvdGQ+ PC90cj4NCjwv
dGJvZHk+PC90YWJsZT48YnI+DQo8aDI+PGEgbmFtZT0ibW9kdWxlX2RhdGUi PmRhdGU8L2E+
PC9oMj4NCjx0YWJsZSBib3JkZXI9IjAiIGNlbGxwYWRkaW5nPSIzIiB3aWR0 aD0iNjAwIj4N
Cjx0Ym9keT48dHI+PHRkIGNsYXNzPSJlIj5kYXRlL3RpbWUgc3VwcG9ydCA8 L3RkPjx0ZCBj
bGFzcz0idiI+ZW5hYmxlZCA8L3RkPjwvdHI+DQo8dHI+PHRkIGNsYXNzPSJl Ij5UaW1lem9u
ZSBEYXRhYmFzZSBWZXJzaW9uIDwvdGQ+PHRkIGNsYXNzPSJ2Ij4yMDA2LjE0 IDwvdGQ+PC90
cj4NCjx0cj48dGQgY2xhc3M9ImUiPlRpbWV6b25lIERhdGFiYXNlIDwvdGQ+ PHRkIGNsYXNz
PSJ2Ij5pbnRlcm5hbCA8L3RkPjwvdHI+DQo8dHI+PHRkIGNsYXNzPSJlIj5E ZWZhdWx0IHRp
bWV6b25lIDwvdGQ+PHRkIGNsYXNzPSJ2Ij5FdXJvcGUvTW9zY293IDwvdGQ+ PC90cj4NCjwv
dGJvZHk+PC90YWJsZT48YnI+DQo8dGFibGUgYm9yZGVyPSIwIiBjZWxscGFk ZGluZz0iMyIg
d2lkdGg9IjYwMCI+DQo8dGJvZHk+PHRyIGNsYXNzPSJoIj48dGg+RGlyZWN0 aXZlPC90aD48
dGg+TG9jYWwgVmFsdWU8L3RoPjx0aD5NYXN0ZXIgVmFsdWU8L3RoPjwvdHI+ DQo8dHI+PHRk
IGNsYXNzPSJlIj5kYXRlLmRlZmF1bHRfbGF0aXR1ZGU8L3RkPjx0ZCBjbGFz cz0idiI+MzEu
NzY2NzwvdGQ+PHRkIGNsYXNzPSJ2Ij4zMS43NjY3PC90ZD48L3RyPg0KPHRy Pjx0ZCBjbGFz
cz0iZSI+ZGF0ZS5kZWZhdWx0X2xvbmdpdHVkZTwvdGQ+PHRkIGNsYXNzPSJ2 Ij4zNS4yMzMz
PC90ZD48dGQgY2xhc3M9InYiPjM1LjIzMzM8L3RkPjwvdHI+DQo8dHI+PHRk IGNsYXNzPSJl
Ij5kYXRlLnN1bnJpc2VfemVuaXRoPC90ZD48dGQgY2xhc3M9InYiPjkwLjU4 MzMzMzwvdGQ+
PHRkIGNsYXNzPSJ2Ij45MC41ODMzMzM8L3RkPjwvdHI+DQo8dHI+PHRkIGNs YXNzPSJlIj5k
YXRlLnN1bnNldF96ZW5pdGg8L3RkPjx0ZCBjbGFzcz0idiI+OTAuNTgzMzMz PC90ZD48dGQg
Y2xhc3M9InYiPjkwLjU4MzMzMzwvdGQ+PC90cj4NCjx0cj48dGQgY2xhc3M9 ImUiPmRhdGUu
dGltZXpvbmU8L3RkPjx0ZCBjbGFzcz0idiI+PGk+bm8gdmFsdWU8L2k+PC90 ZD48dGQgY2xh
c3M9InYiPjxpPm5vIHZhbHVlPC9pPjwvdGQ+PC90cj4NCjwvdGJvZHk+PC90 YWJsZT48YnI+
DQo8aDI+PGEgbmFtZT0ibW9kdWxlX2RvbSI+ZG9tPC9hPjwvaDI+DQo8dGFi bGUgYm9yZGVy
PSIwIiBjZWxscGFkZGluZz0iMyIgd2lkdGg9IjYwMCI+DQo8dGJvZHk+PHRy Pjx0ZCBjbGFz
cz0iZSI+RE9NL1hNTCA8L3RkPjx0ZCBjbGFzcz0idiI+ZW5hYmxlZCA8L3Rk PjwvdHI+DQo8
dHI+PHRkIGNsYXNzPSJlIj5ET00vWE1MIEFQSSBWZXJzaW9uIDwvdGQ+PHRk IGNsYXNzPSJ2
Ij4yMDAzMTEyOSA8L3RkPjwvdHI+DQo8dHI+PHRkIGNsYXNzPSJlIj5saWJ4 bWwgVmVyc2lv
biA8L3RkPjx0ZCBjbGFzcz0idiI+Mi42LjI2IDwvdGQ+PC90cj4NCjx0cj48 dGQgY2xhc3M9
ImUiPkhUTUwgU3VwcG9ydCA8L3RkPjx0ZCBjbGFzcz0idiI+ZW5hYmxlZCA8 L3RkPjwvdHI+
DQo8dHI+PHRkIGNsYXNzPSJlIj5YUGF0aCBTdXBwb3J0IDwvdGQ+PHRkIGNs YXNzPSJ2Ij5l
bmFibGVkIDwvdGQ+PC90cj4NCjx0cj48dGQgY2xhc3M9ImUiPlhQb2ludGVy IFN1cHBvcnQg
PC90ZD48dGQgY2xhc3M9InYiPmVuYWJsZWQgPC90ZD48L3RyPg0KPHRyPjx0 ZCBjbGFzcz0i
ZSI+U2NoZW1hIFN1cHBvcnQgPC90ZD48dGQgY2xhc3M9InYiPmVuYWJsZWQg PC90ZD48L3Ry
Pg0KPHRyPjx0ZCBjbGFzcz0iZSI+UmVsYXhORyBTdXBwb3J0IDwvdGQ+PHRk IGNsYXNzPSJ2
Ij5lbmFibGVkIDwvdGQ+PC90cj4NCjwvdGJvZHk+PC90YWJsZT48YnI+DQo8 aDI+PGEgbmFt
ZT0ibW9kdWxlX2ZpbHRlciI+ZmlsdGVyPC9hPjwvaDI+DQo8dGFibGUgYm9y ZGVyPSIwIiBj
SW5wdXQgVmFsaWRhdGlvbiBhbmQgRmlsdGVyaW5nPC90aD48dGg+ZW5hYmxl ZDwvdGg+PC90
cj4NCjx0cj48dGQgY2xhc3M9ImUiPlJldmlzaW9uIDwvdGQ+PHRkIGNsYXNz PSJ2Ij4kUmV2
aXNpb246IDEuNTIuMi4yNSAkIDwvdGQ+PC90cj4NCjwvdGJvZHk+PC90YWJs ZT48YnI+DQo8
dGFibGUgYm9yZGVyPSIwIiBjZWxscGFkZGluZz0iMyIgd2lkdGg9IjYwMCI+ DQo8dGJvZHk+
PHRyIGNsYXNzPSJoIj48dGg+RGlyZWN0aXZlPC90aD48dGg+TG9jYWwgVmFs dWU8L3RoPjx0
aD5NYXN0ZXIgVmFsdWU8L3RoPjwvdHI+DQo8dHI+PHRkIGNsYXNzPSJlIj5m aWx0ZXIuZGVm
YXVsdDwvdGQ+PHRkIGNsYXNzPSJ2Ij51bnNhZmVfcmF3PC90ZD48dGQgY2xh c3M9InYiPnVu
c2FmZV9yYXc8L3RkPjwvdHI+DQo8dHI+PHRkIGNsYXNzPSJlIj5maWx0ZXIu ZGVmYXVsdF9m
bGFnczwvdGQ+PHRkIGNsYXNzPSJ2Ij48aT5ubyB2YWx1ZTwvaT48L3RkPjx0 ZCBjbGFzcz0i
diI+PGk+bm8gdmFsdWU8L2k+PC90ZD48L3RyPg0KPC90Ym9keT48L3RhYmxl Pjxicj4NCjxo
Mj48YSBuYW1lPSJtb2R1bGVfZnRwIj5mdHA8L2E+PC9oMj4NCjx0YWJsZSBi b3JkZXI9IjAi
IGNlbGxwYWRkaW5nPSIzIiB3aWR0aD0iNjAwIj4NCjx0Ym9keT48dHI+PHRk IGNsYXNzPSJl
Ij5GVFAgc3VwcG9ydCA8L3RkPjx0ZCBjbGFzcz0idiI+ZW5hYmxlZCA8L3Rk PjwvdHI+DQo8
L3Rib2R5PjwvdGFibGU+PGJyPg0KPGgyPjxhIG5hbWU9Im1vZHVsZV9oYXNo Ij5oYXNoPC9h
PjwvaDI+DQo8dGFibGUgYm9yZGVyPSIwIiBjZWxscGFkZGluZz0iMyIgd2lk dGg9IjYwMCI+
DQo8dGJvZHk+PHRyPjx0ZCBjbGFzcz0iZSI+aGFzaCBzdXBwb3J0IDwvdGQ+ PHRkIGNsYXNz
PSJ2Ij5lbmFibGVkIDwvdGQ+PC90cj4NCjx0cj48dGQgY2xhc3M9ImUiPkhh c2hpbmcgRW5n
aW5lcyA8L3RkPjx0ZCBjbGFzcz0idiI+bWQ0IG1kNSBzaGExDQpzaGEyNTYg c2hhMzg0IHNo
YTUxMiByaXBlbWQxMjggcmlwZW1kMTYwIHdoaXJscG9vbCB0aWdlcjEyOCwz DQp0aWdlcjE2
MCwzIHRpZ2VyMTkyLDMgdGlnZXIxMjgsNCB0aWdlcjE2MCw0IHRpZ2VyMTky LDQgc25lZnJ1
IGdvc3QNCmFkbGVyMzIgY3JjMzIgY3JjMzJiIGhhdmFsMTI4LDMgaGF2YWwx NjAsMyBoYXZh
bDE5MiwzIGhhdmFsMjI0LDMNCmhhdmFsMjU2LDMgaGF2YWwxMjgsNCBoYXZh bDE2MCw0IGhh
dmFsMTkyLDQgaGF2YWwyMjQsNCBoYXZhbDI1Niw0DQpoYXZhbDEyOCw1IGhh dmFsMTYwLDUg
aGF2YWwxOTIsNSBoYXZhbDIyNCw1IGhhdmFsMjU2LDUgPC90ZD48L3RyPg0K PC90Ym9keT48
L3RhYmxlPjxicj4NCjxoMj48YSBuYW1lPSJtb2R1bGVfaWNvbnYiPmljb252 PC9hPjwvaDI+
DQo8dGFibGUgYm9yZGVyPSIwIiBjZWxscGFkZGluZz0iMyIgd2lkdGg9IjYw MCI+DQo8dGJv
ZHk+PHRyPjx0ZCBjbGFzcz0iZSI+aWNvbnYgc3VwcG9ydCA8L3RkPjx0ZCBj bGFzcz0idiI+
ZW5hYmxlZCA8L3RkPjwvdHI+DQo8dHI+PHRkIGNsYXNzPSJlIj5pY29udiBp bXBsZW1lbnRh
dGlvbiA8L3RkPjx0ZCBjbGFzcz0idiI+ImxpYmljb252IiA8L3RkPjwvdHI+ DQo8dHI+PHRk
IGNsYXNzPSJlIj5pY29udiBsaWJyYXJ5IHZlcnNpb24gPC90ZD48dGQgY2xh c3M9InYiPjEu
OSA8L3RkPjwvdHI+DQo8L3Rib2R5PjwvdGFibGU+PGJyPg0KPHRhYmxlIGJv cmRlcj0iMCIg
Y2VsbHBhZGRpbmc9IjMiIHdpZHRoPSI2MDAiPg0KPHRib2R5Pjx0ciBjbGFz cz0iaCI+PHRo
PkRpcmVjdGl2ZTwvdGg+PHRoPkxvY2FsIFZhbHVlPC90aD48dGg+TWFzdGVy IFZhbHVlPC90
aD48L3RyPg0KPHRyPjx0ZCBjbGFzcz0iZSI+aWNvbnYuaW5wdXRfZW5jb2Rp bmc8L3RkPjx0
ZCBjbGFzcz0idiI+SVNPLTg4NTktMTwvdGQ+PHRkIGNsYXNzPSJ2Ij5JU08t ODg1OS0xPC90
ZD48L3RyPg0KPHRyPjx0ZCBjbGFzcz0iZSI+aWNvbnYuaW50ZXJuYWxfZW5j b2Rpbmc8L3Rk
Pjx0ZCBjbGFzcz0idiI+SVNPLTg4NTktMTwvdGQ+PHRkIGNsYXNzPSJ2Ij5J U08tODg1OS0x
PC90ZD48L3RyPg0KPHRyPjx0ZCBjbGFzcz0iZSI+aWNvbnYub3V0cHV0X2Vu Y29kaW5nPC90
ZD48dGQgY2xhc3M9InYiPklTTy04ODU5LTE8L3RkPjx0ZCBjbGFzcz0idiI+ SVNPLTg4NTkt
MTwvdGQ+PC90cj4NCjwvdGJvZHk+PC90YWJsZT48YnI+DQo8aDI+PGEgbmFt ZT0ibW9kdWxl
X2pzb24iPmpzb248L2E+PC9oMj4NCjx0YWJsZSBib3JkZXI9IjAiIGNlbGxw YWRkaW5nPSIz
IiB3aWR0aD0iNjAwIj4NCjx0Ym9keT48dHI+PHRkIGNsYXNzPSJlIj5qc29u IHN1cHBvcnQg
ZSI+anNvbiB2ZXJzaW9uIDwvdGQ+PHRkIGNsYXNzPSJ2Ij4xLjIuMSA8L3Rk PjwvdHI+DQo8
L3Rib2R5PjwvdGFibGU+PGJyPg0KPGgyPjxhIG5hbWU9Im1vZHVsZV9saWJ4 bWwiPmxpYnht
bDwvYT48L2gyPg0KPHRhYmxlIGJvcmRlcj0iMCIgY2VsbHBhZGRpbmc9IjMi IHdpZHRoPSI2
MDAiPg0KPHRib2R5Pjx0cj48dGQgY2xhc3M9ImUiPmxpYlhNTCBzdXBwb3J0 IDwvdGQ+PHRk
IGNsYXNzPSJ2Ij5hY3RpdmUgPC90ZD48L3RyPg0KPHRyPjx0ZCBjbGFzcz0i ZSI+bGliWE1M
IFZlcnNpb24gPC90ZD48dGQgY2xhc3M9InYiPjIuNi4yNiA8L3RkPjwvdHI+ DQo8dHI+PHRk
IGNsYXNzPSJlIj5saWJYTUwgc3RyZWFtcyA8L3RkPjx0ZCBjbGFzcz0idiI+ ZW5hYmxlZCA8
L3RkPjwvdHI+DQo8L3Rib2R5PjwvdGFibGU+PGJyPg0KPGgyPjxhIG5hbWU9 Im1vZHVsZV9t
YnN0cmluZyI+bWJzdHJpbmc8L2E+PC9oMj4NCjx0YWJsZSBib3JkZXI9IjAi IGNlbGxwYWRk
aW5nPSIzIiB3aWR0aD0iNjAwIj4NCjx0Ym9keT48dHI+PHRkIGNsYXNzPSJl Ij5NdWx0aWJ5
dGUgU3VwcG9ydCA8L3RkPjx0ZCBjbGFzcz0idiI+ZW5hYmxlZCA8L3RkPjwv dHI+DQo8dHI+
PHRkIGNsYXNzPSJlIj5NdWx0aWJ5dGUgc3RyaW5nIGVuZ2luZSA8L3RkPjx0 ZCBjbGFzcz0i
diI+bGlibWJmbCA8L3RkPjwvdHI+DQo8dHI+PHRkIGNsYXNzPSJlIj5NdWx0 aWJ5dGUgKGph
cGFuZXNlKSByZWdleCBzdXBwb3J0IDwvdGQ+PHRkIGNsYXNzPSJ2Ij5lbmFi bGVkIDwvdGQ+
PC90cj4NCjx0cj48dGQgY2xhc3M9ImUiPk11bHRpYnl0ZSByZWdleCAob25p Z3VydW1hKSB2
ZXJzaW9uIDwvdGQ+PHRkIGNsYXNzPSJ2Ij40LjQuNCA8L3RkPjwvdHI+DQo8 dHI+PHRkIGNs
YXNzPSJlIj5NdWx0aWJ5dGUgcmVnZXggKG9uaWd1cnVtYSkgYmFja3RyYWNr IGNoZWNrIDwv
dGQ+PHRkIGNsYXNzPSJ2Ij5PbiA8L3RkPjwvdHI+DQo8L3Rib2R5PjwvdGFi bGU+PGJyPg0K
PHRhYmxlIGJvcmRlcj0iMCIgY2VsbHBhZGRpbmc9IjMiIHdpZHRoPSI2MDAi Pg0KPHRib2R5
Pjx0ciBjbGFzcz0iaCI+PHRoPm1ic3RyaW5nIGV4dGVuc2lvbiBtYWtlcyB1 c2Ugb2YgInN0
cmVhbWFibGUNCmthbmppIGNvZGUgZmlsdGVyIGFuZCBjb252ZXJ0ZXIiLCB3 aGljaCBpcyBk
aXN0cmlidXRlZCB1bmRlciB0aGUgR05VDQpMZXNzZXIgR2VuZXJhbCBQdWJs aWMgTGljZW5z
ZSB2ZXJzaW9uIDIuMS48L3RoPjwvdHI+DQo8L3Rib2R5PjwvdGFibGU+PGJy Pg0KPHRhYmxl
IGJvcmRlcj0iMCIgY2VsbHBhZGRpbmc9IjMiIHdpZHRoPSI2MDAiPg0KPHRi b2R5Pjx0ciBj
bGFzcz0iaCI+PHRoPkRpcmVjdGl2ZTwvdGg+PHRoPkxvY2FsIFZhbHVlPC90 aD48dGg+TWFz
dGVyIFZhbHVlPC90aD48L3RyPg0KPHRyPjx0ZCBjbGFzcz0iZSI+bWJzdHJp bmcuZGV0ZWN0
X29yZGVyPC90ZD48dGQgY2xhc3M9InYiPjxpPm5vIHZhbHVlPC9pPjwvdGQ+ PHRkIGNsYXNz
PSJ2Ij48aT5ubyB2YWx1ZTwvaT48L3RkPjwvdHI+DQo8dHI+PHRkIGNsYXNz PSJlIj5tYnN0
cmluZy5lbmNvZGluZ190cmFuc2xhdGlvbjwvdGQ+PHRkIGNsYXNzPSJ2Ij5P ZmY8L3RkPjx0
ZCBjbGFzcz0idiI+T2ZmPC90ZD48L3RyPg0KPHRyPjx0ZCBjbGFzcz0iZSI+ bWJzdHJpbmcu
ZnVuY19vdmVybG9hZDwvdGQ+PHRkIGNsYXNzPSJ2Ij4wPC90ZD48dGQgY2xh c3M9InYiPjA8
L3RkPjwvdHI+DQo8dHI+PHRkIGNsYXNzPSJlIj5tYnN0cmluZy5odHRwX2lu cHV0PC90ZD48
dGQgY2xhc3M9InYiPnBhc3M8L3RkPjx0ZCBjbGFzcz0idiI+cGFzczwvdGQ+ PC90cj4NCjx0
cj48dGQgY2xhc3M9ImUiPm1ic3RyaW5nLmh0dHBfb3V0cHV0PC90ZD48dGQg Y2xhc3M9InYi
PnBhc3M8L3RkPjx0ZCBjbGFzcz0idiI+cGFzczwvdGQ+PC90cj4NCjx0cj48 dGQgY2xhc3M9
ImUiPm1ic3RyaW5nLmludGVybmFsX2VuY29kaW5nPC90ZD48dGQgY2xhc3M9 InYiPklTTy04
ODU5LTE8L3RkPjx0ZCBjbGFzcz0idiI+PGk+bm8gdmFsdWU8L2k+PC90ZD48 L3RyPg0KPHRy
Pjx0ZCBjbGFzcz0iZSI+bWJzdHJpbmcubGFuZ3VhZ2U8L3RkPjx0ZCBjbGFz cz0idiI+bmV1
dHJhbDwvdGQ+PHRkIGNsYXNzPSJ2Ij5uZXV0cmFsPC90ZD48L3RyPg0KPHRy Pjx0ZCBjbGFz
cz0iZSI+bWJzdHJpbmcuc3RyaWN0X2RldGVjdGlvbjwvdGQ+PHRkIGNsYXNz PSJ2Ij5PZmY8
L3RkPjx0ZCBjbGFzcz0idiI+T2ZmPC90ZD48L3RyPg0KPHRyPjx0ZCBjbGFz cz0iZSI+bWJz
dHJpbmcuc3Vic3RpdHV0ZV9jaGFyYWN0ZXI8L3RkPjx0ZCBjbGFzcz0idiI+ PGk+bm8gdmFs
dWU8L2k+PC90ZD48dGQgY2xhc3M9InYiPjxpPm5vIHZhbHVlPC9pPjwvdGQ+ PC90cj4NCjwv
dGJvZHk+PC90YWJsZT48YnI+DQo8aDI+PGEgbmFtZT0ibW9kdWxlX215c3Fs Ij5teXNxbDwv
YT48L2gyPg0KPHRhYmxlIGJvcmRlcj0iMCIgY2VsbHBhZGRpbmc9IjMiIHdp ZHRoPSI2MDAi
Pg0KPHRib2R5Pjx0ciBjbGFzcz0iaCI+PHRoPk15U1FMIFN1cHBvcnQ8L3Ro Pjx0aD5lbmFi
bGVkPC90aD48L3RyPg0KPHRyPjx0ZCBjbGFzcz0iZSI+QWN0aXZlIFBlcnNp c3RlbnQgTGlu
a3MgPC90ZD48dGQgY2xhc3M9InYiPjAgPC90ZD48L3RyPg0KPHRyPjx0ZCBj bGFzcz0iZSI+
QWN0aXZlIExpbmtzIDwvdGQ+PHRkIGNsYXNzPSJ2Ij4wIDwvdGQ+PC90cj4N Cjx0cj48dGQg
Y2xhc3M9ImUiPkNsaWVudCBBUEkgdmVyc2lvbiA8L3RkPjx0ZCBjbGFzcz0i diI+NS4wLjI3
IDwvdGQ+PC90cj4NCjwvdGJvZHk+PC90YWJsZT48YnI+DQo8dGFibGUgYm9y ZGVyPSIwIiBj
RGlyZWN0aXZlPC90aD48dGg+TG9jYWwgVmFsdWU8L3RoPjx0aD5NYXN0ZXIg VmFsdWU8L3Ro
PjwvdHI+DQo8dHI+PHRkIGNsYXNzPSJlIj5teXNxbC5hbGxvd19wZXJzaXN0 ZW50PC90ZD48
ZCBjbGFzcz0iZSI+bXlzcWwuY29ubmVjdF90aW1lb3V0PC90ZD48dGQgY2xh c3M9InYiPjYw
PC90ZD48dGQgY2xhc3M9InYiPjYwPC90ZD48L3RyPg0KPHRyPjx0ZCBjbGFz cz0iZSI+bXlz
cWwuZGVmYXVsdF9ob3N0PC90ZD48dGQgY2xhc3M9InYiPjxpPm5vIHZhbHVl PC9pPjwvdGQ+
PHRkIGNsYXNzPSJ2Ij48aT5ubyB2YWx1ZTwvaT48L3RkPjwvdHI+DQo8dHI+ PHRkIGNsYXNz
PSJlIj5teXNxbC5kZWZhdWx0X3Bhc3N3b3JkPC90ZD48dGQgY2xhc3M9InYi PjxpPm5vIHZh
bHVlPC9pPjwvdGQ+PHRkIGNsYXNzPSJ2Ij48aT5ubyB2YWx1ZTwvaT48L3Rk PjwvdHI+DQo8
dHI+PHRkIGNsYXNzPSJlIj5teXNxbC5kZWZhdWx0X3BvcnQ8L3RkPjx0ZCBj bGFzcz0idiI+
PC90cj4NCjx0cj48dGQgY2xhc3M9ImUiPm15c3FsLmRlZmF1bHRfc29ja2V0 PC90ZD48dGQg
ZTwvaT48L3RkPjwvdHI+DQo8dHI+PHRkIGNsYXNzPSJlIj5teXNxbC5kZWZh dWx0X3VzZXI8
L3RkPjx0ZCBjbGFzcz0idiI+PGk+bm8gdmFsdWU8L2k+PC90ZD48dGQgY2xh c3M9InYiPjxp
Pm5vIHZhbHVlPC9pPjwvdGQ+PC90cj4NCjx0cj48dGQgY2xhc3M9ImUiPm15 c3FsLm1heF9s
aW5rczwvdGQ+PHRkIGNsYXNzPSJ2Ij5VbmxpbWl0ZWQ8L3RkPjx0ZCBjbGFz cz0idiI+VW5s
aW1pdGVkPC90ZD48L3RyPg0KPHRyPjx0ZCBjbGFzcz0iZSI+bXlzcWwubWF4 X3BlcnNpc3Rl
bnQ8L3RkPjx0ZCBjbGFzcz0idiI+VW5saW1pdGVkPC90ZD48dGQgY2xhc3M9 InYiPlVubGlt
aXRlZDwvdGQ+PC90cj4NCjx0cj48dGQgY2xhc3M9ImUiPm15c3FsLnRyYWNl X21vZGU8L3Rk
Pjx0ZCBjbGFzcz0idiI+T2ZmPC90ZD48dGQgY2xhc3M9InYiPk9mZjwvdGQ+ PC90cj4NCjwv
dGJvZHk+PC90YWJsZT48YnI+DQo8aDI+PGEgbmFtZT0ibW9kdWxlX215c3Fs aSI+bXlzcWxp
PC9hPjwvaDI+DQo8dGFibGUgYm9yZGVyPSIwIiBjZWxscGFkZGluZz0iMyIg d2lkdGg9IjYw
MCI+DQo8dGJvZHk+PHRyIGNsYXNzPSJoIj48dGg+TXlzcWxJIFN1cHBvcnQ8 L3RoPjx0aD5l
bmFibGVkPC90aD48L3RyPg0KPHRyPjx0ZCBjbGFzcz0iZSI+Q2xpZW50IEFQ SSBsaWJyYXJ5
IHZlcnNpb24gPC90ZD48dGQgY2xhc3M9InYiPjUuMC4yNyA8L3RkPjwvdHI+ DQo8dHI+PHRk
IGNsYXNzPSJlIj5DbGllbnQgQVBJIGhlYWRlciB2ZXJzaW9uIDwvdGQ+PHRk IGNsYXNzPSJ2
Ij41LjAuMjIgPC90ZD48L3RyPg0KPHRyPjx0ZCBjbGFzcz0iZSI+TVlTUUxJ X1NPQ0tFVCA8
L3RkPjx0ZCBjbGFzcz0idiI+L3RtcC9teXNxbC5zb2NrIDwvdGQ+PC90cj4N CjwvdGJvZHk+
PC90YWJsZT48YnI+DQo8dGFibGUgYm9yZGVyPSIwIiBjZWxscGFkZGluZz0i MyIgd2lkdGg9
IjYwMCI+DQo8dGJvZHk+PHRyIGNsYXNzPSJoIj48dGg+RGlyZWN0aXZlPC90 aD48dGg+TG9j
YWwgVmFsdWU8L3RoPjx0aD5NYXN0ZXIgVmFsdWU8L3RoPjwvdHI+DQo8dHI+ PHRkIGNsYXNz
PSJlIj5teXNxbGkuZGVmYXVsdF9ob3N0PC90ZD48dGQgY2xhc3M9InYiPjxp Pm5vIHZhbHVl
PC9pPjwvdGQ+PHRkIGNsYXNzPSJ2Ij48aT5ubyB2YWx1ZTwvaT48L3RkPjwv dHI+DQo8dHI+
PHRkIGNsYXNzPSJlIj5teXNxbGkuZGVmYXVsdF9wb3J0PC90ZD48dGQgY2xh c3M9InYiPjMz
MDY8L3RkPjx0ZCBjbGFzcz0idiI+MzMwNjwvdGQ+PC90cj4NCjx0cj48dGQg Y2xhc3M9ImUi
Pm15c3FsaS5kZWZhdWx0X3B3PC90ZD48dGQgY2xhc3M9InYiPjxpPm5vIHZh bHVlPC9pPjwv
dGQ+PHRkIGNsYXNzPSJ2Ij48aT5ubyB2YWx1ZTwvaT48L3RkPjwvdHI+DQo8 dHI+PHRkIGNs
YXNzPSJlIj5teXNxbGkuZGVmYXVsdF9zb2NrZXQ8L3RkPjx0ZCBjbGFzcz0i diI+PGk+bm8g
dmFsdWU8L2k+PC90ZD48dGQgY2xhc3M9InYiPjxpPm5vIHZhbHVlPC9pPjwv dGQ+PC90cj4N
Cjx0cj48dGQgY2xhc3M9ImUiPm15c3FsaS5kZWZhdWx0X3VzZXI8L3RkPjx0 ZCBjbGFzcz0i
diI+PGk+bm8gdmFsdWU8L2k+PC90ZD48dGQgY2xhc3M9InYiPjxpPm5vIHZh bHVlPC9pPjwv
dGQ+PC90cj4NCjx0cj48dGQgY2xhc3M9ImUiPm15c3FsaS5tYXhfbGlua3M8 L3RkPjx0ZCBj
bGFzcz0idiI+VW5saW1pdGVkPC90ZD48dGQgY2xhc3M9InYiPlVubGltaXRl ZDwvdGQ+PC90
cj4NCjx0cj48dGQgY2xhc3M9ImUiPm15c3FsaS5yZWNvbm5lY3Q8L3RkPjx0 ZCBjbGFzcz0i
diI+T2ZmPC90ZD48dGQgY2xhc3M9InYiPk9mZjwvdGQ+PC90cj4NCjwvdGJv ZHk+PC90YWJs
ZT48YnI+DQo8aDI+PGEgbmFtZT0ibW9kdWxlX29kYmMiPm9kYmM8L2E+PC9o Mj4NCjx0YWJs
ZSBib3JkZXI9IjAiIGNlbGxwYWRkaW5nPSIzIiB3aWR0aD0iNjAwIj4NCjx0 Ym9keT48dHIg
Y2xhc3M9ImgiPjx0aD5PREJDIFN1cHBvcnQ8L3RoPjx0aD5lbmFibGVkPC90 aD48L3RyPg0K
PHRyPjx0ZCBjbGFzcz0iZSI+QWN0aXZlIFBlcnNpc3RlbnQgTGlua3MgPC90 ZD48dGQgY2xh
c3M9InYiPjAgPC90ZD48L3RyPg0KPHRyPjx0ZCBjbGFzcz0iZSI+QWN0aXZl IExpbmtzIDwv
dGQ+PHRkIGNsYXNzPSJ2Ij4wIDwvdGQ+PC90cj4NCjx0cj48dGQgY2xhc3M9 ImUiPk9EQkMg
bGlicmFyeSA8L3RkPjx0ZCBjbGFzcz0idiI+V2luMzIgPC90ZD48L3RyPg0K PC90Ym9keT48
L3RhYmxlPjxicj4NCjx0YWJsZSBib3JkZXI9IjAiIGNlbGxwYWRkaW5nPSIz IiB3aWR0aD0i
NjAwIj4NCjx0Ym9keT48dHIgY2xhc3M9ImgiPjx0aD5EaXJlY3RpdmU8L3Ro Pjx0aD5Mb2Nh
bCBWYWx1ZTwvdGg+PHRoPk1hc3RlciBWYWx1ZTwvdGg+PC90cj4NCjx0cj48 dGQgY2xhc3M9
ImUiPm9kYmMuYWxsb3dfcGVyc2lzdGVudDwvdGQ+PHRkIGNsYXNzPSJ2Ij5P bjwvdGQ+PHRk
IGNsYXNzPSJ2Ij5PbjwvdGQ+PC90cj4NCjx0cj48dGQgY2xhc3M9ImUiPm9k YmMuY2hlY2tf
cGVyc2lzdGVudDwvdGQ+PHRkIGNsYXNzPSJ2Ij5PbjwvdGQ+PHRkIGNsYXNz PSJ2Ij5Pbjwv
dGQ+PC90cj4NCjx0cj48dGQgY2xhc3M9ImUiPm9kYmMuZGVmYXVsdF9kYjwv dGQ+PHRkIGNs
L2k+PC90ZD48L3RyPg0KPHRyPjx0ZCBjbGFzcz0iZSI+b2RiYy5kZWZhdWx0 X3B3PC90ZD48
YWx1ZTwvaT48L3RkPjwvdHI+DQo8dHI+PHRkIGNsYXNzPSJlIj5vZGJjLmRl ZmF1bHRfdXNl
cjwvdGQ+PHRkIGNsYXNzPSJ2Ij48aT5ubyB2YWx1ZTwvaT48L3RkPjx0ZCBj bGFzcz0idiI+
PGk+bm8gdmFsdWU8L2k+PC90ZD48L3RyPg0KPHRyPjx0ZCBjbGFzcz0iZSI+ b2RiYy5kZWZh
dWx0YmlubW9kZTwvdGQ+PHRkIGNsYXNzPSJ2Ij5yZXR1cm4gYXMgaXM8L3Rk Pjx0ZCBjbGFz
cz0idiI+cmV0dXJuIGFzIGlzPC90ZD48L3RyPg0KPHRyPjx0ZCBjbGFzcz0i ZSI+b2RiYy5k
ZWZhdWx0bHJsPC90ZD48dGQgY2xhc3M9InYiPnJldHVybiB1cCB0byA0MDk2 IGJ5dGVzPC90
ZD48dGQgY2xhc3M9InYiPnJldHVybiB1cCB0byA0MDk2IGJ5dGVzPC90ZD48 L3RyPg0KPHRy
Pjx0ZCBjbGFzcz0iZSI+b2RiYy5tYXhfbGlua3M8L3RkPjx0ZCBjbGFzcz0i diI+VW5saW1p
dGVkPC90ZD48dGQgY2xhc3M9InYiPlVubGltaXRlZDwvdGQ+PC90cj4NCjx0 cj48dGQgY2xh
c3M9ImUiPm9kYmMubWF4X3BlcnNpc3RlbnQ8L3RkPjx0ZCBjbGFzcz0idiI+ VW5saW1pdGVk
PC90ZD48dGQgY2xhc3M9InYiPlVubGltaXRlZDwvdGQ+PC90cj4NCjwvdGJv ZHk+PC90YWJs
ZT48YnI+DQo8aDI+PGEgbmFtZT0ibW9kdWxlX3BjcmUiPnBjcmU8L2E+PC9o Mj4NCjx0YWJs
ZSBib3JkZXI9IjAiIGNlbGxwYWRkaW5nPSIzIiB3aWR0aD0iNjAwIj4NCjx0 Ym9keT48dHI+
PHRkIGNsYXNzPSJlIj5QQ1JFIChQZXJsIENvbXBhdGlibGUgUmVndWxhciBF eHByZXNzaW9u
cykgU3VwcG9ydCA8L3RkPjx0ZCBjbGFzcz0idiI+ZW5hYmxlZCA8L3RkPjwv dHI+DQo8dHI+
PHRkIGNsYXNzPSJlIj5QQ1JFIExpYnJhcnkgVmVyc2lvbiA8L3RkPjx0ZCBj bGFzcz0idiI+
Ni43IDA0LUp1bC0yMDA2IDwvdGQ+PC90cj4NCjwvdGJvZHk+PC90YWJsZT48 YnI+DQo8aDI+
PGEgbmFtZT0ibW9kdWxlX1BETyI+UERPPC9hPjwvaDI+DQo8dGFibGUgYm9y ZGVyPSIwIiBj
UERPIHN1cHBvcnQ8L3RoPjx0aD5lbmFibGVkPC90aD48L3RyPg0KPHRyPjx0 ZCBjbGFzcz0i
ZSI+UERPIGRyaXZlcnMgPC90ZD48dGQgY2xhc3M9InYiPnNxbGl0ZSwgc3Fs aXRlMiA8L3Rk
PjwvdHI+DQo8L3Rib2R5PjwvdGFibGU+PGJyPg0KPGgyPjxhIG5hbWU9Im1v ZHVsZV9wZG9f
c3FsaXRlIj5wZG9fc3FsaXRlPC9hPjwvaDI+DQo8dGFibGUgYm9yZGVyPSIw IiBjZWxscGFk
ZGluZz0iMyIgd2lkdGg9IjYwMCI+DQo8dGJvZHk+PHRyIGNsYXNzPSJoIj48 dGg+UERPIERy
aXZlciBmb3IgU1FMaXRlIDMueDwvdGg+PHRoPmVuYWJsZWQ8L3RoPjwvdHI+ DQo8dHI+PHRk
IGNsYXNzPSJlIj5QRUNMIE1vZHVsZSB2ZXJzaW9uIDwvdGQ+PHRkIGNsYXNz PSJ2Ij4xLjAu
MSAkSWQ6IHBkb19zcWxpdGUuYyx2IDEuMTAuMi42IDIwMDYvMDEvMDEgMTI6 NTA6MTIgc25p
cGVyIEV4cCAkIDwvdGQ+PC90cj4NCjx0cj48dGQgY2xhc3M9ImUiPlNRTGl0 ZSBMaWJyYXJ5
IDwvdGQ+PHRkIGNsYXNzPSJ2Ij4zLjMuN3VuZGVmaW5lZCA8L3RkPjwvdHI+ DQo8L3Rib2R5
PjwvdGFibGU+PGJyPg0KPGgyPjxhIG5hbWU9Im1vZHVsZV9SZWZsZWN0aW9u Ij5SZWZsZWN0
aW9uPC9hPjwvaDI+DQo8dGFibGUgYm9yZGVyPSIwIiBjZWxscGFkZGluZz0i MyIgd2lkdGg9
IjYwMCI+DQo8dGJvZHk+PHRyIGNsYXNzPSJoIj48dGg+UmVmbGVjdGlvbjwv dGg+PHRoPmVu
YWJsZWQ8L3RoPjwvdHI+DQo8dHI+PHRkIGNsYXNzPSJlIj5WZXJzaW9uIDwv dGQ+PHRkIGNs
YXNzPSJ2Ij4kSWQ6IHBocF9yZWZsZWN0aW9uLmMsdiAxLjE2NC4yLjMzLjIu MzEgMjAwNi8x
MC8xOCAxNjozNToxNSBqb2hhbm5lcyBFeHAgJCA8L3RkPjwvdHI+DQo8L3Ri b2R5PjwvdGFi
bGU+PGJyPg0KPGgyPjxhIG5hbWU9Im1vZHVsZV9zZXNzaW9uIj5zZXNzaW9u PC9hPjwvaDI+
ZHk+PHRyPjx0ZCBjbGFzcz0iZSI+U2Vzc2lvbiBTdXBwb3J0IDwvdGQ+PHRk IGNsYXNzPSJ2
Ij5lbmFibGVkIDwvdGQ+PC90cj4NCjx0cj48dGQgY2xhc3M9ImUiPlJlZ2lz dGVyZWQgc2F2
ZSBoYW5kbGVycyA8L3RkPjx0ZCBjbGFzcz0idiI+ZmlsZXMgdXNlciBzcWxp dGUgIDwvdGQ+
PC90cj4NCjx0cj48dGQgY2xhc3M9ImUiPlJlZ2lzdGVyZWQgc2VyaWFsaXpl ciBoYW5kbGVy
cyA8L3RkPjx0ZCBjbGFzcz0idiI+cGhwIHBocF9iaW5hcnkgd2RkeCAgPC90 ZD48L3RyPg0K
PC90Ym9keT48L3RhYmxlPjxicj4NCjx0YWJsZSBib3JkZXI9IjAiIGNlbGxw YWRkaW5nPSIz
IiB3aWR0aD0iNjAwIj4NCjx0Ym9keT48dHIgY2xhc3M9ImgiPjx0aD5EaXJl Y3RpdmU8L3Ro
Pjx0aD5Mb2NhbCBWYWx1ZTwvdGg+PHRoPk1hc3RlciBWYWx1ZTwvdGg+PC90 cj4NCjx0cj48
dGQgY2xhc3M9ImUiPnNlc3Npb24uYXV0b19zdGFydDwvdGQ+PHRkIGNsYXNz PSJ2Ij5PZmY8
L3RkPjx0ZCBjbGFzcz0idiI+T2ZmPC90ZD48L3RyPg0KPHRyPjx0ZCBjbGFz cz0iZSI+c2Vz
c2lvbi5idWdfY29tcGF0XzQyPC90ZD48dGQgY2xhc3M9InYiPk9uPC90ZD48 dGQgY2xhc3M9
InYiPk9uPC90ZD48L3RyPg0KPHRyPjx0ZCBjbGFzcz0iZSI+c2Vzc2lvbi5i dWdfY29tcGF0
X3dhcm48L3RkPjx0ZCBjbGFzcz0idiI+T248L3RkPjx0ZCBjbGFzcz0idiI+ T248L3RkPjwv
dHI+DQo8dHI+PHRkIGNsYXNzPSJlIj5zZXNzaW9uLmNhY2hlX2V4cGlyZTwv dGQ+PHRkIGNs
YXNzPSJ2Ij4xODA8L3RkPjx0ZCBjbGFzcz0idiI+MTgwPC90ZD48L3RyPg0K PHRyPjx0ZCBj
bGFzcz0iZSI+c2Vzc2lvbi5jYWNoZV9saW1pdGVyPC90ZD48dGQgY2xhc3M9 InYiPm5vY2Fj
aGU8L3RkPjx0ZCBjbGFzcz0idiI+bm9jYWNoZTwvdGQ+PC90cj4NCjx0cj48 dGQgY2xhc3M9
ImUiPnNlc3Npb24uY29va2llX2RvbWFpbjwvdGQ+PHRkIGNsYXNzPSJ2Ij48 aT5ubyB2YWx1
ZTwvaT48L3RkPjx0ZCBjbGFzcz0idiI+PGk+bm8gdmFsdWU8L2k+PC90ZD48 L3RyPg0KPHRy
Pjx0ZCBjbGFzcz0iZSI+c2Vzc2lvbi5jb29raWVfaHR0cG9ubHk8L3RkPjx0 ZCBjbGFzcz0i
diI+T2ZmPC90ZD48dGQgY2xhc3M9InYiPk9mZjwvdGQ+PC90cj4NCjx0cj48 dGQgY2xhc3M9
ImUiPnNlc3Npb24uY29va2llX2xpZmV0aW1lPC90ZD48dGQgY2xhc3M9InYi PjA8L3RkPjx0
ZCBjbGFzcz0idiI+MDwvdGQ+PC90cj4NCjx0cj48dGQgY2xhc3M9ImUiPnNl c3Npb24uY29v
a2llX3BhdGg8L3RkPjx0ZCBjbGFzcz0idiI+LzwvdGQ+PHRkIGNsYXNzPSJ2 Ij4vPC90ZD48
L3RyPg0KPHRyPjx0ZCBjbGFzcz0iZSI+c2Vzc2lvbi5jb29raWVfc2VjdXJl PC90ZD48dGQg
Y2xhc3M9InYiPk9mZjwvdGQ+PHRkIGNsYXNzPSJ2Ij5PZmY8L3RkPjwvdHI+ DQo8dHI+PHRk
IGNsYXNzPSJlIj5zZXNzaW9uLmVudHJvcHlfZmlsZTwvdGQ+PHRkIGNsYXNz PSJ2Ij48aT5u
Pg0KPHRyPjx0ZCBjbGFzcz0iZSI+c2Vzc2lvbi5lbnRyb3B5X2xlbmd0aDwv dGQ+PHRkIGNs
YXNzPSJ2Ij4wPC90ZD48dGQgY2xhc3M9InYiPjA8L3RkPjwvdHI+DQo8dHI+ PHRkIGNsYXNz
PSJlIj5zZXNzaW9uLmdjX2Rpdmlzb3I8L3RkPjx0ZCBjbGFzcz0idiI+MTAw PC90ZD48dGQg
Y2xhc3M9InYiPjEwMDwvdGQ+PC90cj4NCjx0cj48dGQgY2xhc3M9ImUiPnNl c3Npb24uZ2Nf
bWF4bGlmZXRpbWU8L3RkPjx0ZCBjbGFzcz0idiI+MTQ0MDwvdGQ+PHRkIGNs YXNzPSJ2Ij4x
NDQwPC90ZD48L3RyPg0KPHRyPjx0ZCBjbGFzcz0iZSI+c2Vzc2lvbi5nY19w cm9iYWJpbGl0
eTwvdGQ+PHRkIGNsYXNzPSJ2Ij4xPC90ZD48dGQgY2xhc3M9InYiPjE8L3Rk PjwvdHI+DQo8
dHI+PHRkIGNsYXNzPSJlIj5zZXNzaW9uLmhhc2hfYml0c19wZXJfY2hhcmFj dGVyPC90ZD48
dGQgY2xhc3M9InYiPjQ8L3RkPjx0ZCBjbGFzcz0idiI+NDwvdGQ+PC90cj4N Cjx0cj48dGQg
Y2xhc3M9ImUiPnNlc3Npb24uaGFzaF9mdW5jdGlvbjwvdGQ+PHRkIGNsYXNz PSJ2Ij4wPC90
ZD48dGQgY2xhc3M9InYiPjA8L3RkPjwvdHI+DQo8dHI+PHRkIGNsYXNzPSJl Ij5zZXNzaW9u
Lm5hbWU8L3RkPjx0ZCBjbGFzcz0idiI+UEhQU0VTU0lEPC90ZD48dGQgY2xh c3M9InYiPlBI
UFNFU1NJRDwvdGQ+PC90cj4NCjx0cj48dGQgY2xhc3M9ImUiPnNlc3Npb24u cmVmZXJlcl9j
aGVjazwvdGQ+PHRkIGNsYXNzPSJ2Ij48aT5ubyB2YWx1ZTwvaT48L3RkPjx0 ZCBjbGFzcz0i
diI+PGk+bm8gdmFsdWU8L2k+PC90ZD48L3RyPg0KPHRyPjx0ZCBjbGFzcz0i ZSI+c2Vzc2lv
bi5zYXZlX2hhbmRsZXI8L3RkPjx0ZCBjbGFzcz0idiI+ZmlsZXM8L3RkPjx0 ZCBjbGFzcz0i
diI+ZmlsZXM8L3RkPjwvdHI+DQo8dHI+PHRkIGNsYXNzPSJlIj5zZXNzaW9u LnNhdmVfcGF0
aDwvdGQ+PHRkIGNsYXNzPSJ2Ij5EOi93YW1wL3RtcDwvdGQ+PHRkIGNsYXNz PSJ2Ij5EOi93
YW1wL3RtcDwvdGQ+PC90cj4NCjx0cj48dGQgY2xhc3M9ImUiPnNlc3Npb24u c2VyaWFsaXpl
X2hhbmRsZXI8L3RkPjx0ZCBjbGFzcz0idiI+cGhwPC90ZD48dGQgY2xhc3M9 InYiPnBocDwv
dGQ+PC90cj4NCjx0cj48dGQgY2xhc3M9ImUiPnNlc3Npb24udXNlX2Nvb2tp ZXM8L3RkPjx0
IGNsYXNzPSJlIj5zZXNzaW9uLnVzZV9vbmx5X2Nvb2tpZXM8L3RkPjx0ZCBj bGFzcz0idiI+
T2ZmPC90ZD48dGQgY2xhc3M9InYiPk9mZjwvdGQ+PC90cj4NCjx0cj48dGQg Y2xhc3M9ImUi
PnNlc3Npb24udXNlX3RyYW5zX3NpZDwvdGQ+PHRkIGNsYXNzPSJ2Ij4wPC90 ZD48dGQgY2xh
c3M9InYiPjA8L3RkPjwvdHI+DQo8L3Rib2R5PjwvdGFibGU+PGJyPg0KPGgy PjxhIG5hbWU9
Im1vZHVsZV9TaW1wbGVYTUwiPlNpbXBsZVhNTDwvYT48L2gyPg0KPHRhYmxl IGJvcmRlcj0i
MCIgY2VsbHBhZGRpbmc9IjMiIHdpZHRoPSI2MDAiPg0KPHRib2R5Pjx0ciBj bGFzcz0iaCI+
PHRoPlNpbXBsZXhtbCBzdXBwb3J0PC90aD48dGg+ZW5hYmxlZDwvdGg+PC90 cj4NCjx0cj48
dGQgY2xhc3M9ImUiPlJldmlzaW9uIDwvdGQ+PHRkIGNsYXNzPSJ2Ij4kUmV2 aXNpb246IDEu
MTUxLjIuMjIuMi4xNSAkIDwvdGQ+PC90cj4NCjx0cj48dGQgY2xhc3M9ImUi PlNjaGVtYSBz
dXBwb3J0IDwvdGQ+PHRkIGNsYXNzPSJ2Ij5lbmFibGVkIDwvdGQ+PC90cj4N CjwvdGJvZHk+
PC90YWJsZT48YnI+DQo8aDI+PGEgbmFtZT0ibW9kdWxlX1NQTCI+U1BMPC9h PjwvaDI+DQo8
PHRyIGNsYXNzPSJoIj48dGg+U1BMIHN1cHBvcnQ8L3RoPjx0aD5lbmFibGVk PC90aD48L3Ry
Pg0KPHRyPjx0ZCBjbGFzcz0iZSI+SW50ZXJmYWNlcyA8L3RkPjx0ZCBjbGFz cz0idiI+Q291
bnRhYmxlLCBPdXRlckl0ZXJhdG9yLCBSZWN1cnNpdmVJdGVyYXRvciwgU2Vl a2FibGVJdGVy
YXRvciwgU3BsT2JzZXJ2ZXIsIFNwbFN1YmplY3QgPC90ZD48L3RyPg0KPHRy Pjx0ZCBjbGFz
cz0iZSI+Q2xhc3NlcyA8L3RkPjx0ZCBjbGFzcz0idiI+QXBwZW5kSXRlcmF0 b3IsDQpBcnJh
eUl0ZXJhdG9yLCBBcnJheU9iamVjdCwgQmFkRnVuY3Rpb25DYWxsRXhjZXB0 aW9uLA0KQmFk
TWV0aG9kQ2FsbEV4Y2VwdGlvbiwgQ2FjaGluZ0l0ZXJhdG9yLCBEaXJlY3Rv cnlJdGVyYXRv
ciwNCkRvbWFpbkV4Y2VwdGlvbiwgRW1wdHlJdGVyYXRvciwgRmlsdGVySXRl cmF0b3IsIElu
ZmluaXRlSXRlcmF0b3IsDQpJbnZhbGlkQXJndW1lbnRFeGNlcHRpb24sIEl0 ZXJhdG9ySXRl
cmF0b3IsIExlbmd0aEV4Y2VwdGlvbiwNCkxpbWl0SXRlcmF0b3IsIExvZ2lj RXhjZXB0aW9u
LCBOb1Jld2luZEl0ZXJhdG9yLCBPdXRPZkJvdW5kc0V4Y2VwdGlvbiwNCk91 dE9mUmFuZ2VF
eGNlcHRpb24sIE92ZXJmbG93RXhjZXB0aW9uLCBQYXJlbnRJdGVyYXRvciwg UmFuZ2VFeGNl
cHRpb24sDQpSZWN1cnNpdmVBcnJheUl0ZXJhdG9yLCBSZWN1cnNpdmVDYWNo aW5nSXRlcmF0
b3IsDQpSZWN1cnNpdmVEaXJlY3RvcnlJdGVyYXRvciwgUmVjdXJzaXZlRmls dGVySXRlcmF0
b3IsDQpSZWN1cnNpdmVJdGVyYXRvckl0ZXJhdG9yLCBSZWN1cnNpdmVSZWdl eEl0ZXJhdG9y
LCBSZWdleEl0ZXJhdG9yLA0KUnVudGltZUV4Y2VwdGlvbiwgU2ltcGxlWE1M SXRlcmF0b3Is
IFNwbEZpbGVJbmZvLCBTcGxGaWxlT2JqZWN0LA0KU3BsT2JqZWN0U3RvcmFn ZSwgU3BsVGVt
cEZpbGVPYmplY3QsIFVuZGVyZmxvd0V4Y2VwdGlvbiwNClVuZXhwZWN0ZWRW YWx1ZUV4Y2Vw
dGlvbiA8L3RkPjwvdHI+DQo8L3Rib2R5PjwvdGFibGU+PGJyPg0KPGgyPjxh IG5hbWU9Im1v
ZHVsZV9TUUxpdGUiPlNRTGl0ZTwvYT48L2gyPg0KPHRhYmxlIGJvcmRlcj0i MCIgY2VsbHBh
ZGRpbmc9IjMiIHdpZHRoPSI2MDAiPg0KPHRib2R5Pjx0ciBjbGFzcz0iaCI+ PHRoPlNRTGl0
ZSBzdXBwb3J0PC90aD48dGg+ZW5hYmxlZDwvdGg+PC90cj4NCjx0cj48dGQg Y2xhc3M9ImUi
PlBFQ0wgTW9kdWxlIHZlcnNpb24gPC90ZD48dGQgY2xhc3M9InYiPjIuMC1k ZXYgJElkOiBz
cWxpdGUuYyx2IDEuMTY2LjIuMTMuMi41IDIwMDYvMTAvMjAgMjE6Mjg6MzEg dG9ueTIwMDEg
RXhwICQgPC90ZD48L3RyPg0KPHRyPjx0ZCBjbGFzcz0iZSI+U1FMaXRlIExp YnJhcnkgPC90
ZD48dGQgY2xhc3M9InYiPjIuOC4xNyA8L3RkPjwvdHI+DQo8dHI+PHRkIGNs YXNzPSJlIj5T
UUxpdGUgRW5jb2RpbmcgPC90ZD48dGQgY2xhc3M9InYiPmlzbzg4NTkgPC90 ZD48L3RyPg0K
dGQgY2xhc3M9ImUiPnNxbGl0ZS5hc3NvY19jYXNlPC90ZD48dGQgY2xhc3M9 InYiPjA8L3Rk
Pjx0ZCBjbGFzcz0idiI+MDwvdGQ+PC90cj4NCjwvdGJvZHk+PC90YWJsZT48 YnI+DQo8aDI+
PGEgbmFtZT0ibW9kdWxlX3N0YW5kYXJkIj5zdGFuZGFyZDwvYT48L2gyPg0K PHRhYmxlIGJv
cmRlcj0iMCIgY2VsbHBhZGRpbmc9IjMiIHdpZHRoPSI2MDAiPg0KPHRib2R5 Pjx0cj48dGQg
Y2xhc3M9ImUiPlJlZ2V4IExpYnJhcnkgPC90ZD48dGQgY2xhc3M9InYiPkJ1 bmRsZWQgbGli
cmFyeSBlbmFibGVkIDwvdGQ+PC90cj4NCjx0cj48dGQgY2xhc3M9ImUiPkR5 bmFtaWMgTGli
cmFyeSBTdXBwb3J0IDwvdGQ+PHRkIGNsYXNzPSJ2Ij5lbmFibGVkIDwvdGQ+ PC90cj4NCjx0
cj48dGQgY2xhc3M9ImUiPkludGVybmFsIFNlbmRtYWlsIFN1cHBvcnQgZm9y IFdpbmRvd3Mg
PC90ZD48dGQgY2xhc3M9InYiPmVuYWJsZWQgPC90ZD48L3RyPg0KPC90Ym9k eT48L3RhYmxl
Pjxicj4NCjx0YWJsZSBib3JkZXI9IjAiIGNlbGxwYWRkaW5nPSIzIiB3aWR0 aD0iNjAwIj4N
Cjx0Ym9keT48dHIgY2xhc3M9ImgiPjx0aD5EaXJlY3RpdmU8L3RoPjx0aD5M b2NhbCBWYWx1
ZTwvdGg+PHRoPk1hc3RlciBWYWx1ZTwvdGg+PC90cj4NCjx0cj48dGQgY2xh c3M9ImUiPmFz
c2VydC5hY3RpdmU8L3RkPjx0ZCBjbGFzcz0idiI+MTwvdGQ+PHRkIGNsYXNz PSJ2Ij4xPC90
ZD48L3RyPg0KPHRyPjx0ZCBjbGFzcz0iZSI+YXNzZXJ0LmJhaWw8L3RkPjx0 ZCBjbGFzcz0i
diI+MDwvdGQ+PHRkIGNsYXNzPSJ2Ij4wPC90ZD48L3RyPg0KPHRyPjx0ZCBj bGFzcz0iZSI+
YXNzZXJ0LmNhbGxiYWNrPC90ZD48dGQgY2xhc3M9InYiPjxpPm5vIHZhbHVl PC9pPjwvdGQ+
PSJlIj5hc3NlcnQucXVpZXRfZXZhbDwvdGQ+PHRkIGNsYXNzPSJ2Ij4wPC90 ZD48dGQgY2xh
c3M9InYiPjA8L3RkPjwvdHI+DQo8dHI+PHRkIGNsYXNzPSJlIj5hc3NlcnQu d2FybmluZzwv
dGQ+PHRkIGNsYXNzPSJ2Ij4xPC90ZD48dGQgY2xhc3M9InYiPjE8L3RkPjwv dHI+DQo8dHI+
PHRkIGNsYXNzPSJlIj5hdXRvX2RldGVjdF9saW5lX2VuZGluZ3M8L3RkPjx0 ZCBjbGFzcz0i
ZGVmYXVsdF9zb2NrZXRfdGltZW91dDwvdGQ+PHRkIGNsYXNzPSJ2Ij42MDwv dGQ+PHRkIGNs
YXNzPSJ2Ij42MDwvdGQ+PC90cj4NCjx0cj48dGQgY2xhc3M9ImUiPnNhZmVf bW9kZV9hbGxv
d2VkX2Vudl92YXJzPC90ZD48dGQgY2xhc3M9InYiPlBIUF88L3RkPjx0ZCBj bGFzcz0idiI+
UEhQXzwvdGQ+PC90cj4NCjx0cj48dGQgY2xhc3M9ImUiPnNhZmVfbW9kZV9w cm90ZWN0ZWRf
ZW52X3ZhcnM8L3RkPjx0ZCBjbGFzcz0idiI+TERfTElCUkFSWV9QQVRIPC90 ZD48dGQgY2xh
c3M9InYiPkxEX0xJQlJBUllfUEFUSDwvdGQ+PC90cj4NCjx0cj48dGQgY2xh c3M9ImUiPnVy
bF9yZXdyaXRlci50YWdzPC90ZD48dGQgY2xhc3M9InYiPmE9aHJlZixhcmVh PWhyZWYsZnJh
bWU9c3JjLGlucHV0PXNyYyxmb3JtPSxmaWVsZHNldD08L3RkPjx0ZCBjbGFz cz0idiI+YT1o
cmVmLGFyZWE9aHJlZixmcmFtZT1zcmMsaW5wdXQ9c3JjLGZvcm09LGZpZWxk c2V0PTwvdGQ+
PC90cj4NCjx0cj48dGQgY2xhc3M9ImUiPnVzZXJfYWdlbnQ8L3RkPjx0ZCBj bGFzcz0idiI+
PC90cj4NCjwvdGJvZHk+PC90YWJsZT48YnI+DQo8aDI+PGEgbmFtZT0ibW9k dWxlX3Rva2Vu
aXplciI+dG9rZW5pemVyPC9hPjwvaDI+DQo8dGFibGUgYm9yZGVyPSIwIiBj ZWxscGFkZGlu
Zz0iMyIgd2lkdGg9IjYwMCI+DQo8dGJvZHk+PHRyPjx0ZCBjbGFzcz0iZSI+ VG9rZW5pemVy
IFN1cHBvcnQgPC90ZD48dGQgY2xhc3M9InYiPmVuYWJsZWQgPC90ZD48L3Ry Pg0KPC90Ym9k
eT48L3RhYmxlPjxicj4NCjxoMj48YSBuYW1lPSJtb2R1bGVfd2RkeCI+d2Rk eDwvYT48L2gy
Pg0KPHRhYmxlIGJvcmRlcj0iMCIgY2VsbHBhZGRpbmc9IjMiIHdpZHRoPSI2 MDAiPg0KPHRi
b2R5Pjx0ciBjbGFzcz0iaCI+PHRoPldERFggU3VwcG9ydDwvdGg+PHRoPmVu YWJsZWQ8L3Ro
PjwvdHI+DQo8dHI+PHRkIGNsYXNzPSJlIj5XRERYIFNlc3Npb24gU2VyaWFs aXplciA8L3Rk
Pjx0ZCBjbGFzcz0idiI+ZW5hYmxlZCA8L3RkPjwvdHI+DQo8L3Rib2R5Pjwv dGFibGU+PGJy
Pg0KPGgyPjxhIG5hbWU9Im1vZHVsZV94ZGVidWciPnhkZWJ1ZzwvYT48L2gy Pg0KPHRhYmxl
bGFzcz0iaCI+PHRoPnhkZWJ1ZyBzdXBwb3J0PC90aD48dGg+ZW5hYmxlZDwv dGg+PC90cj4N
Cjx0cj48dGQgY2xhc3M9ImUiPlZlcnNpb24gPC90ZD48dGQgY2xhc3M9InYi PjIuMC4wUkM0
LWRldiA8L3RkPjwvdHI+DQo8L3Rib2R5PjwvdGFibGU+PGJyPg0KPHRhYmxl IGJvcmRlcj0i
PHRoPlN1cHBvcnRlZCBwcm90b2NvbHM8L3RoPjx0aD5SZXZpc2lvbjwvdGg+ PC90cj4NCjx0
cj
Re: (attachments added) Problem when debugging with "Web Script using XDebug" [message #18607 is a reply to message #18572] Thu, 10 May 2007 08:38 Go to previous messageGo to next message
ALi, I noticed that the port is 9999 for xdebug. Is that the port you have
your IDE listening on ? If you change the port, you need to stop and restart
eclipse currently for the new value to be picked up.
Dave Kelsey
> Cheers,
> Ali
>> web server.
>> if XDebug is
>> Ali B. wrote:
>>> Sorry about forgetting to attach the screen shots, here they are.
>>> Ali B. wrote:
>>>> Hello everyone,
>>>> I have installed clean PDT-all-in-one 0.7 RC3 along with the XDebug
>>>> plugin 0.2.0. I have followed every inch of the XDebug plugin included
>>>> PDF instructions (V 1.04) to configure it.
>>>> Now my debugging with "PHP EXE script Xdebug" works like a *charm*. But
>>>> when I try to debug with "PHP Web Script using Xdebug", my browser
>>>> (tried internal, IE, FF) pop ups with an opened url and displays the
>>>> whole page. while eclipse gives me the "Xdebug waiting for session".
>>>> I made sure to run my apache run in the workspace folder using
>>>> Apache.exe -c "DocumentRoot "D:\eclipse\workspace"" and made sure my
>>>> correct php.ini file (the one that displays when running a phpinfo()
>>>> correctly.
>>>> below is my xdebug portion of my php.ini (Note: I am running a
>>>> non-debug
>>>> build of PHP, and thread safety is enabled in my php.ini
>>>> [xdebug]
>>>> zend_extension_ts=D:\wamp\php\ext\php_xdebug.dll
>>>> xdebug.remote_enable=1
>>>> xdebug.remote_host=localhost
>>>> xdebug.remote_port=9000
>>>> xdebug.remote_handler=dbgp
>>>> I have tried with and without double quotes for the path, host and the
>>>> handler but with the same outcome.
>>>> I have also attached a screenshot of the PHP->Debug portion of eclipse
>>>> preferences, and also of the web xdebug config window.
>>>> The project name is test and I am debugging its index.php. When I debug
>>>> with web script using xdebug, I get something like the following url in
>>>> my broswer:
>>>> http://localhost/test/index.php?XDEBUG_SESSION_START=ECLIPSE _XDEBUG&KEY=11786513979533
>>>> Am I missing something here? Appreciate all the help, please let me
>>>> know
>>>> if any more info is needed.
>>>> Cheers,
>>>> Ali
> PHP Logo <http://www.php.net/>
> PHP Version 5.2.0
> System Windows NT THEMACHINE 5.1 build 2600
> Build Date Nov 2 2006 11:50:55
> Configure Command cscript /nologo configure.js
> "--enable-snapshot-build" "--with-gd=shared"
> Server API Apache 2.0 Handler
> Virtual Directory Support enabled
> Configuration File (php.ini) Path D:\wamp\Apache2\bin\php.ini
> PHP API 20041225
> PHP Extension 20060613
> Zend Extension 220060519
> Debug Build no
> Thread Safety enabled
> Zend Memory Manager enabled
> IPv6 Support enabled
> Registered PHP Streams php, file, data, http, ftp, compress.zlib
> Registered Stream Socket Transports tcp, udp
> Registered Stream Filters convert.iconv.*, string.rot13,
> string.toupper, string.tolower, string.strip_tags, convert.*, consumed,
> zlib.*
> Zend logo <http://www.zend.com/> This program makes use of the Zend
> Scripting Language Engine:
> Zend Engine v2.2.0, Copyright (c) 1998-2006 Zend Technologies
> with Xdebug v2.0.0RC4-dev, Copyright (c) 2002, 2003, 2004, 2005, 2006, 2007, by Derick Rethans
> PHP Credits
> < http://localhost/test/index.php?=PHPB8B5F2A0-3C92-11d3-A3A9- 4C7B08C10000>
> Configuration
> PHP Core
> Directive Local Value Master Value
> allow_call_time_pass_reference On On
> allow_url_fopen On On
> allow_url_include Off Off
> always_populate_raw_post_data Off Off
> arg_separator.input & &
> arg_separator.output & &
> asp_tags Off Off
> auto_append_file /no value/ /no value/
> auto_globals_jit On On
> auto_prepend_file /no value/ /no value/
> browscap /no value/ /no value/
> default_charset /no value/ /no value/
> default_mimetype text/html text/html
> define_syslog_variables Off Off
> disable_classes /no value/ /no value/
> disable_functions /no value/ /no value/
> display_errors On On
> display_startup_errors Off Off
> doc_root /no value/ /no value/
> docref_ext /no value/ /no value/
> docref_root /no value/ /no value/
> enable_dl On On
> error_append_string /no value/ /no value/
> error_log D:/wamp/logs/php_error.log D:/wamp/logs/php_error.log
> error_prepend_string /no value/ /no value/
> error_reporting 6135 6135
> expose_php On On
> extension_dir D:/wamp/php/ext/ D:/wamp/php/ext/
> file_uploads On On
> highlight.bg #FFFFFF #FFFFFF
> highlight.comment #FF8000 #FF8000
> highlight.default #0000BB #0000BB
> highlight.html #000000 #000000
> highlight.keyword #007700 #007700
> highlight.string #DD0000 #DD0000
> html_errors On On
> ignore_repeated_errors Off Off
> ignore_repeated_source Off Off
> ignore_user_abort Off Off
> implicit_flush Off Off
> include_path .;C:\php5\pear .;C:\php5\pear
> log_errors On On
> log_errors_max_len 1024 1024
> magic_quotes_gpc On On
> magic_quotes_runtime Off Off
> magic_quotes_sybase Off Off
> mail.force_extra_parameters /no value/ /no value/
> max_execution_time 30 30
> max_input_time 60 60
> open_basedir /no value/ /no value/
> output_buffering /no value/ /no value/
> output_handler /no value/ /no value/
> post_max_size 8M 8M
> precision 12 12
> realpath_cache_size 16K 16K
> realpath_cache_ttl 120 120
> register_argc_argv On On
> register_globals Off Off
> register_long_arrays On On
> report_memleaks On On
> report_zend_debug On On
> safe_mode Off Off
> safe_mode_exec_dir /no value/ /no value/
> safe_mode_gid Off Off
> safe_mode_include_dir /no value/ /no value/
> sendmail_from you@yourdomain you@yourdomain
> sendmail_path /no value/ /no value/
> serialize_precision 100 100
> short_open_tag Off Off
> SMTP localhost localhost
> smtp_port 25 25
> sql.safe_mode Off Off
> track_errors Off Off
> unserialize_callback_func /no value/ /no value/
> upload_max_filesize 2M 2M
> upload_tmp_dir D:/wamp/tmp D:/wamp/tmp
> user_dir /no value/ /no value/
> variables_order EGPCS EGPCS
> xmlrpc_error_number 0 0
> xmlrpc_errors Off Off
> y2k_compliance On On
> zend.ze1_compatibility_mode Off Off
> apache2handler
> Apache Version Apache/2.0.59 (Win32) PHP/5.2.0
> Apache API Version 20020903
> Server Administrator webmaster@localhost
> Hostname:Port localhost:80
> Max Requests Per Child: 0 - Keep Alive: on - Max Per Connection: 100
> Timeouts Connection: 300 - Keep-Alive: 15
> Virtual Server No
> Server Root D:/wamp/Apache2
> Loaded Modules core mod_win32 mpm_winnt http_core mod_so mod_access
> mod_actions mod_alias mod_asis mod_auth mod_autoindex mod_cgi mod_dir
> mod_env mod_imap mod_include mod_isapi mod_log_config mod_mime
> mod_negotiation mod_rewrite mod_setenvif mod_userdir mod_php5
> engine 1 1
> last_modified 0 0
> xbithack 0 0
> Apache Environment
> Variable Value
> HTTP_HOST localhost
> HTTP_USER_AGENT Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US;
> rv:1.8.1.3) Gecko/20070309 Firefox/2.0.0.3
> HTTP_ACCEPT
> text/xml,application/xml,application/xhtml+xml,text/html;q=0 .9,text/plain;q=0.8,image/png,*/*;q=0.5
> HTTP_ACCEPT_LANGUAGE en-us,en;q=0.7,ar;q=0.3
> HTTP_ACCEPT_ENCODING gzip,deflate
> HTTP_ACCEPT_CHARSET ISO-8859-1,utf-8;q=0.7,*;q=0.7
> HTTP_KEEP_ALIVE 300
> HTTP_CONNECTION keep-alive
> PATH D:\ActiveState Komodo IDE 4.0\;C:\Program Files\PC Connectivity
> Solution\;C:\php5\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS \System32\Wbem;C:\Program
> Files\Common Files\Adobe\AGL;C:\Program
> Files\Java\jre1.5.0_08\bin\;C:\Program Files\IDM Computer
> Solutions\UltraEdit-32;C:\Program Files\QuickTime\QTSystem\
> SystemRoot C:\WINDOWS
> COMSPEC C:\WINDOWS\system32\cmd.exe
> PATHEXT .COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH
> WINDIR C:\WINDOWS
> SERVER_SIGNATURE <address>Apache/2.0.59 (Win32) PHP/5.2.0 Server at
> localhost Port 80</address>
> SERVER_SOFTWARE Apache/2.0.59 (Win32) PHP/5.2.0
> SERVER_NAME localhost
> SERVER_ADDR 127.0.0.1
> SERVER_PORT 80
> REMOTE_ADDR 127.0.0.1
> DOCUMENT_ROOT D:/eclipse/workspace
> SERVER_ADMIN webmaster@localhost
> SCRIPT_FILENAME D:/eclipse/workspace/test/index.php
> REMOTE_PORT 1141
> GATEWAY_INTERFACE CGI/1.1
> SERVER_PROTOCOL HTTP/1.1
> REQUEST_METHOD GET
> QUERY_STRING XDEBUG_SESSION_START=ECLIPSE_XDEBUG&KEY=11787299630621
> REQUEST_URI
> /test/index.php?XDEBUG_SESSION_START=ECLIPSE_XDEBUG&KEY= 11787299630621
> SCRIPT_NAME /test/index.php
> HTTP Headers Information
> HTTP Request Headers
> HTTP Request GET
> HTTP/1.1
> Host localhost
> User-Agent Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.1.3)
> Accept
> Accept-Language en-us,en;q=0.7,ar;q=0.3
> Accept-Encoding gzip,deflate
> Accept-Charset ISO-8859-1,utf-8;q=0.7,*;q=0.7
> Keep-Alive 300
> Connection keep-alive
> HTTP Response Headers
> X-Powered-By PHP/5.2.0
> Set-Cookie XDEBUG_SESSION=ECLIPSE_XDEBUG; expires=Wed, 09-May-2007
> 17:59:49 GMT; path=/
> Keep-Alive timeout=15, max=100
> Connection Keep-Alive
> Transfer-Encoding chunked
> Content-Type text/html
> bcmath
> BCMath support enabled
> calendar
> Calendar support enabled
> com_dotnet
> COM support enabled
> DCOM support disabled
> .Net support enabled
> com.allow_dcom 0 0
> com.autoregister_casesensitive 1 1
> com.autoregister_typelib 0 0
> com.autoregister_verbose 0 0
> com.code_page /no value/ /no value/
> com.typelib_file /no value/ /no value/
> ctype
> ctype functions enabled
> date
> date/time support enabled
> Timezone Database Version 2006.14
> Timezone Database internal
> Default timezone Europe/Moscow
> date.default_latitude 31.7667 31.7667
> date.default_longitude 35.2333 35.2333
> date.sunrise_zenith 90.583333 90.583333
> date.sunset_zenith 90.583333 90.583333
> date.timezone /no value/ /no value/
> dom
> DOM/XML enabled
> DOM/XML API Version 20031129
> libxml Version 2.6.26
> HTML Support enabled
> XPath Support enabled
> XPointer Support enabled
> Schema Support enabled
> RelaxNG Support enabled
> filter
> Input Validation and Filtering enabled
> Revision $Revision: 1.52.2.25 $
> filter.default unsafe_raw unsafe_raw
> filter.default_flags /no value/ /no value/
> ftp
> FTP support enabled
> hash
> hash support enabled
> Hashing Engines md4 md5 sha1 sha256 sha384 sha512 ripemd128 ripemd160
> whirlpool tiger128,3 tiger160,3 tiger192,3 tiger128,4 tiger160,4
> tiger192,4 snefru gost adler32 crc32 crc32b haval128,3 haval160,3
> haval192,3 haval224,3 haval256,3 haval128,4 haval160,4 haval192,4
> haval224,4 haval256,4 haval128,5 haval160,5 haval192,5 haval224,5
> haval256,5
> iconv
> iconv support enabled
> iconv implementation "libiconv"
> iconv library version 1.9
> iconv.input_encoding ISO-8859-1 ISO-8859-1
> iconv.internal_encoding ISO-8859-1 ISO-8859-1
> iconv.output_encoding ISO-8859-1 ISO-8859-1
> json
> json support enabled
> json version 1.2.1
> libxml
> libXML support active
> libXML Version 2.6.26
> libXML streams enabled
> mbstring
> Multibyte Support enabled
> Multibyte string engine libmbfl
> Multibyte (japanese) regex support enabled
> Multibyte regex (oniguruma) version 4.4.4
> Multibyte regex (oniguruma) backtrack check On
> mbstring extension makes use of "streamable kanji code filter and
> converter", which is distributed under the GNU Lesser General Public
> License version 2.1.
> mbstring.detect_order /no value/ /no value/
> mbstring.encoding_translation Off Off
> mbstring.func_overload 0 0
> mbstring.http_input pass pass
> mbstring.http_output pass pass
> mbstring.internal_encoding ISO-8859-1 /no value/
> mbstring.language neutral neutral
> mbstring.strict_detection Off Off
> mbstring.substitute_character /no value/ /no value/
> mysql
> MySQL Support enabled
> Active Persistent Links 0
> Active Links 0
> Client API version 5.0.27
> mysql.allow_persistent On On
> mysql.connect_timeout 60 60
> mysql.default_host /no value/ /no value/
> mysql.default_password /no value/ /no value/
> mysql.default_port /no value/ /no value/
> mysql.default_socket /no value/ /no value/
> mysql.default_user /no value/ /no value/
> mysql.max_links Unlimited Unlimited
> mysql.max_persistent Unlimited Unlimited
> mysql.trace_mode Off Off
> mysqli
> MysqlI Support enabled
> Client API library version 5.0.27
> Client API header version 5.0.22
> MYSQLI_SOCKET /tmp/mysql.sock
> mysqli.default_host /no value/ /no value/
> mysqli.default_port 3306 3306
> mysqli.default_pw /no value/ /no value/
> mysqli.default_socket /no value/ /no value/
> mysqli.default_user /no value/ /no value/
> mysqli.max_links Unlimited Unlimited
> mysqli.reconnect Off Off
> odbc
> ODBC Support enabled
> Active Links 0
> ODBC library Win32
> odbc.allow_persistent On On
> odbc.check_persistent On On
> odbc.default_db /no value/ /no value/
> odbc.default_pw /no value/ /no value/
> odbc.default_user /no value/ /no value/
> odbc.defaultbinmode return as is return as is
> odbc.defaultlrl return up to 4096 bytes return up to 4096 bytes
> odbc.max_links Unlimited Unlimited
> odbc.max_persistent Unlimited Unlimited
> pcre
> PCRE (Perl Compatible Regular Expressions) Support enabled
> PCRE Library Version 6.7 04-Jul-2006
> PDO
> PDO support enabled
> PDO drivers sqlite, sqlite2
> pdo_sqlite
> PDO Driver for SQLite 3.x enabled
> PECL Module version 1.0.1 $Id: pdo_sqlite.c,v 1.10.2.6 2006/01/01
> 12:50:12 sniper Exp $
> SQLite Library 3.3.7undefined
> Reflection
> Reflection enabled
> Version $Id: php_reflection.c,v 1.164.2.33.2.31 2006/10/18 16:35:15
> johannes Exp $
> session
> Session Support enabled
> Registered save handlers files user sqlite
> Registered serializer handlers php php_binary wddx
> session.auto_start Off Off
> session.bug_compat_42 On On
> session.bug_compat_warn On On
> session.cache_expire 180 180
> session.cache_limiter nocache nocache
> session.cookie_domain /no value/ /no value/
> session.cookie_httponly Off Off
> session.cookie_lifetime 0 0
> session.cookie_path / /
> session.cookie_secure Off Off
> session.entropy_file /no value/ /no value/
> session.entropy_length 0 0
> session.gc_divisor 100 100
> session.gc_maxlifetime 1440 1440
> session.gc_probability 1 1
> session.hash_bits_per_character 4 4
> session.hash_function 0 0
> session.name PHPSESSID PHPSESSID
> session.referer_check /no value/ /no value/
> session.save_handler files files
> session.save_path D:/wamp/tmp D:/wamp/tmp
> session.serialize_handler php php
> session.use_cookies On On
> session.use_only_cookies Off Off
> session.use_trans_sid 0 0
> SimpleXML
> Simplexml support enabled
> Revision $Revision: 1.151.2.22.2.15 $
> Schema support enabled
> SPL
> SPL support enabled
> Interfaces Countable, OuterIterator, RecursiveIterator,
> SeekableIterator, SplObserver, SplSubject
> Classes AppendIterator, ArrayIterator, ArrayObject,
> BadFunctionCallException, BadMethodCallException, CachingIterator,
> DirectoryIterator, DomainException, EmptyIterator, FilterIterator,
> InfiniteIterator, InvalidArgumentException, IteratorIterator,
> LengthException, LimitIterator, LogicException, NoRewindIterator,
> OutOfBoundsException, OutOfRangeException, OverflowException,
> ParentIterator, RangeException, RecursiveArrayIterator,
> RecursiveCachingIterator, RecursiveDirectoryIterator,
> RecursiveFilterIterator, RecursiveIteratorIterator,
> RecursiveRegexIterator, RegexIterator, RuntimeException,
> SimpleXMLIterator, SplFileInfo, SplFileObject, SplObjectStorage,
> SplTempFileObject, UnderflowException, UnexpectedValueException
> SQLite
> SQLite support enabled
> PECL Module version 2.0-dev $Id: sqlite.c,v 1.166.2.13.2.5 2006/10/20
> 21:28:31 tony2001 Exp $
> SQLite Library 2.8.17
> SQLite Encoding iso8859
> sqlite.assoc_case 0 0
> standard
> Regex Library Bundled library enabled
> Dynamic Library Support enabled
> Internal Sendmail Support for Windows enabled
> assert.active 1 1
> assert.bail 0 0
> assert.callback /no value/ /no value/
> assert.quiet_eval 0 0
> assert.warning 1 1
> auto_detect_line_endings 0 0
> default_socket_timeout 60 60
> safe_mode_allowed_env_vars PHP_ PHP_
> safe_mode_protected_env_vars LD_LIBRARY_PATH LD_LIBRARY_PATH
> url_rewriter.tags a=href,area=href,frame=src,input=src,form=,fieldset=
> user_agent /no value/ /no value/
> tokenizer
> Tokenizer Support enabled
> wddx
> WDDX Support enabled
> WDDX Session Serializer enabled
> xdebug
> xdebug support enabled
> Version 2.0.0RC4-dev
> Supported protocols Revision
> DBGp - Common DeBuGger Protocol $Revision: 1.117 $
> GDB - GNU Debugger protocol $Revision: 1.87 $
> PHP3 - PHP 3 Debugger protocol $Revision: 1.22 $
> xdebug.auto_trace Off Off
> xdebug.collect_includes On On
> xdebug.collect_params Off Off
> xdebug.collect_return Off Off
> xdebug.collect_vars Off Off
> xdebug.default_enable On On
> xdebug.dump.COOKIE /no value/ /no value/
> xdebug.dump.ENV /no value/ /no value/
> xdebug.dump.FILES /no value/ /no value/
> xdebug.dump.GET /no value/ /no value/
> xdebug.dump.POST /no value/ /no value/
> xdebug.dump.REQUEST /no value/ /no value/
> xdebug.dump.SERVER /no value/ /no value/
> xdebug.dump.SESSION /no value/ /no value/
> xdebug.dump_globals On On
> xdebug.dump_once On On
> xdebug.dump_undefined Off Off
> xdebug.extended_info On On
> xdebug.idekey DMON /no value/
> xdebug.manual_url http://www.php.net http://www.php.net
> xdebug.max_nesting_level 100 100
> xdebug.profiler_aggregate Off Off
> xdebug.profiler_append Off Off
> xdebug.profiler_enable Off Off
> xdebug.profiler_enable_trigger Off Off
> xdebug.profiler_output_dir /tmp /tmp
> xdebug.profiler_output_name crc32 crc32
> xdebug.remote_autostart Off Off
> xdebug.remote_enable On On
> xdebug.remote_handler dbgp dbgp
> xdebug.remote_host localhost localhost
> xdebug.remote_log /no value/ /no value/
> xdebug.remote_mode req req
> xdebug.remote_port 9999 9000
> xdebug.show_exception_trace Off Off
> xdebug.show_local_vars Off Off
> xdebug.show_mem_delta Off Off
> xdebug.trace_format 0 0
> xdebug.trace_options 0 0
> xdebug.trace_output_dir /tmp /tmp
> xdebug.trace_output_name crc32 crc32
> xdebug.var_display_max_children 128 128
> xdebug.var_display_max_data 512 512
> xdebug.var_display_max_depth 3 3
> xml
> XML Support active
> XML Namespace Support active
> libxml2 Version 2.6.26
> xmlreader
> XMLReader enabled
> xmlwriter
> XMLWriter enabled
> zlib
> ZLib Support enabled
> Stream Wrapper support compress.zlib://
> Stream Filter support zlib.inflate, zlib.deflate
> Compiled Version 1.2.3
> Linked Version 1.2.3
> zlib.output_compression Off Off
> zlib.output_compression_level -1 -1
> zlib.output_handler /no value/ /no value/
> Additional Modules
> Module Name
> Environment
> Variable Value
> %firefox% c:
> /no value/ ::=::\
> /no value/ C:=C:\Documents and Settings\Dmon
> /no value/ D:=D:\wamp\Apache2\bin
> ALLUSERSPROFILE C:\Documents and Settings\All Users
> APPDATA C:\Documents and Settings\Dmon\Application Data
> CLASSPATH .;C:\Program Files\Java\jre1.5.0_08\bin\;C:\Program
> Files\Java\jre1.5.0_10\lib\ext\QTJava.zip
> CLIENTNAME Console
> COLLECTIONID COL8143
> CommonProgramFiles C:\Program Files\Common Files
> COMPUTERNAME THEMACHINE
> ComSpec C:\WINDOWS\system32\cmd.exe
> FP_NO_HOST_CHECK NO
> HMSERVER https://wwss1proa.cce.hp.com/wuss/servlet/WUSSServlet
> HOMEDRIVE C:
> HOMEPATH \Documents and Settings\Dmon
> ITEMID dj-22741-15
> LANG 1033
> LOGONSERVER \\THEMACHINE
> NUMBER_OF_PROCESSORS 2
> OS Windows_NT
> OSVER winXPP
> Path D:\ActiveState Komodo IDE 4.0\;C:\Program Files\PC Connectivity
> PROCESSOR_ARCHITECTURE x86
> PROCESSOR_IDENTIFIER x86 Family 15 Model 4 Stepping 3, GenuineIntel
> PROCESSOR_LEVEL 15
> PROCESSOR_REVISION 0403
> PROMPT $P$G
> QTJAVA C:\Program Files\Java\jre1.5.0_10\lib\ext\QTJava.zip
> SESSIONID 1155477565570htx606012e3e73:10d07d45345:-624b
> SESSIONNAME Console
> SWUTVER 1.0.22.20030804
> SystemDrive C:
> TEMP C:\DOCUME~1\Dmon\LOCALS~1\Temp
> TIMEOUT 0
> TMP C:\DOCUME~1\Dmon\LOCALS~1\Temp
> TOOLPATH /C:\Program%20Files\HP\HP%20Software%20Update\install.htm
> UPDATEDIR C:\DOCUME~1\Dmon\LOCALS~1\Temp\radE7D66.tmp
> USERDOMAIN THEMACHINE
> USERNAME Dmon
> USERPROFILE C:\Documents and Settings\Dmon
> VERSION 3.0.5.001
> windir C:\WINDOWS
> XDEBUG_CONFIG remote_port=9999 remote_enable=1 idekey=DMON
> AP_PARENT_PID 3816
> PHP Variables
> Variable Value
> _REQUEST["XDEBUG_SESSION_START"] ECLIPSE_XDEBUG
> _REQUEST["KEY"] 11787299630621
> _GET["XDEBUG_SESSION_START"] ECLIPSE_XDEBUG
> _GET["KEY"] 11787299630621
> _SERVER["HTTP_HOST"] localhost
> _SERVER["HTTP_USER_AGENT"] Mozilla/5.0 (Windows; U; Windows NT 5.1;
> en-US; rv:1.8.1.3) Gecko/20070309 Firefox/2.0.0.3
> _SERVER["HTTP_ACCEPT"]
> _SERVER["HTTP_ACCEPT_LANGUAGE"] en-us,en;q=0.7,ar;q=0.3
> _SERVER["HTTP_ACCEPT_ENCODING"] gzip,deflate
> _SERVER["HTTP_ACCEPT_CHARSET"] ISO-8859-1,utf-8;q=0.7,*;q=0.7
> _SERVER["HTTP_KEEP_ALIVE"] 300
> _SERVER["HTTP_CONNECTION"] keep-alive
> _SERVER["PATH"] D:\ActiveState Komodo IDE 4.0\;C:\Program Files\PC
> Connectivity
> _SERVER["SystemRoot"] C:\WINDOWS
> _SERVER["COMSPEC"] C:\WINDOWS\system32\cmd.exe
> _SERVER["PATHEXT"] .COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH
> _SERVER["WINDIR"] C:\WINDOWS
> _SERVER["SERVER_SIGNATURE"] <address>Apache/2.0.59 (Win32) PHP/5.2.0
> Server at localhost Port 80</address>
> _SERVER["SERVER_SOFTWARE"] Apache/2.0.59 (Win32) PHP/5.2.0
> _SERVER["SERVER_NAME"] localhost
> _SERVER["SERVER_ADDR"] 127.0.0.1
> _SERVER["SERVER_PORT"] 80
> _SERVER["REMOTE_ADDR"] 127.0.0.1
> _SERVER["DOCUMENT_ROOT"] D:/eclipse/workspace
> _SERVER["SERVER_ADMIN"] webmaster@localhost
> _SERVER["SCRIPT_FILENAME"] D:/eclipse/workspace/test/index.php
> _SERVER["REMOTE_PORT"] 1141
> _SERVER["GATEWAY_INTERFACE"] CGI/1.1
> _SERVER["SERVER_PROTOCOL"] HTTP/1.1
> _SERVER["REQUEST_METHOD"] GET
> _SERVER["QUERY_STRING"]
> _SERVER["REQUEST_URI"]
> _SERVER["SCRIPT_NAME"] /test/index.php
> _SERVER["PHP_SELF"] /test/index.php
> _SERVER["REQUEST_TIME"] 1178729988
> _SERVER["argv"]
> Array
> [0] => XDEBUG_SESSION_START=ECLIPSE_XDEBUG&KEY=11787299630621
> _SERVER["argc"] 1
> _ENV["%firefox%"] c:
> _ENV["ALLUSERSPROFILE"] C:\Documents and Settings\All Users
> _ENV["APPDATA"] C:\Documents and Settings\Dmon\Application Data
> _ENV["CLASSPATH"] .;C:\Program Files\Java\jre1.5.0_08\bin\;C:\Program
> _ENV["CLIENTNAME"] Console
> _ENV["COLLECTIONID"] COL8143
> _ENV["CommonProgramFiles"] C:\Program Files\Common Files
> _ENV["COMPUTERNAME"] THEMACHINE
> _ENV["ComSpec"] C:\WINDOWS\system32\cmd.exe
> _ENV["FP_NO_HOST_CHECK"] NO
> _ENV["HMSERVER"] https://wwss1proa.cce.hp.com/wuss/servlet/WUSSServlet
> _ENV["HOMEDRIVE"] C:
> _ENV["HOMEPATH"] \Documents and Settings\Dmon
> _ENV["ITEMID"] dj-22741-15
> _ENV["LANG"] 1033
> _ENV["LOGONSERVER"] \\THEMACHINE
> _ENV["NUMBER_OF_PROCESSORS"] 2
> _ENV["OS"] Windows_NT
> _ENV["OSVER"] winXPP
> _ENV["Path"] D:\ActiveState Komodo IDE 4.0\;C:\Program Files\PC
> Connectivity
> _ENV["PATHEXT"] .COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH
> _ENV["PROCESSOR_ARCHITECTURE"] x86
> _ENV["PROCESSOR_IDENTIFIER"] x86 Family 15 Model 4 Stepping 3, GenuineIntel
> _ENV["PROCESSOR_LEVEL"] 15
> _ENV["PROCESSOR_REVISION"] 0403
> _ENV["ProgramFiles"] C:\Program Files
> _ENV["PROMPT"] $P$G
> _ENV["QTJAVA"] C:\Program Files\Java\jre1.5.0_10\lib\ext\QTJava.zip
> _ENV["SESSIONID"] 1155477565570htx606012e3e73:10d07d45345:-624b
> _ENV["SESSIONNAME"] Console
> _ENV["SWUTVER"] 1.0.22.20030804
> _ENV["SystemDrive"] C:
> _ENV["SystemRoot"] C:\WINDOWS
> _ENV["TEMP"] C:\DOCUME~1\Dmon\LOCALS~1\Temp
> _ENV["TIMEOUT"] 0
> _ENV["TMP"] C:\DOCUME~1\Dmon\LOCALS~1\Temp
> _ENV["TOOLPATH"] /C:\Program%20Files\HP\HP%20Software%20Update\install.htm
> _ENV["UPDATEDIR"] C:\DOCUME~1\Dmon\LOCALS~1\Temp\radE7D66.tmp
> _ENV["USERDOMAIN"] THEMACHINE
> _ENV["USERNAME"] Dmon
> _ENV["USERPROFILE"] C:\Documents and Settings\Dmon
> _ENV["VERSION"] 3.0.5.001
> _ENV["windir"] C:\WINDOWS
> _ENV["XDEBUG_CONFIG"] remote_port=9999 remote_enable=1 idekey=DMON
> _ENV["AP_PARENT_PID"] 3816
> PHP License
> This program is free software; you can redistribute it and/or modify it
> under the terms of the PHP License as published by the PHP Group and
> included in the distribution in the file: LICENSE
> This program is distributed in the hope that it will be useful, but
> WITHOUT ANY WARRANTY; without even the implied warranty of
> MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
> If you did not receive a copy of the PHP license, or have any questions
> about PHP licensing, please contact license@php.net.
Re: (attachments added) Problem when debugging with "Web Script using XDebug" [message #19250 is a reply to message #18607] Thu, 10 May 2007 18:16 Go to previous messageGo to next message
Ali B. is currently offline Ali B.Friend
Member
Hey Dave!
Yes! this was it. Earlier, I set an env variable to point to port 9999
and a constant idekey. and appearently it was bypassing my php.ini settings.
I deleted that variable, restarted the apache along with the command
prompt window.
Ran Apache ,debugged,and... Voila!
Thanks you very much Dave for your great help :)
Ali
> restart
> Dave Kelsey
> Ali B. wrote:
>> Thanks for the reply Dave, here is a saved page of what I get when I
>> web-xdebug a file with <?php phpinfo(); ?> while starting the apache
>> with Apache.exe -c "DocumentRoot "D:\eclipse\workspace""
>> Thanks again, appreciate your help.
>> Cheers,
>> Ali
>> Dave Kelsey wrote:
>>> Hi Ali. It sounds like XDebug is not initiating the session from the
>>> web server.
>>> Can you post the output from a web script which does phpinfo() to see
>>> if XDebug is
>>> seen and what the configuration is when running within the web browser.
>>>> Ali B. wrote:
>>>>> Hello everyone,
>>>>> But
>>>>> correctly.
>>>>> non-debug
>>>>> [xdebug]
>>>>> debug
>>>>> url in
>>>>> my broswer:
>>>>> know
>>>>> Cheers,
>>>>> Ali
>> PHP Version 5.2.0
>> PHP API 20041225
>> Debug Build no
>> consumed, zlib.*
>> PHP Credits
>> Configuration
>> PHP Core
>> asp_tags Off Off
>> enable_dl On On
>> expose_php On On
>> file_uploads On On
>> html_errors On On
>> log_errors On On
>> post_max_size 8M 8M
>> precision 12 12
>> safe_mode Off Off
>> smtp_port 25 25
>> apache2handler
>> Virtual Server No
>> mod_access mod_actions mod_alias mod_asis mod_auth mod_autoindex
>> mod_cgi mod_dir mod_env mod_imap mod_include mod_isapi mod_log_config
>> mod_mime mod_negotiation mod_rewrite mod_setenvif mod_userdir mod_php5
>> engine 1 1
>> last_modified 0 0
>> xbithack 0 0
>> Apache Environment
>> Variable Value
>> HTTP_HOST localhost
>> HTTP_ACCEPT
>> HTTP_KEEP_ALIVE 300
>> Connectivity
>> WINDIR C:\WINDOWS
>> SERVER_PORT 80
>> REMOTE_PORT 1141
>> REQUEST_METHOD GET
>> REQUEST_URI
>> HTTP Request GET
>> HTTP/1.1
>> Host localhost
>> Accept
>> Keep-Alive 300
>> bcmath
>> calendar
>> com_dotnet
>> COM support enabled
>> com.allow_dcom 0 0
>> ctype
>> date
>> dom
>> DOM/XML enabled
>> filter
>> ftp
>> FTP support enabled
>> hash
>> ripemd160 whirlpool tiger128,3 tiger160,3 tiger192,3 tiger128,4
>> tiger160,4 tiger192,4 snefru gost adler32 crc32 crc32b haval128,3
>> haval160,3 haval192,3 haval224,3 haval256,3 haval128,4 haval160,4
>> haval192,4 haval224,4 haval256,4 haval128,5 haval160,5 haval192,5
>> haval224,5 haval256,5
>> iconv
>> json
>> json version 1.2.1
>> libxml
>> mbstring
>> mysql
>> Active Links 0
>> mysqli
>> odbc
>> Active Links 0
>> ODBC library Win32
>> pcre
>> PDO
>> PDO support enabled
>> pdo_sqlite
>> Reflection
>> Reflection enabled
>> 16:35:15 johannes Exp $
>> session
>> SimpleXML
>> SPL
>> SPL support enabled
>> SQLite
>> 2006/10/20 21:28:31 tony2001 Exp $
>> standard
>> assert.active 1 1
>> assert.bail 0 0
>> assert.warning 1 1
>> url_rewriter.tags
>> tokenizer
>> wddx
>> xdebug
>> xml
>> XML Support active
>> xmlreader
>> XMLReader enabled
>> xmlwriter
>> XMLWriter enabled
>> zlib
>> Additional Modules
>> Module Name
>> Environment
>> Variable Value
>> %firefox% c:
>> /no value/ ::=::\
>> CLIENTNAME Console
>> FP_NO_HOST_CHECK NO
>> HOMEDRIVE C:
>> ITEMID dj-22741-15
>> LANG 1033
>> OS Windows_NT
>> OSVER winXPP
>> Connectivity
>> PROCESSOR_LEVEL 15
>> PROMPT $P$G
>> SESSIONNAME Console
>> SystemDrive C:
>> TIMEOUT 0
>> USERNAME Dmon
>> VERSION 3.0.5.001
>> windir C:\WINDOWS
>> AP_PARENT_PID 3816
>> PHP Variables
>> Variable Value
>> Connectivity
>> PHP/5.2.0 Server at localhost Port 80</address>
>> _SERVER["argv"]
>> Array
>> _SERVER["argc"] 1
>> _ENV["LANG"] 1033
>> Connectivity
>> GenuineIntel
>> _ENV["PROMPT"] $P$G
>> _ENV["TIMEOUT"] 0
>> _ENV["TOOLPATH"]
>> PHP License
>> it under the terms of the PHP License as published by the PHP Group
>> and included in the distribution in the file: LICENSE
>> questions about PHP licensing, please contact license@php.net.
Re: (attachments added) Problem when debugging with "Web Script using XDebug" [message #19288 is a reply to message #19250] Thu, 10 May 2007 18:34 Go to previous messageGo to next message
Member
Hey Dave,
I have one last question about this if you please.
I hope this wouldn't sound stupid: Now web debugging is a great way to
debug, but until the debug completes, the web browser page stays blank.
Only when stepping into phpinfo(); half of its outcome gets displayed.
Is this an expected thing? or is an xdebug config thing?
Thanks in advance
Ali
Ali B. wrote:
> Hey Dave!
> settings.
> prompt window.
> Cheers,
> Ali
>> have
>> restart
>> Dave Kelsey
>>> Cheers,
>>> Ali
>>>> web server.
>>>> see if XDebug is
>>>>> Ali B. wrote:
>>>>>> Hello everyone,
>>>>>> included
>>>>>> *charm*. But
>>>>>> correctly.
>>>>>> non-debug
>>>>>> [xdebug]
>>>>>> the
>>>>>> eclipse
>>>>>> debug
>>>>>> url in
>>>>>> my broswer:
>>>>>> me know
>>>>>> Cheers,
>>>>>> Ali
>>> PHP Version 5.2.0
>>> PHP API 20041225
>>> Debug Build no
>>> consumed, zlib.*
>>> PHP Credits
>>> Configuration
>>> PHP Core
>>> asp_tags Off Off
>>> enable_dl On On
>>> expose_php On On
>>> file_uploads On On
>>> html_errors On On
>>> log_errors On On
>>> post_max_size 8M 8M
>>> precision 12 12
>>> safe_mode Off Off
>>> smtp_port 25 25
>>> apache2handler
>>> Virtual Server No
>>> engine 1 1
>>> last_modified 0 0
>>> xbithack 0 0
>>> Apache Environment
>>> Variable Value
>>> HTTP_HOST localhost
>>> HTTP_ACCEPT
>>> HTTP_KEEP_ALIVE 300
>>> Connectivity
>>> WINDIR C:\WINDOWS
>>> SERVER_PORT 80
>>> REMOTE_PORT 1141
>>> REQUEST_METHOD GET
>>> REQUEST_URI
>>> HTTP Request GET
>>> HTTP/1.1
>>> Host localhost
>>> Accept
>>> Keep-Alive 300
>>> 09-May-2007 17:59:49 GMT; path=/
>>> bcmath
>>> calendar
>>> com_dotnet
>>> COM support enabled
>>> com.allow_dcom 0 0
>>> ctype
>>> date
>>> dom
>>> DOM/XML enabled
>>> filter
>>> ftp
>>> FTP support enabled
>>> hash
>>> iconv
>>> json
>>> json version 1.2.1
>>> libxml
>>> mbstring
>>> mysql
>>> Active Links 0
>>> mysqli
>>> odbc
>>> Active Links 0
>>> ODBC library Win32
>>> pcre
>>> PDO
>>> PDO support enabled
>>> pdo_sqlite
>>> Reflection
>>> Reflection enabled
>>> session
>>> SimpleXML
>>> SPL
>>> SPL support enabled
>>> SQLite
>>> standard
>>> assert.active 1 1
>>> assert.bail 0 0
>>> assert.warning 1 1
>>> url_rewriter.tags
>>> tokenizer
>>> wddx
>>> xdebug
>>> xml
>>> XML Support active
>>> xmlreader
>>> XMLReader enabled
>>> xmlwriter
>>> XMLWriter enabled
>>> zlib
>>> Additional Modules
>>> Module Name
>>> Environment
>>> Variable Value
>>> %firefox% c:
>>> /no value/ ::=::\
>>> CLIENTNAME Console
>>> FP_NO_HOST_CHECK NO
>>> HOMEDRIVE C:
>>> ITEMID dj-22741-15
>>> LANG 1033
>>> OS Windows_NT
>>> OSVER winXPP
>>> Connectivity
>>> PROCESSOR_LEVEL 15
>>> PROMPT $P$G
>>> SESSIONNAME Console
>>> SystemDrive C:
>>> TIMEOUT 0
>>> USERNAME Dmon
>>> VERSION 3.0.5.001
>>> windir C:\WINDOWS
>>> AP_PARENT_PID 3816
>>> PHP Variables
>>> Variable Value
>>> 5.1; en-US; rv:1.8.1.3) Gecko/20070309 Firefox/2.0.0.3
>>> Connectivity
>>> _SERVER["argv"]
>>> Array
>>> _SERVER["argc"] 1
>>> _ENV["HMSERVER"]
>>> _ENV["LANG"] 1033
>>> Connectivity
>>> GenuineIntel
>>> _ENV["PROMPT"] $P$G
>>> _ENV["TIMEOUT"] 0
>>> _ENV["TOOLPATH"]
>>> PHP License
Re: (attachments added) Problem when debugging with "Web Script using XDebug" [message #19335 is a reply to message #19288] Fri, 11 May 2007 03:24 Go to previous messageGo to next message
Originally posted by: apaz.yahoo.com
Yeap. That's a normal behavior on all web debuging, not only PHP.
There might be some situations where you will see some content even if
the request is still being process in the server, but I wouldn't count
on seeing anything in the browser before the request is complete.
-a.
Ali B. wrote:
> Hey Dave,
> Thanks in advance
> Cheers,
> Ali
> Ali B. wrote:
>> Hey Dave!
>> settings.
>> prompt window.
>> Cheers,
>> Ali
>>> have
>>> restart
>>> Dave Kelsey
>>>> Cheers,
>>>> Ali
>>>>> the web server.
>>>>> see if XDebug is
>>>>> browser.
>>>>>> Ali B. wrote:
>>>>>>> Hello everyone,
>>>>>>> included
>>>>>>> *charm*. But
>>>>>>> correctly.
>>>>>>> non-debug
>>>>>>> [xdebug]
>>>>>>> and the
>>>>>>> eclipse
>>>>>>> debug
>>>>>>> url in
>>>>>>> my broswer:
>>>>>>> me know
>>>>>>> Cheers,
>>>>>>> Ali
>>>> PHP Version 5.2.0
>>>> PHP API 20041225
>>>> Debug Build no
>>>> consumed, zlib.*
>>>> PHP Credits
>>>> Configuration
>>>> PHP Core
>>>> asp_tags Off Off
>>>> enable_dl On On
>>>> expose_php On On
>>>> file_uploads On On
>>>> html_errors On On
>>>> log_errors On On
>>>> post_max_size 8M 8M
>>>> precision 12 12
>>>> safe_mode Off Off
>>>> smtp_port 25 25
>>>> apache2handler
>>>> 100
>>>> Virtual Server No
>>>> mod_log_config mod_mime mod_negotiation mod_rewrite mod_setenvif
>>>> engine 1 1
>>>> last_modified 0 0
>>>> xbithack 0 0
>>>> Apache Environment
>>>> Variable Value
>>>> HTTP_HOST localhost
>>>> HTTP_ACCEPT
>>>> HTTP_KEEP_ALIVE 300
>>>> Connectivity
>>>> WINDIR C:\WINDOWS
>>>> SERVER_PORT 80
>>>> REMOTE_PORT 1141
>>>> REQUEST_METHOD GET
>>>> REQUEST_URI
>>>> HTTP Request GET
>>>> HTTP/1.1
>>>> Host localhost
>>>> Accept
>>>> Keep-Alive 300
>>>> bcmath
>>>> calendar
>>>> com_dotnet
>>>> COM support enabled
>>>> com.allow_dcom 0 0
>>>> ctype
>>>> date
>>>> dom
>>>> DOM/XML enabled
>>>> filter
>>>> ftp
>>>> FTP support enabled
>>>> hash
>>>> iconv
>>>> json
>>>> json version 1.2.1
>>>> libxml
>>>> mbstring
>>>> mysql
>>>> Active Links 0
>>>> mysqli
>>>> odbc
>>>> Active Links 0
>>>> ODBC library Win32
>>>> pcre
>>>> PDO
>>>> PDO support enabled
>>>> pdo_sqlite
>>>> 2006/01/01 12:50:12 sniper Exp $
>>>> Reflection
>>>> Reflection enabled
>>>> session
>>>> SimpleXML
>>>> SPL
>>>> SPL support enabled
>>>> SQLite
>>>> standard
>>>> assert.active 1 1
>>>> assert.bail 0 0
>>>> assert.warning 1 1
>>>> url_rewriter.tags
>>>> tokenizer
>>>> wddx
>>>> xdebug
>>>> xml
>>>> XML Support active
>>>> xmlreader
>>>> XMLReader enabled
>>>> xmlwriter
>>>> XMLWriter enabled
>>>> zlib
>>>> Additional Modules
>>>> Module Name
>>>> Environment
>>>> Variable Value
>>>> %firefox% c:
>>>> /no value/ ::=::\
>>>> CLIENTNAME Console
>>>> FP_NO_HOST_CHECK NO
>>>> HOMEDRIVE C:
>>>> ITEMID dj-22741-15
>>>> LANG 1033
>>>> OS Windows_NT
>>>> OSVER winXPP
>>>> Connectivity
>>>> PROCESSOR_LEVEL 15
>>>> PROMPT $P$G
>>>> SESSIONNAME Console
>>>> SystemDrive C:
>>>> TIMEOUT 0
>>>> USERNAME Dmon
>>>> VERSION 3.0.5.001
>>>> windir C:\WINDOWS
>>>> AP_PARENT_PID 3816
>>>> PHP Variables
>>>> Variable Value
>>>> _SERVER["argv"] Array
>>>> _SERVER["argc"] 1
>>>> _ENV["HMSERVER"]
>>>> _ENV["LANG"] 1033
>>>> Connectivity
>>>> GenuineIntel
>>>> _ENV["PROMPT"] $P$G
>>>> _ENV["TIMEOUT"] 0
>>>> _ENV["TOOLPATH"]
>>>> PHP License
Re: (attachments added) Problem when debugging with "Web Script using XDebug" [message #19385 is a reply to message #19288] Fri, 11 May 2007 03:39 Go to previous messageGo to next message
-a.
Ali B. wrote:
> Hey Dave,
> Thanks in advance
> Cheers,
> Ali
> Ali B. wrote:
>> Hey Dave!
>> settings.
>> prompt window.
>> Cheers,
>> Ali
>>> have
>>> restart
>>> Dave Kelsey
>>>> Cheers,
>>>> Ali
>>>>> the web server.
>>>>> see if XDebug is
>>>>> browser.
>>>>>> Ali B. wrote:
>>>>>>> Hello everyone,
>>>>>>> included
>>>>>>> *charm*. But
>>>>>>> correctly.
>>>>>>> non-debug
>>>>>>> [xdebug]
>>>>>>> and the
>>>>>>> eclipse
>>>>>>> debug
>>>>>>> url in
>>>>>>> my broswer:
>>>>>>> me know
>>>>>>> Cheers,
>>>>>>> Ali
>>>> PHP Version 5.2.0
>>>> PHP API 20041225
>>>> Debug Build no
>>>> consumed, zlib.*
>>>> PHP Credits
>>>> Configuration
>>>> PHP Core
>>>> asp_tags Off Off
>>>> enable_dl On On
>>>> expose_php On On
>>>> file_uploads On On
>>>> html_errors On On
>>>> log_errors On On
>>>> post_max_size 8M 8M
>>>> precision 12 12
>>>> safe_mode Off Off
>>>> smtp_port 25 25
>>>> apache2handler
>>>> 100
>>>> Virtual Server No
>>>> engine 1 1
>>>> last_modified 0 0
>>>> xbithack 0 0
>>>> Apache Environment
>>>> Variable Value
>>>> HTTP_HOST localhost
>>>> HTTP_ACCEPT
>>>> HTTP_KEEP_ALIVE 300
>>>> Connectivity
>>>> WINDIR C:\WINDOWS
>>>> SERVER_PORT 80
>>>> REMOTE_PORT 1141
>>>> REQUEST_METHOD GET
>>>> REQUEST_URI
>>>> HTTP Request GET
>>>> HTTP/1.1
>>>> Host localhost
>>>> Accept
>>>> Keep-Alive 300
>>>> bcmath
>>>> calendar
>>>> com_dotnet
>>>> COM support enabled
>>>> com.allow_dcom 0 0
>>>> ctype
>>>> date
>>>> dom
>>>> DOM/XML enabled
>>>> filter
>>>> ftp
>>>> FTP support enabled
>>>> hash
>>>> iconv
>>>> json
>>>> json version 1.2.1
>>>> libxml
>>>> mbstring
>>>> mysql
>>>> Active Links 0
>>>> mysqli
>>>> odbc
>>>> Active Links 0
>>>> ODBC library Win32
>>>> pcre
>>>> PDO
>>>> PDO support enabled
>>>> pdo_sqlite
>>>> Reflection
>>>> Reflection enabled
>>>> session
>>>> SimpleXML
>>>> SPL
>>>> SPL support enabled
>>>> SQLite
>>>> standard
>>>> assert.active 1 1
>>>> assert.bail 0 0
>>>> assert.warning 1 1
>>>> url_rewriter.tags
>>>> tokenizer
>>>> wddx
>>>> xdebug
>>>> xml
>>>> XML Support active
>>>> xmlreader
>>>> XMLReader enabled
>>>> xmlwriter
>>>> XMLWriter enabled
>>>> zlib
>>>> Additional Modules
>>>> Module Name
>>>> Environment
>>>> Variable Value
>>>> %firefox% c:
>>>> /no value/ ::=::\
>>>> CLIENTNAME Console
>>>> FP_NO_HOST_CHECK NO
>>>> HOMEDRIVE C:
>>>> ITEMID dj-22741-15
>>>> LANG 1033
>>>> OS Windows_NT
>>>> OSVER winXPP
>>>> Connectivity
>>>> PROCESSOR_LEVEL 15
>>>> PROMPT $P$G
>>>> SESSIONNAME Console
>>>> SystemDrive C:
>>>> TIMEOUT 0
>>>> USERNAME Dmon
>>>> VERSION 3.0.5.001
>>>> windir C:\WINDOWS
>>>> AP_PARENT_PID 3816
>>>> PHP Variables
>>>> Variable Value
>>>> _SERVER["argc"] 1
>>>> _ENV["HMSERVER"]
>>>> _ENV["LANG"] 1033
>>>> Connectivity
>>>> GenuineIntel
>>>> _ENV["PROMPT"] $P$G
>>>> _ENV["TIMEOUT"] 0
>>>> _ENV["TOOLPATH"]
>>>> PHP License
Re: (attachments added) Problem when debugging with "Web Script using XDebug" [message #19431 is a reply to message #19385] Fri, 11 May 2007 06:30 Go to previous messageGo to next message
Alexander Bodnarashik is currently offline Alexander BodnarashikFriend
> -a.
> Ali B. wrote:
>> Hey Dave,
>> blank. Only when stepping into phpinfo(); half of its outcome gets
>> displayed.
I think one of the reasons could be buffering (php and apache), either you can turn it off or put flush() (in case of php debugging) following some code, which generates output. However it doesn't guarantee, that you'll get any data in browser before debugging finished, as apache may have own buffers as well as OS.
Re: (attachments added) Problem when debugging with "Web Script using XDebug" [message #19481 is a reply to message #19335] Fri, 11 May 2007 09:44 Go to previous messageGo to next message
D Kelsey is currently offline D KelseyFriend
As Andres says, this is expected behaviour.
There is a feature of XDebug which allows you to capture stdout which
may allow you to at least see some of the output while you are debugging
say in the console or some other specialist view. I haven't implemented
that feature yet so don't know how useful it would be in a web debug
environment, also it won't be rendering the html as you won't have the
complete html document until the script ends.
Dave Kelsey
> -a.
> Ali B. wrote:
>> Hey Dave,
>> displayed.
>> Thanks in advance
>> Cheers,
>> Ali
>> Ali B. wrote:
>>> Hey Dave!
>>> 9999 and a constant idekey. and appearently it was bypassing my
>>> php.ini settings.
>>> prompt window.
>>> Cheers,
>>> Ali
>>>> you have
>>>> restart
>>>> Dave Kelsey
>>>>> I web-xdebug a file with <?php phpinfo(); ?> while starting the
>>>>> apache with Apache.exe -c "DocumentRoot "D:\eclipse\workspace""
>>>>> Cheers,
>>>>> Ali
>>>>>> the web server.
>>>>>> see if XDebug is
>>>>>> browser.
>>>>>>> Ali B. wrote:
>>>>>>>> Hello everyone,
>>>>>>>> included
>>>>>>>> *charm*. But
>>>>>>>> the
>>>>>>>> session".
>>>>>>>> sure my
>>>>>>>> phpinfo()
>>>>>>>> correctly.
>>>>>>>> non-debug
>>>>>>>> [xdebug]
>>>>>>>> and the
>>>>>>>> eclipse
>>>>>>>> I debug
>>>>>>>> url in
>>>>>>>> my broswer:
>>>>>>>> me know
>>>>>>>> Cheers,
>>>>>>>> Ali
>>>>> PHP Version 5.2.0
>>>>> PHP API 20041225
>>>>> Debug Build no
>>>>> consumed, zlib.*
>>>>> PHP Credits
>>>>> Configuration
>>>>> PHP Core
>>>>> asp_tags Off Off
>>>>> enable_dl On On
>>>>> expose_php On On
>>>>> file_uploads On On
>>>>> html_errors On On
>>>>> log_errors On On
>>>>> post_max_size 8M 8M
>>>>> precision 12 12
>>>>> safe_mode Off Off
>>>>> smtp_port 25 25
>>>>> apache2handler
>>>>> Connection: 100
>>>>> Virtual Server No
>>>>> engine 1 1
>>>>> last_modified 0 0
>>>>> xbithack 0 0
>>>>> Apache Environment
>>>>> Variable Value
>>>>> HTTP_HOST localhost
>>>>> HTTP_ACCEPT
>>>>> HTTP_KEEP_ALIVE 300
>>>>> Connectivity
>>>>> WINDIR C:\WINDOWS
>>>>> SERVER_PORT 80
>>>>> REMOTE_PORT 1141
>>>>> REQUEST_METHOD GET
>>>>> QUERY_STRING
>>>>> REQUEST_URI
>>>>> HTTP Request GET
>>>>> HTTP/1.1
>>>>> Host localhost
>>>>> Accept
>>>>> Keep-Alive 300
>>>>> bcmath
>>>>> calendar
>>>>> com_dotnet
>>>>> COM support enabled
>>>>> com.allow_dcom 0 0
>>>>> ctype
>>>>> date
>>>>> dom
>>>>> DOM/XML enabled
>>>>> filter
>>>>> ftp
>>>>> FTP support enabled
>>>>> hash
>>>>> iconv
>>>>> json
>>>>> json version 1.2.1
>>>>> libxml
>>>>> mbstring
>>>>> Public License version 2.1.
>>>>> mysql
>>>>> Active Links 0
>>>>> mysqli
>>>>> odbc
>>>>> Active Links 0
>>>>> ODBC library Win32
>>>>> pcre
>>>>> PDO
>>>>> PDO support enabled
>>>>> pdo_sqlite
>>>>> Reflection
>>>>> Reflection enabled
>>>>> session
>>>>> SimpleXML
>>>>> SPL
>>>>> SPL support enabled
>>>>> SQLite
>>>>> standard
>>>>> assert.active 1 1
>>>>> assert.bail 0 0
>>>>> assert.warning 1 1
>>>>> url_rewriter.tags
>>>>> tokenizer
>>>>> wddx
>>>>> xdebug
>>>>> xml
>>>>> XML Support active
>>>>> xmlreader
>>>>> XMLReader enabled
>>>>> xmlwriter
>>>>> XMLWriter enabled
>>>>> zlib
>>>>> Additional Modules
>>>>> Module Name
>>>>> Environment
>>>>> Variable Value
>>>>> %firefox% c:
>>>>> /no value/ ::=::\
>>>>> CLIENTNAME Console
>>>>> FP_NO_HOST_CHECK NO
>>>>> HOMEDRIVE C:
>>>>> ITEMID dj-22741-15
>>>>> LANG 1033
>>>>> OS Windows_NT
>>>>> OSVER winXPP
>>>>> Connectivity
>>>>> GenuineIntel
>>>>> PROCESSOR_LEVEL 15
>>>>> PROMPT $P$G
>>>>> SESSIONNAME Console
>>>>> SystemDrive C:
>>>>> TIMEOUT 0
>>>>> USERNAME Dmon
>>>>> VERSION 3.0.5.001
>>>>> windir C:\WINDOWS
>>>>> AP_PARENT_PID 3816
>>>>> PHP Variables
>>>>> Variable Value
>>>>> _SERVER["argc"] 1
>>>>> _ENV["HMSERVER"]
>>>>> _ENV["LANG"] 1033
>>>>> Connectivity
>>>>> GenuineIntel
>>>>> _ENV["PROMPT"] $P$G
>>>>> _ENV["TIMEOUT"] 0
>>>>> _ENV["TOOLPATH"]
>>>>> PHP License
>>>>> modify it under the terms of the PHP License as published by the
>>>>> PHP Group and included in the distribution in the file: LICENSE
Re: (attachments added) Problem when debugging with "Web Script using XDebug" [message #19614 is a reply to message #19431] Fri, 11 May 2007 17:50 Go to previous messageGo to next message
Member
Thanks Dave, Andres and Alexander.
Putting flush() within the code is working for me so far. And I agree
that it makes sense not to expect to get every output one by one.
Dave I think you have done a great job working this plugin. For me, I
can't wait for other features to be implemented with time. I will post a
feature request for anything that I would think would be useful ;)
Thanks again
Cheers
Ali
>> -a.
>> Ali B. wrote:
>>> Hey Dave,
>>> displayed.
Re: (attachments added) Problem when debugging with "Web Script using XDebug" [message #19776 is a reply to message #19614] Fri, 11 May 2007 22:40 Go to previous message
Dave has indeed done a great job. I would like to take the opportunity
to reminde everyone who uses the plugin to register and vote for it in
bugzilla:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=169408
Andres.
> Thanks again
> Cheers
> Ali
>>> -a.
>>> Ali B. wrote:
>>>> Hey Dave,
>>>> displayed.
Previous Topic:Here's a small tutorial about remote debugging with xdebug
Next Topic:Nice tool for xdebuggers > XDebug Helper for Firefox
Current Time: Tue Feb 20 22:14:17 GMT 2018
Powered by FUDForum. Page generated in 0.02948 seconds
