Home » Eclipse Projects » BIRT » BIRT Field Guide book
BIRT Field Guide book [message #193843] Tue, 03 October 2006 14:33 Go to next message
Originally posted by: phil.issler.dataflux.com
Does anyone know if the upcoming book "BIRT: A Field Guide to Reporting"
by Diana Peh, et al. will be new content? Or will it be simply a
printed version of the BIRT user guide "Field Guide to BIRT"?
Re: BIRT Field Guide book [message #193980 is a reply to message #193843] Tue, 03 October 2006 21:39 Go to previous message
Jane Tatchell is currently offline Jane TatchellFriend
Member
I should change the name for the content in the BIRT Report Developer Guide
in the online help for the next release. It's rather misleading.
The content in the online help is a small subset of the what is in the
published book. The online help provides a set of procedures about how to
use individual elements of the BIRT Report Designer user interface. The book
provides these procedures and many more. More significantly, it contains
considerable overview and conceptual material to explain the full process of
report design and development which will enable you to use the whole
Designer in an effective way, both individually and as part of a team. At
approximately 700 pages in length, this book is a substantial volume that is
much more than a guide to the UI.
Don't forget too, the Integrating and Extending BIRT book, which describes
the programming capabilities of the BIRT environment, from scripting,
through coding reporting and charting applications, to using the extension
points to provide custom functionality to your BIRT environment - or to
contribute to the community. :-)
Jane Tatchell
BIRT documentation lead
"Phil Issler" <phil.issler@dataflux.com> wrote in message
news:eftsb4$vl6$1@utils.eclipse.org...
> by Diana Peh, et al. will be new content? Or will it be simply a printed
Previous Topic:Graphs in Web Viewer example app?
Next Topic:Benchmarck BIRT
Current Time: Wed Jan 24 04:09:33 GMT 2018
Powered by FUDForum. Page generated in 0.01888 seconds
