Home » Eclipse Projects » BIRT » Text Wrapping in BIRT
Text Wrapping in BIRT [message #193641] Mon, 02 October 2006 16:38 Go to next message
Originally posted by: awall.3esi.com
How do I turn on/off text-wrapping in BIRT? Right now I have sets of data
that spit across multiple lines, and I would rather that it justs cuts off
the data (doesn't show the last couple digits, for example) instead of
splitting across multiple lines, or worse, making the column wider.
Is there any way to do this in BIRT? I've been struggling with the
designer, and looking in the BIRt documentation, and I see no text-wrap
option anywhere, any clues?
Thanks.
Re: Text Wrapping in BIRT [message #194127 is a reply to message #193641] Wed, 04 October 2006 14:42 Go to previous message
Tomas Vala is currently offline Tomas ValaFriend
Member
Nobody knows? I am also like very much to avoid text wrapping in BIRT....
"Adam Wall" <awall@3esi.com> p
Previous Topic:Getting output from a Stored Procedure Dataset in BIRT
Next Topic:Getting empty reports
Current Time: Sun May 20 17:48:30 GMT 2018
Powered by FUDForum. Page generated in 0.01996 seconds
