Home » Eclipse Projects » BIRT » Birt Logging
Birt Logging [message #193456] Sun, 01 October 2006 13:21 Go to next message
Originally posted by: jegd.ctv.es
I'm trying to deactivate birt's logging system. I've tried to set the level logging to Level.OFF after setting the log direccory,
but I'm still getting messages through the console. Is there any way to deactivate this?
Re: Birt Logging [message #193566 is a reply to message #193456] Mon, 02 October 2006 14:37 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
Have you tried:
config.setLogConfig(null, Level.OFF);
Jason
<jegd@ctv.es> wrote in message news:efofcb$aoh$1@utils.eclipse.org...
> Hi
> deactivate this?
> Thanks
Re: Birt Logging [message #194010 is a reply to message #193456] Wed, 04 October 2006 00:40 Go to previous message
Originally posted by: bryant.harris.irisfinancial.com
If you're running the ReportEngine inside of a server, it is just using jdk
logging and you can install a handler. If you are using log4j you can use a
jdk logger to log4j adapter like the one in the Orangestad project
(http://orangestad.sourceforge.net).
If you are talking about within the tool then ignore me.
> Hi
> deactivate this?
> Thanks
Previous Topic:Benchmarck BIRT
Next Topic:Date Report Parameter
Current Time: Sun May 27 05:28:54 GMT 2018
Powered by FUDForum. Page generated in 0.01960 seconds
