Home » Newcomers » Newcomers » Eclipse Juno Update crashes(Eclipse Juno Crash)
Eclipse Juno Update crashes [message #1200938] |
Thu, 21 November 2013 13:47 |
Sandah Aung Messages: 1 Registered: November 2013 |
Junior Member |
I am using 32-bit Eclipse Juno on a 32-bit Windows machine running a 32-bit JDK. Today I updated it and it wouldn't start anymore. Below is the content of the error file it generated.
!SESSION 2013-11-21 18:07:50.771 -----------------------------------------------
eclipse.buildId=v21.1.0-569685
java.version=1.7.0_17
Framework arguments: -product com.android.ide.eclipse.adt.package.product
Command-line arguments: -os win32 -ws win32 -arch x86 -product com.android.ide.eclipse.adt.package.product
!ENTRY org.eclipse.equinox.ds 4 0 2013-11-21 18:07:51.275
!MESSAGE [SCR] Exception while activating instance org.eclipse.e4.ui.css.swt.internal.theme.ThemeEngineManager@1eba31 of component org.eclipse.e4.ui.css.swt.theme
!STACK 0
java.lang.NoClassDefFoundError: org/eclipse/swt/widgets/Display
at java.lang.Class.getDeclaredMethods0(Native Method)
at java.lang.Class.privateGetDeclaredMethods(Class.java:2451)
at java.lang.Class.getDeclaredMethods(Class.java:1810)
at org.eclipse.equinox.internal.ds.model.ServiceComponent.getMethod(ServiceComponent.java:126)
at org.eclipse.equinox.internal.ds.model.ServiceComponent.activate(ServiceComponent.java:213)
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.activate(ServiceComponentProp.java:146)
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.build(ServiceComponentProp.java:347)
at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponent(InstanceProcess.java:620)
at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponents(InstanceProcess.java:197)
at org.eclipse.equinox.internal.ds.Resolver.buildNewlySatisfied(Resolver.java:473)
at org.eclipse.equinox.internal.ds.Resolver.enableComponents(Resolver.java:217)
at org.eclipse.equinox.internal.ds.SCRManager.performWork(SCRManager.java:816)
at org.eclipse.equinox.internal.ds.SCRManager$QueuedJob.dispatch(SCRManager.java:783)
at org.eclipse.equinox.internal.ds.WorkThread.run(WorkThread.java:89)
at java.lang.Thread.run(Thread.java:722)
Caused by: java.lang.ClassNotFoundException: org.eclipse.swt.widgets.Display
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:501)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at java.lang.ClassLoader.loadClass(ClassLoader.java:356)
... 15 more
!ENTRY org.eclipse.equinox.ds 4 0 2013-11-21 18:07:51.278
!STACK 0
... 15 more
!ENTRY org.eclipse.osgi 4 0 2013-11-21 18:07:51.625
!MESSAGE An error occurred while automatically activating bundle org.eclipse.ui.workbench (447).
!STACK 0
org.osgi.framework.BundleException: The activator org.eclipse.ui.internal.WorkbenchPlugin for bundle org.eclipse.ui.workbench is invalid
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadBundleActivator(AbstractBundle.java:172)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:679)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:300)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:440)
at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:263)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:469)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:395)
at org.eclipse.osgi.internal.loader.SingleSourcePackage.loadClass(SingleSourcePackage.java:35)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:461)
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Class.java:2413)
at java.lang.Class.getConstructor0(Class.java:2723)
at java.lang.Class.newInstance0(Class.java:345)
at java.lang.Class.newInstance(Class.java:327)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:184)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:191)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:601)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
Caused by: java.lang.NoClassDefFoundError: org/eclipse/swt/SWTError
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadBundleActivator(AbstractBundle.java:167)
... 36 more
Caused by: java.lang.ClassNotFoundException: org.eclipse.swt.SWTError
... 42 more
Root exception:
... 42 more
!ENTRY org.eclipse.osgi 2 0 2013-11-21 18:07:51.738
!MESSAGE One or more bundles are not resolved because the following root constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2013-11-21 18:07:51.738
!MESSAGE Bundle reference:file:plugins/org.eclipse.cdt.managedbuilder.ui_8.1.0.201302132326.jar was not resolved.
!SUBENTRY 2 org.eclipse.cdt.managedbuilder.ui 2 0 2013-11-21 18:07:51.738
!MESSAGE Missing required bundle org.eclipse.cdt.core_[5.0.0,6.0.0).
!MESSAGE Missing required bundle org.eclipse.cdt.ui_[5.0.0,6.0.0).
!MESSAGE Missing required bundle org.eclipse.cdt.managedbuilder.core_[8.1.0,9.0.0).
!MESSAGE Bundle reference:file:plugins/org.eclipse.cdt.make.ui_7.2.0.201302132326.jar was not resolved.
!SUBENTRY 2 org.eclipse.cdt.make.ui 2 0 2013-11-21 18:07:51.738
!MESSAGE Bundle reference:file:plugins/org.eclipse.cdt.core.win32_5.3.0.201302132326.jar was not resolved.
!SUBENTRY 2 org.eclipse.cdt.core.win32 2 0 2013-11-21 18:07:51.738
!MESSAGE Missing host org.eclipse.cdt.core_[5.2.0,6.0.0).
!MESSAGE Bundle reference:file:plugins/org.eclipse.cdt.dsf.ui_2.3.0.201302132326.jar was not resolved.
!SUBENTRY 2 org.eclipse.cdt.dsf.ui 2 0 2013-11-21 18:07:51.738
!MESSAGE Missing required bundle org.eclipse.cdt.core_5.1.0.
!MESSAGE Missing required bundle org.eclipse.cdt.ui_5.1.0.
!MESSAGE Bundle reference:file:plugins/org.eclipse.cdt.core.win32.x86_5.2.0.201302132326/ was not resolved.
!SUBENTRY 2 org.eclipse.cdt.core.win32.x86 2 0 2013-11-21 18:07:51.738
!MESSAGE Bundle reference:file:plugins/org.eclipse.cdt.debug.mi.core_7.2.0.201302132326.jar was not resolved.
!SUBENTRY 2 org.eclipse.cdt.debug.mi.core 2 0 2013-11-21 18:07:51.739
!SUBENTRY 1 org.eclipse.osgi 2 0 2013-11-21 18:07:51.739
!MESSAGE Bundle reference:file:plugins/org.eclipse.cdt.debug.ui_7.2.0.201302132326.jar was not resolved.
!SUBENTRY 2 org.eclipse.cdt.debug.ui 2 0 2013-11-21 18:07:51.739
!MESSAGE Bundle reference:file:plugins/org.eclipse.cdt.codan.checkers_1.1.0.201302132326.jar was not resolved.
!SUBENTRY 2 org.eclipse.cdt.codan.checkers 2 0 2013-11-21 18:07:51.739
!MESSAGE Missing required bundle org.eclipse.cdt.core_0.0.0.
!MESSAGE Bundle reference:file:plugins/org.eclipse.cdt.dsf.gdb_4.1.1.201302132326.jar was not resolved.
!SUBENTRY 2 org.eclipse.cdt.dsf.gdb 2 0 2013-11-21 18:07:51.739
!MESSAGE Bundle reference:file:plugins/org.eclipse.cdt.dsf_2.3.0.201302132326.jar was not resolved.
!SUBENTRY 2 org.eclipse.cdt.dsf 2 0 2013-11-21 18:07:51.739
!MESSAGE Bundle reference:file:plugins/org.eclipse.cdt.launch_7.1.0.201302132326.jar was not resolved.
!SUBENTRY 2 org.eclipse.cdt.launch 2 0 2013-11-21 18:07:51.739
!MESSAGE Bundle reference:file:plugins/org.eclipse.cdt.dsf.gdb.ui_2.3.1.201302132326.jar was not resolved.
!SUBENTRY 2 org.eclipse.cdt.dsf.gdb.ui 2 0 2013-11-21 18:07:51.739
!MESSAGE Missing required bundle org.eclipse.cdt.ui_0.0.0.
!MESSAGE Bundle reference:file:plugins/com.android.ide.eclipse.ndk_22.3.0.v201310242005-887826.jar was not resolved.
!SUBENTRY 2 com.android.ide.eclipse.ndk 2 0 2013-11-21 18:07:51.739
!MESSAGE Missing required bundle org.eclipse.cdt.managedbuilder.core_0.0.0.
!MESSAGE Bundle reference:file:plugins/org.eclipse.cdt.debug.core_7.2.0.201302132326.jar was not resolved.
!SUBENTRY 2 org.eclipse.cdt.debug.core 2 0 2013-11-21 18:07:51.739
!SUBENTRY 1 org.eclipse.osgi 2 0 2013-11-21 18:07:51.740
!MESSAGE Bundle reference:file:plugins/org.eclipse.cdt.codan.checkers.ui_1.1.0.201302132326.jar was not resolved.
!SUBENTRY 2 org.eclipse.cdt.codan.checkers.ui 2 0 2013-11-21 18:07:51.740
!MESSAGE Bundle reference:file:plugins/org.eclipse.cdt.make.core_7.2.0.201302132326.jar was not resolved.
!SUBENTRY 2 org.eclipse.cdt.make.core 2 0 2013-11-21 18:07:51.740
!MESSAGE Bundle reference:file:plugins/org.eclipse.cdt.codan.core.cxx_1.1.0.201302132326.jar was not resolved.
!SUBENTRY 2 org.eclipse.cdt.codan.core.cxx 2 0 2013-11-21 18:07:51.740
!MESSAGE Bundle reference:file:plugins/org.eclipse.cdt.managedbuilder.gnu.ui_8.1.0.201302132326.jar was not resolved.
!SUBENTRY 2 org.eclipse.cdt.managedbuilder.gnu.ui 2 0 2013-11-21 18:07:51.740
!MESSAGE Bundle reference:file:plugins/org.eclipse.cdt.codan.ui_2.1.0.201302132326.jar was not resolved.
!SUBENTRY 2 org.eclipse.cdt.codan.ui 2 0 2013-11-21 18:07:51.740
!MESSAGE Bundle reference:file:plugins/org.eclipse.cdt.codan.ui.cxx_3.0.0.201302132326.jar was not resolved.
!SUBENTRY 2 org.eclipse.cdt.codan.ui.cxx 2 0 2013-11-21 18:07:51.740
!ENTRY org.eclipse.osgi 2 0 2013-11-21 18:07:51.763
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2013-11-21 18:07:51.763
!MESSAGE Bundle com.android.ide.eclipse.ndk_22.3.0.v201310242005-887826 [375] was not resolved.
!SUBENTRY 2 com.android.ide.eclipse.ndk 2 0 2013-11-21 18:07:51.763
!SUBENTRY 2 com.android.ide.eclipse.ndk 2 0 2013-11-21 18:07:51.764
!MESSAGE Missing required bundle org.eclipse.cdt.managedbuilder.ui_0.0.0.
!MESSAGE Missing required bundle org.eclipse.cdt.debug.core_0.0.0.
!MESSAGE Missing required bundle org.eclipse.cdt.debug.ui_0.0.0.
!MESSAGE Missing required bundle org.eclipse.cdt.dsf_0.0.0.
!MESSAGE Missing required bundle org.eclipse.cdt.dsf.gdb_0.0.0.
!MESSAGE Missing required bundle org.eclipse.cdt.dsf.gdb.ui_0.0.0.
!MESSAGE Missing required bundle org.eclipse.cdt.launch_0.0.0.
!SUBENTRY 1 org.eclipse.osgi 2 0 2013-11-21 18:07:51.764
!MESSAGE Bundle org.eclipse.cdt.codan.checkers_1.1.0.201302132326 [384] was not resolved.
!SUBENTRY 2 org.eclipse.cdt.codan.checkers 2 0 2013-11-21 18:07:51.764
!MESSAGE Missing required bundle org.eclipse.cdt.codan.core.cxx_0.0.0.
!MESSAGE Bundle org.eclipse.cdt.codan.checkers.ui_1.1.0.201302132326 [385] was not resolved.
!SUBENTRY 2 org.eclipse.cdt.codan.checkers.ui 2 0 2013-11-21 18:07:51.764
!MESSAGE Missing required bundle org.eclipse.cdt.codan.ui.cxx_0.0.0.
!MESSAGE Missing required bundle org.eclipse.cdt.codan.checkers_0.0.0.
!MESSAGE Bundle org.eclipse.cdt.codan.core.cxx_1.1.0.201302132326 [387] was not resolved.
!SUBENTRY 2 org.eclipse.cdt.codan.core.cxx 2 0 2013-11-21 18:07:51.764
!MESSAGE Bundle org.eclipse.cdt.codan.ui_2.1.0.201302132326 [388] was not resolved.
!SUBENTRY 2 org.eclipse.cdt.codan.ui 2 0 2013-11-21 18:07:51.764
!MESSAGE Bundle org.eclipse.cdt.codan.ui.cxx_3.0.0.201302132326 [389] was not resolved.
!SUBENTRY 2 org.eclipse.cdt.codan.ui.cxx 2 0 2013-11-21 18:07:51.764
!MESSAGE Missing required bundle org.eclipse.cdt.codan.ui_0.0.0.
!MESSAGE Bundle org.eclipse.cdt.core.win32_5.3.0.201302132326 [390] was not resolved.
!SUBENTRY 2 org.eclipse.cdt.core.win32 2 0 2013-11-21 18:07:51.764
!MESSAGE Bundle org.eclipse.cdt.core.win32.x86_5.2.0.201302132326 [391] was not resolved.
!SUBENTRY 2 org.eclipse.cdt.core.win32.x86 2 0 2013-11-21 18:07:51.764
!MESSAGE Bundle org.eclipse.cdt.debug.core_7.2.0.201302132326 [392] was not resolved.
!SUBENTRY 2 org.eclipse.cdt.debug.core 2 0 2013-11-21 18:07:51.764
!MESSAGE Bundle org.eclipse.cdt.debug.mi.core_7.2.0.201302132326 [393] was not resolved.
!SUBENTRY 2 org.eclipse.cdt.debug.mi.core 2 0 2013-11-21 18:07:51.764
!MESSAGE Missing required bundle org.eclipse.cdt.debug.core_[7.0.0,8.1.0).
!SUBENTRY 2 org.eclipse.cdt.debug.mi.core 2 0 2013-11-21 18:07:51.765
!SUBENTRY 1 org.eclipse.osgi 2 0 2013-11-21 18:07:51.765
!MESSAGE Bundle org.eclipse.cdt.debug.ui_7.2.0.201302132326 [394] was not resolved.
!SUBENTRY 2 org.eclipse.cdt.debug.ui 2 0 2013-11-21 18:07:51.765
!MESSAGE Bundle org.eclipse.cdt.dsf_2.3.0.201302132326 [395] was not resolved.
!SUBENTRY 2 org.eclipse.cdt.dsf 2 0 2013-11-21 18:07:51.765
!MESSAGE Bundle org.eclipse.cdt.dsf.gdb_4.1.1.201302132326 [396] was not resolved.
!SUBENTRY 2 org.eclipse.cdt.dsf.gdb 2 0 2013-11-21 18:07:51.765
!MESSAGE Missing required bundle org.eclipse.cdt.launch_6.1.0.
!MESSAGE Bundle org.eclipse.cdt.dsf.gdb.ui_2.3.1.201302132326 [397] was not resolved.
!SUBENTRY 2 org.eclipse.cdt.dsf.gdb.ui 2 0 2013-11-21 18:07:51.765
!MESSAGE Missing required bundle org.eclipse.cdt.dsf.ui_0.0.0.
!MESSAGE Bundle org.eclipse.cdt.dsf.ui_2.3.0.201302132326 [398] was not resolved.
!SUBENTRY 2 org.eclipse.cdt.dsf.ui 2 0 2013-11-21 18:07:51.765
!MESSAGE Missing required bundle org.eclipse.cdt.dsf_2.0.0.
!MESSAGE Missing required bundle org.eclipse.cdt.debug.core_6.0.0.
!MESSAGE Missing required bundle org.eclipse.cdt.debug.ui_6.1.0.
!MESSAGE Bundle org.eclipse.cdt.gdb.ui_7.0.0.201302132326 [400] was not resolved.
!SUBENTRY 2 org.eclipse.cdt.gdb.ui 2 0 2013-11-21 18:07:51.765
!MESSAGE Missing required bundle org.eclipse.cdt.debug.ui_7.0.0.
!MESSAGE Bundle org.eclipse.cdt.launch_7.1.0.201302132326 [401] was not resolved.
!SUBENTRY 2 org.eclipse.cdt.launch 2 0 2013-11-21 18:07:51.765
!MESSAGE Missing required bundle org.eclipse.cdt.debug.ui_[7.0.0,8.1.0).
!SUBENTRY 1 org.eclipse.osgi 2 0 2013-11-21 18:07:51.766
!MESSAGE Bundle org.eclipse.cdt.make.core_7.2.0.201302132326 [402] was not resolved.
!SUBENTRY 2 org.eclipse.cdt.make.core 2 0 2013-11-21 18:07:51.766
!MESSAGE Bundle org.eclipse.cdt.make.ui_7.2.0.201302132326 [403] was not resolved.
!SUBENTRY 2 org.eclipse.cdt.make.ui 2 0 2013-11-21 18:07:51.766
!MESSAGE Missing required bundle org.eclipse.cdt.make.core_[7.0.0,8.1.0).
!MESSAGE Bundle org.eclipse.cdt.managedbuilder.gnu.ui_8.1.0.201302132326 [404] was not resolved.
!SUBENTRY 2 org.eclipse.cdt.managedbuilder.gnu.ui 2 0 2013-11-21 18:07:51.766
!MESSAGE Bundle org.eclipse.cdt.managedbuilder.ui_8.1.0.201302132326 [405] was not resolved.
!SUBENTRY 2 org.eclipse.cdt.managedbuilder.ui 2 0 2013-11-21 18:07:51.766
!MESSAGE Missing required bundle org.eclipse.cdt.make.core_0.0.0.
!MESSAGE Missing required bundle org.eclipse.cdt.make.ui_0.0.0.
!ENTRY org.eclipse.osgi 4 0 2013-11-21 18:07:51.771
!MESSAGE Application error
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in "org.eclipse.ui.ide.application" was unable to instantiate class "org.eclipse.ui.internal.ide.application.IDEApplication".
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:194)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:188)
Caused by: java.lang.NoClassDefFoundError: org/eclipse/ui/application/WorkbenchAdvisor
... 15 more
Caused by: org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter$TerminatingClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.ui.workbench (447).
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:122)
... 21 more
Caused by: org.osgi.framework.BundleException: The activator org.eclipse.ui.internal.WorkbenchPlugin for bundle org.eclipse.ui.workbench is invalid
... 30 more
... 36 more
... 42 more
!ENTRY org.eclipse.e4.ui.css.swt.theme 4 0 2013-11-21 18:07:51.798
!MESSAGE [SCR] Error while attempting to deactivate instance of component Component[
name = org.eclipse.e4.ui.css.swt.theme
activate = activate
deactivate = deactivate
modified =
configuration-policy = optional
factory = null
autoenable = true
immediate = true
implementation = org.eclipse.e4.ui.css.swt.internal.theme.ThemeEngineManager
state = Disabled
properties =
serviceFactory = false
serviceInterface = [org.eclipse.e4.ui.css.swt.theme.IThemeManager]
references = null
located in bundle = org.eclipse.e4.ui.css.swt.theme_0.9.3.v20120806-170624 [421]
!STACK 0
at org.eclipse.equinox.internal.ds.model.ServiceComponent.deactivate(ServiceComponent.java:337)
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.deactivate(ServiceComponentProp.java:161)
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.dispose(ServiceComponentProp.java:389)
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.dispose(ServiceComponentProp.java:102)
at org.eclipse.equinox.internal.ds.InstanceProcess.disposeInstances(InstanceProcess.java:366)
at org.eclipse.equinox.internal.ds.InstanceProcess.disposeInstances(InstanceProcess.java:306)
at org.eclipse.equinox.internal.ds.Resolver.disposeComponentConfigs(Resolver.java:717)
at org.eclipse.equinox.internal.ds.Resolver.disableComponents(Resolver.java:693)
at org.eclipse.equinox.internal.ds.SCRManager.stoppingBundle(SCRManager.java:554)
at org.eclipse.equinox.internal.ds.SCRManager.bundleChanged(SCRManager.java:233)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.dispatchEvent(BundleContextImpl.java:847)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.osgi.framework.internal.core.Framework.publishBundleEventPrivileged(Framework.java:1568)
at org.eclipse.osgi.framework.internal.core.Framework.publishBundleEvent(Framework.java:1504)
at org.eclipse.osgi.framework.internal.core.Framework.publishBundleEvent(Framework.java:1499)
at org.eclipse.osgi.framework.internal.core.BundleHost.stopWorker(BundleHost.java:506)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.suspend(AbstractBundle.java:566)
at org.eclipse.osgi.framework.internal.core.Framework.suspendBundle(Framework.java:1206)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.decFWSL(StartLevelManager.java:592)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:257)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.shutdown(StartLevelManager.java:215)
at org.eclipse.osgi.framework.internal.core.InternalSystemBundle.suspend(InternalSystemBundle.java:284)
at org.eclipse.osgi.framework.internal.core.Framework.shutdown(Framework.java:692)
at org.eclipse.osgi.framework.internal.core.Framework.close(Framework.java:600)
at org.eclipse.core.runtime.adaptor.EclipseStarter.shutdown(EclipseStarter.java:399)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:199)
... 38 more
!ENTRY org.eclipse.e4.ui.css.swt.theme 4 0 2013-11-21 18:07:51.802
activate = activate
modified =
factory = null
autoenable = true
immediate = true
state = Disabled
properties =
references = null
!STACK 0
... 38 more
Current Time: Wed Apr 24 22:20:58 GMT 2024
Powered by FUDForum. Page generated in 0.08291 seconds
