Home » Modeling » GMF (Graphical Modeling Framework) » Remove the default create-connection feedback.
Remove the default create-connection feedback. [message #192374] Fri, 13 June 2008 09:22 Go to next message
Dollyn Sun is currently offline Dollyn SunFriend
Member
--------------090108030802060507050304
Content-Type: text/plain; charset=UTF-8; format=flowed
HI,
When the mouse moved on some node, there will be tow arrow like this:
____________
| NODE | --->
and you can click on these two arrows to add connections.
But if the target model type is an Interface, these two arrows is not
useable.
So I donn't want it appear any more. What should I do?
Thanks.
*/Dollyn/*
Content-Type: text/html; charset=UTF-8
<html>
<head>
</head>
HI,<br>
<br>
When the mouse moved on some node, there will be tow arrow like this:<br>
<br>
____________<br>
|           | <br>
|   NODE    | ---&gt;<br>
------------  &lt;---<br>
<br>
and you can click on these two arrows to add connections.<br>
<br>
useable.<br>
So I donn't want it appear any more. What should I do?<br>
<br>
<br>
Thanks.<br>
<div class="moz-signature">-- <br>
<meta http-equiv="Content-Language" content="zh-cn">
<meta http-equiv="Content-Type" content="text/html; ">
<title>Dollyn</title>
<p><b><i><font color="#0000ff" face="Courier New">Dollyn</font></i></b></p>
</div>
</body>
</html>
--------------090108030802060507050304--
Dollyn
Re: Remove the default create-connection feedback. [message #192712 is a reply to message #192374] Sun, 15 June 2008 14:44 Go to previous messageGo to next message
Member
No one knows about this? Or you cann't understand what do I mean?
English is not my mother language.
Any suggestions?
Dollyn 写道:
> HI,
> ____________
> | NODE | --->
> useable.
> Thanks.
> */Dollyn/*
Dollyn
Re: Remove the default create-connection feedback. [message #192718 is a reply to message #192712] Sun, 15 June 2008 16:13 Go to previous message
Originally posted by: me.urszeidler.de
You can disable them in the preferences of your generated editor.
But you could customize it by supplying
xxxModelingAssistantProvider with the correct link types.
greetings, urs.
Previous Topic:Drag and drop from palette and view
Next Topic:Broken Link on the GMF Documentation Page
Current Time: Sun Feb 25 02:00:27 GMT 2018
Powered by FUDForum. Page generated in 0.01625 seconds
