Home » Language IDEs » ServerTools (WTP) » Another "Cannot find the tag library descriptor for..." taglib problem
Another "Cannot find the tag library descriptor for..." taglib problem [message #191651] Fri, 20 April 2007 04:30 Go to next message
Originally posted by: eclipse.helmstetter.com
OK, I know this one has been beaten to death. I've been struggling with
this for a few days now, and I've read just about every message on the
topic and tried just about everything. I've tried both WTP
2.0M6-200704060120 and R-1.5.3.
These are the URIs that are not being resoloved:
/struts-tags test-struts2/src/main/webapp/WEB-INF/decorators
/struts-tags test-struts2/src/main/webapp/common
http://acegisecurity.org/authz
http://www.opensymphony.com/sitemesh/decorator
http://www.opensymphony.com/sitemesh/page
All of these TLDs are in jar files that are in my build path. The URIs
match the format specified in the TLD files. The project is a web
project, with the 2.4 Servlet API specified in web.xml.
Any help, ideas would be greatly appreciated.
Mark
Re: Another "Cannot find the tag library descriptor for..." taglib problem [message #191660 is a reply to message #191651] Fri, 20 April 2007 04:51 Go to previous message
Well, I suppose persistence pays off. I managed to get it working. I'm
using Maven2 to generate the project artifacts, and I solved the problem
by running:
mvn eclipse:clean
mvn eclipse:eclipse -Dwtpversion=1.5
then refreshing the project. I could not get this to work previously
with 1.5.3, but seems to be working now with 2.0M6-200704060120.
> Mark
Previous Topic:jsp compiler support?
Next Topic:server launch configuration, classpath user entries work?
Current Time: Sun Apr 22 12:40:13 GMT 2018
Powered by FUDForum. Page generated in 0.01742 seconds
