Home » Eclipse Projects » Eclipse Platform » problems Starting Eclipse in W2K
problems Starting Eclipse in W2K [message #187941] Sun, 01 February 2004 12:20 Go to next message
Eclipse User
Originally posted by: psbawa59.yahoo.com
When I try to start eclipse in Windows2000 I get following error in .log
file..
!SESSION
!ENTRY org.eclipse.core.launcher 4 0 Feb 24, 2003 10:42:07.125
!MESSAGE Exception launching the Eclipse Platform:
!STACK
org.eclipse.swt.SWTError: Cannot initialize Drop
at org.eclipse.swt.dnd.DND.error(DND.java:220)
at org.eclipse.swt.dnd.DND.error(DND.java:181)
at org.eclipse.swt.dnd.DropTarget.<init>(DropTarget.java:133)
org.eclipse.ui.internal.ShortcutBarPart.initDragAndDrop(Shor tcutBarPart.java:187)
org.eclipse.ui.internal.ShortcutBarPart.<init>(ShortcutBarPart.java:169)
org.eclipse.ui.internal.WorkbenchWindow.createShortcutBar(Wo rkbenchWindow.java:763)
org.eclipse.ui.internal.WorkbenchWindow.configureShell(Workb enchWindow.java:717)
at org.eclipse.jface.window.Window.createShell(Window.java:353)
at org.eclipse.jface.window.Window.create(Window.java:304)
org.eclipse.ui.internal.Workbench.openFirstTimeWindow(Workbe nch.java:1136)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:875)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1459)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:246)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:139)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:47)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:85)
at org.eclipse.core.launcher.Main.basicRun(Main.java:279)
at org.eclipse.core.launcher.Main.run(Main.java:742)
at org.eclipse.core.launcher.Main.main(Main.java:581)
Re: problems Starting Eclipse in W2K [message #188236 is a reply to message #187941] Mon, 02 February 2004 09:06 Go to previous message
Grant Gayed is currently offline Grant Gayed
Assuming that you're using a 2.1.x release, this looks like bug
https://bugs.eclipse.org/bugs/show_bug.cgi?id=29258 , which has been fixed
in the 3.0 stream. Try running a recent Eclipse 3.0 build on your machine
and if it still doesn't work then please log a bug report with Platform -
SWT. Thanks!
Grant
> file..
> !SESSION
> !STACK
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Previous Topic:external output path for clearcase project
Next Topic:Richtext editing
Current Time: Mon May 20 10:53:40 EDT 2013
Powered by FUDForum. Page generated in 0.01940 seconds
