Home » Eclipse Projects » Web Tools Project (WTP) » handle on web content
handle on web content [message #187510] Fri, 02 February 2007 11:58 Go to next message
Eclipse User
Originally posted by: mremme.braintags.de
i am working with wst 1.5. From out of a plugin i would like to get a reference to the web content directory of a
dynamic web project as IPath or else. Does anybody know how to manage this?
tia, Michael
Re: handle on web content [message #187534 is a reply to message #187510] Fri, 02 February 2007 13:43 Go to previous messageGo to next message
Larry Isaacs is currently offline Larry Isaacs
Michael,
You can use ModuleCoreNature.isFlexibleProject(IProject) to confirm you
have a WTP flexible project. If so, then
ComponentCore.createComponent(IProject) will give you an
IVirtualComponent which is the flexible project. Calling
getRootFolder() on this flexible project will give you an IVirtualFolder
as the root folder. If this is a Dynamic Web Project, this root folder
will be the web content folder. You can call getProjectRelativePath()
or getWorkspaceRelativePath() on this IVirtualFolder to get an IPath.
Checkout the Javadoc of these methods for details. HTH.
Larry
Michael Remme wrote:
> reference to the web content directory of a dynamic web project as IPath
> tia, Michael
Re: handle on web content [message #187588 is a reply to message #187534] Tue, 06 February 2007 10:12 Go to previous messageGo to next message
Eclipse User
hmm - so far it works, but i think i do not understand all.
In the example code above the nature is not null.
The project relative path for WEB-INF is correct,
ModuleCoreNature nature = ModuleCoreNature.getModuleCoreNature( module.getProject() );
IVirtualComponent vc = ComponentCore.createComponent( module.getProject() );
IVirtualFolder root = vc.getRootFolder();
IVirtualFolder webInf = root.getFolder( "WEB-INF" );
IPath path = webInf.getProjectRelativePath();
webInf.create( IResource.BACKGROUND_REFRESH, monitor );
IVirtualFolder clasDir = webInf.getFolder( "classes" );
clasDir.create( IResource.BACKGROUND_REFRESH, monitor );
here its getting wrong for me, because exist is "true" but the path is returned as "/src"
boolean exist = clasDir.exists();
path = clasDir.getProjectRelativePath();
return path;
I mean, at the moment i am simply using the WEB-INF entry and pull down later, but i would like to understand.
Michael
Larry Isaacs schrieb:
> Michael,
> Cheers,
> Larry
>> tia, Michael
Re: handle on web content [message #187596 is a reply to message #187588] Tue, 06 February 2007 10:36 Go to previous messageGo to next message
Any Java related content in your project is assumed to be destined for
the WEB-INF/classes directory. This means the Java "content" should go
under the "Java Source" folder you specified when you created the
Dynamic Web Project. The default value for this "Java Source" folder is
"src". What you are seeing is the mapping that "redirects" build
artifacts that come from this "src" directory to the "WEB-INF/classes"
directory when the project is published to a server or assembled into a
war file.
Larry
> returned as "/src"
> return path;
> Michael
>> Michael,
>> you have a WTP flexible project. If so, then
>> IVirtualFolder as the root folder. If this is a Dynamic Web Project,
>> this root folder will be the web content folder. You can call
>> getProjectRelativePath() or getWorkspaceRelativePath() on this
>> Cheers,
>> Larry
>>> Hi,
>>> tia, Michael
Re: handle on web content [message #187611 is a reply to message #187596] Tue, 06 February 2007 11:36 Go to previous messageGo to next message
Eclipse User
ok - then this is not the right way for me to use this scheme.
Then another question which i did not goog so far neither:
Can i gain a handle to the webapp directory of the server ( e.g. tomcat ) where the project is published into?
best, Michael
> war file.
> Cheers,
> Larry
>> returned as "/src"
>> return path;
>> Michael
>>> Michael,
>>> Cheers,
>>> Larry
>>>> Hi,
>>>> a reference to the web content directory of a dynamic web project as
>>>> tia, Michael
Re: handle on web content [message #187619 is a reply to message #187611] Tue, 06 February 2007 12:16 Go to previous messageGo to next message
I'm not aware of any public API that would suffice. What is it you are
trying to do?
Larry
> best, Michael
>> go under the "Java Source" folder you specified when you created the
>> is "src". What you are seeing is the mapping that "redirects" build
>> a war file.
>> Cheers,
>> Larry
>>> return path;
>>> Michael
>>>> Michael,
>>>> Project, this root folder will be the web content folder. You can
>>>> call getProjectRelativePath() or getWorkspaceRelativePath() on this
>>>> Cheers,
>>>> Larry
>>>>> Hi,
>>>>> tia, Michael
Re: handle on web content [message #187659 is a reply to message #187619] Wed, 07 February 2007 04:18 Go to previous messageGo to next message
Eclipse User
Hi Larry,
thank you for your help.
I am trying to solve our internal problem which was discussed earlyer under "extending dynamic webproject".
In short:
One dynamic Webproject A is extending another dynamic WebProject B. WebProject B uses s Java project.
Coming from sysdeo i am used to that all classes of all projects are synchronized into tomcat.
With wst i read and improved with the thread above that this is not possible.
Thus i started a plugin with the extendion point org.eclipse.wst.server.core.publishTasks.
My first idea was to copy the classes of the referenced projects into the WEB-INF/classes of the WebContent. I hoped
that - if my publish task would be processed before all others - that the copies would be synchronized by the standard
publish into the webapp. I know now that this is not working.
Thus now i want to copy the classes into the webapp directly and that for i would like to gain a handle onto the webapp
directory.
For now i will make something like a semi static solution for our internal use only, publishing into
"tomcatInstallDir/webapp/projectname/WEB-INF/classes". But at the end i would like to reach a dynamic solution.
best, Michael
> trying to do?
> Larry
>> best, Michael
>>> for the WEB-INF/classes directory. This means the Java "content"
>>> should go under the "Java Source" folder you specified when you
>>> created the Dynamic Web Project. The default value for this "Java
>>> Source" folder is "src". What you are seeing is the mapping that
>>> "redirects" build artifacts that come from this "src" directory to
>>> the "WEB-INF/classes" directory when the project is published to a
>>> server or assembled into a war file.
>>> Cheers,
>>> Larry
>>>> return path;
>>>> Michael
>>>>> Michael,
>>>>> Cheers,
>>>>> Larry
>>>>>> Hi,
>>>>>> get a reference to the web content directory of a dynamic web
>>>>>> tia, Michael
Re: handle on web content [message #187724 is a reply to message #187659] Wed, 07 February 2007 12:05 Go to previous message
If it helps, the job of the publish task wouldn't be to copy the classes
of the referenced project to WebProject A (assuming I understand you
correctly), but to the destination of the publish. Your "source"
location for the classes in WebProject B wouldn't be the virtual folder
for its "WEB-INF/classes", but I believe, simply its Java output folder.
Larry
> Hi Larry,
> In short:
> possible.
> the WEB-INF/classes of the WebContent. I hoped that - if my publish task
> synchronized by the standard publish into the webapp. I know now that
> for i would like to gain a handle onto the webapp directory.
> best, Michael
>> are trying to do?
>> Larry
>>> best, Michael
>>>> Cheers,
>>>> Larry
>>>>> return path;
>>>>> Michael
>>>>>> Michael,
>>>>>> confirm you have a WTP flexible project. If so, then
>>>>>> Cheers,
>>>>>> Larry
>>>>>>> Hi,
>>>>>>> tia, Michael
Previous Topic:String Substitution feature in JSP with tomcat doesnt work?!
Next Topic:WebSphere Integration and Performance
Current Time: Fri May 24 20:01:42 EDT 2013
Powered by FUDForum. Page generated in 0.02243 seconds
