Home » Eclipse Projects » Java WorkFlow Tooling (JWT) » Pluggable grammars and graphical representations
Pluggable grammars and graphical representations [message #17723] Thu, 19 January 2006 01:32 Go to next message
Originally posted by: rzulauf.objeng.ch
Dear Fabrice and all
just to give you an update on the progress I have made so far:
Following the MVC paradigm and the inherent support of it in GEF we will
obviously need to create the following packages:
- process model
- process edit parts
- process figures
The tricky thing about pluggable grammars and graphical representations
will be the fact that both model and figures are not static, ie. change
depending on current grammar and representation. This means that the
edit parts and all other GEF elements as well sort of inherit this
dynamic characteristic.
The solution I have come up with so far is to work heavily interface
based and provide factories which create concrete model objects, edit
parts and figures of the correct type, depending on grammar and
representation. It is sort of hard to put into words how this works exactly.
I am working on a proof of concept (GEF based editor) and as soon as it
is more or less workable I will provide a class diagram and detailed
description of the concepts that I employed.
Roman
Re: Pluggable grammars and graphical representations [message #19526 is a reply to message #17723] Tue, 24 January 2006 10:41 Go to previous message
Roman,
sorry for not replying sooner.
> - process model
> - process figures
> exactly.
Yes, this is a good approach. I was thinking of an adapter pattern and I
think it is what you ended with, am I wrong ?
OK this is fine. As soon you have something could send it to me please ?
I think it would be interesting to add this to the creation review slides.
Thanks for your help !
Fabrice
> Best regards,
> Roman
Previous Topic:how to dig contributions?
Next Topic:I am think about EMF
Current Time: Wed Jun 20 15:47:18 GMT 2018
Powered by FUDForum. Page generated in 0.01449 seconds
