Home » Language IDEs » C / C++ IDE (CDT) » Mingw/Mingw GDB with Eclipse CDT (Managed Make)
Mingw/Mingw GDB with Eclipse CDT (Managed Make) [message #186216] Tue, 27 February 2007 21:12 Go to next message
Siddhartha Gandhi is currently offline Siddhartha GandhiFriend
This has been a pain in the neck for a while, I've talked to a lot of
people and haven't made much progress with this.
1) The cygpath error. But I've seen the bugzilla entry and I'm
anticipating this will get fixed. I don't like seeing errors :P
2) Mingw/Mingw GDB. Even when I configure the commands from g++ to
mingw32-g++ and etc., it does not work. I get some "referring to non
existent file" error. Plus, I shouldn't have to configure each and every
project like that. There should be a settings where I can permanently make
it like that. Cygwin works beautifully, debugger and everything, I think
CDT was programmed with Cygwin in mind but not Mingw. Internal build
works, and I would at least like to make all projects default internal
build. But no, that's not possible, right now..
I know it isn't too much extra effor to click internal build, but if it
could be done automatically it would make CDT a bit more perfect...
Re: Mingw/Mingw GDB with Eclipse CDT (Managed Make) [message #186291 is a reply to message #186216] Wed, 28 February 2007 07:47 Go to previous messageGo to next message
Originally posted by: dmsubs.NOSPAM.consertum.com
Try looking at the Zylin plugin from :
http://www.zylin.com/embeddedcdt.html
I think many of the enhancements in this plugin are going to be in CDT4.0.
Derek
> make it like that. Cygwin works beautifully, debugger and everything, I
> think CDT was programmed with Cygwin in mind but not Mingw. Internal
> build works, and I would at least like to make all projects default
> internal build. But no, that's not possible, right now..
Re: Mingw/Mingw GDB with Eclipse CDT (Managed Make) [message #186458 is a reply to message #186216] Wed, 28 February 2007 17:58 Go to previous messageGo to next message
Yes, proper MinGW integration is coming in CDT 4.
Doug.
Re: Mingw/Mingw GDB with Eclipse CDT (Managed Make) [message #186482 is a reply to message #186458] Wed, 28 February 2007 21:39 Go to previous messageGo to next message
Thank you.
Just wondering, about when would be the next release?
Re: Mingw/Mingw GDB with Eclipse CDT (Managed Make) [message #186497 is a reply to message #186291] Thu, 01 March 2007 03:19 Go to previous messageGo to next message
Originally posted by: siamanda.somewhere.com
Check out my earlier post on cygwin and the gdb source not found problem. I
dont use mingw but if I'm not mistaken mingw is partly based on cygwin. The
problem I ran into was that the CTD could not find the files needed because
it couldnt map C:/ to /cygdrive/c. So might be able to find a similar work
around.
"Derek Morris" <dmsubs@NOSPAM.consertum.com> wrote in message
news:es3c3d$jfs$1@utils.eclipse.org...
> Derek
Re: Mingw/Mingw GDB with Eclipse CDT (Managed Make) [message #186513 is a reply to message #186497] Thu, 01 March 2007 03:35 Go to previous messageGo to next message
Actually, its the other way around. Cygwin uses mingw.
Re: Mingw/Mingw GDB with Eclipse CDT (Managed Make) [message #186819 is a reply to message #186482] Thu, 01 March 2007 18:51 Go to previous messageGo to next message
> Thank you.
End of June, along with the rest of Europa.
Doug.
Re: Mingw/Mingw GDB with Eclipse CDT (Managed Make) [message #186822 is a reply to message #186513] Thu, 01 March 2007 18:53 Go to previous messageGo to next message
Actually, neither is true. Cygwin and MinGW are separate. Cygwin has
made MinGW available as part of it's distrbution but they are separate
compilers.
Doug.
Re: Mingw/Mingw GDB with Eclipse CDT (Managed Make) [message #186824 is a reply to message #186497] Thu, 01 March 2007 18:55 Go to previous messageGo to next message
Yes, we need to find a way to automate this mapping so you don't have to
enter it all the time. There is a bug open on it, feel free to
contribute ideas to it.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=150372
Doug
> around.
>> Derek
Re: Mingw/Mingw GDB with Eclipse CDT (Managed Make) [message #186845 is a reply to message #186822] Thu, 01 March 2007 21:36 Go to previous message
Yeah..which is what I mean...Mingw is the compiler package...
Previous Topic:Howto suspend?
Next Topic:Fix CDT 4.x for Build Project Before Running External Tool
Current Time: Sun May 27 20:00:12 GMT 2018
Powered by FUDForum. Page generated in 0.02438 seconds
