Impossible to turn off bookmarks generation for table groups? [message #185459] |
Thu, 17 August 2006 00:24 |
Originally posted by: mbd_int.no~spam~hotmail.com~
Here are the steps to reproduce the problem we are having:
1. Load the attached TOCTest.rptdesign
2. Render the report as PDF. See the attached result
3. Select the table and then navigate to "Groups" tab
4. double-click on the grouping entry -- you will see the dialog (see
attached screenshots)
5. In the dialog try to remove the TOC Item expression value. Press Ok
6. Now, repeat steps 3 and 4. You'll see that the value is preserved. All
subsequent renderings into PDF file will still contain auto-generated
bookmarks for table groups.
The problem here is that -- it is impossible turn off generation of the
bookmarks per group. Auto-generation of bookmarks per groups in tables is a
nice feature in some cases but in others it is unwanted and prevents user
from achieving his own custom bookmarks structure.
Am I missing something here or is this a bug?
Thank you,
-Boris
P.S. I inspected .rptdesign for any entries of TOC Item expressions for
table groupings and found none -- all points to the fact that they are
computed for the dialog from step #4 above.
Re: Impossible to turn off bookmarks generation for table groups? [message #185789 is a reply to message #185674] |
Thu, 17 August 2006 23:10 |
Thank you - this did work. I'm submitting a bug report to get the
intuitiveness of this feature addressed.
"floor" <floorflux@hotmail.com> wrote in message
news:ec2dp3$oe5$1@utils.eclipse.org...
> Boris,
> That is kind of messed up, but if you put null in for the TOC Item
> expression value, I believe it should fix your problem.
> --floor
> "Boris" <mbd_int@no~spam~hotmail.com~> wrote in message
> news:ec0d04$5i1$1@utils.eclipse.org...
>> a nice feature in some cases but in others it is unwanted and prevents
>> user from achieving his own custom bookmarks structure.
>> Thank you,
>> -Boris
FUDForum. Page generated in 0.01951 seconds
