Home » Eclipse Projects » Plugin Development Environment (PDE) » Setting dialog attributes for new Launch Configuration Type(Automatic Setting attributes for new Launch Configuration Type)
Setting dialog attributes for new Launch Configuration Type [message #1170094] Mon, 04 November 2013 12:00
Guilherme MoraesFriend
I created an eclipse plugin (editor) with a new Launch Configuration Type. When I Create a new Run ou Debug launcher, the attributes "Project" and "Main Class" was empity. The attribute "Name" is set to "New_configuration" by default.
1) How can I automatic set the attribute "Project" to the Project of current file and the attributes "Name" and "Main Class" to the File name?
The Dialog that I want to automatic set attributes is like that:
http://help.eclipse.org/juno/topic/org.eclipse.cdt.doc.user/images/run_config.png
Thx a Lot
[Updated on: Mon, 04 November 2013 12:01]
Report message to a moderator
Previous Topic:Filter closed and not existing run configurations
Next Topic:How to access packages of plugins from java project
Current Time: Fri May 25 07:24:32 GMT 2018
Powered by FUDForum. Page generated in 0.01562 seconds
