| java.util.List not supported by the JAX-RPC specification [message #182641] |
Mon, 13 November 2006 20:30  |
Originally posted by: vancouverhg.hotmail.com
This error was generated following Creating Bottom Up Web Service tutorial
for my class DVD.java?
http://www.eclipse.org/webtools/jst/components/ws/1.5/tutori als/BottomUpWebService/BottomUpWebService.html
Is there a work around for this?
Thanks in advance
The service class "hansen.playground.DVD" does not comply to one or more
requirements of the JAX-RPC 1.1 specification, and may not deploy or
function correctly.
The method "getActors" on the service class "hansen.playground.DVD" uses
a data type, "java.util.List", that is not supported by the JAX-RPC
specification. Instances of the type may not serialize or deserialize
correctly. Loss of data or complete failure of the Web service may result.
The method "setActors" on the service class "hansen.playground.DVD" uses
DVD.java
package hansen.playground;
import java.util.*;
public class DVD implements java.io.Serializable {
private String id;
private String title;
private String length;
private List actors;
public DVD() {}
public String getId() {
return id;
public String getTitle() {
return title;
public String getLength() {
return length;
public List getActors() {
return actors;
public void setId(String newid) {
id = newid;
public void setTitle(String newtitle) {
title = newtitle;
public void setLength(String newlength) {
length = newlength;
public void setActors(List newactors) {
actors = newactors;
| Re: java.util.List not supported by the JAX-RPC specification [message #182712 is a reply to message #182641] |
Tue, 14 November 2006 11:09  |
Seng Phung Lu Messages: 62 Registered: July 2009 |
Member |
Hi Dave,
The JAX-RPC spec does not specify a clear mapping between the
java.util.List object and XML. The good news is you have other options.
For your example below, you could declare the type of 'actors' in the
parameter itself. For example, use a String[] or Actors[] (where Actors
is a complex type).
Since any Object can reside in a List, it would be impossible for the
Web service run-time to predict the type of the Object to
serialize/deserialize XML at run time.
Hope that helps,
-Seng
> tutorial for my class DVD.java?
> Thanks in advance
> function correctly.
> uses a data type, "java.util.List", that is not supported by the JAX-RPC
> DVD.java
> import java.util.*;
> private String id;
> public DVD() {}
> return id;
> return title;
> return length;
> return actors;
> id = newid;
> title = newtitle;
> length = newlength;
> actors = newactors;
FUDForum. Page generated in 0.08187 seconds
