Home » Language IDEs » ServerTools (WTP) » Websphere 6 Performance
Websphere 6 Performance [message #182045] Wed, 01 November 2006 19:44 Go to next message
shelley  is currently offline shelley Friend
We're seeing some major performance issues with WTP and WebSphere 6.0.
The same application that takes 3 minutes to initially publish to Jboss
or OC4J in Eclipse is taking 12+ minutes on Websphere. We were
previously using WebSphere within the Rational Application Devloper IDE
and publishing took nowhere near this long. Any ideas would be greatly
appreciated.
Re: Websphere 6 Performance [message #182072 is a reply to message #182045] Thu, 02 November 2006 14:47 Go to previous messageGo to next message
Tim deBoer is currently offline Tim deBoerFriend
Member
Hi Shelley,
The WebSphere server adapters in Rational Application Developer and
WebSphere Application Server Toolkit are commercial offerings that provide
tighter integration and have been optimized to reduce file copying and
improve performance. The three server adapters you refer to in WTP all use
file copying and command line interfaces to publish applications, so while
we can cover more types of servers in WTP it is unlikely that you would get
similar performance.
That said, you should be getting similar performance from these three server
adapters. This probably indicates that the WebSphere adapter in WTP is not
using the correct/best interfaces to the server, or simply has a performance
bug. Please open a bug so that the developer of this code can take a look.
Re: Websphere 6 Performance [message #182317 is a reply to message #182072] Tue, 07 November 2006 14:43 Go to previous messageGo to next message
A bug has been logged for this issue:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=163218
Tim deBoer wrote:
> Hi Shelley,
WebSphere [message #191173 is a reply to message #182317] Thu, 05 April 2007 21:40 Go to previous message
In speaking with IBM representatives for our company, I have been told that the
WebSphere/WTP performance/integration issues [1] and WAS 6.1 support [2] are
currently being addressed and should be contributed back to WTP with the release
of RAD 7. These bugs are still in NEW status. Is there any work being done on
these bugs? What is the expected target milestone?
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=163218
[2] https://bugs.eclipse.org/bugs/show_bug.cgi?id=160220
Previous Topic:Authentication?
Next Topic:WTP & WebSphere
Current Time: Mon May 21 17:15:33 GMT 2018
Powered by FUDForum. Page generated in 0.01666 seconds
