Home » Eclipse Projects » GEF » ToolbarLayout Problem
ToolbarLayout Problem [message #181207] Fri, 13 May 2005 04:00 Go to next message
Hao Zhang is currently offline Hao ZhangFriend
Hi all,
I am developing a table-like application, there are 3 types of figures:
Table, Column, and Cell. Table and Column are using ToolbarLayout as
layout manager, the Table figure is in fact the diagram, I can dynamically
add some cells into the column. Now I have some problem about the Column
figure's size.
I want Column figure's height to be the sum of its children(Cells).
Currently, I give every cell figure a minimumSize and a preferredSize,
they are same value, and I refresh column's preferredSize to (100,-1),
which works quite well, because I think the minimum size of cells prevent
column to be too small. But when the columns get higher, the editor does
not show a vertical scroll bar, unless I set column's preferredSize to
some taller value.
I failed to trace how they work, because so many calls occured, and
sometimes they call each other, I am totally confused.
I don't understand the relationship between preferredSize and minimumSize
well, seems like the sizes are cached? When should I call
setPreferredSize() or setMinimumSize() to change child/container's size,
and when should I override them in my figure, and when should I implement
a custom layout?
And, What are the complete factors determing any figure's final bound?
Such as its layout's getPreferredSize(), getMinimumSize(), and what else?
Sincerely
Hao
Re: ToolbarLayout Problem [message #181281 is a reply to message #181207] Fri, 13 May 2005 14:46 Go to previous message
This screenshot may help to describe my problem.
I expect a vertical scrollbar on the right side of editor.
"Hao Zhang" <bjzhanghao@21cn.com> ????
news:4fc21beb07a5b9f0bcd57791c20147a9$1@www.eclipse.org...
> Hi all,
> figure's size.
> some taller value.
> a custom layout?
> Sincerely
> Hao
  • Attachment: snap.gif
    (Size: 9.25KB, Downloaded 49 times)
Previous Topic:NoClassDefFoundError
Next Topic:Where to download GEF 2.0.1?
Current Time: Sun Apr 22 22:30:02 GMT 2018
Powered by FUDForum. Page generated in 0.01372 seconds
