Home » Newcomers » Newcomers » Project Explorer Tree in Eclipse 3.2
Project Explorer Tree in Eclipse 3.2 [message #181034] Tue, 21 November 2006 10:06 Go to next message
Originally posted by: siddharth.star.gmail.com
Since I am fairly new to developing functionalities on top of eclispe can
someone please help me with the following query?
I want to create an eclipse project wherein i want to cutomize the project
explorer corresponding to this project. In my project explorer, I want to
show nodes (hope this is what it is called in eclipse, basically this
refers to the children that appear on expanding a particular item of the
tree) which at some places refer to the file physically present and in
some case there should appear nodes which are virtual(have no mapping to
the filesystem). Can I do it using the Resource Navigator and if yes,
would it be a bid deal or fairly simple?
Siddharth
From what I could make out this can be done tweaking the tree viewer set
as Input to the Resource Navigator. Please validate if I am right or else
please suggest me a better approach.
Re: Project Explorer Tree in Eclipse 3.2 [message #181090 is a reply to message #181034] Tue, 21 November 2006 15:00 Go to previous message
Originally posted by: wayne.beaton._NOSPAM_eclipse.org
Siddharth wrote:
> can someone please help me with the following query?
> project explorer corresponding to this project. In my project explorer,
> I want to show nodes (hope this is what it is called in eclipse,
> basically this refers to the children that appear on expanding a
> particular item of the tree) which at some places refer to the file
> physically present and in some case there should appear nodes which are
> virtual(have no mapping to the filesystem). Can I do it using the
> Resource Navigator and if yes, would it be a bid deal or fairly simple?
> Siddharth
> set as Input to the Resource Navigator. Please validate if I am right or
> else please suggest me a better approach.
Hi Siddharth. I think you might be looking for the Common Navigator. Try
starting here:
http://wiki.eclipse.org/index.php/Common_Navigator_Framework
HTH,
Wayne
Previous Topic:Updating an eclipse plug-in
Next Topic:Upgrade from Eclipse 3.1.1 to 3.2.1 problem
Current Time: Sat May 26 23:49:40 GMT 2018
Powered by FUDForum. Page generated in 0.02303 seconds
