| JDK configuration [message #180023] |
Tue, 14 November 2006 11:30  |
Originally posted by: rdegrand.jeffco.us
Is there a way to configure which jdk is used to execute eclipse. I have
other products on my machine that have configured and loaded jdk1.3. If I
add jdk1.4 in the path earlier it breaks these other tools.
thx
| Re: JDK configuration [message #180056 is a reply to message #180031] |
Tue, 14 November 2006 12:33   |
But isn't that for the project and not for eclipse itself ? Eclipse finds
the first jdk on the path to load itself. Isn't there an .ini file that I
could update with the jdk I want to use to execute eclipse ??
| Re: JDK configuration [message #180202 is a reply to message #180023] |
Tue, 14 November 2006 18:13  |
Originally posted by: eclipse4.rizzoweb.com
> have other products on my machine that have configured and loaded
> jdk1.3. If I add jdk1.4 in the path earlier it breaks these other tools.
This is a pretty common question - please search the message archives
before posting new questions.
Specifically, see this message I recently posted:
Date: Mon, 30 Oct 2006
Subject: Re: JVM undetected
Newsgroups: eclipse.newcomer
The gist of it is that you should specify a -vm argument, either on the
eclipse.exe command line on in eclipse.ini
Hope this helps,
Eric
FUDForum. Page generated in 0.01618 seconds
