Home » Newcomers » Newcomers » Split Screen
Split Screen [message #179985] Tue, 14 November 2006 14:18 Go to next message
Originally posted by: spurcell.ilevy.com
Just trying to use the IDE. I have a simple HTML document that I am
screwing around with. I was wondering, can the window I am viewing be
split? Also, the window tab shows "java" at the top.
What is the proper way to work with html, javascript files?
Re: Split Screen [message #180016 is a reply to message #179985] Tue, 14 November 2006 15:13 Go to previous messageGo to next message
A) Yes, you can have a split view of one file. The key is to use the
menu Window > New Editor - that will open a second editor on the file.
Then you can drag it around by its tab or title-bar to place it beside
or underneath the other editor panel(s).
B) Have you installed the Web Tools Project (WTP), or just plain vanilla
Eclipse? The WTP has support for web development, such as editors for
HTML/JSP, etc. You should be able to use the Update Manager (Help >
Software Updates > Find and Install...) to install the WTP components.
Hope this helps,
Eric
Re: Split Screen [message #180100 is a reply to message #180016] Tue, 14 November 2006 18:13 Go to previous messageGo to next message
Thanks for the split screen, I have that now working. Works good.
Also, I just installed the WTP packages. How do I use those if I have a
html page on my screen? Major issue I have had is the editor not
formatting well.
Re: Split Screen [message #180107 is a reply to message #179985] Tue, 14 November 2006 19:03 Go to previous messageGo to next message
Select "Window > New Editor". This will open a second editor on the
current file. Changes in one editor will be reflected in the other. Not
exactly the same as a split view, but it works just as well.
Wayne
Re: Split Screen [message #180187 is a reply to message #180100] Tue, 14 November 2006 23:05 Go to previous message
> formatting well.
When you install WTP, it should associate the appropriate editors with
the various file extensions. So .html files should automatically open in
the proper editor.
If it is still opening in a plain text editor or the Java editor, try
closing the file and then choosing Open with... from the right-click
menu on that file.
Hope this helps,
Eric
Previous Topic:Assembler files in eclips
Next Topic:JDK configuration
Current Time: Sun Feb 25 02:18:45 GMT 2018
Powered by FUDForum. Page generated in 0.03134 seconds
