Home » Newcomers » Newcomers » Can I modify package explorer?
Can I modify package explorer? [message #179677] Sun, 12 November 2006 16:29 Go to next message
Originally posted by: francuesta.gmail.com
Hello, I donŽt know if a can modify the three of the package explorer. I
want that when you select an XML file, you can view a tree with the
contain of the same. Would it be possible or I must create a new tree
view? If itŽs possible, how can I do it?
Thank you!!!!
Re: Can I modify package explorer? [message #179865 is a reply to message #179677] Mon, 13 November 2006 12:11 Go to previous messageGo to next message
Dani Megert is currently offline Dani MegertFriend
> I want that when you select an XML file, you can view a tree with the
You can't do this with the Package Explorer. Take a look at the Project
Explorer.
Dani
> Thank you!!!!
Re: Can I modify package explorer? [message #180001 is a reply to message #179677] Tue, 14 November 2006 15:00 Go to previous message
If you are using the WTP, it will already display a tree-like view of
XML files in the Outline View (Window > Show View...)
Other XML plug-ins do the same, such as XMLBuddy.
Hope this helps,
Eric
Previous Topic:Eclips project
Next Topic:eclipse tools for RUP
Current Time: Thu May 24 14:20:04 GMT 2018
Powered by FUDForum. Page generated in 0.02796 seconds
