Application works using "Debug As", But fails using "Run As" [message #1153346] |
Thu, 24 October 2013 14:55 |
William Moore Messages: 2 Registered: October 2013 |
Junior Member |
I have developed an project using www.openshift.com/blogs/how-to-build-java-websocket-applications-using-the-jsr-356-api.
I can run this program when using "Debug As" but not with "Run As".
When I attempt to use "Run As", the following error is encountered:
Oct 24, 2013 8:44:52 AM org.glassfish.tyrus.server.ServerContainerFactory create
INFO: Provider class loaded: org.glassfish.tyrus.container.grizzly.GrizzlyEngine
java.net.BindException: Address already in use: bind
at sun.nio.ch.Net.bind0(Native Method)
at sun.nio.ch.Net.bind(Unknown Source)
at sun.nio.ch.ServerSocketChannelImpl.bind(Unknown Source)
at sun.nio.ch.ServerSocketAdaptor.bind(Unknown Source)
at org.glassfish.grizzly.nio.transport.TCPNIOBindingHandler.bindToChannelAndAddress(TCPNIOBindingHandler.java:131)
at org.glassfish.grizzly.nio.transport.TCPNIOBindingHandler.bind(TCPNIOBindingHandler.java:87)
at org.glassfish.grizzly.nio.transport.TCPNIOBindingHandler.bind(TCPNIOBindingHandler.java:64)
at org.glassfish.grizzly.AbstractBindingHandler.bind(AbstractBindingHandler.java:140)
at org.glassfish.grizzly.AbstractBindingHandler.bind(AbstractBindingHandler.java:159)
at org.glassfish.grizzly.nio.transport.TCPNIOTransport.bind(TCPNIOTransport.java:470)
at org.glassfish.grizzly.http.server.NetworkListener.start(NetworkListener.java:658)
at org.glassfish.grizzly.http.server.HttpServer.start(HttpServer.java:264)
at org.glassfish.tyrus.container.grizzly.GrizzlyEngine$1.start(GrizzlyEngine.java:88)
at org.glassfish.tyrus.server.TyrusServerContainer.start(TyrusServerContainer.java:119)
at org.glassfish.tyrus.server.Server.start(Server.java:122)
at chat.server.ChatApp.runServer(ChatApp.java:21)
at chat.server.ChatApp.main(ChatApp.java:11)
Any suggestions would be appreciated.
FUDForum. Page generated in 0.02913 seconds
