Unable to open any non-Eclipse generated WSDLs [message #177772] |
Wed, 23 August 2006 13:27 |
Originally posted by: Sarwar_Raza.3Com.com
I've been unable to use WTP (1.5 w/ Eclipse 3.2) WSDL editor to view any
WSDLs except those created using WTP. Is this is a known issue? It seems to
throw the same exception everytime, no matter what WSDL I attempt to open
(File-->Open File).
Stack trace attached.
\Sarwar
Unable to create this part due to an internal error. Reason for the failure:
org.eclipse.ui.internal.editors.text.JavaFileEditorInput
java.lang.ClassCastException:
org.eclipse.wst.wsdl.ui.internal.asd.ASDMultiPageEditor.buil dAndSetModel(ASDMultiPageEditor.java:128)
org.eclipse.wst.wsdl.ui.internal.asd.ASDMultiPageEditor.crea tePages(ASDMultiPageEditor.java:106)
org.eclipse.wst.wsdl.ui.internal.InternalWSDLMultiPageEditor .createPages(InternalWSDLMultiPageEditor.java:347)
org.eclipse.ui.part.MultiPageEditorPart.createPartControl(Mu ltiPageEditorPart.java:276)
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:596)
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:372)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:566)
org.eclipse.ui.internal.EditorReference.getEditor(EditorRefe rence.java:214)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2588)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2521)
at org.eclipse.ui.internal.WorkbenchPage.access$10(WorkbenchPag e.java:2513)
at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.ja va:2498)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2493)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2470)
org.eclipse.ui.internal.editors.text.OpenExternalFileAction. run(OpenExternalFileAction.java:132)
org.eclipse.ui.internal.editors.text.OpenExternalFileAction. run(OpenExternalFileAction.java:100)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:254)
org.eclipse.ui.internal.WWinPluginAction.runWithEvent(WWinPl uginAction.java:229)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:539)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3348)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2968)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Re: Unable to open any non-Eclipse generated WSDLs [message #177789 is a reply to message #177772] |
Wed, 23 August 2006 14:47 |
Sarwar,
Many editors don't support any input other the IFileEditorInput, i.e.,
they can only be opened for resources in the workspace. So put yours
WSDLs in a project and it should work fine.
>(File-->Open File).
>Thanks
>\Sarwar
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: Unable to open any non-Eclipse generated WSDLs [message #177850 is a reply to message #177789] |
Thu, 24 August 2006 22:54 |
Thanks Ed. Adding it to the project made the problem go away.
Works like a charm now.
\Sarwar
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:echpq2$35b$2@utils.eclipse.org...
> Sarwar,
>>to throw the same exception everytime, no matter what WSDL I attempt to
>>open (File-->Open File).
>>Thanks
>>\Sarwar
>>failure: org.eclipse.ui.internal.editors.text.JavaFileEditorInput
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
FUDForum. Page generated in 0.03332 seconds
