Home » Eclipse Projects » BIRT » JNDI and Username-Password
JNDI and Username-Password [message #176192] Mon, 10 July 2006 13:21 Go to next message
orkus9 is currently offline orkus9Friend
i use Eclipse 3.2, Birt 2.1, JBoss 4.0.2, Report Engine Api 2.1.
I am using the Report Engine API to generate the report within my
jboss-webapplication. So far so good. All works fine with a jdbc connection.
Now i want to change the datasource from jdbc to jndi.
This works fine, when i use the same user and password for the jdbc
source and jndi source.
My foo-ds.xml file looks like this:
<no-tx-datasource>
<jndi-name>cro24.xtrial.ds.foo.read-only</jndi-name>
<connection-url>jdbc:postgresql://localhost/foo</connection-url>
<driver-class>org.postgresql.Driver</driver-class>
<user-name>foo_user</user-name>
<password>foo_pw</password>
<min-pool-size>5</min-pool-size>
<max-pool-size>10</max-pool-size>
<idle-timeout-minutes>5</idle-timeout-minutes>
<!--<track-statements>true</track-statements>-->
</no-tx-datasource>
My birt-xml-file looks like this:
<data-sources>
<oda-data-source extensionID="org.eclipse.birt.report.data.oda.jdbc"
name="Data Source" id="39">
<text-property name="displayName">Data Source</text-property>
<property name="odaDriverClass">org.postgresql.Driver</property>
<property name="odaURL">jdbc:postgresql://localhost:5432/foo</property>
<property name="odaUser">foo-foo</property>
<encrypted-property name="odaPassword">ZXRtc191c2VyXzAx</encrypted-property>
<property name="odaJndiName">java:cro24.xtrial.ds.tabulator</property >
</oda-data-source>
</data-sources>
All works fine, while the username and password of jdbc connection and
jndi is the same.
When i change the jdbc-connection to an not existing user (e.g. foo-foo)
then, i get a error:
INFO: getJndiDSConnection: Unable to get JNDI data source connection;
org.jboss.util.NestedSQLException: Could not create connection; - nested
throwable: (org.postgresql.util.PSQLException: FATAL:
Passwort-Authentifizierung f??r Benutzer ??foo-foo?? fehlgeschlagen); -
nested throwable: (org.jboss.resource.JBossResourceException: Could not
create connection; - nested throwable:
(org.postgresql.util.PSQLException: FATAL: Passwort-Authentifizierung
f??r Benutzer ??foo-foo?? fehlgeschlagen))
Jul 10, 2006 2:47:07 PM
org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager doConnect
FINER: Calling DriverManager.getConnection.
url=jdbc:postgresql://localhost:5432/foo
org.eclipse.birt.report.data.oda.jdbc.JDBCException JDBCException
FINE: odajdbc.CannotGetConn
org.eclipse.birt.report.data.oda.jdbc.JDBCException logSQLException
FINE: SQL Exception #1
When i change the host to an nonexisting host (in my birt-xml-file),
birt gets the correct host from the foo-ds.xml file.
Why does birt not read the username and password also from foo-ds.xml?
Is this a Bug?
Best regrads
orkus9
Re: JNDI and Username-Password [message #176537 is a reply to message #176192] Wed, 12 July 2006 02:35 Go to previous messageGo to next message
Linda ChanFriend
It's up to your JNDI resource factory (jboss) to determine how and when it uses
its own configuration, e.g. your foo-ds.xml . In other words, BIRT never reads
a JNDI resource configuration directly.
To control the value of the BIRT jdbc username and password used at runtime...
the recommended way is to bind the username/password property to a report
parameter. This way, the username and password used at design-time can be
different from those used at runtime when deployed in a web application.
Orkus wrote:
> Hello,
> <no-tx-datasource>
> </no-tx-datasource>
> <data-sources>
> </oda-data-source>
> </data-sources>
> jndi is the same.
> Is this a Bug?
> Best regrads
> orkus9
Re: JNDI and Username-Password [message #178462 is a reply to message #176537] Tue, 18 July 2006 15:46 Go to previous messageGo to next message
George Handin is currently offline George HandinFriend
Exposing the username and password via report parameters is unacceptable
and dangerous security risk.
It appears that BIRT has a bug in that even though JBoss is loading the
JNDI resource, the BIRT report engine is not querying for the configured
JNDI configuration each time a report is executed. I've logged a defect
requesting this behavior:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=150965
> Orkus wrote:
>> Hello,
>> <no-tx-datasource>
>> </no-tx-datasource>
>> <data-sources>
>> </oda-data-source>
>> </data-sources>
>> jndi is the same.
>> Is this a Bug?
>> Best regrads
>> orkus9
Re: JNDI and Username-Password [message #178650 is a reply to message #178462] Wed, 19 July 2006 07:18 Go to previous message
i fully agree to you!
Good luck with the bugzilla entry.
i tried this twice. My bugs were closed (set to invalid). Your bug will
be closed too.
I dont really know, why the jndi configuration is mixed up with the
jdbc configuration. This is a bug (in my view).
more information is here:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=150219
>> when it uses
>> never reads
>> runtime...
>> Orkus wrote:
>>> Hello,
>>> connection.
>>> <no-tx-datasource>
>>> </no-tx-datasource>
>>> <data-sources>
>>> <encrypted-property
>>> </oda-data-source>
>>> </data-sources>
>>> jndi is the same.
>>> Is this a Bug?
>>> Best regrads
>>> orkus9
Previous Topic:Problem with Birt 2.1 ReportEngine
Next Topic:Dummy question: Get value x Axis (help me!)
Current Time: Sat Apr 21 04:16:22 GMT 2018
Powered by FUDForum. Page generated in 0.01797 seconds
