Home » Modeling » EMF » xcore derived list of objects(Why is it impossible to get Object[ ] out of a derived attribute? Sample Code included)
xcore derived list of objects [message #1139790] Wed, 16 October 2013 01:13 Go to next message
Tim Hinkes is currently offline Tim HinkesFriend
i'm very new to emf/xcore, but i think it could be a great advantage for my coding workflow.
Today i encountered a problem.
class LimitOrder
	Currency currency
	BigDecimal price
	BigDecimal amount
	OrderType orderType
	refers OpenOrder order opposite limitOrder
class OrderBook
	contains LimitOrder[] limitOrders
	derived LimitOrder[] askList get
		return limitOrders.filter[it.orderType == OrderType::ASK].toEList
Could someone point out for me why it is impossible to get a List/Collection of actual Objects out of a derived Attribute, but it is fine to get a List of Datatypes (derived someFooDatatype[] ask get{...}) as a derived Attribute?
Or did i get something wrong for what one should use the derived directive?
I have a big list of Orders, there orders have the types ASK/BID(Enums) But instead of saving two seperate lists in the OrderBook class, i want to get these Orders as Lists sorted by ask or bid. I thoght this is it for what there are derived attributes
Like getting the Age of a Person without saving the age, but saving the birthday?!
Thank you in advance
Re: xcore derived list of objects [message #1140023 is a reply to message #1139790] Wed, 16 October 2013 04:59 Go to previous messageGo to next message
Tim,
Comments below.
On 16/10/2013 4:48 AM, Tim Hinkes wrote:
> Hello,
> class LimitOrder
> Currency currency
> BigDecimal price
> BigDecimal amount
> OrderType orderType
> class OrderBook
What you show is a derived reference and needs a "refers" keyword.
> directive?
You have to be more careful with multi-valued derived values because the
list returned by it must implement internal APIs, so there are
alternatives with the first one being not quite correct (but you'll only
noticed that occasionally at runtime), the second one being correct but
complex (https://bugs.eclipse.org/bugs/show_bug.cgi?id=377103), and the
third one generating the same Java API and being correct (but not
providing a reflectively visible feature.
refers derived LimitOrder[] askList get
refers derived LimitOrder[] askList2 get
val result = limitOrders.filter[it.orderType == OrderType::ASK]
return new UnmodifiableEList(this as InternalEObject,
ExamplePackage$Literals::ORDER_BOOK__ASK_LIST2, result.size,
result.toList.toArray)
op LimitOrder[] getAskList3()
> the birthday?!
Just keep in mind the distinction between attributes and references
where the former must refer to a data type (defined with a type or enum
keywork) and the later must refer to a class (defined with a class or
interface keyword).
Re: xcore derived list of objects [message #1140423 is a reply to message #1140023] Wed, 16 October 2013 10:46 Go to previous message
Thank you
It works Smile
Previous Topic:Switch between editable and readonly for an EMF property
Next Topic:EMF disable to open old model versions
Current Time: Fri Feb 23 20:23:03 GMT 2018
Powered by FUDForum. Page generated in 0.02040 seconds
