Home » Eclipse Projects » Sapphire » Runtime Exception when opening Editor
Runtime Exception when opening Editor [message #1138538] Tue, 15 October 2013 06:38 Go to next message
Uli B is currently offline Uli BFriend
Member
I have a Sapphire (0.6.5) application that works fine when running with "Debug As ..." from the development environment.
It can also be installed into eclipse (as plugin, dropin, feature or whatever) without errors. But on opening the editor I then get "Failed to create the parts control" with a runtime exception:
java.lang.RuntimeException: IDispatcher : Could not instantiate implementation class.
	at org.eclipse.sapphire.modeling.ModelElementType.instantiate(ModelElementType.java:324)
	at org.eclipse.sapphire.modeling.ModelElementType.instantiate(ModelElementType.java:336)
	at org.eclipse.sapphire.ui.swt.xml.editor.SapphireEditorForXml.createModel(SapphireEditorForXml.java:95)
	at org.eclipse.sapphire.ui.SapphireEditor.addPages(SapphireEditor.java:484)
	at org.eclipse.ui.forms.editor.FormEditor.createPages(FormEditor.java:138)
	at org.eclipse.ui.part.MultiPageEditorPart.createPartControl(MultiPageEditorPart.java:358)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPartControl(CompatibilityPart.java:142)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityEditor.createPartControl(CompatibilityEditor.java:96)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:323)
	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
	at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:877)
	at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:857)
	at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:119)
	at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:333)
	at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:254)
	at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:102)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:71)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:53)
	at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:129)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:949)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:633)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:735)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:706)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:700)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:685)
	at org.eclipse.e4.ui.internal.workbench.PartServiceImpl$1.handleEvent(PartServiceImpl.java:90)
	at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:41)
	at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:180)
	at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:150)
	at org.eclipse.swt.widgets.Display.syncExec(Display.java:4688)
	at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:205)
	at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:38)
	at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197)
	at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
	at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
	at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
	at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
	at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
	at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:80)
	at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:58)
	at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
	at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:171)
	at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.showElementInWindow(ModelServiceImpl.java:576)
	at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.bringToTop(ModelServiceImpl.java:543)
	at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.delegateBringToTop(PartServiceImpl.java:610)
	at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.bringToTop(PartServiceImpl.java:322)
	at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.showPart(PartServiceImpl.java:1034)
	at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:3112)
	at org.eclipse.ui.internal.WorkbenchPage.access$21(WorkbenchPage.java:3034)
	at org.eclipse.ui.internal.WorkbenchPage$8.run(WorkbenchPage.java:3016)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3012)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2976)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2967)
	at org.eclipse.ui.ide.IDE.openEditor(IDE.java:534)
	at org.eclipse.ui.ide.IDE.openEditor(IDE.java:493)
	at org.bricks.etml.wizards.SampleNewWizard$2.run(SampleNewWizard.java:118)
	at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
	at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
	at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4145)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3762)
	at org.eclipse.jface.operation.ModalContext$ModalContextThread.block(ModalContext.java:173)
	at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:388)
	at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java:1028)
	at org.bricks.etml.wizards.SampleNewWizard.performFinish(SampleNewWizard.java:70)
	at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:827)
	at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:432)
	at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:628)
	at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:248)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1057)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4170)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3759)
	at org.eclipse.jface.window.Window.runEventLoop(Window.java:826)
	at org.eclipse.jface.window.Window.open(Window.java:802)
	at org.eclipse.ui.internal.handlers.WizardHandler$New.executeHandler(WizardHandler.java:259)
	at org.eclipse.ui.internal.handlers.WizardHandler.execute(WizardHandler.java:279)
	at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:290)
	at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:90)
	at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:243)
	at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:224)
	at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:132)
	at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:167)
	at org.eclipse.core.commands.Command.executeWithChecks(Command.java:499)
	at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
	at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:213)
	at org.eclipse.ui.internal.handlers.LegacyHandlerService.executeCommand(LegacyHandlerService.java:420)
	at org.eclipse.ui.internal.actions.CommandAction.runWithEvent(CommandAction.java:157)
	at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
	at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
	at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1113)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:997)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:138)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:610)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:567)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
Any idea what is missing or wrong?
Re: Runtime Exception when opening Editor [message #1139188 is a reply to message #1138538] Tue, 15 October 2013 15:48 Go to previous messageGo to next message
Konstantin Komissarchik is currently offline Konstantin KomissarchikFriend
In Sapphire 0.6.x and prior, an annotation processor must run during the build in order to generate model element implementation classes. The most common cause of the above exception is that implementation classes are missing from the plugin jar. For type somepackage.IDispatcher, the implementation class would be somepackage.internal.Dispatcher.
Compare your project metadata with Sapphire samples project. In particular, take a look at customBuildCallbacks.xml file as well as the related wiring in build.properties.
Re: Runtime Exception when opening Editor [message #1139510 is a reply to message #1139188] Tue, 15 October 2013 20:40 Go to previous messageGo to next message
Member
Hi Konstantin,
many thanks for answering. Indeed, annotation processing was not enabled ...
Re: Runtime Exception when opening Editor [message #1141154 is a reply to message #1139510] Wed, 16 October 2013 21:41 Go to previous messageGo to next message
Member
Seems there is one thing left. The editor opens as long as Sapphire itself is also installed. When I install my plugin to a fresh Eclipse (Helios, Kepler), opening the Editor fails. It turns out, that the fragment org.eclipse.sapphire.osgi.fragment_0.6.6.201310081535.jar is not installed with its host org.eclipse.sapphire.modeling_0.6.6.201310081535.jar.
(dropping in the fragment makes the editor work.)
How can I make sure that the fragment is installed? From the examples, I can't figure out that.
Re: Runtime Exception when opening Editor [message #1141292 is a reply to message #1141154] Wed, 16 October 2013 23:56 Go to previous messageGo to next message
The fragment is part of org.eclipse.sapphire.osgi feature. Typically, you will want your feature to declare various Sapphire features as dependencies. Straight plugin dependencies aren't typically sufficient since you will not typically depend directly on all Sapphire components that you end up using.
Re: Runtime Exception when opening Editor [message #1145236 is a reply to message #1141292] Sat, 19 October 2013 11:05 Go to previous message
Member
Thanks again. After adding some Sapphire features to my feature it works fine.
Previous Topic:internal packages in sapphire.ui
Next Topic:Property depending on path property not refreshed after Browse dialog closes
Current Time: Mon Jun 25 13:57:45 GMT 2018
Powered by FUDForum. Page generated in 0.02103 seconds
