Home » Archived » Test and Performance Tools Platform (TPTP) » Connection to remote mashine
Connection to remote mashine [message #16374] Fri, 22 April 2005 10:20 Go to next message
Originally posted by: vadimfs.web.de
I have installed first agent controller local, on my computer.
This has functioned. (Startings of an application in profiles perspective
and, e.g., Execution Time Analysis look.)
and, e.g., Execution time at analysis look.
Now I have installed agent controller on other computer.
I start agent controller from command consolle in such a way: go up
RASERVER_HOME/bin and gives RAServer.exe.
On my computer I have in Eclipse Window - Preferences-
Profilling and Logging - Hosts
IP:10002 as a new computer added and localhost:10002 deleted.
With the test Connection 'Connection Success' is indicated.
If I, however, profiles start the following error message is given:
Reason:
IWAT0284E The agent controller is not available on host localhost.
Make sure that:
* the agent controller is installed.
* the agent controller is configured to communicate with your machine.
* you have the correct host name and port number for the agent controller.
Why?
Re: Connection to remote mashine [message #16929 is a reply to message #16374] Mon, 25 April 2005 22:00 Go to previous messageGo to next message
Vishnu is currently offline VishnuFriend
Vadim,
I am not sure how you are starting the Profiling application (using launch
or attach).
But whatever mechanism you use,
1. Open the Profile window (Run->Profile) and select the configuration you
are going to use (need to create the configuration if starting a new one)
and you should see the "Host" tab on the right-side. 2. In the Host tab, you
will see the "locahost:10002" alongwith your remote machine (as you already
added the remote machine through Window->Preferences). But by default
localhost entry is selected in this tab (it also depends on which machine
you used last).
3. Please select the remote machine you want to connect to in the Host tab.
4. In the adjacent tabs, enter the java application details (if launching)
or select the agent (if attaching) and click on Profile. Now you should be
able to connect to the RAC running on the remote machine.
I am assuming you are following instructions provided at the following
location (Section 4.0).
http://www.eclipse.org/tptp/home/documents/tutorials/profili ngtool/profilingexample_32.html
Let me know if you still have problems.
Vishnu
"Vadim" <vadimfs@web.de> wrote in message
news:de5fddc11664cdb34015686e32b0545d$1@www.eclipse.org...
> Reason:
> Make sure that:
> Why?
Re: Connection to remote mashine [message #16989 is a reply to message #16374] Tue, 26 April 2005 12:21 Go to previous message
George Christelis is currently offline George ChristelisFriend
Hi Vadim,
During the agent controller config, could you ensure that the network access
mode was set correctly? You should have been presented with something
similar to:
Network access mode (ALL=allow any host, LOCAL=allow only this host,
CUSTOM=list
of hosts):
Default>"LOCAL" (Press <ENTER> to accept the default value)
New value>
Setting this to ALL or defining a custom list of hosts might solve your
problem. You can change this by rerunning the agent controller SetConfig
George
Did you set the
> Reason:
> Make sure that:
> Why?
Previous Topic:Extended monitoring
Next Topic:Perfmon in TPTP 4.0
Current Time: Wed May 23 03:40:56 GMT 2018
Powered by FUDForum. Page generated in 0.01667 seconds
