Home » Language IDEs » ServerTools (WTP) » How to get details of this error message
How to get details of this error message [message #172944] Wed, 05 July 2006 04:04 Go to next message
Wang Xianzhu is currently offline Wang XianzhuFriend
I got a validation error message when I validate an XML file:
Severity and Description Path Resource Location Creation Time Id
Referenced file contains errors
(jar:platform:/resource/common/build/runway-common-1.1/runwa y-common-1.1.jar!/com/runway/common/umh/umh.xsd).
For more information, right click on the message and select "Show
Details..."
However, I can't "right click on the message" because when I move the mouse,
the message popup disappears. I can't focus it with 'F2'. In the
"Problems" view, when I right click on the message, the popup menu does not
have "Show Details...".
How can I get the details of this message? Or there is no details at all?
Wang Xianzhu
Re: How to get details of this error message [message #173201 is a reply to message #172944] Wed, 05 July 2006 17:41 Go to previous messageGo to next message
Lawrence Mandel is currently offline Lawrence MandelFriend
The Show Details option is available from the Problems view. Right click
the message in the Problems view to see this option.
Bug 148468 is already open to track the improvement of this error message.
Lawrence
Re: How to get details of this error message [message #173447 is a reply to message #173201] Fri, 07 July 2006 03:18 Go to previous messageGo to next message
Thanks, but in my environment, when I right click on the message in the
Problems View, I see only the following choices:
Go To
Show In -> Package Explorer
Copy
Paste
Select All
Quick Fix
Properties
There is no 'Show Details...' option. My eclipse was installed using
wtp-all-in-one-sdk-R-1.0.1-200602171228-win32.zip.
The function of real time validation and the 'Validation' command seem to be
seperate functions. Why not make them integrated together?
Wang Xianzhu
<lmandel@ca.ibm.com> ??????:e8gtka$3s1$1@utils.eclipse.org...
> Lawrence
Re: How to get details of this error message [message #174144 is a reply to message #173447] Wed, 12 July 2006 17:41 Go to previous message
Hmm. I haven't heard any other reports of this feature being broken on WTP
1.0.1. I've verified that it is working on WTP 1.5.
If by "real time validation" you mean validation on save it is the same
function as the Run Validation (Validate in WTP 1.5) action. As you type
validation should also be the same. Please open bugs for any differences
you find.
Lawrence
Previous Topic:No launchable artifact
Next Topic:Determining if there are errors in an XML document, programatically.
Current Time: Fri Apr 27 06:58:36 GMT 2018
Powered by FUDForum. Page generated in 0.01898 seconds
