Home » Language IDEs » ServerTools (WTP) » Tomcat realms problem - SQLException
Tomcat realms problem - SQLException [message #170492] Sun, 04 June 2006 09:05 Go to next message
Originally posted by: parrott.sarah.googlemail.com
I'm trying to use realms in tomcat to authenticate people at a website.
I'm using eclipse to do this in, with a MySQL database to hold the
username, passwords and roles.
When I try to start the server, thru eclipse, I get the following output:
02-Jun-2006 15:25:27 org.apache.catalina.core.AprLifecycleListener
lifecycleEvent
INFO: The Apache Tomcat Native library which allows optimal performance in
production environments was not found on the java.library.path: C:\Program
Files\Java\jdk1.5.0_06\bin;.;C:\WINDOWS\system32;C:\WINDOWS; C:\PROGRA~1\Borland\Delphi5\Projects\Bpl;C:\PROGRA~1\Borland \Delphi5\Bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\Syste m32\Wbem;W:\ArcGIS\arcexe9x\bin;C:\Program
Files\MySQL\MySQL Server 5.0\bin
02-Jun-2006 15:25:27 org.apache.coyote.http11.Http11BaseProtocol init
INFO: Initializing Coyote HTTP/1.1 on http-8080
02-Jun-2006 15:25:27 org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 1101 ms
02-Jun-2006 15:25:27 org.apache.catalina.core.StandardService start
INFO: Starting service Catalina
02-Jun-2006 15:25:27 org.apache.catalina.core.StandardEngine start
INFO: Starting Servlet Engine: Apache Tomcat/5.5.17
02-Jun-2006 15:25:27 org.apache.catalina.realm.JDBCRealm start
SEVERE: Exception opening database connection
java.sql.SQLException: org.gjt.mm.mysql.Driver
at org.apache.catalina.realm.JDBCRealm.open(JDBCRealm.java:689)
at org.apache.catalina.realm.JDBCRealm.start(JDBCRealm.java:766 )
at org.apache.catalina.core.ContainerBase.start(ContainerBase.j ava:1005)
at org.apache.catalina.core.StandardEngine.start(StandardEngine .java:442)
at org.apache.catalina.core.StandardService.start(StandardServi ce.java:450)
at org.apache.catalina.core.StandardServer.start(StandardServer .java:709)
at org.apache.catalina.startup.Catalina.start(Catalina.java:551 )
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:2 94)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:43 2)
02-Jun-2006 15:25:27 org.apache.catalina.core.StandardHost start
INFO: XML validation disabled
02-Jun-2006 15:25:27 org.apache.catalina.startup.ContextConfig
validateSecurityRoles
INFO: WARNING: Security role name admini used in an <auth-constraint>
without being defined in a <security-role>
02-Jun-2006 15:25:28 org.apache.coyote.http11.Http11BaseProtocol start
INFO: Starting Coyote HTTP/1.1 on http-8080
02-Jun-2006 15:25:28 org.apache.jk.common.ChannelSocket init
INFO: JK: ajp13 listening on /0.0.0.0:8009
02-Jun-2006 15:25:28 org.apache.jk.server.JkMain start
INFO: Jk running ID=0 time=0/210 config=null
02-Jun-2006 15:25:28 org.apache.catalina.storeconfig.StoreLoader load
INFO: Find registry server-registry.xml at classpath resource
02-Jun-2006 15:25:28 org.apache.catalina.startup.Catalina start
INFO: Server startup in 1452 ms
This is what I have in my web.xml document (in relation to realms):
<security-constraint>
<web-resource-collection>
<web-resource-name>Protected Area</web-resource-name>
<!-- Define the context-relative URL(s) to be protected -->
<url-pattern>/admin/*</url-pattern>
<http-method>DELETE</http-method>
<http-method>GET</http-method>
<http-method>POST</http-method>
<http-method>PUT</http-method>
</web-resource-collection>
<auth-constraint>
<role-name>admini</role-name>
</auth-constraint>
<user-data-constraint>
<transport-guarantee>NONE</transport-guarantee>
</user-data-constraint>
</security-constraint>
<!-- Default login configuration uses form-based authentication -->
<login-config>
<auth-method>FORM</auth-method>
<realm-name>Example Form-Based Authentication Area</realm-name>
<form-login-config>
<form-login-page>/jsp/login.jsp</form-login-page>
<form-error-page>/jsp/logon_fial.jsp</form-error-page>
</form-login-config>
</login-config>
and in my server.xml document:
<Realm className="org.apache.catalina.realm.JDBCRealm"
connectionURL="jdbc:mysql://localhost/authority?user=root&amp;password=**mypassword**"
driverName="org.gjt.mm.mysql.Driver"
roleNameCol="role_ID"
userCredCol="pword"
userNameCol="username"
userRoleTable="user_roles"
userTable="members"/>
I've added the jar file for the jdbc driver to the classpath for the
project, and I can connect to the database fine through eclipses 'Database
Explorer' using the same connection URL.
Any ideas why this is not working?
Sarah
Re: Tomcat realms problem - SQLException [message #170573 is a reply to message #170492] Mon, 05 June 2006 15:03 Go to previous messageGo to next message
Larry Isaacs is currently offline Larry IsaacsFriend
For Dynamic Web projects, adding a jar to the build path only affects
building the project, assuming that's what you mean by adding it to the
project's classpath. Making the jar available at runtime is a different
task for Web projects. If it is to be included with the Web application
when deployed, you can copy it to the WEB-INF/lib directory of the
project, or use the J2EE Module Dependencies page in the Properties
dialog for the project to "include" it. Note that there have been bugs
in the later approach, so which version of Eclipse you are using can
make a difference. Either of these approaches will also include the jar
on the build path so you don't need to explicitly add it there yourself.
Larry
Sarah Parrott wrote:
> lifecycleEvent
> in production environments was not found on the java.library.path:
> C:\Program
> at
> at
> <auth-constraint>
> </auth-constraint>
> <login-config>
> <form-login-config>
> </login-config>
> driverName="org.gjt.mm.mysql.Driver" roleNameCol="role_ID"
> userCredCol="pword" userNameCol="username"
> userRoleTable="user_roles" userTable="members"/>
> 'Database Explorer' using the same connection URL.
> Sarah
Re: Tomcat realms problem - SQLException [message #173337 is a reply to message #170492] Thu, 06 July 2006 12:29 Go to previous message
> lifecycleEvent
> C:\Program
> at
> at
> <auth-constraint>
> </auth-constraint>
> <login-config>
> <form-login-config>
> </login-config>
> Sarah
Put JDBC drivers in tomcatdir/common/lib.
You do that on "production" servers too.
Previous Topic:Java Facet
Next Topic:Tomcat Server oroblem with Eclipse
Current Time: Sun Feb 25 02:00:03 GMT 2018
Powered by FUDForum. Page generated in 0.01622 seconds
