Home » Eclipse Projects » BIRT » OSGI framework doesn't start / assertion failure
OSGI framework doesn't start / assertion failure [message #169686] Tue, 13 June 2006 13:38 Go to next message
Florian Georg is currently offline Florian GeorgFriend
Member
--------------020902090305050709030907
I try to use the BIRT 2.1 Report Engine API in a simple Java Application
(no plugin project).
However, I'm getting NPEs for hours now:
EngineConfig config = new EngineConfig();
config.setEngineHome("c:/birt/birt-runtime-2_1_0/ReportEngine ");
// (System out states: 'Can't load the report engine')
ReportEngine engine = new ReportEngine(config); // <==== NPE !
I tracked this down to
" org.eclipse.birt.core.framework.Platform#startup(PlatformCon fig) ".
============== snip =================
// start up the OSGI framework
try
launcher = new OSGILauncher( );
// startup the OSGi framework,
launcher.startup( config );
// the core plugins is loaded in the start up
// 1. platform should not be null any more.
// 2. the IFactoryService has been registed
// see
// org.eclipse.birt.core.plugin.CorePlugin#start(BundleContext
// context).
assert platform != null; // <===== platform *is* null for me !!
catch ( Exception ex )
platform = null;
throw new BirtException( "Can't startup the OSGI framework",
new Object[]{}, ex );
================ snap =================
Hm, no exception here, but platform==null and no IFactoryService around
Any ideas what this could be?
I see tricky ClassLoader stuff in there, perhaps something is wrong with
my execution setting?
Thanks in advance !
Florian
Content-Type: text/x-vcard; charset=utf-8;
name="Florian.Georg.vcf"
Content-Disposition: attachment;
filename="Florian.Georg.vcf"
begin:vcard
fn:Florian Georg
n:Georg;Florian
org:Innovations Softwaretechnologie GmbH;Product Development
adr:;;Ziegelei 7;Immenstaad;;88090;Germany
email;internet:Florian.Georg@innovations.de
title:Developer
tel;work:+49-7545-202-512
url:http://www.innovations.de
version:2.1
end:vcard
--------------020902090305050709030907--
Re: OSGI framework doesn't start / assertion failure [message #169768 is a reply to message #169686] Tue, 13 June 2006 16:56 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
What does the directory structure below ReportEngine look like?
Do you have a configuration directory?
Jason
"Florian Georg" <Florian.Georg@Innovations.de> wrote in message
news:e6mf4e$mmu$1@utils.eclipse.org...
> try
> // see
> // context).
> platform = null;
> Thanks in advance !
> Florian
Re: OSGI framework doesn't start / assertion failure [message #170043 is a reply to message #169768] Wed, 14 June 2006 06:49 Go to previous messageGo to next message
Member
--------------040907090202030905000604
Thanks, figured it out:
The config.ini file in the configuration folder was incidentally deleted
by me !
Nevertheless I think the Platform should not come up with a NPE in such
cases ... is there a possibility for the OSGILauncher to check for
correct directory layout/configuration on startup?
thanks again,
Florian
> Jason
>>try
>>// see
>>// context).
>>platform = null;
>>Thanks in advance !
>> Florian
begin:vcard
fn:Florian Georg
n:Georg;Florian
title:Developer
version:2.1
end:vcard
--------------040907090202030905000604--
Re: OSGI framework doesn't start / assertion failure [message #170244 is a reply to message #170043] Wed, 14 June 2006 15:41 Go to previous message
You can log an enhancement request in bugzilla.
Jason
news:e6obh1$v5g$1@utils.eclipse.org...
> by me !
> thanks again,
> Florian
>> Jason
>>>try
>>>// see
>>>// context).
>>>platform = null;
>>>Thanks in advance !
>>> Florian
Previous Topic:Page (html document)-level Javascripting - is possible?
Next Topic:Design Engine Error
Current Time: Sun Feb 25 08:31:53 GMT 2018
Powered by FUDForum. Page generated in 0.01437 seconds
