Home » Language IDEs » ServerTools (WTP) » Embed XML Editor
Embed XML Editor [message #169449] Tue, 16 May 2006 18:09 Go to next message
Andrew Eberbach is currently offline Andrew EberbachFriend
I'd like to embed the XML editor (optionally with both the design and
source tabs) in another editor. Is this possible? If so, can someone point
me to a good place to get started?
thanks,
Andrew
Re: Embed XML Editor [message #169572 is a reply to message #169449] Thu, 18 May 2006 07:28 Go to previous message
Alain Marc Pannetier is currently offline Alain Marc PannetierFriend
I'm not sure you can nest the tabs (doubt it).
What you can do is a Multi Part Editor in which one of the nested editor
is
the StructuredSourceEditor.
You can start with downloading the examples plugin, install it, import
(with source) the MultiPart Editor and then substitute the TextEditor page
with the
void createPage0() {
try {
editor = new StructuredTextEditor();
int index = addPage(editor, getEditorInput());
setPageText(index, editor.getTitle());
} catch (PartInitException e) {
You will need to declare a dependency on org.eclipse.wst.sse.ui.
You can also probably find out how to include the tab with the model view
in another page but I've not tried that yet.
Alain
Previous Topic:BUILD FAILED error in WTP when building the WebProject
Next Topic:xsd edit does not reflect in graph view
Current Time: Sun Feb 25 04:36:33 GMT 2018
Powered by FUDForum. Page generated in 0.01942 seconds
