Home » Eclipse Projects » Subversive » Rename files does not work (if lower letters are replaced by capital letters)
Rename files does not work (if lower letters are replaced by capital letters) [message #15995] Sun, 13 April 2008 18:29 Go to next message
Lars Vogel Unavailable until 15 August 2016 is currently offline Lars Vogel Unavailable until 15 August 2016Friend
try to rename a file from myfile.txt to myFile.txt which is under svn
controll.
This doesn't work, as the svn plug-in thinks that this is the same file.
Can you please fix this?
Best regards, Lars
Re: Rename files does not work (if lower letters are replaced by capital letters) [message #16014 is a reply to message #15995] Mon, 14 April 2008 06:47 Go to previous messageGo to next message
Originally posted by: Marko.Schulz.gmail.com
Are you working under Windows (or more generally: with a case-insensitive
file system)? Then this is less an issue of subversive but more one of
subversion or the operating system. See
http://subversion.tigris.org/faq.html#case-change
marko schulz
Re: Rename files does not work (if lower letters are replaced by capital letters) [message #16050 is a reply to message #16014] Tue, 15 April 2008 15:19 Go to previous message
Hi Marko,
ok, thank you. Best regards, Lars
"Marko Schulz" <Marko.Schulz@gmail.com> wrote in message
news:ftuugu$qag$1@build.eclipse.org...
> marko schulz
Previous Topic:Corrupted projects?
Next Topic:Subversive History Extremely Slow
Current Time: Thu Apr 26 02:14:29 GMT 2018
Powered by FUDForum. Page generated in 0.02371 seconds
