Home » Language IDEs » Java Development Tools (JDT) » Debug problems with 3.0
Debug problems with 3.0 [message #168470] Tue, 13 July 2004 10:43 Go to next message
Ian Carr is currently offline Ian CarrFriend
I am trying out one of my projects under the released 3.0 and am having
problems with debugger stability.
I seem to be able to reproduce the problems by simply steping a java
executable between 20 and 40 times in succession. Eclipse will then
either become unresponsive for a minute or so possibly recovering, or
after a shorter time 10-20 seconds throw up a dialog box indicating a
timeout exception:
Step into failed
Reason:
Exceptions occurred attempting to step into the frame
and in the details:
org.eclipse.jdi.TimeoutException occurred creating step request
After the exceptions stopping and restarting the app may fix it or I
have to restart eclipse itself.
I have tried upping the debug timeout to 8000 from the default of 3000
without any effect
I am running on a Sun jdk: 1.4.2_03-b02
Is this a known problem with a work-around or just me?
Ian Carr
Re: Debug problems with 3.0 [message #168494 is a reply to message #168470] Tue, 13 July 2004 11:50 Go to previous messageGo to next message
> timeout exception:
> Step into failed
> Reason:
> and in the details:
> without any effect
> Ian Carr
Wrote a trivial app (simple nested for loop), ran on my portable with
jdk 1.4.2_04 no problem, on my desktop with 1.4.2_03-b02 crashes at
about 10 iterations.
I will install the later jdk on my desktop and see if that helps!
Ian Carr
Re: Debug problems with 3.0 [message #168510 is a reply to message #168494] Tue, 13 July 2004 12:16 Go to previous messageGo to next message
Ian Carr wrote:
>> having problems with debugger stability.
>> timeout exception:
>> Step into failed
>> Reason:
>> and in the details:
>> without any effect
>> Ian Carr
> Ian Carr
put jdk 1.4.2_05 on the desktop still get the same problem.
Ian Carr
Re: Debug problems with 3.0 [message #168525 is a reply to message #168510] Tue, 13 July 2004 12:33 Go to previous messageGo to next message
>>> timeout exception:
>>> Step into failed
>>> Reason:
>>> and in the details:
>>> 3000 without any effect
>>> Ian Carr
>> Ian Carr
> Ian Carr
Interestingly, the desktop is a Pentium 4 with HyperThreading the laptop
is a Pentium 4 M without Hyperthreading.
If I disable HyperThreading from the bios for the desktop, debugging
becomes totally stable, I get bored hitting the step key in my simple
app. Switch it back on and I can't step more than 12 iterations round my
for loop!
looks like a thread/synchronization problem?
Ian Carr
Re: Debug problems with 3.0 [message #168628 is a reply to message #168525] Wed, 14 July 2004 00:38 Go to previous message
Kevin Barnes is currently offline Kevin BarnesFriend
I'd suggest you file a bug report against "Platform-Debug". It would be
most helpful if you could attach the source that you are using to
reproduce the problem, as well as your .log file
([workspace]/.metadata/.lot)
Kevin
>>>> or after a shorter time 10-20 seconds throw up a dialog box
>>>> indicating a timeout exception:
>>>> Step into failed
>>>> Reason:
>>>> and in the details:
>>>> Ian Carr
>>> Ian Carr
>> Ian Carr
> for loop!
> Ian Carr
Previous Topic:JavaDoc Search
Next Topic:Class loading problem with Sysdeo Tomcat plug-in
Current Time: Tue May 22 08:35:12 GMT 2018
Powered by FUDForum. Page generated in 0.01942 seconds
