Home » Archived » BIRT » Reference code for RC4+ Engine API
Reference code for RC4+ Engine API [message #168033] |
Wed, 07 June 2006 00:33 |
Originally posted by: schneeman.gmail.com
Is there a reference code snippet for running a report via the Report
Engine API (RC4)? All the way from creating the EngineConfig to running
the Task?
I was running using the 2.0.1 sample from the Eclipse website, but I
found some issues with it. I changed my code to look like a 2.1.0
snippet, but now I'm finding issues with running a report that makes a
reference to a report library (but not running "self-contained" reports).
It could very well be my use of the APIs. Could someone point me to a
canonical reference for RC4? I'll redo my code, rerun the report and
report back with a more detailed error if I still can't get it to work.
Thanks.
Re: Reference code for RC4+ Engine API [message #168043 is a reply to message #168033] |
Wed, 07 June 2006 00:56 |
Here is the report runner class from the RC4 source
Jason
package org.eclipse.birt.report.engine.api;
import java.io.File;
import java.io.FileInputStream;
import java.io.FileNotFoundException;
import java.io.IOException;
import java.util.Collection;
import java.util.HashMap;
import java.util.Iterator;
import java.util.Locale;
import java.util.Properties;
import java.util.logging.Level;
import java.util.logging.Logger;
import org.apache.commons.cli.BasicParser;
import org.apache.commons.cli.CommandLine;
import org.apache.commons.cli.Options;
import org.eclipse.birt.core.data.DataTypeUtil;
import org.eclipse.birt.core.exception.BirtException;
import org.eclipse.birt.core.framework.IPlatformContext;
import org.eclipse.birt.core.framework.Platform;
import org.eclipse.birt.core.framework.PlatformFileContext;
* Defines a standalone reporting application that uses
* <code>StandaloneReportEngine</code> class. This application allows
running
* a report to output in one or multiple formats.
* <p>
* Report parameters are handled as command line parameters. Currently, only
* scalar parameters are handled.
* @version $Revision: 1.23 $ $Date: 2006/04/25 08:18:00 $
public class ReportRunner
// The static logger
static protected Logger logger = Logger.getLogger( ReportRunner.class
.getName( ) );
* the input paramters
protected String[] args; // The command line arguments
* the source input ,can be designName or reportArchive name
protected String source; // Name of the design file
* The target file name
protected String targetFile = null;
* execution mode, one of the Run, RunAndRender and Render. the default
mode
* is RunAndRender
protected String mode = "RunAndRender"; // the execution mode, one of the
* the output locale, used in Run and RunAndRender modes.
protected String locale = "en"; // Application running locale //$NON-NLS-1$
* the output format, used in Render and RunAndRender.
protected String format = "html"; // The output format, defaults to HTML
* used to decorate the HTML output, used in Render and RunAndRender mode.
protected String htmlType = "HTML"; // The type of html
* the output encoding, used in html format in Render and RunAndRender
* modes.
protected String encoding = "utf-8"; // the targe encoding
* paramters used to execute the report, used in Run and RunAndRender
modes.
protected HashMap params = new HashMap( ); // the input params
* output page number, used in Render mode.
protected long pageNumber = -1;
* engine used to execute the tasks.
private IReportEngine engine;
* Constructor of ReportRunner
* @param args -
* application arguments
public ReportRunner( String[] args )
this.args = (String[]) args.clone( );
* Main function.
* @param args -
* application argumetns.
public static void main( String[] args )
int result = new ReportRunner( args ).execute( );
System.exit( result );
* Check if the arguments are valid. If yes, continue to execuate the
* report. If no, simply return.
public int execute( )
if ( args.length == 0 )
printUsage( );
return 0;
try
// startup the platform
if ( engine == null )
EngineConfig config = new EngineConfig( );
Platform.startup( config );
IReportEngineFactory factory = (IReportEngineFactory) Platform
.createFactoryObject(
IReportEngineFactory.EXTENSION_REPORT_ENGINE_FACTORY );
engine = factory.createReportEngine( config );
// JRE default level is INFO, which may reveal too much internal
// logging
// information.
engine.changeLogLevel( Level.WARNING );
// Process command line arguments
parseOptions( );
if ( "Run".equalsIgnoreCase( mode ) )
return runReport( );
else if ( "Render".equalsIgnoreCase( mode ) )
return renderReport( );
else
return runAndRenderReport( );
catch ( Exception ex )
logger.log( Level.SEVERE, "exception in parsing the paramters", ex );
return -1;
finally
Platform.shutdown( );
* Execute the report design which includes: <br>
* 1. Read the input design and create the task. <br>
* 2. Set report render options (including format, locale, output file name
* etc). <br>
* 3. Run the task.
protected int runAndRenderReport( )
try
// parse the source to get the report runnable
IReportRunnable runnable = engine.openReportDesign( source );
// validate the input paramter values
HashMap inputValues = evaluateParameterValues( runnable );
IRunAndRenderTask task = engine.createRunAndRenderTask( runnable );
task.setParameterValues( inputValues );
// set report render options
IRenderOption options;
if ( format.equalsIgnoreCase( "html" ) )
options = new HTMLRenderOption( );
if ( "ReportletNoCSS".equals( htmlType ) )
( (HTMLRenderOption) options ).setEmbeddable( true );
else
options = new RenderOptionBase();
options.setOutputFormat( format );
// setup the output file
options.setOutputFileName( targetFile );
// setup the output encoding
options.getOutputSetting( ).put( HTMLRenderOption.URL_ENCODING,
encoding );
// set the render options
task.setRenderOption( options );
// setup the application context
HTMLRenderContext renderContext = new HTMLRenderContext( );
renderContext.setImageDirectory( "image" ); //$NON-NLS-1$
HashMap appContext = new HashMap( );
appContext.put( EngineConstants.APPCONTEXT_HTML_RENDER_CONTEXT,
renderContext );
task.setAppContext( appContext );
// setup the locale
task.setLocale( getLocale( locale ) );
task.run( );
return 0;
catch ( EngineException e )
logger.log( Level.SEVERE, e.getMessage( ), e );
return -1;
* running the report to create the report document
protected int runReport( )
try
// create the report task
IRunTask task = engine.createRunTask( runnable );
// set the paramter values
// set the application context
task.setAppContext( new HashMap( ) );
// run the task to create the report document
task.run( targetFile );
// close the task.
task.close( );
return 0;
catch ( org.eclipse.birt.report.engine.api.EngineException e )
return -1;
* render the report.
protected int renderReport( )
try
// use the archive to open the report document
IReportDocument document = engine.openReportDocument( source );
// create the render task
IRenderTask task = engine.createRenderTask( document );
else
// set the output format
encoding );
renderContext );
// setup the locale
if ( pageNumber <= 0 )
int extPos = targetFile.lastIndexOf( '.' );
assert extPos != -1;
String pathName = targetFile.substring( 0, extPos );
String extName = targetFile.substring( extPos );
for ( long i = 1; i <= document.getPageCount( ); i++ )
String fileName = pathName + '_' + ( i ) + extName;
options.setOutputFileName( fileName );
task.render( i );
else
task.render( pageNumber );
task.close( );
return 0;
return -1;
* print out the command line usage.
protected void printUsage( )
System.out.println( "org.eclipse.birt.report.engine.impl.ReportRunner" );
//$NON-NLS-1$
System.out.println( "" ); //$NON-NLS-1$
System.out
.println( "--mode/-m [ run | render | runrender] the default is
runrender" );
System.out.println( " for runrender mode:" );
System.out.println( "\t we should add it in the end<design file>" );
//$NON-NLS-1$
System.out.println( "\t --format/-f [ HTML | PDF ]" ); //$NON-NLS-1$
System.out.println( "\t --output/-o <target file>" ); //$NON-NLS-1$
System.out.println( "\t --htmlType/-t < HTML | ReportletNoCSS >" );
//$NON-NLS-1$
System.out.println( "\t --locale /-l<locale>" ); //$NON-NLS-1$
System.out.println( "\t --parameter/-p <parameterName=parameterValue>" );
//$NON-NLS-1$
System.out.println( "\t --file/-F <parameter file>" ); //$NON-NLS-1$
System.out.println( "\t --encoding/-e <target encoding>" ); //$NON-NLS-1$
System.out.println( "\nLocale: default is english\n" ); //$NON-NLS-1$
System.out
.println( "\nparameters in command line will overide parameters in
parameter file" ); //$NON-NLS-1$
System.out
.println( "\nparameter name can't include characters such as ' ', '=',
':' " ); //$NON-NLS-1$
System.out.println( "For RUN mode:" );
//$NON-NLS-1$
//$NON-NLS-1$
System.out
System.out
System.out.println( "For RENDER mode:" );
//$NON-NLS-1$
System.out.println( "\\t --page/-p <pageNumber>" );
* Private function to convert a locale name string to a locale object
* @param locale -
* locale name string
* @return A locale object
private Locale getLocale( String locale )
int index = locale.indexOf( '_' );
if ( index != -1 )
// e.g, zh_CN (language_country)
String language = locale.substring( 0, index );
String country = locale.substring( index + 1 );
return new Locale( language, country );
// e.g, en (language)
return new Locale( locale );
CommandLine results;
protected void parseRunOptions( ) throws Exception
if ( results.hasOption( 'o' ) )
targetFile = results.getOptionValue( 'o' );
parseParameterOptions( );
protected void parseRenderOptions( ) throws Exception
assert ( mode.equals( "Run" ) );
if ( results.hasOption( 'f' ) )
format = results.getOptionValue( 'f' );
if ( results.hasOption( 't' ) )
htmlType = results.getOptionValue( 't' );
if ( results.hasOption( 'l' ) )
locale = results.getOptionValue( 'l' );
if ( results.hasOption( 'e' ) )
encoding = results.getOptionValue( 'e' );
if ( results.hasOption( 'p' ) )
pageNumber = Long.parseLong( results.getOptionValue( 'p' ) );
protected void parseRunAndRenderOptions( ) throws Exception
assert ( mode.equals( "RunAndRender" ) );
* parse the arguments.
* -html html-file-name -pdf pdf-file-name -fo fo-file-name -l locale-name
* -p page-number design-file-name
* @param args -
* arguments
protected void parseOptions( )
source = args[args.length - 1];
args[args.length - 1] = ""; //$NON-NLS-1$
try
Options option = new Options( );// Collection of all the options
* Add these basic argument into instance option
option.addOption( "m", "mode", true, "RunAndRender" );
option.addOption( "o", "output", true, "" ); //$NON-NLS-1$ //$NON-NLS-2$
//$NON-NLS-3$
option.addOption( "f", "format", true, "html" );
//$NON-NLS-1$//$NON-NLS-2$ //$NON-NLS-3$
option.addOption( "t", "htmlType", true, "" ); //$NON-NLS-1$//$NON-NLS-2$
//$NON-NLS-3$
option.addOption( "l", "locale", true, "" ); //$NON-NLS-1$ //$NON-NLS-2$
//$NON-NLS-3$
option.addOption( "e", "encoding", true, "" ); //$NON-NLS-1$
option.addOption( "p", "parameter", true, "" );
option.addOption( "p", "page", true, "" );
option.addOption( "F", "file", true, "parameter file" );
results = new BasicParser( ).parse( option, args, true );
if ( results.hasOption( 'm' ) )
mode = results.getOptionValue( 'm' );
parseRunOptions( );
parseRenderOptions( );
else
parseRunAndRenderOptions( );
checkTargetFileName( );
logger.log( Level.SEVERE, ex.getMessage( ), ex );
printUsage( );
* read paramters from the param and add it into the params.
* @param param
* parameter string line. use '=' to separate the name and
value.
* @param params
* maps contains all the paramter name and value.
protected void readParamString( String param, HashMap params )
if ( param == null || param.length( ) < 2 )
return;
int index = param.indexOf( "=" );
if ( index < 1 )
return;
String name = param.substring( 0, index ).trim( );
String value = param.substring( index + 1 ).trim( );
if ( value.startsWith( "\"" ) && value.endsWith( "\"" )
&& value.length( ) > 2 )
value = value.substring( 1, value.length( ) - 1 );
params.put( name, value );
* paraser the paramter command line inputs.
* @return the HashMap contains all the paramter name and values.
protected void parseParameterOptions( )
if ( results.hasOption( 'F' ) )
String fileName = results.getOptionValue( 'F' );
readParamFile( fileName, params );
String[] stringParams = results.getOptionValues( 'p' );
if ( stringParams != null )
for ( int i = 0; i < stringParams.length; i++ )
readParamString( stringParams[i], params );
protected void readParamFile( String fileName, HashMap params )
File file = new File( fileName );
Properties ps = new Properties( );
try
ps.load( new FileInputStream( file ) );
catch ( FileNotFoundException e )
"file: " + file.getAbsolutePath( ) + " not exists!" ); //$NON-NLS-1$
catch ( IOException e )
"Can't open file: " + file.getAbsolutePath( ) ); //$NON-NLS-1
params.putAll( ps );
private HashMap evaluateParameterValues( IReportRunnable runnable )
HashMap inputValues = new HashMap( );
IGetParameterDefinitionTask task = engine
.createGetParameterDefinitionTask( runnable );
Collection paramDefns = task.getParameterDefns( false );
Iterator iter = paramDefns.iterator( );
while ( iter.hasNext( ) )
// now only support scalar parameter
IParameterDefnBase pBase = (IParameterDefnBase) iter.next( );
if ( pBase instanceof IScalarParameterDefn )
IScalarParameterDefn paramDefn = (IScalarParameterDefn) pBase;
String paramName = paramDefn.getName( );
String inputValue = (String) params.get( paramName );
int paramType = paramDefn.getDataType( );
try
Object paramValue = stringToObject( paramType, inputValue );
if ( paramValue != null )
inputValues.put( paramName, paramValue );
catch ( BirtException ex )
logger.log( Level.SEVERE, "the value of parameter "
+ paramName + " is invalid", ex );
return inputValues;
* @param p
* the scalar parameter
* @param expr
* the default value expression
protected Object stringToObject( int type, String value )
throws BirtException
if ( value == null )
return null;
switch ( type )
case IScalarParameterDefn.TYPE_BOOLEAN :
return DataTypeUtil.toBoolean( value );
case IScalarParameterDefn.TYPE_DATE_TIME :
return DataTypeUtil.toDate( value );
case IScalarParameterDefn.TYPE_DECIMAL :
return DataTypeUtil.toBigDecimal( value );
case IScalarParameterDefn.TYPE_FLOAT :
return DataTypeUtil.toDouble( value );
case IScalarParameterDefn.TYPE_STRING :
return DataTypeUtil.toString( value );
return null;
* If -o (targetFile) is not specified, assume same directory as inputfile,
* and inputfile.*** as output file name (where *** is the output format.
* If -o specifies a directory, assume the file name is the same as
* inputfile.***.
* If -o specifies a file, it has a path part and a filename part. Take the
* path as the directory to store the file and other resources (for example
* image).
protected void checkTargetFileName( )
String fileExt = "." + format;
fileExt = ".rptdocument";
File designFile = new File( new File( source ).getAbsolutePath( ) );
String designFileName = designFile.getName( );
int n = designFileName.lastIndexOf( '.' );
if ( n != -1 )
designFileName = designFileName.substring( 0, n );
if ( targetFile == null )
targetFile = designFile.getParent( ) + File.separatorChar
+ designFileName + fileExt;
else if ( !targetFile.toLowerCase( ).endsWith( fileExt.toLowerCase( ) ) )
targetFile = targetFile + File.separatorChar + designFileName
+ fileExt;
File file = new File( targetFile );
if ( !file.getParentFile( ).exists( ) )
file.getParentFile( ).mkdir( );
"Brent" <schneeman@gmail.com> wrote in message
news:e656sn$67u$1@utils.eclipse.org...
> the Task?
> I was running using the 2.0.1 sample from the Eclipse website, but I found
> some issues with it. I changed my code to look like a 2.1.0 snippet, but
> now I'm finding issues with running a report that makes a reference to a
> Thanks.
Re: Reference code for RC4+ Engine API [message #168207 is a reply to message #168043] |
Wed, 07 June 2006 17:29 |
Thanks Jason. When I try to run this, I get an exception:
org.eclipse.birt.core.exception.BirtException: $NO-RB$ Can't startup the
OSGI framework
at org.eclipse.birt.core.framework.Platform.startup(Platform.ja va:90)
at org.eclipse.birt.core.framework.Platform.initialize
(Platform.java:115)
org.eclipse.birt.report.engine.api.ReportEngine.<init>(ReportEngine.java:47)
Any ideas?
"Jason Weathersby" <jweathersby@actuate.com> wrote in message
news:e6587f$dm7$1@utils.eclipse.org...
[snip]
Re: Reference code for RC4+ Engine API [message #168229 is a reply to message #168207] |
Wed, 07 June 2006 17:48 |
I figured it out - I need to set the BIRT_HOME JVM property. This seem to be
because the reference code is calling the deprecated
config.setEngineContext() api.
I find that the following snippet allows me to not set the BIRT_HOME
property:
EngineConfig config = new EngineConfig();
IPlatformContext context = new PlatformFileContext();
//config.setEngineContext( context ); //deprecated.
config.setPlatformContext(context);
ReportEngine engine = new ReportEngine(config);
engine.changeLogLevel(Level.WARNING);
Thanks again.
news:e672d2$2o2$1@utils.eclipse.org...
> OSGI framework
> (Platform.java:115)
> at
> Any ideas?
> [snip]
Re: Reference code for RC4+ Engine API [message #168234 is a reply to message #168229] |
Wed, 07 June 2006 18:20 |
Yeah, I was completely wrong here, please disregard. I find I still need to
set BIRT_HOME.
news:e673gl$91h$1@utils.eclipse.org...
>be because the reference code is calling the deprecated
> property:
> Thanks again.
>> OSGI framework
>> (Platform.java:115)
>> at
>> Any ideas?
>> [snip]
Current Time: Thu Mar 28 12:26:26 GMT 2024
Powered by FUDForum. Page generated in 0.03551 seconds
