Home » Eclipse Projects » Hudson » SVN_REVISION not showing correct number(SVN_REVISION is not able to in the email-ext plugin )
SVN_REVISION not showing correct number [message #1105931] Tue, 10 September 2013 13:05
srini chokkarapu is currently offline srini chokkarapuFriend
hi,
I am using hudson 2.2.1, email-ext plugin 2.10, subversion plugin 2.3.8.
In my job, I am checking out mulitple projects from svn.
I am getting "400" all the time with SVN_REVISION.
The subversion plugin also provides env variables:
SVN_REVISION_n and SVN_URL_n where n is a 1-based index matching the locations configured. However none of them is being substituted in the email-ext below:
Here is the Default content in the text box:
$PROJECT_NAME - Build # $BUILD_NUMBER - $BUILD_STATUS - $SVN_REVISION
$SVN_URL
$SVN_REVISION_1
but I get
test - Build # 17 - Successful - 400
$SVN_URL
$SVN_REVISION_1
is there anything wrong with my setup?
Thanks.
Previous Topic:Allow email-ext to attach files to emails
Next Topic:Avoiding multiple ticket filing to Bug Tracker from Jenkins / Hudson for same test case failure.
Current Time: Tue Apr 24 07:16:49 GMT 2018
Powered by FUDForum. Page generated in 0.01768 seconds
